PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36
  1. Cat-back
  2. need help friends car is missing!!!!!
  3. Major misfire problem
  4. Hit the track again going for more 11s...
  5. whats data logging
  6. am i the only one
  7. 4TH gear doesn't work, then it does! What's going on?
  8. wish me luck
  9. Knock
  10. neeed help changing brake pads on brembo lnf
  11. real world numbers for trifecta tune
  12. is anyone jealous of new mazdaspeed 3?
  13. mandrelexhuastsytems.com
  14. Want more quite exhaust.
  15. Holy Crap!- ANOTHER question about the GM STAGE KIT!!!
  16. GM Stage Kit - yet ANOTHER question
  17. I want a loud exhaust
  18. Help please
  19. BOV installation process and recommendations
  20. do all SS cobalt's have LSD and a Short Shifter
  21. Twm sts
  22. pros and cons of cut out?????
  23. intersting build could use some help..lol
  24. Has anyone actually observed knock on RPD?
  25. WTF is wrong?
  26. Putting an LNF engine in a LSJ cobalt: Is it feasible?
  27. update to blown turbo
  28. Do not buy clutchmasters it will not work. I just got screwed.
  29. infiniteboost run and dyno!
  30. is there a how to on hooking up a manual boost controller?
  31. Leaded race fuel?
  32. tranny
  33. Best Intercooler?
  34. bpv
  35. Superchip vs misfire
  36. Painting LNF valve cover
  37. GM Stage 1..parts or tune?
  38. Electronic Boost Controller for the LNF
  39. Clunking noise
  40. Redline
  41. muffler delete fair price?
  42. Anyone with hp tuners have an lnf stock tune i can use?
  43. Exhaust?
  44. Wiring on a Blitz i Color Spec S HELP!!!!
  45. Gt3071r
  46. part help
  47. GMS1 tune
  48. My Stock Dyno Run
  49. Charge Pipe Question
  50. WTF just happened.
  51. widening throttle body
  52. down pipe
  53. Help! Who has upgraded clutch. Probs with my clutchmaster stage 3
  54. $5000 budget
  55. After GM Kit(s)
  56. hks bov werid noise
  57. 3 inch exhaust no resonator or muffler SS/TC?
  58. K04 turbo
  59. leanin out
  60. Plug in Pigtails for LNF upgrade
  61. PLX dm-100
  62. exhaust
  63. P2237
  64. HPP Tune warranty void?
  65. Intakes, What a mess, and downpipe update
  66. supercharger info
  67. rags to riches
  68. ZZP Catless DP w/ MD vs. ZZP Catless DP Magnaflow Muffler VIDZ
  69. Tuned by BYT*SS*TURBO, Holy shit, Holy shit!!!
  70. Limited slip differential install on 09 turbo SS
  71. K&N air filter?
  72. Help, Turbo question!
  73. Water/meth pump startup
  74. Catless DP ?s
  75. infiniteboost dyno! (323.3whp/404.4wtq!!)
  76. just bought clutch masters stage 3!!!
  77. Problem with my Cobalt
  78. what aftermarket clucthes are out for the t/c
  79. superchips chime in.
  80. airbox mod
  81. GM turbo upgrade kit. Is it out yet?
  82. Down Pipe Question
  83. How much boost?
  84. should i get the stage 3 clutch now or later
  85. exhaust
  86. what to buy next
  87. Any1 Notice This?
  88. bald turbo freak turbo upgrade
  89. Transmission
  90. Trifecta tune or GMS1 for TC
  91. does anyone else have this problem
  92. Oil leak analysis on my '09 TC
  93. ground kit?
  94. brakes wearing strange
  95. Mandrel
  96. Clutch Advice. Chime in please
  97. whats the difference on gmpp exhaust.
  98. Calculating Actual Power Made. Challenge me! lol
  99. High Boost Kit
  100. Gas fill up
  101. Easy Kil
  102. Want motor mounts
  103. New Turbo and Summer Tires
  104. put put during warm up?
  105. mod questions
  106. oil leaking out
  107. Some questions regarding Charge pipes
  108. best intercooler
  109. Clarification on the GM Stage Kit
  110. Epic Day At The Dyno!!!! (331WHP/393WTQ Stock Turbo!!)
  111. Pig Rich.. Injen/DP
  112. optimal shift points for power?
  113. Any sound clips with 3" catted dp and magnaflow/ borla muffler!!
  114. 2010 Cobalt SS ride with GM Stage 1 kit (with pictures)
  115. Loosing Boost at higher RPM's?
  116. help with ttr poly trans bushing
  117. first ss t/c with cams
  118. Dual Output Exhaust?
  119. Mild transmission clunk when shifting?
  120. stage 1 kit seriously?
  121. GMPP STAGE 1 Kit - Where are the gatherings ?
  122. 2010 Cobalt SS/TC Stage 1 test drive!
