PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Random misfires on LHU with rich afr on pulls
  2. low rpm lean condition
  3. Smoking issue
  4. What turbo 600whp+?
  5. Running rich af idle code
  6. Parts I will probably have for sale
  7. Throwing check engine codes
  8. Big thanks to Powell Race Parts!
  9. wastegate solenoid
  10. 09 Cobalt T-map issue
  11. 09 SS/TC Downpipe
  12. accuracy of this meth info
  13. Clutch Slipping after new clutch
  14. Locked steering wheel need help
  15. No Start After Clutch Change
  16. LNF replacement axle source
  17. How has everyones luck been with LDK block?
  18. Bankrupt..clutch pedal fall in the bottom
  19. LDK Cobalt SS only boost 5 psi
  20. Is the K04r worth it?
  21. 09 SS Overheating
  22. 09 SS P0087, P2196 and P2097, P2177, P2196, P0303
  23. Help with P0037 O2 heater code
  24. Turbo flutter or surge
  25. fuse
  26. p2188 and p0191? Fuel Pressure
  27. LNF Stock Boost Gauge Questions
  28. How much play is too much?
  29. ZZP Clutch Rod
  30. turbo recomendatios
  31. intermittent turbo flutter
  32. Need Help
  33. 4t45e to F23 swap on LNF
  34. LNF injector type and fuel control system
  35. Link Force ECU
  36. Z54 and Forge BPV
  37. 2009 ss/tc P2177 HELLPPPPP
  38. Fluttering and boost issues on fresh LHU swap
  39. Looking For A Good Remote Tuner
  40. Boost Issue LNF
  41. Hks bov
  42. E85, conflicting information
  43. Eng pwr reduced
  44. F35 question
  45. KMO43 tune is bitchen!
  46. Coolant Temp/Speedomoter Issue
  47. Engine sputtering before hitting red line
  48. Walnut blasting
  49. need e47 tune!
  50. Oil cooler delete?
  51. Intermittent noise near valve cover
  52. New clutch, any suggestions?
  53. Help. Thermostat removal
  54. Need help!! Over heating problem
  55. Fuel trim issues / Running lean
  56. hit curb hard enough to crack front splitter. Can’t build boost. No idle
  57. Tuners in Alberta?
  58. stuck in open loop
  59. LNF/LDK head on LTG short block ???
  60. High RPM misfire when mapping.
  61. P2101 and p0606. Help
  62. Modified RFL Exhaust
  63. Stock 2009 Cobalt LNF Turbo Inlet Size
  64. Tuning
  65. Limp mode!!
  66. Zzp hpfp
  67. New turbo on LHU, which one to choose
  68. LNF bad piston/ring. What should I do next?
  69. Throttle body install
  70. Lnf black spark plugs, running rich and blowing sensors
  71. What is this noise?
  72. Stutter or Misfire underload? Unsolved
  73. P0088/P0089, building boost at cruise speeds
  74. Performance coil pack
  75. Is the GMS1 still available?
  76. Ideas wanted, rough running LDK LONG
  77. HELP! My LNF is suddenly making more boost than before
  78. LHU Swap
  79. Are there any cons to disabling P0011 & P0014 err codes
  80. p0108
  81. Blown Head Gasket or Cracked Block
  82. Engine Tick? 09 LNF
  83. Need another engine: LNF again or LDK?
  84. LNF Rebuild
  85. Multiple codes and fuel trims went to max
  86. HELP PLEASE!? - Cant seem to get a definitive answer!! (BPV/Solenoid/Spool)
  87. LNF Traction Control button and Dash piece
  88. B&M Shiftplus
  89. LNF Boost Control
  90. Turkey Gobble after ZFR install - Please help
  91. 09 SS/TC, hesitation / ABS issue ???
  92. Intermittent Boost leak
  93. Upgraded turbo help
  94. average $$ for dyno tuning?
  95. gms1 sensors wiring
  96. Limp mode Cels Help LNF
  97. Both fans not turning on when ac is on
  98. 450hp stock block
  99. Steering Column Part # Differences
  100. Engine codes, any and all help would be appreciated
  101. Vacuum/boost lines + bpv solenoid: what goes where?
  102. E85 Filter???
  103. P0343 Help
  104. Pcv system questions
  105. Powell v.3 oil/air separator with s256et, setup help
  106. TTR intake manifold
  107. Aerospace Interceptor users, a question
  108. Turbo discharge at low throttle input
  109. P0326, knock sensor
  110. P0221 - but a little strange
  111. Big Turbo Stock Motor?
  112. What do I do next?
  113. Coolant temp
  114. Weird noise questions
  115. What the hell is wrong with these people?
  116. Flex Fuel
  117. zzp downpipe er other brand?
