- Changing out front struts
- Wheel alignment? Camber kit?
- Cutting Stock Fe1 Springs
- FE5 'quick strut' available?
- SS TC Suspension
- Lowering questions. Help
- Help Lowering
- Strut question
- street driving, ksports or konis?
- New springs, metal banging from the back over bumps
- BC coilovers information
- Steering Rack Spacer?
- Knocking from front end
- New rear caliper sticking
- changing ball joints
- Going Sportlines, any tips?
- my cobalt ss front end bottoming out
- Alignment on sportlines?
- Varrstoens plus kw v2's
- strut came off!!!
- Talk me out of buying these
- Question about getting lower
- 2006 LS - Specific problem need opinions
- Megan Lowering springs.....
- rear brakes
- spacers and extended studs
- Compressing Front Caliper on 2005 SS SC?
- Rear Sway Bar Test on Track
- should this happen after i install sportlines?
- B&G springs and bump stops
- Disc brakes
- New Springs
- Pedders Problem... I think
- Rack spacers
- Jack & Support the Rear?
- Need new brakes bad
- Rear Shock Question
- Noise from front end
- Help. Changed Hubs. Now Svc Traction, Svc Esc, Brake, ABS and Svc TPMS Lights on.
- Slammed Cobalts on Coilovers maxed out ONLY please
- D2 vs BC vs Ksport
- Got My Brakes In
- front springs help!!!
- Cobalt 07 ss/sc strut/mount
- Powell Hardcore Bar questions
- BC coilovers
- Stock ride height on 08 and up ss.
- strut nut
- Time to get new shocks and struts
- R1 Concepts FTW
- Ksport vs Stance
- New suspension parts help
- Coilover spring rate
- Sedan Suspension
- Going to but coilovera in the future is this a good buy?
- Which one?
- stock ride height??
- compressing caliper question
- Hi! Remember me?
- Steering Alignment Issues
- Slamming the slobalt
- Pogo like no other!
- zzp control arms gone?
- Too much coil bind?
- Another "will this fit" thread: FE5+Pedders on LS
- 4 Lug wheel spacing
- Caliper Replacement
- i want bigger rotors..
- Koni Sports
- how big of a difference from sc to tc springs?
- Creaking sound comming from passenger side?
- Canuck to Pedders
- redrilling hubs help!
- Bump stops and dead coils...
- Four Door G6 Suspension question
- Canuck Motorsports Dead Coils?
- Options for rotors
- New rotors and pads point me in the right...
- Lowering springs
- Rustproofing Coilovers
- What break pads do you use?
- Brembo caliper bolts torque specs
- brembos
- Drilled and slotted rotors?
- Need a new Rear Sub-Frame :(
- Canuck Motorsports Shipping
- Difference in 05-07 vs 08+ Fe5 struts
- Installing springs
- Help A Brotha Out
- Need opinions for Auto-x/street suspension
- Rotated mounts
- Good setup for a drop?
- Trouble reinstalling Koni struts
- What coils should I get? pt 4824
- SSC springs/shocks weight limit?
- 2008 ss/tc stock set up
- how to get rid of brkae pulsation?
- 07 Cobalt Rear beam
- ark gt springs
- cut stock springs
- cut stock springs
- Do you need Rack spacers w/ SSC's?
- brake system
- Springs - help me decide - post your pics if you got em
- Pedders GB Interest??
- abs light problems
- Stupid roads...I need alignment help!!
- Rack and Pinion
- Weird noise coming from front suspension
- Coilover Spring length
- Lnfs better for lowering?
- pedders
- Spec of lower rear shock bolt
- New to Suspension Work -- Where to Start?
- Dropped on d2's !!!
- steering problem?
- SSC/CM lowering springs
- Pedders on ls sedan
- pictures of cars on megan racing coilovers
- My brakes are acting up, HELP!!!
- Whats the name of this part description
- Brake Life
- d2 coilover questions
- Control arm bushing replacement. Need help!!
