PDA
View Full Version : Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24
  1. Sportline Ride Quality?
  2. Koni Struts on my SS S/C..
  3. Ksport GT springs on eBay??? Worth it???
  4. Thoughts/questions after being lowered
  5. JBP Control Arm Bushings destroyed
  6. lowered and noisy
  7. SportLine Spring questions.
  8. bump steer
  9. How much did you pay to get your springs on?
  10. springs ?
  11. Brake pedal play, what is normal?
  12. Such thing as cheap rotors?
  13. To anyone with ssc springs
  14. Camber kit?
  15. Approx. how long does it take/cost to install Eibach Sprtlines?
  16. Side skirts???
  17. What your brakes SHOULDNT look like after 45K Miles......
  18. anyone have air suspension
  19. Used Springs....
  20. Progress Lowering Springs??
  21. lower springs?
  22. best style of rotors for racing
  23. Failed Spring Install
  24. tenzo's from ebay
  25. New 07 Balt owner, wanting to Auto-X
  26. Who knows anything about EPS steering?
  27. found some new stuff
  28. arospeed?
  29. What happens when you hit a curb at 60mph
  30. springs or coil overs
  31. sportlines q and a
  32. finally got my coilover kit!!!!!!!!!!!!!!!!!!!!!!!!
  33. Speedbuilt Front Strut Tower Bar
  34. Progress Rear Sway bars in stock
  35. oh man
  36. Question about alignment after lowing springs.
  37. BWoody VS Intense trans bushings
  38. What Color Should I Paint Calipers?
  39. Eibach Sportlines initial impressions
  40. whats worse for your suspension?
  41. CA #1 Springs
  42. ksport question
  43. asap
  44. C E D rotors in
  45. Springs W/ Underbody Lights
  46. Cheapest Eibach Sportlines?
  47. Springs and Shocks HELP!!!
  48. Front Sway vs Rear Sway (ratio/balancing)
  49. Whats the diff between pro and sportlines
  50. Which springs are better ?
  51. B&G Springs From Gravana
  52. Springs dilemma
  53. How long will factory struts hold up?
  54. bwoody rear strut is installed..
  55. Progress Springs yay nay?
  56. Question for Sportline Guys
  57. clunking in rear right of car when driving??
  58. BWoody Traction Bars....install problem..?
  59. Vibration after lowering car with Eibachs?
  60. Tenzo-R springs for sale
  61. H&R problem looking for help vendors!
  62. Lowering Springs
  63. Just installed my sportlines but.....
  64. 2007
  65. Eibach Sways
  66. Noob to suspension.. please help me.
  67. Progress rear sway is in
  68. Springs on a 2.2 HELP!!
  69. Generic Guide to replace a front spring??
  70. Updated Pics With Sportlines
  71. Eibach Springs on SS Sedan?? Do they fit
  72. Got the 4 door lowered
  73. BWoody Front sway bar end links?
  74. which springs can i get
  75. operation i need traction haha
  76. quick question
  77. reducing wheel hop??
  78. cobalt addiction number 1 springs
  79. Need advice on rear strut/sway bar
  80. Need some help- sideways like
  81. Alignment Help Please!!
  82. Lowering my car today!
  83. h&R or tenzo
  84. Replace 2.4 springs with 2.2 springs
  85. Pics!!! Installed!!! Dp, Cabs, Sportlines, Konis, Brake Lines
  86. Prothane motor mount bushings
  87. help choosing some lowering springs.
  88. lowest springs?
  89. Determining the life of stock suspension components
  90. ss and ls suspension
  91. Those with Intense Poly Inserts
  92. KYB Full replacement struts and shocks
  93. floor strut bar?
  94. May have messed up front suspension
  95. SC Koni guys, need help
  96. Do i need an alignment when i put my tenzos on?
  97. for all those who have asked, SSC springs
  98. Some Lowering Questions
  99. 2.2 sway bars
  100. pics of your lowered SS plzzzz
  101. break/clutch fluid issue
  102. Where would i look to get a custom strut bar made?
  103. New Eibachs
  104. Stock Axles
  105. alignment corrections
  106. Tips for getting the strut bolts out of the knuckle
  107. Koni's
  108. Is there a Brake Conversion Kit out for the 2.2's
  109. Anyone have these rotors?
  110. Eibachs with 225/45/18's???
  111. sportlines on loaded sedan...rubbing?
  112. Update: Eibach Springs
  113. How much does an alignment cost.
  114. springs?
