- Do you have to get a camber kit when you lower your car?
- Time for new brakes!
- R1 brakes came today
- SSC Springs
- 2.4 L suspension question
- CA KSports anygood
- ARK Performance GTF Lowering Springs installed =D
- Some questions
- ordered megan racing springs..
- Question about Canuck Motorsports Lowering Springs?
- Lowering on ksport springs
- GroundControl
- Vented disk brakes?
- ss/tc springs on a 2lt? need more?
- my brake pedal needs viagra!
- Possible to remove the front struts without air tools on SS/TC?
- Pedders & Rack Spacers
- Coilovers
- What Springs Should I Get?
- Thinking about doing a 4 to 5 lug swap, need input..
- Suspension Questions Help
- lsj with tc shocks struts and peddars
- Sportline Spring Question?
- Cutting the stock springs
- Sportline??????
- question about koni yellow rear shocks
- best springs from these 3?
- Need help deciding strut/shock package
- need to replace rotors and pads what should i get
- New tires=more wheel well gap. Best solution to lowering?
- Turn Out Ripping Up Fender Liner?
- stupid control arm bushings
- Negative Camber after alignment
- Help with lowering springs
- need help on picking out springs
- Fe5 ss/tc
- shocks and struts blown
- Coilover cars, come here.
- countrySS on coilovers
- b&g springs the lowest
- KSPORT Coilovers
- eibah pro kit
- Bent rear Hub (Axel?)
- Just got my tc struts and shocks now a few questions
- lowering the ss/tc
- Been having problems with H&R springs
- Roll Fenders or No?
- Lowering Springs for 07 Cobalt LS
- Need Help I wanna Lower my 2.4 on springs
- Moog vs Ac delco Control arm bushings?
- Pedders Coilovers
- Front sway bar on the 2.4 question..
- megan racing spring
- What kind of coilovers
- Shocks Discussion
- Uneven tread
- Lowering Springs vs. Coilovers vs. Cutting Springs
- Sportlines on FE1's
- pro kit springs? good or bad? pics?
- Rattling noise from rear suspension
- i need brake help ASAP
- Power Stop Ceramic Pads for TC Fronts?
- Wanting to get into road course racing
- sportlines vs pedders round 1 fight!
- Rear Brake piston tool
- put on my d2 springs today PICS
- Is there something wrong?
- Lower Lowering Springs?
- strut bar
- Ripped a caliper piston rubber seal... What do I do?
- Sportlines or Progress springs
- ______ARK Performance DT-P/ST-P Coilover_______
- Probably a simple answer any help is welcome
- clunking noise from front end
- bg springs comments concerns?
- CA #1 springs anyone?
- Ordered Eibach sportlines for my TC do I need spacers
- Rear Swaybar?
- Need lowering springs asap 07 ss/sc
- Best Springs for 08 Sport Sedan
- Anyone running SS/TC struts with SS/SC springs?
- can i get some more pics of ppl on ksports?
- Cobalt SS/SC Coilover Kits
- dealer said
- Which OTTP Rack SPacers to get
- Camber Question
- Increase handbrake performance???
- Lowering Question
- Turning radius
- Springs Under $150?
- ARK Performance INC Cobalt SS/SC GTF Lowering Springs
- Hawk Front Pads for TC
- Upgrading SS/SC Suspension
- brake conversion
- Well im joining the pedders fanclub...
- BC coilover adjustment question
- zzp tower bar
- SS/TC Shocks w/ pedders
- Struts and Springs
- strut bearings
- What sway bar to buy?
- Front End problems!!
- Clunking Noise and driver side sits lower than passenger
- Suspension peeps, enter.
- 06 cobalt lt rear end axle : (
- What are my options? Rubbing badly
- Crate engine pedder package. LSJ or LNF?
- What would I need to go from Fe3 to Fe5 front sway bar?
- Broken Rear Lug Studs
- ktc shocks struts comared to lsj
- Need help
- Bad night
- Pedders?
- H&R Springs
- SS/SC SPRINGS and STEERING RACK--HELP
- Woo! Springs & sway bar installed!
- What Color to paint calipers?
- Endlink length matter much?
- eibach vs h&r
- SS/TC Brakes
- new kw v1 coilovers :)
- lets see ur cobalts with air ride suspension
- Pedders Springs install
- Suspesnion Problems, No Traction
- all right boys lets talk big braks
- lowering
- changing front sway bar
- Roll cage?
