PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36
  1. highest boost for 20g lnf
  2. Strut bar Question!!?
  3. dashdaq
  4. Any Negatives With Muffler Delete??
  5. Injen / CIA "Cold Air" Intake Guys - In Here!!!
  6. Ported Turbo manifold
  7. OTT 304 Stainless CB?
  8. Which aftermarket air intake fits the best?
  9. Welded 14' Magnaflow Muffler On
  10. Help me get the right cobalt
  11. Honing 02 housing
  12. gas mileage with tune??
  13. got tuned last night
  14. Factory Muffler.....
  15. wat other parts are in the making
  16. Trifecta'ed stock, now buying more parts...
  17. Wideband...
  18. 1-2 shift issue. More like annoyance...
  19. Need advice
  20. Troubles with Intakes
  21. Regarding Intercoolers...
  22. I hope this doesn't mean bad news for us.
  23. Catless Down Pipe
  24. Option B bolt
  25. ss/sc catback fit an ss/tc
  26. TTR Motor mount tighten to specs
  27. CIA Catted downpipe GB Feeler
  28. About to get tuned!
  29. any one have "exhaust depot" down pipe or charge pipes?
  30. cel p0100 help
  31. LNF Agency Power Performance Exhaust
  32. where can i get a reconfigurable performance display???
  33. putting a muffler on a side exit exhaust
  34. few questions
  35. EXEDY Hyper Single install!!!!!!!!!!!!
  36. question on Dejon BOV Spring....
  37. turbo upgrade!!??
  38. Possible Max for High Pressure Fuel Pump?
  39. Anyone with dejon charge pipes???
  40. quick turbo question
  41. An SS/TC Without The Turbocharger!!!
  42. S-Max Balt Intercooler Pics!!!
  43. TTR Upper engine and Tranny mounts???
  44. Upgraded Oil Pan
  45. DP...Hahn VS. CIA VS. ZZP
  46. ss/tc owners with a second pcm!!!!!!!
  47. new parts under the hood (Caution Large Pics)
  48. fabricating rear lip exhaust cut-out
  49. Fuel Delivery/Management Upgrades For SS/TC
  50. taking bolts off stock exhaust flange
  51. Oil??
  52. Dyno tuned with synapse stage 3 kit
  53. Feeler. Dual exhaust. vidz?
  54. anyone heard from magnaflow?
  55. My first CEL Code. Help
  56. Next upgrade
  57. hahn ppc tuner then upgrade question
  58. Hard lesson learned
  59. side exit exhaust
  60. misfire at 12k mi
  61. Put my Hahn 3" exhaust on today :-)
  62. hahn delete plate
  63. second gear sychros gone. 20k miles
  64. Dashhawk
  65. Injen CAI
  66. 316whp 341wtq @ 21psi TUNE only
  67. Anyone have the catless CIA downpipe???
  68. clunky tranny solution??
  69. no boost CEL on
  70. Cant decide?
  71. Got tuned
  72. Injector interest build up!!!! Post up!
  73. Noisy transmissions???
  74. E85, Who's done it? Anyone yet?
  75. Video of Dejon Intake+BPV Spring!
  76. Rim question
  77. Intake or Drop in???
  78. Hahn Exhuast Install
  79. Map Sensor Question
  80. new Ss/TC falls on its face
  81. 284whp 326wtq @ 20psi tune only
  82. Free mods, Weight Reduction??
  83. Injectors
  84. mandrel exhaust systems
  85. more power please
  86. SS/TC rear sway bar
  87. rear brake locked up
  88. is this for real??
  89. Pcv Valve
  90. Um....
  91. Ignition coil cover for LNF?
  92. do i need a new map sensor if...?
  93. ecu swap question
  94. Straight Exhaust Pipe Dilemma!!!
  95. Made 345 whp 375 wtrq On the stock turbo.
  96. Turbo Kits
  97. Wanting More?
  98. Sportlines. Any real upgrade on T/C
  99. Misfire/ESC/Rear brakes = at the dealer
  100. knock/misfire problem
  101. Race Intercooler?
  102. FYI GM puts IN WRITING Powertrain Warranty Void if Aftermarket Cal is found, cause..
  103. What a kick in the bag...
  104. hahn ppc tuner
  105. muffler suggestion??
  106. weird problem
  107. Cab Fuse Box Removal?
  108. Hahn CAI Problem List
  109. pros and cons
  110. programmer
  111. Anyone have the Hahn PPC Tuner?
  112. LNF Throttle Body Swap Testing
  113. Hahn CAI Flaw Solved!
  114. Aftermarket map sensor?
  115. Cutout for exhaust
  116. jus launched my friends 09tc
  117. Price difference in down pipes
  118. Intake and tune??
  119. Just got tuned - Will it affect NLS?
  120. Need help deciding on an intake!!!
  121. Has anybody put in a cooler thermostat?
  122. cheapest axleback for sound?