  115. Rotors Gb
  116. my struts are going bad what do i do
  117. Springs/Struts Vs. Coilovers
  118. Help today, Progress Sway w/ T/F strut connector
  119. Sportlines on my 2.2 w/ better wheels! (56k=doom!)
  120. rear axle
  121. power slot rotors
  122. Progress springs?
  123. progress lowering springs
  124. Ca Traction Bars
  125. best rotors
  126. cross drilled/slotted rotors
  127. Slicks on Stock?
  128. emergency brake
  129. Got Quotes On Springs
  130. What springs do you guys like best?
  131. Baer Brake upgrade
  132. Gravana INGS body kit
  133. Air Suspension
  134. Airride or Coilover, Which Is Best For Performance?
  135. Tenzo R's for a 2.4l ss
  136. Anyone with problems on their Lowered LS/LT?
  137. Need Help? Eibach Sportline Or Ssc
  138. which coilovers
  139. Mild vibration/noise on braking
  140. HELP! How do I compress the piston on the rear caliper!?!?
  141. Brakes for autocrossing
  142. Sway bar sizes...
  143. Koni Front Strut ??
  144. Eibach Sportlines and strut life?
  145. Well i finally got around to lowering my car
  146. Anybody With Problems With Their 2.2 Suspension
  147. Ca #1 Sport Springs
  148. spring drop rates
  149. Newbie Member Spring Question
  150. Finally installed Sportlines on the LS
  151. Just got Eibach Sportlines for my LT
  152. Factory shocks making noise?
  153. SS Brake Pads
  154. Eibach Sportimes and Tires
  155. Ingalls Dampner Question
  156. Gm Brake upgrade
  157. will these work on an ss/sc
  158. eibach sportlines question
  159. got som ?'s on dc strut bar
  160. What front strut bar do you suggest is the best?
  161. how long do brakes last
  162. how long do brakes last
  163. Question about alignment and camber kit!
  164. Eibach Springs (History video)
  165. Installing Springs, how much do I have to trim to Bump Stops?
  166. Wheel hop after Bwoody install?
  167. Bump stop cutting, Alignments, Camber kits for Lowering Springs
  168. airbags
  169. Installing Eibach Springs... how much trimming to Bump Stops?
  170. tenzo r springs question
  171. Anyone know where to buy the JBP front strut tower brace?
  172. Can my turbo 2.4 use a strut bar? look at pic and c what u think.
  173. Front Springs on 2.2L??????
  174. Eibach Sportlines
  175. ssc springs
  176. SS/SC Suspension
  177. Bump stops
  178. Spring question?
  179. Who makes the best springs for the ss/sc?
  180. who has sportline springs
  181. Wheel hop no more.
  182. Where to find anti-squeal for brake pads?
  183. Done !! Eibach
  184. springs...help!
  185. kw coilovers
  186. Traction Bars, Sway Bar Links
  187. eibach sway bar ?
  188. Black SS/SC with Painted Caliper
  189. Eibach Sportlines
  190. Brake install problem - need quick response!!!!
  191. Handlin Mods
  192. Pulling Right
  193. Camber??
  194. Yyyeeesss!!!
  195. cavalier coilovers
  196. Torque Specs
  197. which suspension mod?
  198. to cut or not to cut bumpstops?
  199. stearing column
  200. strut bar specs
  201. EI Sportlines Bump stop question
  202. Need some help on lowering springs!PLEASE
  203. anyone with lowered ss/sc?
  204. brakes
  205. Problem???
  206. another group buy
  207. front end allignment
  208. Installing sportlines
  209. Need info on stock springs
  210. FREE springs!!!!
  211. SS vs SS/SC Suspensions
  212. New guy question...
  213. Traction Bars vs. Torque Dampener
  214. Bwoody Traction Bars
  215. Where to buy SSC springs???
  216. Rear Sway Bar Question
  217. How-To for lowering springs
  218. Eibach Sportlines sold out eveywhere!!
  219. ss/sc springs on a 2.4?
  220. Cobalt Addiction floor brace
  221. ***Counterfeit Eibach’s Update***
  222. Adjustable Sway bar links
  223. Alignment Specs
  224. best prices for sportlines or H&R?
  225. Sportlines installed on my 2.2 (before and after pics) (56k != good choice)
  226. Counterfeit Eibach’s or not?
  227. white ss on tenzos
  228. Dropped 2 in 1 afternoon!
  229. coilover drop???
  230. SMG Number1one's?
  231. Bwoody Traction Controls Bars
  232. does anyone have a pic
  233. So Many Problems
  234. Where to buy Eibach sportline in Canada?
  235. Best Handeling Springs
  236. Powerslot rotors + Hawk HPS pads
  237. Broken Lug
  238. 4 wheel disc
  239. Uneven lowering?
  240. Koni Shock-Strut Update
  241. progress rear anti-sway bar?
  242. Lowering questions - Coilovers
  243. used eibachs
  244. spring rates
  245. eibach sportline question
  246. Stock Sway Bar Sizes
  247. SSC Springs
  248. Rear after market springs
  249. speed bleeders
  250. need e-brake help