- powergrid endlinks
- Brake pad question...
- suspenion mods for kwanzaa
- Megan Racing Coilovers or Pedders Springs for SS/TC
- No rear brakes!
- Pointed The Right Way
- Rear Suspension
- CobaltSS.net's 2010 Holiday Charity Drive!
- coil locks question
- shorter bump stops?
- H&R sport springs-Which ones?
- SS/TC rear sway bar options?
- need some advice on spacer
- lube spray for winter squeak??
- Airlift Air Bags for my SS/TC
- Brake help please everyone out there
- adjustable endlinks with coilovers
- master polyurethane bushing kit for cobalt?
- LNF knuckle swap
- BC coilovers
- Brake Kit
- swat bar links
- CAB play
- Help for coil springs
- Sway Bar Question
- My brakes were frozen
- spanner wrench size for megan coilovers?
- what do you recommend?
- Looking for new rotors
- SS/TC's with coilovers
- ZZP Strut Tower Brace
- Any way to validate t/c springs?
- Tein springs on SS/SC?
- 2 Questions about struts
- Aftermarket suspension in the winter
- vibration after lowering
- Strut tower help
- steering shaft replacement
- Squeeky brakes
- 2006 SS/SC Mild Brake Upgrade? Rotors + Pads, Suggestions wanted!
- Have a few questions about suspension and lowering, help?
- Urgent: To cut bump stops or not..
- The TRUTH!..Coilovers/springs, rear shims
- how do i dial in my coilovers?
- Urgent: Sportlines vs B&G's
- Wheel ALignment Question
- need 2nd alignment after steering rack spacers?
- Some stupid ?
- megan coilovers problem.
- Pedders Question
- Steering Rack Spacer
- rotors??
- Ebay Coilovers?
- I installed OTTP steering rack spacers and now my car pulls to the right.
- Ingall's Camber Kit
- Wheel Hub P/N
- B&G vs. Sportlines - I need your input
- Monroe Sensa-Trac......?!
- rear suspension setup
- Urgent info needed for strut question..
- Quick Spring Question
- lowering cobalt
- Question on lowering springs for 4 door cobalt !
- Dreaded rear breaks.....2 options
- FE1/FE5 mixing question
- Pedders/FE5 combo on NA 'SS'...
- Rear Brake Parking Lever Fix?
- brake upgrades for a 05 LS
- Control Arms - LSJ vs LNF...
- Strut Tower Brace Installed
- Anyone heard or have of D2 Suspension?
- Too much brake fluid.
- Control Arm & Sway Bar Links
- wanna lower my bolt but...
- Shocks/Strut question
- Hawk is cheap! Don't "brake" the bank; huge savings on Hawk at PFYC.com w/promo code
- springs question
- Rotors Installed!
- Going Pedder, should I get shocks as well?
- 07 Cobalt RF bushings....
- Drilled Slotted Rotors With Brakes $200
- Why do I keep warping rotors?
- Sqeaky brakes!!! Whhy??
- will these work?
- how hard
- Best springs for my preferences?
- lowered winters
- when will they settle?
- Rotors & Pads
- Stainless Brake Lines
- Tein's vs Sportlines
- Rear Axle
- FE5 t/c's and Sportlines..??
- Knuckle swap question.
- Help Please w/ Brembo Brakes
- LNF to LSJ Brake Swap
- Leading control arm bushing
- brakes i quit
- Rear Suspension Knocking
- Springs
- Super noob coilover question
- Will FE5 coil/struts fit on my car?
- Spring advice please
- Want opinions on what i should get
- will cobalt ss front contorl arms fit a cobalt ls
- just lowered my car and now has a shake while driving
- Sportlines and Minnesota snow??
- Pedders???
- Modern Performance Rotors
- Brake job on 09TC and now new noise
- g5 after the drop
- Need Help-Sportlines.
- brembo brakes to ss/sc brakes
- Need new rotors - help
- Need some help - Brakes
- rack spacer
- tired of the bouncy lol
- Aftermarket steering coil????
- clunking noise when hitting bumps
- New Brake Pads [Experience Requested]
- Can't find a conclusive answer...
- tein vs h&r
