PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. LNF k frame support for swap
  2. ZZP FMIC - Bumper fitment
  3. Utilizing the 2.0 LNF Outside the Cobalt
  4. Need help with a P0101 code and little/no boost
  5. Stock exhaust manifold scroll divider
  6. Retrofits
  7. Hahn new turbo kits
  8. Trifecta Fail!
  9. Spark Plug Socket Stuck in hole. With Pictures
  10. LNF AFR Error
  11. Car hard to start after filling up with gas
  12. Upgrades for fuel injectors
  13. LNF and LK9 intake manifolds
  14. LNF rebuild vs replacement
  15. CEL P2096, stuttering, stalling, and loss of boost
  16. 2009 SS/TC Sedan Build Thread - Lots of pics
  17. Need help with this please! Bad all over!!
  18. NGauge for cobalt?
  19. Recommended mods??
  20. Lnf pcv
  21. oil galley plugs on ldk
  22. Trying to do timing chain tensioner... Did I make an oopsie?
  23. Engine reduced light.
  24. My Cobalt ss 09 is running fantastic!
  25. K04 turbo lines upgraded to AN fittings plz help
  26. surge s20g
  27. Intake valve cleaning
  28. Pumping brake increase fuel trim?
  29. 2009 Cobalt SS Downpipe
  30. Flutter?
  31. 500whp LNF sleeper
  32. Recommend me a clutch?
  33. P0101 code did a boost leak test, no boost leaks.
  34. Oil in charge piping.
  35. Best timing chain kit?
  36. 2009 ss tc missfire
  37. Cleared CEL P0101 then Oil Pressure Light Appeared (car won't staying running)
  38. New ZZP S256 Build -- Torque Specs and Other Jazz
  39. Compressor housing fitting
  40. Mu3 Trans
  41. Wastegate and PCV Lines
  42. Oil feed banjo washer P/N
  43. Clutch Pedal Position Sensor
  44. E85 Balt wont start
  45. Need help with some codes
  46. Throwing some codes, need help
  47. LNF Seat Swap
  48. Erratic STFT
  49. Bouncing RPMs when coasting in nuetral
  50. Where did your transmission fail?
  51. Has anyone ever ran a 6258
  52. replacing clutch disk
  53. Lnf low boost first gear
  54. low boost until computer is reset?
  55. clutch replacement
  56. Removing clutch line
  57. New LDK and blown K04r seals - need advise
  58. EVAP System Monitor Failed
  59. looking for tuner in IL
  60. I'm thinking I should start a build thread. Guess this is it.
  61. Can really use some help here.
  62. 09 ss hesistating p0114,
  63. Lopey Idle on Cold Start
  64. Lnf or ldk head?
  65. Exhaust choices
  66. Cold side charge piping.
  67. Painting intake manifold
  68. Bad Boost Control Solenoid/BPV Solenoid?
  69. Brake Rotors & Pads
  70. Spark plugs!
  71. 34.8 PSI in MAP
  72. Performance Autowerks vs ZZP built transmission
  73. LDK - vs - LHU
  74. No BPV or BOV Important things to know?
  75. HHR SS finally lowered!
  76. Rough Idle, No CEL Codes?
  77. Timing Chain Maintenance Requirements
  78. What Spark Plugs Should You Use On LNF?
  79. Engine shutting off when temp is high.
  80. Got a P0243? Here is the help
  81. Spark Plugs!
  82. Overboost
  83. Fuel Trim Woes
  84. Bcm
  85. RPD Boost showing "Data Not Available"
  86. RS written ln ECU. Any idea?
  87. Thoughts on this 09 SS sedan
  88. Oil in Exhaust: Smoking..
  89. Gasket set for cobalt ss
  90. N2MB wot box help
  91. P0303 09 lnf
  92. Manual boost controller question
  93. Are bov's really that bad for the lnf?
  94. 09 SS/TC Exhaust
  95. MPX Exhuast vs Turbo XS RFL
  96. Loud spool on old oil quit spool on new oil
  97. Meth or Aux Fuel Rail
  98. Rough Start Up
  99. Making too much boost on ZZP tune?
  100. Logging for the Stage 3 head
  101. Billet bov questions
  102. P2261, P0236, no boost, no power, misfire
  103. Getting downpipe, need tune?
  104. Bcm
  105. 3 plugs on front of block
  106. starter
  107. Part Throttle Compressor Surge
  108. Lots Knock Retard
  109. Weird air fuel ratio on my RPD
  110. Big turbo lnf won't boost past 7psi
  111. Low Compression Numbers
  112. ***** how much pressure does turbo cold side build
  113. how the lnf crank breather system
  114. Transmission Noise LNF GMPP
  115. Is there a kit to rebuild the LNF BPV?
  116. Can't shift into 1st, 3rd, 5th. 2nd, 4th, and 5th works fine.
  117. Need suggestions
  118. Cam tools
  119. High Pressure Fuel Pump Replacement
  120. Priming the oil
  121. Need a good Tune
  122. P0299 Turbo under boost issue
  123. Lagging boost and random misfire on all 4?
  124. not running full boost
  125. Fan Switch
  126. i think my zfr is done
  127. If anyone with a zfr and forge bpv wanna solve the low throttle woo sound come in
  128. Engine didn't start after rebuild! UPDATE
  129. LNF Cobalt Life Expectancy ?
  130. New tb , relearn?
  131. 2009 Cobalt SS TC - boost limited to 22.4 psi?
