PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Just wondering..
  2. Misfire, A/F at 11, no data etc
  3. 5k miles tranny goes AGAIN!
  4. sputter when shifting at wot
  5. A/F ratio problem
  6. Bedding a factory new/replacement clutch FYI
  7. BC coilovers?
  8. CEL Code PO140!
  9. Cobalt LNF MPx Lightweight crank pulley - testing going very well!
  10. Brake Lube; How do I properly prevent squeal?
  11. muffler swap...
  12. Does this mean my clutch is slipping?
  13. Surging!
  14. when 'good tunes' go bad......
  15. Stage 3 Treadstone install walkthrough
  16. ZZP Shift Linkage..
  17. Issues with K&N SRI at start up?
  18. Misfire; now boosting 22psi Stock Tune!
  19. question about timing on your tune!
  20. what to get extra money
  21. Hahn Downpipe Rattle???
  22. Charge Pipe
  23. Injen CP and HKS BOV?
  24. E-Brake Won't Stay up
  25. Bad Break Boost Sensor
  26. help understanding intercooler
  27. Oil Sweating? around valve gasket
  28. thinking about twincharging 09 SS TC
  29. Dyno Time
  30. from 1-10 how bad?
  31. mobil 1 filter
  32. Radar detector (beltronics)
  33. KR after dp install...
  34. Confused... Need Input
  35. SAAB intercooler for Cobalt SS Turbo
  36. speedo lag fix....
  37. whp estimate
  38. Trans fluid
  39. Anybody used ZZP's motor trans mounts?
  40. colder plugs
  41. Misfire?
  42. Losing Boost?
  43. overdrive crank pulleys
  44. intercooler, ZZP or MPx?
  45. interceptors
  46. 60-130
  47. who the fukk makes the best charge pipes!
  48. Zzp look please
  49. Rotors
  50. a few ideas
  51. Low temp thermostat
  52. Not having great luck with K&N Typhoon Intake.
  53. Soon to be installing Treadstone Stage 3 Kit
  54. ottp rotated mounts install
  55. Slicks on a SS/TC?
  56. New Clear Image Stuff?
  57. GMS1 vs 2000 ls1 z28?
  58. trans problems
  59. Agency Power Catback Installed
  60. Roll race , tuned sstc vs stock e92 M3???
  61. please please please help what to do
  62. Gms1 and top tmap
  63. Wierd reaction in 4th and 5th gear
  64. Lnf won't boost
  65. experts quick question with a CEL
  66. ZZP LNF Cam Testing
  67. GMS1 Stock 0-60
  68. Decisions, decisions!
  69. legal standing mile???
  70. downpipe gasket
  71. LNF Stock turbo limit
  72. spark plug replacement
  73. Help! Hahn chargepipe vacuum nipple!
  74. went to the heart breaker dyno today and....
  75. HP tuner?
  76. PO497 Code?????? Techs help out!
  77. Cold Start Surge w/ stock airbox and AEM turbo inlet tube
  78. GMS1 in GM TechLink Bulletin
  79. restrictor pill??
  80. Confused about exhaust
  81. 3 bar sensors installed. Fluttering now.
  82. Cat back question
  83. anybody throw on a winter tune?
  84. mods done
  85. ZZP Intake hose
  86. GMS2, what would it look like if it was real?
  87. exhaust
  88. check engine lights
  89. zzperformance black friday
  90. 4t65ehd
  91. need help with hp tuners again!!!
  92. So add a wrx sti to the kill list
  93. Hahn Catted DP Installed
  94. Car stalled slowing to a stop??
  95. lnf spark plug install
  96. Did a pull in the cobalt.
  97. Compressor surge...what causes it?
  98. Wouldn't this be nice
  99. Lil question for 2.2L
  100. RDFABS?? Anyone heard of them?
  101. So I ordered my TUNE...
  102. ZZP Adjustable Clutch Rod
  103. Is the oilcap vented?
  104. Noob with engine cover off
  105. MPx Downpipe Or BAD-MAB Downpipe
  106. Intercooler Choices
  107. Next bolt-on?
  108. Intake or Exhaust
  109. Threw a P0141
  110. Getting trifecta, can/should I NLS?
  111. HELP installing HP tuners problem
  112. GMS1 Sonseors only...
  113. big turbo lnf race videos where u at
  114. what can i expect in the future in in aftermarket parts for the lnf
  115. Question AEM DRY FLOW FILTER
  116. quick question about triffecta
  117. Dejon SRI
  118. would these tires work for an ss/tc in winter?
