PDA
View Full Version : Suspension
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Strut/Spring life and shock question
  2. FE5 or Moog LCA's?
  3. back to stock, loose rattling all over front suspension...HELP?
  4. OTTP Rear bar
  5. fe5 shocks with fe3 springs
  6. lowered people... good jack?
  7. Knocking/popping when turning the wheel?
  8. Rear twisting beam
  9. Installing Pedders Tomorrow
  10. Anyone have Speed Bleeders for their brembos?
  11. vibrations
  12. K Sport lowering springs on 06 ss/na
  13. Installed Stance GR+ Coilovers
  14. new brakes
  15. Rear springs only?
  16. Mookeeh (ebay) universal camber plates.
  17. purposely swapped to 5x110...
  18. nuh uhhhhh herra frusshh moar low
  19. Pretty sure this isn't right
  20. Whiteline Rear Swap Anyone???
  21. bad tie rod end?
  22. Megan coilovers fitment...
  23. brembo brake upgradequestion
  24. Megan racing coilovers
  25. Question/HELP!
  26. Mid Summer Spring Sale
  27. What part is this?
  28. Fe5 shocks and struts
  29. Wanna go little lower
  30. Vibration after changing rear brakes
  31. Moog Control Arm Bushings
  32. ZZP Cross Drilled/Slotted Rotors Question
  33. Mother Clunker!
  34. Coilover sleeve experiment.
  35. FE5 Suspension for an ion
  36. megan coils
  37. D2 springs on 05 l61
  38. '06 LS going warping brake rotors in less than 5k miles
  39. How does this setup look?
  40. Unboxing the Powell rear axle bushing
  41. shocks?
  42. coilover question regarding LNF axles
  43. E-Brake Adjust
  44. Suspension thread again
  45. 5 lug update
  46. need new control arm bushings.. I think lol
  47. Sway Bar Endlinks
  48. Seized Calibers... need some help
  49. Tire weight
  50. Eibach pro kit springs what shocks&struts
  51. Quick Brake Question
  52. Info
  53. Eibachs
  54. are my power slot slotted rotors on backwards
  55. Choosing Coilovers
  56. Engine Cradle Removal
  57. KW coilovers?
  58. whats next?
  59. wanting to lower my ss tc
  60. wheres a thread showing springs pics?
  61. What springs are best for me?
  62. R1 concepts help
  63. Timken Wheel Bearing
  64. YYZ springs
  65. Brake Line Fittings
  66. AutoX with Stance GR+??
  67. Service ESC light
  68. Trade suspension.
  69. 06 SS/SC Rear Brake Caliper Parking Brake
  70. Stance people! Help!
  71. getting blown out?
  72. Sway Bar Clunk
  73. Question - FE5 Struts & Shocks w/ Pedders Springs
  74. Grunting/squeaking
  75. Which coilovers are right for me??
  76. 5x110 to 4x100
  77. Koni shocks and struts VS coilovers
  78. Camber off after lowering which camber bolts to use?
  79. Good price??
  80. H&R/springs question
  81. odd tire wear, even when it was stock...
  82. Which shocks/struts?
  83. BC Coil noise
  84. Brembo brake job
  85. Help with brakes
  86. Megan Coilovers
  87. How are your Pedders looking after use?
  88. d2 and Megan lowering springs question
  89. Shimmy Shake...
  90. Wheel hub ABS sensor question for John Powell , or anyone with knowledge LOL
  91. Steering Knuckle Upgrade Question
  92. Brembo bleeding question
  93. In need of some assistance.
  94. Powell spherical CABs install
  95. Help please!!!!
  96. Powell racing parts
  97. slight noise from front driver side
  98. FE5 struts and shocks soft?
  99. Brake pad question
  100. Megan Coils
  101. Major upgrade in the works
  102. Lowering Spring Question
  103. Need help finding strusts and springs
  104. arp 7708 enough for 15mm?
  105. ball joint question/help
  106. Post Pics of your Rear fender and wheel on coilovers
  107. shaking steering wheel... help me diagnose?
  108. Upgraded Steering Knuckles Question
  109. 5 lug swap
  110. help clunking noise
  111. do rear sway bars help?
  112. coil bind?
  113. Found out my camber is off on the passenger front side
  114. eibach sportlines+stock strut=good idea?
  115. ARP 7708 for 15mm spacers?
  116. SS/TC Springs w/FE1 stock shocks/struts on 06 LS
  117. Pedders Sport Ryder lowering Springs For Sale
  118. D2 lowering springs
  119. need better brake pads...
  120. i need better brakes
  121. rear caliper bolts
  122. spring swap?
  123. Disintigrated Rear Sportlines
  124. spacers for stock?
  125. lowering issues??
  126. ss brake setup on my g5?
