- I'm pissed off!
- What guarantees LSD on an 09 SS?
- SS/TC BOV Opinions?
- charge piping
- LS1 in a cobalt?
- new ss/tc
- sliping belt maybe?
- NLS+ short throw shifter=???
- Jacks/Jack Stands
- 08 cobalt ss vs 99 camaro ss
- Fuel pump failed
- A few odd issues...
- Here are my mods now what?
- is there any sort of tune that will help over the gms1 tune?
- No Lift Shift Causing any harm?
- engine noise! plz help!
- tunning over gm stage 1
- Help?! No Boost?
- Stock Exhaust VS. Muffler Delete
- GMPP 3 bar MAP's are installed!
- P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
- NLS and mods
- New To The LNF Community...DP Question
- guys i need your help
- flutter?
- CIA Charge Pipes?
- Dealer installed bracket for SS
- 1 gallon loss of coolant + good pressure test = ???
- help!
- Quietest Downpipe
- Disconnent battery
- Clamp size for Injen charge pipe
- trade
- Vararam Industries LNF Intake Update....
- Part #s for Front and Rear Pads/Rotors
- car
- high flow down pipe
- question
- Boost leak test
- Official numbers?
- A little teeaking !
- bad rocker arm/lifter questions
- Need some opinions about a less powerful LNF than normal...
- Clutch problems
- Dead spot in top of clutch pedal
- Loss of Power and Boost
- ss/tc governer/tune
- What's a good exhaust
- Filling transmisssion fluid??
- Hahn 3in catback diameter
- Low Boost After Tune Update...?
- E85 fuel???
- Build a cai ?
- Bone Stock 09' Cobalt SS VS. SR20det 240sx
- ZZP Downpipe installed
- transmission fluid???
- does a 08T/C LH axle fit a 06 S/C
- need help
- CF Oil Catch Can
- Elbow/bleeder valve on mu3 tranny
- Help with Intake Install!?!?
- Favored cai ?
- Charge pipe
- ZZP maf relocate finished!
- Treadstone Intercooler kit and Cold Air Intake!PICS!!
- Power steering issue. Recalled!
- Occasional wheel hop bad???
- Those with ported heads
- MAF Relocation and Intakes
- Woe baby !!
- car is running kinda funny please help
- Cardelino18 Motor Build
- Thermostat
- e brake sucks
- trifecta fan control
- intercooler clamps torque specs?
- Sunroof issues?
- Rods
- What do these codes mean?
- removal of intercooler
- Has anyone tried the JET Performance Mass Airflow Sensor?
- cylinders,pistons,or turbo seals??
- S20g
- wierd sound from rear
- anyone have an extra intake?
- LNF Carbon Fiber Intake Manifold
- hpt question
- Have you seen these new mufflers?
- noob question lol
- Lost 3rd
- BTF Complressor wheel
- code: 0299 won't go above 5 psi
- Fuse for windows keep blowing
- Call me retarded but...
- CUSTOM Intercooler Piping $??
- Filter Size, Hahn Intake?
- headlight moisture
- People with Crazy Steve IC...
- Help 3787's problem?
- Went to the Track with ZZP Turbo Upgrade
- HP Tuners and warranty
- Traction control , ABS Question
- apexi n1, or blox mufflers?
- What's going on?
- 2010 SS Upgrade options
- hks bov recirculation
- New Turbo?Help..
- CEL P2096 Please help
- pulling motor?
- new o2 sensor knock
- its bad... really bad...
- Front AXel Nut Socket Size
- bov question????
- LNF stock pistons?
- meth?
- GMS1 dilemma??
- smoke and pop for NLS
- What did I do?
- Where do I go from here?
- Dual Exhaust for SS/TC
- Eventual trade in for 07 STI (I hope)
- Terminator2nd
- Who has HP Tuners?
- Should I get the Hahn CP?
- 3rd gear wont engage
- LNF Intake Test Car needed for couple hours in Houston Tx. Area
- Impact of oil viscosity and cam phasing
- Advice, Downpipe
- Spark Plug Horror Story
- o2 sensor.