  119. Valve Cover Gasket
  120. breather hose removal
  121. My Birthday's Tomorrow
  122. A must read for all LNF tuners
  123. Apexi AVC-R
  124. Steering column question
  125. Treadstone intake data?
  126. T3/t4 manifold
  127. 3" down to 2.5"
  128. TBE (Turbo Back Exhaust) Video
  129. Good news for newer Calif Cars...SMOG
  130. Best SS/TC Exhaust
  131. Blew map sensors
  132. Recirculating BOV for BNR Stage 3 Build
  133. Just put a CAI on my 2010 SS/TC not fully boosting up?!
  134. cut out and engine light
  135. CEL came on!
  136. EAGLE LNF Rods
  137. November 5th I begin Modding
  138. Negative Boost at idle
  139. I saved some loot and I'm a modding nOOb
  140. Lower Ic piping
  141. Hks bov
  142. GM Stage 1 Sensor O Rings
  143. Questions about nitrous and C16 or C10
  144. Hesitation @ 3000rpm in first gear only
  145. New Short Ram Intake from CIA?
  146. zzp exhaust
  147. injen cp and bov
  148. installing dejon cp & hks bov..
  149. People with zzp turbo kit
  150. Disable CBV?
  151. DSM Turbo Question
  152. CAI / Charge Pipe Heat Wrap?
  153. so got a new exhaust today
  154. hp tune/trifecta
  155. Anyone Want to know What Driving a NA LNF Feels Like?
  156. surge with revised aem
  157. hp tuners problem
  158. Drilled disc brakes in the winter
  159. How hard is it to use HPtuner?
  160. Anybody know about D2 Lowering Springs?
  161. downpipe gasket
  162. turbo upgrade
  163. HELP turbo surging, and BOV not working
  164. catted dp issue
  165. help real quick
  166. K&N intake with trifecta tune
  167. 2 and 3 steps colder plugs
  168. whos gonna try it?!
  169. Building boost in neutral
  170. Meth/LNF Engine
  171. LNF GMS1 Upgrade Kit
  172. Car has been boosting weird....popped hood and saw...
  173. GMS1 Spliced and Heat wrapped
  174. does any one have a pic of the underside of our valve cover?
  175. dynoed today, im happy
  176. Opinion's on a DownPipe!
  177. where could i get strong axels?
  178. CSS Members that have experienced a boost leak chime in!
  179. fuel pump
  180. Treadstone Performance LNF Bolt on's, and Stage Kits
  181. silonoid on intake mani
  182. 09 chevy cobalt SS TURBO FUEL question
  183. Hesitation and Boost at idle Issue!
  184. Stock Turbo PSI??????
  185. solo performance exhaust
  186. electric cut-out HELP!!
  187. How far can you push the stock clutch with a tune?
  188. Meth kit or Turbo
  189. Different Boost spikes
  190. Finally got dynod!!!
  191. for all of you with the trifecta tune.....
  192. questions about high revs.
  193. E-3 Spark Plugs
  194. Wheels actually slowing me down?
  195. what mods to do when i get my taxes?
  196. 3b projector lights
  197. At the track with stock turbo...
  198. tranny fluid?
  199. Question for LNF owners
  200. meth ?????ss!
  201. Interesting Problem
  202. Upgrading turbo
  203. ECU tunes and detectability / warranty
  204. Best Exhaust?
  205. Here we go with the bolt ons...
  206. Performance upgrades
  207. Tune questions
  208. Warranty question
  209. Anyone see Matt's prototype dual injector setup?
  210. Treadstone Stage Packages Released! Looking for Main Sponsor On Stage 3 kit
  211. Getting a Trifecta Tune ?'s
  212. Crazy Steve or MPx intercooler
  213. 2.2 and LNF = do they have the same Crank Damper?
  214. MPx IC Long term review
  215. GMS1 Combos
  216. ZZP PCM Install
  217. gms1 sensors
  218. Just got dyno'd and the numbers seem low
  219. Data logging equipment questions
  220. LNF Build book?
  221. My New Dyno Numbers!!!
  222. question about E-break!
  223. quick question about BOV on a bigger turbo
  224. brake dust covers tpms reset
  225. Fastest SS on the boards!!!
  226. intercooler install
  227. What a day
  228. Treadstone Performance releases 3" Catback Exhaust System
  229. Tune Me?
  230. boost is spotty?
  231. Gas....wont start?
  232. need help wit launching!!!!!!!!!!!!
  233. Treadstone Performance LNF Turbocharger Bypass Valve Block off now Available!
  234. changin heads
  235. white smoke???
  236. By chance does any have before and after MPx intercooler gains
  237. charge pipe gains?
  238. so guess what hapend today!?
  239. What to buy next
  240. crappy dyno day with zzp kit
  241. Boost pressure sensor? GMS1
  242. Charge piping and Maf question!
  243. Exhaust question
  244. clutch issues...suggestions?
  245. 0-60, 0-100, 60-100, 1/4 et calculator
  246. Drewbroo's unbiased Tunes review (Superchips, Trifecta, Term HP, BYT HP)
  247. change oil before dyno poll
  248. Blown =(
  249. Change oil before tuning?
  250. P2188 code
