View Full Version : Suspension
- Brembo front pads part number help
- Rear axel swap
- Is this right?
- Major lateral play in front wheels
- Is there a diagram?
- Handbrake Return Spring
- Rockauto Dynamic Friction Brakes
- 09 Cobalt SS Rear Brake Part number help
- Adjusting brake booster rod
- Downgrading
- Suspension/strut setup
- DIY Polyurethane Bushings
- CV Boot
- 2008 Cobalt SS goodridge lines
- Has anyone noticed SS/TC rotor prices?
- FE5 with pedders or Megan Racing EZ II Coilovers Chevy Cobalt SS (05-10) MR-CDK-CC06-
- 07 Cobalt SS Rear Axle Replacement
- FE5 Struts/springs to FE1
- Replaced lower control arms ... now one is clunking even louder
- Decided to investigate a chewed up Rotor on my 06 SS
- Raceland coilovers are on
- Need strut mounts
- Lower control arm part #s help-?
- Replace Control Arms when installing Powell TCABs?
- Driver side rear brake line rusted through
- Koni Yellows / YYZ w/ Coilover Camber Plates
- Steering Rack Spacers
- Alignment questions
- KSport Kontrol Pro
- LNF Control Arms
- Godspeed mono ss coilovers
- 09 SS full suspension upgrades
- Stance coilovers spring upgrades?
- Bilstein b6 rear shocks or oem fe5?
- Advice on torn TCAB sperical
- LNF rear caliper slide pins
- What parts needed to install FE5 shocks/struts/springs?
- What producer I got springs in rear suspension?
- parts list for front end rebuild?
- Trying to track down FE5 springs.
- Thinking of going FE5.
- 2009 SS strut replacement and now car sits higher in front.
- Rear pivot bushing install nightmare.
- KYB Exel-G struts question
- Rear caliper bleeder screws
- FE5 Upper Control Arm Install
- Coilovers anyone?
- Anyone have an FE5 front sway bar they can weigh?
- Coilover install Question
- Seized Strut tower mount
- Ride Height
- Lol, not like videos how does rod come off strut
- wheel hub differences
- Brake upgrades
- 2007 cobalt fe3 strut complete?
- Stabilizer end link nut spinning
- Need PN/source for rear brake banjo bolt washers
- Intermittent ESC Active, Please Help
- Rear Axle Bushing Braket bolt to body spinning
- Is this a stock SS/TC spring
- Upside dow rear lowering springs?
- coilovers - canada
- 07 cobalt ss suspension & brake parts
- '06 Lt sedan clunking over bumps
- KSport Kontrol Pro Coilovers
- 07 SS Supercharged FE5
- ZZP control arms
- I need help finding a new rear axle
- Suspension Replacement Question
- Confirming what CABs fit FE5
- ABS causing loss of traction?
- LT suspension upgrade question
- Off road / rally car
- Ride Quality
- 06 SS zzp Brembo calipers
- Stock Ferodo made in Italy brake pads.
- Front Struts
- replace control arm 08 Cobalt
- Prothane Sway bar bushings !help please!
- Lowered FE1, steering rack spacers, and steering problems
- How to Adjust Ride Height of Rear Coilover Shock?
- Helper Spring Size and Stiffness
- Upgrading Suspension - Complete FE5/YYZ
- more control arm woes
- control arm bushings tool
- Engine subframe/cradle swap
- control arm ball joint
- Popping noise when turning right or braking.
- Need basic info on LS rims
- New ZZP front sway bar making noise
- did all turbo cobalt ss have the fe5 ?
- FE5 suspension parts
- 2006 cobalt ss rear disc brake noise after everything replaced
- Strut mount bearing orientation (Moog
- Passenger Rear popping new Coilovers
- Rear Coilovers install
- Help please
- Caliper Bracket Rubbing on Rotor
- Lowering, Just the Back
- Combat Torque Steer.
- Need Help with suspension
- Brembo rebuild seal kit, MIA.
- 07 ssna want to lower about 1 inch possibly 1 1/2inch
- Camber
- My YYZ V.1 for your YYZ V.3/5?
- Tricks for more camber for the front wheels?
- Need info on rear SS springs
- Koni adjustable front struts - Good initial damper setting?
- FE1 link length
- HELP!!! spring rate for rear springs???
- Adjustable rear shocks for LNF?
- how to disconnect e-brake cable from caliper?
- Brembo pad direction
- Koni cartridges in Monroe's
- Brembo's on 08 Sport
- An interesting read from Brembo.
- Powell YYZ V5 spring total drop
- Has anyone tried welding rear CAB/subframe nut?
- Question about which Rack to use... ?
- 06 pursuit gt sedan.. ABS on Hub Bearing Disable Question...