  123. Aeroforce interceptor
  124. Front crankshaft oil seal leak TSB.
  125. Meth on 91 octane
  126. Hahn Coolram Intake Underrated?
  127. cherry bomb
  128. cherry bomb
  129. cherry bomb
  130. Safe to Install Downpipe?
  131. Hahn Intake Problem
  132. exhaust depot
  133. car wont start after intercooler piping install
  134. New Rear TC Rotors
  135. 91/92 vs 94 octane, anyone feel a difference?
  136. Twincharging an LNF?
  137. trifecta tuned ???
  138. So who thinks their intakes are messing up their car??
  139. pulled fuse = 10hp??? lol
  140. Is a thermostat on LNF necessary?
  141. pulley removeal and AZ hp tuner?
  142. Dynamat
  143. turbo timer
  144. need any parts?
  145. plx obd2 scan guage??
  146. exhaust help
  147. possible oil leak
  148. Coil pack issue?
  149. Problem
  150. Ecu help
  151. ZZP LNF Races Again- Mission Accomplished
  152. Downpipe
  153. rpm and psi drop suddenly
  154. Can someone tell me if I have g85?
  155. ZZ performance pcm reflash
  156. cat temps
  157. Ok, possible GB
  158. Occasional power loss when flooring it?....
  159. new to the site. have a few questions.
  160. Complete intake for more power?
  161. "Vent to atmosphere or not to vent to atmosphere..."
  162. Anyone know what this is about?
  163. Now we are talking
  164. is it possible?
  165. 2005 Cobalt SS/SC wanna make it SS/TC
  166. Boost pressure
  167. Stage 1 Custom Tuning
  168. MAP SENSOR p0107
  169. power difference between catless dp and highflow
  170. Why do Turbo cars make a "pssh" sound every time they change gears?
  171. Sweaty Valve cover
  172. Trifecta Infiniboost. First Video.
  173. Boost Not Available????
  174. Gm Stg 1 vs. Custom tune
  175. oil catch can
  176. Installed Stage 1 but I dont feel a difference :(
  177. over rev questions
  178. Problem with shifter??
  179. Accuracy of RPD w/ Tune
  180. 365 whp obtainable on stock turbo?
  181. NLS misfire.
  182. CIA SRI is on the car
  183. Confused on what parts
  184. K&N Drop-In MAF question
  185. Dejon intake Do you need a tune after the install?
  186. When to the track
  187. Would Dejon SRI Cause a Misfire?
  188. Deleted Cat?
  189. After Downpipe Install? Come in
  190. Injen charge piping rattle
  191. Intercooler Piping question
  192. Trifecta tune question??
  193. AEM vs. INJEN vs. HAHN
  194. cali. emissions on LNF
  195. Cold Air Intake - Cobalt SS TC plz post here
  196. cobalts addiction
  197. Hahn intake Problem
  198. Modding / Guages
  199. Just Bought Hahn Upgrades...
  200. CEL after stall
  201. Best Gas?
  202. Attn people with second ecu..need help
  203. 08-09 LNF Ratteling Down Pipe/Exhaust FIX
  204. Tune & warranty???
  205. ZZP Downpipe Review
  206. Ratteling DownPipe Fix Suggestions (anyone else with this problem?)
  207. Chips but no dip
  208. S-Max Intercooler Dyno Results!!!!!!!!!!
  209. rpd question
  210. Spark plugs replacement
  211. break pads
  212. Exhaust/DP ?
  213. Laptop OBD2 Scanner
  214. What to do?
  215. boost but no boost
  216. Anyone have a BPV part #?
  217. Aem intake bypass
  218. people with injen charge piping
  219. Weird Idling on startup
  220. first nls ever
  221. CEL and no boost in 1st...
  222. what di I hvae to do to install a bov on my 09 ss/tc
  223. Car running very sluggish
  224. block off plate with bov
  225. Tuned guys chime in.
  226. Misfire reading?
  227. New CatBack Exhaust
  228. How to make your LNF fast
  229. installed new trifecta tune
  230. Intense Racing Tune
  231. Ummm... Problem
  232. Mandrel Bent - Which muffler is best?
  233. New SS Cobalt/03-04 Mach 1, Cobra
  234. downpipe question
  235. aftermarket BOV on stock piping
  236. Hahn CP & BOV?
  237. best intercooler for the price?
  238. O2 Bung???
  239. Who's putting down what....
  240. Injen hot side charge pipe clamps?
  241. Issues with NLS!!
  242. What kind of intake?
  243. Hesitation when at WOT????
  244. Has anyone tried these??
  245. Best downpipe?
  246. SVC Tire monitor light
  247. Warranty with intake....
  248. Bolt ons
  249. Those of you getting or wanting the trifecta dual tune, have a ?
  250. Everybody who bought a short throw shifter chime in...