- Need diagram of bpv, vac line.
- Gauges
- No fuel filter?
- Best Spark Plugs?
- Another satisfied Trifecta tuned customer!
- ko4 question
- camshaft sensor
- just a question...
- Coldstart stall problem, video
- S252 Spool RPM
- Photos of Production MPx Oil Catch can for Cobalt SS Turbo
- Engine Power Reduced
- bov
- Trifecta Dealer Needed
- ONBOARD COMPUTER for 0-60,1/4 mile and G's
- datalog
- Dual Intercepters
- Stock ss/tc wheels holding up?
- i think the balt will have to go!
- whinning noise
- spark plugs. what are YOU running?
- a quick question?
- Intakes
- Brakes/Rotors
- Possible stock bpv issue.
- my bov story
- some help please
- Dyno Tested: Vacuum Tank Bypass mod
- help
- Misfire/cutting out above 15psi w/ stage 1
- What is needed?
- brake help
- ecoTechnik turbo kit
- O2 sensor CEL
- Time for a new turbo
- CEL for fuel pressure regulator?
- Need a new clutch need help?
- Timkin Hub assembly 2009 SS TC
- Rock Products Engine Parts
- Oil in the wrong place!!!
- 09 Cobalt SS Turbocharged for sale(25psi,320 hp)
- 09
- Bunch of goodies.
- Dejon Upper Piping
- Need help with tranny!!!!ASAP!!
- LNF stage 2 kit?
- Any problems related to GMPP Stage 1? Maintenance?
- warranty question
- ZZP's adjustable clutch rod
- Another freaking oil thread...
- need some help locating a connector! help please
- wideband o2
- Is the piping supposed to be clamped right in front of the barb?
- Help K@N causingCEL on LNF
- Looking for an Intercooler Test Car
- Calling All knowledgable LNF Tuners/Owners: Our Intake prayers may have been answered
- GMPPStg1+kn+CIA dp dyno results
- 09 Cobalt SS For Sale
- Cali's sucky gas
- intercooler sensors
- DRL fuse, hid headlights
- All You Need to Know About Different Tunes
- ZZP Clutch rod install...Help please!
- Disconnected Evap Purge Solenoid = Very Happy LNF
- Just ordered gmstg1
- White smoke
- will nitto 555 hold infiniboost
- intercooling
- Hahn CAI for sale
- Pre detonation and severe spark knock
- Up Next!?
- LNF UPGRADE (2 Days in Shop) HELP PLEASE
- Turbo Swap Time!
- Need Houston area tuner
- Clutch opinions
- Car Turns over, won't start after engine rebuild
- turboback exhaust for cobalt!!
- 09 ss vs c63 amg
- Cel on
- First drive with Exedy Hyper Single, OTTP MNTS
- New 3d Video of TreadstonePerformance Turbo Manifold
- stage 1, rpd ?
- dashdaq quarter mile
- If you have Injen CP, buy larger silicon couplings
- Help received code error P0497
- LNF in-tank Fuel Pump Upgrade
- Smoking out the exhaust?
- Dyno question
- took the plunge
- Gms1 redline????
- Got tired of waiting...
- Idea for failing front O2 sensor
- upgraded compressor wheel
- Need a tune & live in Missouri??
- CIA catback help
- vendor
- competative mode
- Stock plugs on LNF+high boost+meth. picslol
- lsj and lnf put together?
- my a/f ratio is it good?
- CAI hahn install.
- GMPP anti wheel hop mounts
- how to remove charge pipe bolt
- carbon fibre hood
- Lowering Springs
- Installed the new MPx catback today
- Crate Engine Depot vs Canada
- I'm a new trifecta tune dealer in nj
- Vacuum Routing
- ZZP turbo upgrade specs
- gm stage 1 flash problems
- My CPPS switch failing?
- Is aluminum flywheel worth buying?
- pushin my luck.........
- When to do First Oil Change?
- Trifecta Tune --> I want feedback from a Canadian Buyer!
- What Psi are you running
- infiniboost trifecta
- tired of throwing a cel with a catless dp?
