PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36
  1. Superchips Flashpack
  2. dyno results
  3. lsd?
  4. now its fast (trifecta)
  5. ecu flash
  6. Ottp Motor Mount Pics
  7. CIA or Hahn Downpipe?
  8. 09 Turbo Boost issue
  9. Clear Image Intake
  10. So two pops means what?
  11. runing fine? rich? lean? HELP!
  12. Custom 3" exhaust ....
  13. Noob question about no lift shift
  14. boost problems
  15. LE5--->LNF. Purchased a SS/TC
  16. Running to lean at idle
  17. Dejon Turbo Upgrade question
  18. Oil around intercooler piping
  19. question bout catless dp
  20. stripped bolt
  21. will 245 40 fit the stock tc rims?
  22. 90 Days Till Cobalt LNF Upgrade Kit !!! YES!!
  23. Mounts for this LNF!??
  24. ss/tc modding
  25. noob question
  26. Tire?
  27. RPD package
  28. my Psykotoon
  29. Stock Turbo Info?
  30. Intake/DP/mount
  31. HOw to install APEXI turbo timer?
  32. trifecta tune Miami,FL
  33. Nitrous Express N-tercooler Kit
  34. Clear Image exhaust!
  35. Eibach Sway Bars
  36. Looking for a good tuner in Utah
  37. Trifecta Tune Experience and Review...
  38. got dynoed today
  39. Race gas question
  40. cobalt ss/sc vs tc
  41. Question to computer tuners
  42. Hahn Charge piping question
  43. Another satisfied Trifecta tune owner!
  44. CIA DownPipe Install
  45. Learn Down Feature still present w/ GM tune!
  46. Finally Got My Car Back!!!
  47. Which tune for me?
  48. TC Brake help
  49. Hahn PPC Tuner
  50. Boost/Burn Questions
  51. Lnf Pcm?
  52. boost gauge and check engine light?
  53. Just installed Hahn CAI
  54. Anyone but these on their SS/TC yet?
  55. New Intercooler
  56. Stock charge piping
  57. MAP sensors
  58. Is Magnaflow gonna.....
  59. bored with the tc
  60. Aftermarket LNF Forged Pistons
  61. Dejon CAI????
  62. Best tuner?
  63. Check Gas Cap when I get on the the throttle. Any Ideas?
  64. TTR Solid Upper Engine Mount
  65. Is this the correct flange for the dp?
  66. check engine light, car runs fine. anyone else?
  67. stainless or alumnized downpipe?
  68. How many miles do you have on your LNF?..So far so good? (4/13/09)
  69. Issues with Hahn Intake and water/meth
  70. Hahn Intake=Teh Sex
  71. Really Confused Here Need Some Opinions
  72. Adding mods to aftermarket tunes... any gains?
  73. Injen Intake System!!!
  74. K & N drop in waste of time???
  75. My turbo cat-back with a video
  76. For Those With Trifecta Tune
  77. Check engine light
  78. Stock Turbo Question
  79. Intake with Warranty...
  80. Competitive Mode Button
  81. Will rear brake pads from and 08 fit the 09?
  82. Radiator Please Help!!!
  83. will catless downpipe pass emissions
  84. is it worth it
  85. 08 lnf cyl head pn#
  86. Limp Mode Check Engine Light
  87. clear image downpipe
  88. 300whp+ near stock
  89. Calling anybody with a Tuned SS/TC with dyno results!
  90. Crankshaft Position Variation Relearn
  91. service esc
  92. wtf!!!!!!! have WAIT for down pipe
  93. 3 questions for the tc
  94. Looking at doing a turbo swap.
  95. Tune and Methanol Injection
  96. someone convince me.. or i'm an idiot...
  97. Misfires - Injector Cleaner
  98. downpipe install dificulty?
  99. Down Pipe
  100. best clutch for the money?
  101. best downpipe for the money?
  102. ss/tc clutch question with mods
  103. Gutting out second cat??
  104. Intake intsallation help
  105. insurance stage kit question
  106. Need advice on what to do for my first $2000 of mods
  107. Q on charge piping and intake cooling
  108. everybody, check this line
  109. Brake Pads
  110. exhaust jdm style
  111. Good news!!!
  112. Trifecta and "Learn Down"
  113. Can;lt Get Last Bolt On Stock DP Off HELP!!!!!
  114. Trifecta does it again!!
  115. LNF o2 sensor removal
  116. twin turbo the LNF?
  117. twincharge ss/tc?
  118. Do I need more than 1 TUNE?
  119. Crazt steves intercooler
  120. bov spring upgrade
  121. rear mount TURBO?