- Hawk HPS & Ceramic brakes ship free and at the lowest price at PFYC - PartsForYourCar
- Best brakes to get
- Best suspension combo for launching from a dig?
- Stance Coilovers
- Going from Pedder springs to coilovers
- horrid noise
- bc or megan coils
- Car still pulls with perfect alignment
- Turn Rotors or no?
- Cant decide.. H&R or Progress
- CM/SSC Spring Questions
- Best coilovers?
- Lip height.
- Debating on lowering LS
- suspension squeak
- Bumpstop/alignment questions w megan springs
- cobalt brembo brake line help
- Fake Eibachs
- Coilover Adjustment questions
- Sway bar delete?
- sway bar link question
- Goin Low
- SS/TC Brake Situation. Advice welcomed.
- Not sure what to do with this.. Please help
- FE5 strut on j-body
- just want to get LOW
- problem with sstc breaks
- whats the best coilovers for drop??
- SS/TC front pad upgarde.
- Fe5 / Koni Question
- Progress Springs. Any Good?
- Fe1 to Fe5
- Engine Pulley
- FE5 LNF on a l61
- Weird noise
- Stagg vs KYB
- Noise
- alignment?
- Pedders rear springs making clunking noise
- ksport coilvers for sale!!!! Great Price
- Any new info on balt air suspension?
- Strange grinding noise from right wheel
- trying to make final springs decision
- Fender rolling?
- strut question
- SS/SC Springs??
- lowering spring personal opinions
- How To | Be "Hella Flush"
- how too for springs?
- need some rideheight specs
- Ksports or sportlines
- Brembo Powdercoat Options
- koni yellows HELP??
- cavy bushings??
- 08-10 Fe5 struts in a 05 FE1 car?
- KW vs Stance
- Any way to fix axle bind?
- DGR coil overs
- Must have with XXX bar
- B&G.or H&R??
- best deal!?!
- Broken strut round 2
- better springs than sportlines
- interchangeable calipers?
- KW V2 Spring rates
- Ksport coilovers question
- eibach sportline question
- Modern performance-eibach lowering springs
- Suspension "clank"
- SS/TC E-Brake Failure
- Coilover Sleeves??
- HELP :confused:
- will lsj elibach fits my lnf?
- How to scare your girlfriend
- rear drum brakes to disc
- Rear brake yelping like a dog
- Trans mount inserts
- Lowering With Stock Shocks and Struts
- Pedders Installation Problem
- Swapping to LSJ brakes
- tires cutting down.. help
- Ever heard of Stagg Struts?
- Pic Request: Non SS sedan on CM Springs
- SSC springs on SS/TC sedan?
- Size of hub bolts?
- Steering Wheel Not Returning To Center
- SS Brake line help
- FE5 Control Arm Bushings
- Which costs less? Bushings/LCA's
- Rebuilding rear calipers
- coilover help!!
- Haven't logged on in a while...,
- Steering Rack Spacers Location
- Suspension clunk on aftermarket parts
- Pedders vs Sportline
- stock vs. stock + PRS Bar vs pedders vs pedders + PRS Hardcore
- Lowering Spring Info
- Question
- People with stance coilovers
- Stance coilover question
- is there a how to on how to replace endlinks?
- how low does the car sit on unlowered coils???
- Rear FE5/FE3 springs
- end links
- 2.4 on fe5 struts
- eibach sportline or tein s. tech lowering springs
- i know this was prob already discussed but..
- Rotor and Pad Help
- Spring help!
- srt 4 megans...
- H&R springs
- B&G spring question
- brake issue
- Will these control arms fit?
- questions about megan coils
- Coils
- help..
- cross camber issue
- How to diagnose bad strut mounts?
- How Low For Snow?
- lowest I can drop...
- Pedder Spring concerns
- fast question about end links
- Gonna get some Volks, or Work Emotions
- Stainless brake lines