  123. any one with a spec clutch
  124. college graduation=mods
  125. Dejon catless DP w/cutout
  126. Lets try one big exhaust thread...
  127. Intake Camshaft Sensor.....any GM techs out there?
  128. Pulse plugs...
  129. dejon spring upgrade question
  130. shifting into 5th
  131. Crazy new kind of turbo( idk what its called help me out)
  132. LNF fuel system
  133. launch controll bogged out
  134. Hey ya'll....
  135. what possible damage could i do???
  136. hahn cai pvc hose coming off problem solution....testing
  137. Too Rich?
  138. Need help deciding
  139. Dejon Intake Install Help ASAP!
  140. side mount exhaust
  141. what size air filter on hahn intake
  142. RPD package being installed
  143. Why do all ss/tc exhaust setups kinda..suck?
  144. 3.0 to a 2.8 pulley
  145. 255/35/18's?
  146. how to increase boost
  147. Brand New SS/TC Leaking???
  148. Nearly Stock dyno and Trifecta Tuned dyno
  149. INterceptors
  150. Opinions please...
  151. upgrading stock turbo?
  152. Dejon Intake/Spring Install Guides!
  153. Fuel Pump Voltage
  154. oh noes...
  155. taking off the downpipe
  156. Ca Dual Cluster Bezel
  157. Blow through MAF
  158. Next Upgrade?
  159. It Has Begun!!!!!!
  160. A/F ratio question
  161. got a new BOV and charge pipe, few question
  162. have a question on a redline oil change
  163. Quick Info On Peoples tunes
  164. what kinda oil do u use?
  165. dose gmpp have a exaust out for us?
  166. Water/meth question
  167. anyone.....
  168. breaking in new lnf motor 2009
  169. header/mainfold question for ss/tc
  170. C.e.l
  171. hahn downpipe install just put on....
  172. Catless DP?
  173. Cross Drilled and Slotted rotors
  174. Wiseco LNF Pistons In Stock with Pics
  175. K&N drop in
  176. Sky redline charge piping?
  177. Stock boost?
  178. is there any point? (tire)
  179. Did Megan Racing release the catback for the SS t/c yet?
  180. Hahn Parts in canada???
  181. wire diagram
  182. boost controller or tune?
  183. Bigger turbo
  184. Those with external BOVs
  185. Wheel HP/WTQ?
  186. Plugs
  187. Tuning Help Please!
  188. Clear Image DP
  189. Question about a dashhawk
  190. HELP Headlights from modern performance
  191. Aluminized + Paint = ????
  192. GM Stage Kit question.
  193. What should I do?
  194. no power in ACC...help
  195. line rubbing intercooler piping?
  196. Dejon intake...
  197. Sprint Booster Power Converter
  198. Learn down /DP Question
  199. BSR Tune
  200. AF Ratio Signals
  201. blown turbo....
  202. Premium gas vs Regular gas
  203. trifecta tune...
  204. Dejon Spring Upgrade Question
  205. how badly did i break my car?!
  206. car randomly won't build boost, help please
  207. Local Tuner
  208. Installing S-Max Intercooler & CrYo Kit
  209. hahn charge pipe install
  210. injen charge piping
  211. best rmp to shift
  212. Help!!! Wierd little problem
  213. wiring diagram
  214. Intake and turbo inlet size
  215. Trifecta Tune....I knew this was coming :(
  216. Track, launch control, overheat
  217. Trifecta Tune Only...1/4 Mile
  218. Question need help
  219. Wot???
  220. tmw short shifter question
  221. Whats your oil?
  222. OOOO, AAHHH Shiney
  223. Psykotune question
  224. SS/TC= or not = SS/SC Supension?
  225. ECU Swap
  226. Temperature results of Stock vs cold air vs short ram
  227. gm wont fix brakes!!!! what to change???
  228. SS/TC Interceptor/Wideband questions
  229. Official Turbo Swap Thread
  230. Cheap or no?
  231. if my charge piping pops loose...
  232. Boost on Trifecta Tune
  233. when is my car broken in
  234. White SS/TC in Glens Falls NY on Highway
  235. What would it take to beat a c5 vette?
  236. Map Sensor Question
  237. max speed in each gear
  238. Down pipe problems
  239. 55 shot on a LNF?
  240. HP tuner in south florida...
  241. downpipe install
  242. 09 ss/tc with NO tune pushing 18 psi
  243. top speed with trifecta tune?
  244. Mph Each Gear???!!!
  245. Clutch Slip?...How well is yours holding up?
  246. Anyone with Cams yet?
  247. A Pillar Guages?
  248. Dejon Short Ram Intake, Charge Piping, BPV upgrade
  249. running lean at idle... (boost leak?)
  250. weird noises in new TC