  118. Need help with cursed car
  119. Head gasket, sleeves? Is she dead?
  120. fuel question
  121. Major computer issues-U0073
  122. boost issues help needed
  123. Huge amount of oil in cylinder 2 and 4
  124. Losing Oil New Turbo
  125. LT4 Fuel Pump
  126. BPV Solenoid failure
  127. How much psi a forged LNF/LDK can hold ?
  128. no boost very low hp
  129. TurboXS RFL - Exhaust Leak
  130. Charge pipe fitting
  131. Dual exhaust?!
  132. pics of powell aos installed please
  133. quick question
  134. 2008 ss only boosts to 7 psi, only happens occasionally
  135. Car hesitate to accelerate
  136. Second time posting
  137. GM Stage kit
  138. Timing chain
  139. 09 cobalt issues after turbo install
  140. Need help regarding what to do with my turbo
  141. interest in lnf throttle body spacer with meth port(s)
  142. Electical Probem PLEAS HELP!
  143. Running car without an O2 senor
  144. boost problem
  145. Boost controller or wastegate actuator
  146. Trifecta logs
  147. 303 WHP 325 Ft Lbs ---What Clutch ?
  148. What do you guys get in the way of missfires
  149. In tank pump electrical question
  150. 08 turbo ss trouble codes p2187 and p013a
  151. Turbo question
  152. Boost Solenoid!
  153. P0335 & p0331
  154. Safe lnf build
  155. Rebuilt motor P0016/P0017
  156. P0497 and P0234
  157. Some more questions
  158. Z06 HPFP testing on LNF
  159. More Power
  160. How to Install GlowShift Oil Temp Gauge?
  161. Need a new green spring!
  162. Lnf p0449
  163. Dejon Spring info.
  164. Car stalled when accelerating
  165. Grinding in second gear
  166. No choice but to build now!
  167. I need a personalized clutch recommendation
  168. Changing Front Rotors
  169. 2008 saturn sky redline needs a tuner
  170. 3 bar MAPs p0236
  171. racing seats
  172. P2187- Lean on Idle Assistance
  173. 108k Miles on LNF, installing ZFR, should I timing chain?
  174. New Product: LNF THROTTLE SPACERS
  175. Quietest 3" Exhaust ?
  176. Is my timing chain stretched?
  177. First upgrade, more to come.
  178. ZZP Z54 Turbo info
  179. LDK build thread, version 2.0
  180. K04 wastegate nut size
  181. Turbosmart Type 5 BPV open or closed at idle?
  182. Cam Phaser Not Reading
  183. Turbo Gaskets
  184. Rear O2 sensor not ready
  185. 2010 SS surging and loss of power
  186. Oil and coolant turbo lines
  187. LHU block off plate
  188. Update on Colodude's 2017 rebuild
  189. Who sells viton fuel injector seals these days?
  190. S252 vs KO4r
  191. LNF Meth Injection Ideas
  192. Zeeky420 build thread
  193. Pulsating boost gauge
  194. oil pressure sender in ldk block
  195. WR-3 Boost Issue
  196. Replacing water pump?
  197. ZZP Tube w/ stock airbox vs K&N SRI (no airbox mod)
  198. ZZP fuel pump rewire kit
  199. LNF/LDK turbo oil feed fitting thread
  200. Vac no Boost
  201. Problem after zzp intercooler sistem install.
  202. wastegate help
  203. Pressure Test Charge Pipe Leak
  204. Opel Injectors
  205. What do you guys think.
  206. Boost Issue
  207. Engine or turbo issue?
  208. Boost Problem please help!!!!!!
  209. HEEELP! No boost.
  210. Turbo Squeal
  211. New LNF engine
  212. Chaange oil
  213. Car will not start!
  214. P0807
  215. P2228 What is it? Why would someone get this?
  216. Sudden massive power loss and lots of misfire codes?!
  217. LNF Coolant banjo size
  218. Water in oil. Needing advice from experienced LNF mechanics.
  219. 388HP/415lb/ft Gobalt SS Turbcharged Spec Video!
  220. 09cobaltss/tc wont start after cam replacement and valve cleaning
  221. 2010 LNF won't start after f40 install
  222. LNF jumped time need help
  223. Ryan's ldk build
  224. LNF "Rebuild"
  225. Green spring for a forge bov
  226. Need some advice for turbo upgrade
  227. P0087 and P0089 codes
  228. Question about my cars BOV Setup
  229. Turbo flutter with k&n sri
  230. Bolt
  231. Anyone else have trouble reading dipstick?
  232. ko4 replacement...
  233. new LDK long block, which cams LNF or LHU?
  234. Recommended ecotec oil pressure
  235. Mod recommendations?
  236. Lash adjuster removal
  237. Cold and doesn't want to run
  238. LNF Fuel Thread
  239. LNF Subaru Sound when cold
  240. PCV routing with 20g
  241. Lifting Points
  242. Nitrous on my LDK
  243. LNF timing nightmare :(
  244. 3 bar map sensor wiring help?
  245. Looks like I need a new engine
  246. Forge BPV leaks air around the outside seal. Test yours
  247. Project "impulse buy" 09 SS Sedan.
  248. Something let go on the Cobalt tonight...
  249. Attention, Ohio LNF Owners
  250. zfr turbo