  127. Spring rates in coil overs
  128. Help, Car pulls left when I let off the gas
  129. Legit deal?
  130. USED pedders
  131. Bad shock/strut??
  132. Does Redline=CobaltSS Stainless Brake lines?
  133. Help Noise coming from the back driver side
  134. need opinion on rotors and pads for LNF
  135. HELP HELP HELP Control arms how to guide WHERE
  136. stance coils help
  137. CED vs GMPartsDirect
  138. What to do? New Struts/Shocks or go Coilovers?
  139. Replace JM4 front brakes with JL9 front brakes
  140. ss/sc springs on a base cobalt
  141. Looking To Buy EBC Brake Pads
  142. uneven?! why
  143. lowering springs
  144. Rear shock question..
  145. Raceland Coilovers in our future?
  146. Eibach Sportline Lowering Springs
  147. Question about coilovers.
  148. ANOTHER steering wheel shaking thread
  149. Lug size needed for spacers.
  150. ☢☢☢ KSPORT Suspension - ULTIMATE REVIEW THREAD ☢☢☢
  151. Car pulls to the right.
  152. Control arms and ball joints
  153. New brakes good deal?
  154. Car Suspension Question
  155. Rear Torsion Beam Bushing Making Noise?
  156. Where can you buy FE5 Rear beam bushings?
  157. Shim Kit
  158. do these fit help asap
  159. ★★★ STANCE Suspension - ULTIMATE REVIEW THREAD ★★★
  160. XYZ Sport coilovers??
  161. Wagon dropped on CM Balt SS spings...
  162. ZZP Strut tower bar?
  163. 2007 Cobalt rotor issue....Frustrating!
  164. Tenzo Part #
  165. Rubbing, no more paint!
  166. Lsj rear caliper issues
  167. Need a better ride
  168. CM/SSC Springs Feeler?
  169. LNF Break Pads
  170. Installed Coilovers and.... SURPRISE!!
  171. alignments LSJ vs LNF
  172. 2006 SS/NA strut/spring Q
  173. Suspension ride height questions
  174. Squeak When Moving From A Stop
  175. Track Suspension.
  176. Drum Brake squeek...ongoing problem
  177. control arm bushings
  178. best way to go?
  179. Testing waters. LNF struts/shocks w/ pedders
  180. Koni shocks and struts. Info and how to adjust
  181. koni front strut inserts
  182. FE5 Control arms from CED
  183. FE5 shock question
  184. Coilover Q's
  185. Where to but stance coilovers
  186. Service Traction/ESC Off/ABS Light
  187. Strut Mounts
  188. problems with my coilovers HELP
  189. Looking for coilovers
  190. Parking Brake Balance
  191. Negative camber is good right?
  192. Anybody installed KONI yellow inserts before?
  193. whole strut replacement or just shock absorber?
  194. slammed + base auto how to beat axle bind?
  195. JL9 pad question
  196. Why no GC sleeves for us?
  197. The OFFICIAL Coilover Thread
  198. vibrations
  199. 15% off our already low Hawk HPS and Ceramic Brake Pads @ PFYC - PartsForYourCar
  200. Springs moaning?
  201. installing extended studs on front hubs
  202. front end noise fix
  203. need help with this one!!!
  204. Sport lines
  205. Powell Raceshop Time Attack inspired twisting beam
  206. BC or Megan suspension?
  207. FE5 struts with Pedder springs??
  208. top hat
  209. Fe1 to fe5
  210. Stock Brake Pad's
  211. Do I need a 4 wheel alignment after coilovers?
  212. Sagging or shock blow out?
  213. Brembo Calipers Repaint!
  214. OTTP trans mounts vs zzp trans mounts
  215. level out?
  216. H&R to Pedders results
  217. Probably a dumb question
  218. Eibach Front & Rear Sway Bar Kit
  219. Interesting...lol
  220. Rotated trans mounts on a base model
  221. Alignment help (not a cobalt)
  222. FE5 dampners vs Koni Sport dampners
  223. KW's installed
  224. sway bars
  225. installing coilovers!
  226. "suspension techniques" lowering springs
  227. Strut Hardware
  228. Eibach Sportline....Broken
  229. Loweing problems
  230. lowered SS = low speed vibrations on passenger side
  231. Stance coilovers question
  232. getting coils
  233. DropZones Not Cutting it Any More
  234. New rotors, new pics
  235. brembro front brake kit from ced
  236. springs wear
  237. just orderd sportlines
  238. Stance coilovers for fe5 setup
  239. FE5 Struts + Pedders
  240. clunking when turning in front
  241. Stock SS springs for $20??
  242. Some simple brake questions (`07 SS/SC)
  243. going from ls to ss springs
  244. Who has welded in a new rear sway bar?
  245. what springs are seconf best toPedders?
  246. SSC or Pedders Springs
  247. LSJ Rear Beam Axle - same as standard cobalt minus the stub axles?
  248. Replacement spindle for 2007 SS / SC? Same as all?
  249. Apex Springs??
  250. Kyb gr-2