  122. Stock intake breather broke
  123. misfiring
  124. Lsd Help!!!
  125. Intake now, or wait for Clear Image?
  126. NEED HELP who has had their rear pads and rotors done by the gm service department?
  127. 09 ss wheel fitment info!!
  128. ZZP SS/T Dynos 403 WHP!
  129. Stock Boost Levels......
  130. The biggest upgrade????
  131. The biggest upgrade????
  132. Electric cutout
  133. Factory Airbox Mod
  134. Can we fool the "Learn Down" feature without touching the ECU?
  135. Boost Normal?
  136. I feel like a whore....(with the car)
  137. Help: Sway bar link
  138. Cia Boost Tubing Install
  139. Max power engine can hold?
  140. looking to upgrade somethings...
  141. map issue!!!!!!!!!!!!!!!!
  142. Intercooler CO2 sprayer
  143. Dejon Ic piping
  144. aem air intake
  145. Question about mods
  146. how do i get the trifecta tune?
  147. Trifecta Tune INSTALLED!
  148. People using slicks on TCs
  149. Just installed Injen CAI.....
  150. clutch pedal squeaking
  151. what parts can i use from the cobalt ss sc
  152. Question about stock LSD
  153. Can't get the valve cover off
  154. Question for those with the Dejon intake.
  155. 57 Trim???
  156. Trifecta Tune Question
  157. Dejon Inake in!
  158. First set of upgrades?
  159. SS/TC airbox mod
  160. turbo upgrade packages???
  161. Dejon Downpipe
  162. Torque setting for valve cover?
  163. what else do i need?
  164. Does race fuel help?
  165. Exhaust Systems.
  166. Mustang And Dyno Dynamics Dyno Results
  167. turbo out let size
  168. New Dyno Results.
  169. BSR tune?!
  170. about to blow my car up
  171. Homemade Short Ram Intake? (Thought Experiment)
  172. hahn charge piping help
  173. ss/tc CEL
  174. How much wheel HP are you going for?
  175. Injector Pump Noise Reducer
  176. Oiled vs Not (K&N v. AEM)
  177. After the tune
  178. Choko Please Come In!
  179. who sells cams and where can i get them?
  180. Excited
  181. Excited
  182. SS/TC Performance&Accessories
  183. who bought the cobalt in greenville sc
  184. Shifter install prob
  185. Question from LA Area
  186. Question
  187. ok i seriously need help
  188. turbo is out
  189. mods from the forum classifieds
  190. Bought My Amsoil 5/30 At A Store!!
  191. triple interceptors.....
  192. started disasembly
  193. Intake problems explored
  194. Cronis misifre code P0303 resolved
  195. Front pads
  196. hahn charge piping help
  197. t bolt clmaps
  198. Gear Shifting Feel
  199. Intake Cold Air/Short Ram
  200. Spark Plugs, upgrade?
  201. Has anyone down this?
  202. New Here, Getting Cobalt Nxt Wk
  203. Tuned Cobalt SS vs. Modified Evo X vs. 87 Buick GN
  204. Gm Stage Kit + Some Supporting Mods, Bad Idea
  205. New Stainless Downpipes
  206. Hahn modpipe with electric cutout (video)
  207. what is
  208. anyone got ark exhaust on tc
  209. Your Downpipe...
  210. what to get?
  211. Spring is here!
  212. Quick LSD question
  213. LNF takeouts for sale?
  214. Flashing CEL after NLS=Fail?
  215. who sells
  216. Inteceptor gauges
  217. Ss/tc Oil And Changing Frequency
  218. Which One First???
  219. Looking For..
  220. Differences between a 91 and 93 octane tune
  221. where can i get?
  222. help please
  223. Another Intake Concern help pleasse!!!
  224. 1st to 2nd gear grind NLS
  225. intercooler spray
  226. Have any "Tunes" caused Drivetrain / Engine Failures?
  227. Hid Plug And Play Kit Or Projector Plug And Play
  228. Straight Pipe
  229. Hahn Vs Clear Image
  230. the best two performance upgrades????
  231. questions about the temp
  232. my new hahn intake
  233. Recirculating BOV
  234. Cant Keep Spark Plugs......
  235. Electric cut out
  236. Synapse Engineering BOV
  237. short ram intake or full cold air? lnf only plz
  238. Switch clutch from car to TC?
  239. Cryogenic intake system?
  240. Everyone with an oil leak near the cam sensor come in here!!!
  241. high flow cat vs no cat ss/tc
  242. Anybody Wit A Modded Computer
  243. Pipe came off
  244. Cruze In Show Rooms By 01-01-10
  245. installed today
  246. Slow Tach?
  247. Intake Issue!!
  248. Off Road DP Question
  249. Just got back from the dyno
  250. twin charged LNF???
