PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. How exactly does the Trifecta Tune Work??
  2. Installing ZZP Catless downpipe
  3. Braking sound problem?..
  4. Catless DP Trouble Fixed!!
  5. snow perormance NITRO BOOSTER?
  6. Stage 3 Exedy Clutch
  7. Stage 1 OTTP mounts with trifecta??
  8. Headed to Track Tonight!
  9. having some boost issues??
  10. Spark Plug question
  11. Any Hahn Coolram Owners Switch To K&N SRI
  12. SS/TC Cylinder Misfire
  13. They Call Me Godly's Build/Progress Thread
  14. so happy bpv diaphram arriving tomorrow!!
  15. *REVIEW* - OTTP Rotated Trans Mounts
  16. Any input?
  17. Code P0100
  18. Aftermarket Intercooler for more Ground Clearance
  19. Too much boost, wooshing noise
  20. lsd?
  21. BYT tune?
  22. running like crap after a long road trip
  23. Gmpp
  24. new down pipe
  25. best intercooler?
  26. megan racing
  27. Car feels slow any ideas?
  28. RPD Accuracy...
  29. E85
  30. found more broken sh!t
  31. 85 Degrees 100% Humidity=PO234
  32. 1st serious issue with my TC
  33. Meth install problems.. before and after
  34. k&n intake install
  35. Our intercoolers need more protection
  36. 2009 cobalt ss/tc cel light HELP
  37. Thinking about GMS1...
  38. turbo swap question
  39. brake line crush washer
  40. Can an Hahn intake rub low end torque? (vid TC without bolt-ons vs bolt-ons..)
  41. New Brakes
  42. SS/SC tranny mounts on T/C
  43. Oil Line Help
  44. ahh code p0236 help
  45. Breaking up after NLS->2, CEL flashes.
  46. So,whats the deal?
  47. P013E with ZZP Catted DP, solutions?
  48. METH Injection
  49. bov bop ...no boost what happened?
  50. Spark Plugs
  51. 1:30 Appointment
  52. Can you K&N SRI with AEM Dry filter?
  53. What should I do next?
  54. K&N Sri Filter Position
  55. normal??
  56. time for a new turbo
  57. motor mounts
  58. Brake fix?
  59. K&N SRI installed, Football mod, Bushings
  60. intercooler or meth
  61. Upgraded rear break question
  62. question about warranty
  63. how far can i push the zzp kit
  64. funny BPV noise + K&N intake
  65. could my incorrect plug gapping cause my car to run rich?
  66. What would you do? GMS1 then Trifecta or just Trifecta
  67. very basic HPT question
  68. aftermarket parts for sale
  69. fuel trims
  70. dejon intake vaccum line connector question
  71. ZZP downpipe O2 bung question
  72. ZZP canned tune or GMS1
  73. Aerodynamics
  74. Where is the vcm?
  75. Purple Hornies?
  76. re routed vac line from can
  77. urgent! problem with car!
  78. zzp vs injen charge pipes
  79. What exhaust
  80. GMS1 dyno w K&N intake
  81. Final Verdict on K&N Intake
  82. spark plugs
  83. people with blow off valve please come!
  84. Installing meth kit
  85. SS/TC stock exhaust size
  86. Kind of a stupid question about clutches
  87. ZZP Uppercharge pipe install question
  88. PCM, hypotheticly speaking..
  89. Where is BTF????
  90. Solenoid Issues (Whatever you want to call it) Revisited
  91. k&n intake vs. injen intake
  92. Dynoed the GMS1 at Car Craft 2010 in MN
  93. Terrible fuel economy
  94. New intake and restricted air flow? (pics!)
  95. click sound from car
  96. Blown motor. Rebuild time
  97. can you go from gms1 to trifecta
  98. buying a SS/TC thats hp tuned with mods.
  99. ? about zzp turbo kit
  100. hp tune
  101. Hp tuners vs. Trifecta
  102. LOOK what fed ex brought!!
  103. block off plate question
  104. c02 on your intercooler interesting
  105. GM CP question
  106. Superchips and Downpipe?
  107. Turbo Upgrade...
  108. Front Rotors
  109. Low compression ??????
  110. rpd no boost data available.
  111. People with ZZP Upper Pipe
  112. Here is an interesting article about a ecotec car going 99.7 mpg.
  113. buick regal cs going awd 255 hp turbo (lnf?)
  114. Charge pipe came off. Need advice.
  115. Radio has no powa!!!
  116. ALL manufacturers of MAF relocate
  117. Idle Problems?
  118. lnf meth.. is it worth it?
  119. Stg1 Tune file
  120. Help please!!!!!
  121. Boost Noob Needs Help/Suggestions
  122. My Upgrade Thread
  123. what is your boost gauge reading???