- 06 pursuit gt sedan from fe3 to 08+ fe5 Struts, which link's to use?
- Greenstang Suspension Upgrade
- Steering Rack Vibration
- Brakes
- Coils binding
- Cobalt LCA bushing the same?
- Message I sent to Powell, but looking for opinions
- New Brakes
- Prime choice Struts and shocks?
- Powell koni strut install
- Broken rear coils
- Eibach Stabilizer Bar
- fe3 control arm on fe5 suspension
- 09 TC Parking brake dash light on
- Powell springs vs Pedders Experienced racers only
- Hard Steering 06 Cobalt SS 2.0
- Front toe-in or toe-out?
- Brembo Interchangeability
- 60 mph starts to vibrate
- mushy brake pedal
- Make it Softer!
- Spring Time
- Stuck E-brake !
- Loud Clunk on braking and releasing brakes
- Coilovers
- Koni rear shocks with coilovers
- inner control arm bushing replacement?
- Retro fit brake calipers??
- Caliper grease?
- TC Sway bar size
- Rack and pinion problem
- help with new spring rates..
- 2008 LNF Brake Pads Confused...
- Brake question
- Coilovers
- Base Model Suspension coil-overs vs struts
- Brembo Brake Help
- Pothole = LH RR Wheel is -2.0 degree off! Camber & Toe!
- Strutting my stuff
- ZZP springs?
- Rebuilding a Cobalt need some info an help
- Sring Spacers
- Just Releassed
- Need suspension help..
- I have read the sticky. Need JM4 to JL9
- Spindles for dirt circle track
- These ksports keep clunking
- Knocking noise. All new parts. Video
- BC coilover and swift springs question
- Rear beam replacement
- stock struts with lowering spring vs coilovers
- Uneven ride height after lowering springs
- New Shocks and Springs... Still making BANGING noises...
- steering rack spacer size?
- Rattling and Brakes
- Rear Strut Bolts
- Tire rubbing strut on left side
- Installing 2008 Cobalt SS brakes on 2009 HHR SS
- Handbrake Problem - Stumped
- End-links Q & Bushing Re-clocking
- Swerving
- Brake Pad Recommendations
- Tien lowering springs
- Coilovers installed- rear bottoming out?
- What sway bar should I buy
- brembo swap 05 ss lsj now getting abs light
- Chevy LNF Turbo 5x110 --> 5x114.3
- Tie rod and adjuster threads - right hand?
- Powell rotated trans mount - lower charge pipe rubbing against bolt
- Help with stance coilovers
- E-brake problem
- Brembo caliber measurement
- Aftermarket Sway bar bushings for 09 SS tc
- Coilovers or Lowering Springs for...?
- 2009 Cobalt SS/TC - Wheelhop reduction strategy?
- TC Brembos with IRL 17 inch wheels
- Is it still good?
- ECS/TCS/ABS acting up - causing hesitation while driving
- 06 SS Brakes, hubs and rear axle
- Strut help?
- Bad lowering springs?
- 06 ss brakes
- Brake and hub swap, quick reply needed
- Jerky steering problem low speed.
- Whats the proper way of tightening rear axle beam?
- Leading CAB How-to?
- tips?
- Warning: Brembo 4 pot brakes 08-10 SS/TC
- Wheel hub replacement.
- Lowering spring opinions
- Eibach Pro Kit and end links
- Prothane LCA kit opinions?
- Suspension Upgrade
- Best struts/shocks to go with YYZ's?
- Car pulls to the left under load :(
- 2ND torn cv boot
- Shredded Two Brand New Tires From SwayBar Links
- Steer wheel shake
- lowered - alignment question
- Need some help with swaybar bushings
- Rear Caliper Bolt Size
- Swapped stock for KSport Kontrol Pros, NEED HELP PLEASE.
- suspension/engine mount problem
- Upgrading from FE1 to FE5.
- MOOG K200792 Lower Control Arm Bushings
- anyone have stance coils for sale?
- Lowering Springs install help
- Strut Issue While Lowering
- Slight issue
- Rear Sway Bar Bolt
- 06 LT with 06 SS Cradle/Sway Bar...which end links?
- How low before issues
- Whats the deal with Corvette rear shocks?
- Floaty light rear?
- Best Lowering Springs for Cobalt SS/SC
- Powell's under car rails
- Sway Bar Bushings
- 209 FE5 Strut
- Having YYZ while keeping ZZP resonator.
- Help! Steering crunching/loose!
- Cars all over the place.
- SS Brakelines
- Ugh not so stock front ride height.
- Lnf rear axle beam compatibles
- sway bar endlinks
- Brembo brakes
- BC Coilovers?
- Coilovers
- Coilover question
- 07 brake conversion