  132. 2009 SS/TC Missing when giving it throttle! HELP!
  133. P2097
  134. RPD Missing DATA / CODES
  135. PVC intake plastic piece
  136. Leaking Fuel Lines
  137. Charge pipe blew off
  138. Hybrid Stroke?
  139. SS/TC vaccum hose diagram?? Help
  140. 6258 Sky Project Spool
  141. No_ss build thread
  142. PCV goes to fresh air
  143. Slipping 3rd-5Th gears southbend clutch
  144. LNF boost issues
  145. Clutch Upgrade Help
  146. ZFR 7136 Requirements/build
  147. P0011 Timing Over advance Bank 1(intake)
  148. The part number for coolant banjo gaskets on turbo
  149. Lower charge pipe/tmap problems solved
  150. Maf sensor
  151. No boost/limp mode after upgrades
  152. Something big from ZZPerformance
  153. Something big from ZZPerformance
  154. Lnf cobalt ss 90k mileage
  155. LNF engine curious if anyone else had this happening
  156. Weird power loss problem
  157. LNF/LDK top piston ring orientation
  158. Bought a new to me SS! need some advice.
  159. Just replaced my suspension, and have questions regarding display conputer..
  160. Doing Brakes and replacing Swaybar Endlinks
  161. New intake
  162. Valve cleaning
  163. head gasket!!!
  164. Weird turbo noise
  165. No lift shift not working
  166. Can't get my car to start after engine build!!
  167. Brakes
  168. Pvc valve in mani
  169. 2010 cobalt limp mode
  170. Interceptor c to f
  171. How many have had crank/pistons/rods balanced
  172. Erratic fuel trims and AFR EVAP?
  173. Water/Meth Injection.
  174. downpipe interest
  175. Loss of power/Boost!!
  176. cruise control issue after trans install
  177. Boost problem
  178. Kmo43 2016
  179. Overheating smell
  180. Lnf vs Ldk
  181. ARP head stud thread pitch and washer size?
  182. Injen Intercooler?
  183. ZZP recall on high voltage coil packs
  184. Anyone running the HAHN LNF turbo upgrade?
  185. KMO43 vs Jcalvin1126
  186. Charge piping question
  187. Fuel line
  188. has anybody heard of or used these products
  189. resleeve?
  190. Lnf shift cables
  191. What is needed to run a Tial BOV?
  192. LNF and nitrous
  193. this has me scratching my head
  194. P0100 Air Flow Circuit & Low traction while driving
  195. Blown turbo or dead cylinder?
  196. 09 hhrss tune
  197. What to replace on timing chain with play/looseness?
  198. Need some help for smog please!
  199. Gen 3 block??
  200. Coming back!!
  201. MODS with GM1 Tune
  202. P0101 without a boost leak
  203. help
  204. WOT Misfire ad 2krpm hesitation.
  205. Temp lnf
  206. Temp lnf
  207. Road to 350hp advice?
  208. Stock Boost solenoid On s257, Pics, need help
  209. Typical EGT During Pull
  210. Nostrum Energy LNF Big Injectors
  211. SS info
  212. Loss of about 50hp & 50torque
  213. What hose is this?
  214. NLS misfire. Flashing CEL.
  215. back in the game
  216. GMS1 help.
  217. Doing a turbo swap, s257sx-e, need suggestions to tie up a few of my questions.
  218. Super high iat2
  219. still having cold start issues
  220. Everything working, but car wont start.
  221. E85 lnf
  222. Tranny Probs
  223. boost some boost no boost P0299 help
  224. Size of the boost source line?
  225. WOT BOX wiring help
  226. clutch for hptune
  227. Car judders only uphill at wot
  228. How is my car running? Any tuners that can help?
  229. Lnf issues wtf
  230. 21PSI 100% stock.
  231. Engine trouble? P0010
  232. RPD vs Boost gauge vs aeroforce
  233. uhh ohh somthing went wrong!!
  234. Does this sound like a blown trans?
  235. LNF fast clicking under valve cover
  236. LNF Stock Air Box Cone Filter Mod
  237. s256et on e85/e47?
  238. Engine Replacement
  239. Gross leak to evap purge low flow?
  240. Mpx Catch Can
  241. LNF Instrument cluster Pinout
  242. BYT vs ZZP Dyno Graphs
  243. ZZP PCM Fuel Trim
  244. 3.82 vs 4.05 mph to rpm correlation
  245. K&n sri
  246. Intercooler opinions
  247. Intake, BPV, and Tune Questions
  248. Wheel Hop, Ingalls Torque Damper, and K&N SRI
  249. How many doing ported LNF/LDK heads?
  250. Can't shakes P2178