  124. Timing Marks ??????
  125. Boost leak (noob question)
  126. Coilovers vs H&R springs
  127. Turbo Manifold
  128. What kind of gains can I expect?
  129. lost 3 mpg injen install.
  130. Need Opinions and help.....
  131. MAF problems
  132. All those with Purge solenoid fails join in.
  133. help! newb problem
  134. injens cai vs other intakes
  135. E85 and/or CAM 2 for GMS1??
  136. WOT box install
  137. so whats new?
  138. stock MAP sensor..25lbs?
  139. quick question
  140. Best way into high 12's
  141. STS install...HELP!
  142. Downpipe thoughts
  143. Boost Poll
  144. GMS1 TMap sensor bolt question. HELP ME PLZ! thx
  145. Intercooler advice...
  146. GT3076R Kit ?
  147. Fuel pressure fluctuation at idle
  148. Superchips where are you?
  149. Lowering the Balt
  150. Exhaust length?
  151. zzp charge piping
  152. engine issues!!!!!!!!! :/
  153. btf
  154. Where are the IAT sensors?
  155. Lifetime powertrain warranty
  156. coupler size at turbo inlet
  157. possible solution to false KR
  158. noob question!!
  159. Dealer/GMS1/Warranty bull$!@%!
  160. Stage 1 install question
  161. Tire ?
  162. Recirc line questions
  163. What should I gap my plugs at
  164. Bolt ons with HPT tune
  165. Stage 1 t/c, loss of power
  166. What Meth Kit?
  167. In need of a Mod! Advice needed.
  168. Everyone having issues with gms1 chime in!
  169. How much HP do you think ?
  170. need advice!!!!
  171. turbo flange
  172. Shifter...
  173. I'm scared
  174. Need More Power!!!
  175. P0236 Turbocharger problem
  176. 2 quick NLS and performance display question
  177. LNF turbo manifold
  178. Gms 1 lower sensor
  179. LNF 3 bolt flange
  180. Headlights
  181. E85
  182. mpx downpipe
  183. Bracket cracked on factory pressure piping (photos)
  184. 5 Speed upgrades MU3
  185. Has anyone had a cam position sensor go bad?
  186. recently bought a 2010 cobalt ss
  187. Oil leak at 2000mi?
  188. agghhh. Pacesetter! damn you!
  189. Finally Ordered Stage 1 :)
  190. wont go above 5 psi today!!!!
  191. Going for a tune
  192. rpd question
  193. Boost Question?
  194. cheapest fix for our loose and sloppy trans/drivetrain
  195. Starting issue
  196. ZZP catless DP is coming!
  197. question about void warrenty/GMP Tune
  198. 02 sensor defouler (try out test)
  199. How would I up my compression?
  200. Basic Cone Filter Swap?
  201. NLS Advice
  202. need help installing A/F gauge (cheap one)
  203. Po107, no data on the rpd!
  204. SS/TC Key Stuck in Ignition
  205. Wheel hop? How do I know if i have it real bad?
  206. need i or should i retune
  207. Running 25psi solid.
  208. catch can
  209. a little help clearing things up please
  210. bolt on mods after GMS1??
  211. This was shown to me, so I figured I would share it. Not sure if its old or not.
  212. boosting to 7psi
  213. Idk whats wrong? please help!
  214. Problems stock
  215. rear spring issue
  216. No you dont need to be in comp mode to nls !!!!!
  217. Do I have to be in Competitive mode for NLS?
  218. stock and running close to 20 psi
  219. One step closer to my 2010 TC!
  220. Headlight Intake
  221. BTF Link
  222. Big purple turbo
  223. think someone will make...
  224. in an effort to clean up the engine bay..
  225. Will the o2 sensor affect the performance w/o the o2 bung?
  226. hks block off flange?
  227. Cp
  228. throttle body coolant line
  229. Genuine Saab charge piping (or others)
  230. Gms1+cai?
  231. Interested in Tuning?
  232. Trifecta tune on stock TC
  233. Broke the bank and joined the ranks
  234. 07 ss 2.o supercharged
  235. T3/T04E question
  236. Dyno results gm stg 1 , k&n intake, Dp, charge pipe
  237. check engine light with hahn intake need help.
  238. Byt*ss*turbo is an a-hole!
  239. Best Charge Air Piping?
  240. Basic Help Needed..
  241. 5th gear gone
  242. ZZP Downpipe Q
  243. LNF MagnaFlow Exhaust
  244. Catted vs. Cattless DP
  245. GMS1 Track Results, Not Impressed
  246. CEL; Cylinder 2 Misfire?
  247. Top teir gasoline.
  248. HELP Ignition Key Stuck - can't get key to release
  249. Looking for Norcal turbo/fab shop
  250. can't decide
