- New SS/TC sedan club member!
- n2mb install on ss tc?? Question?
- What's the deal with cat warm up mode problem?
- AEM digital boost gauge???
- my K&n install
- New cam news...
- Just tuned the car. Few Qs
- modern performance, i love u guys but grrrr anyway
- Back to ZZP for round 2!
- valve cover vent hose
- 08 SS/TC Intake + Tune Suggestions
- torque specs
- Downpipe installation questions
- Lower MAP bolt spec
- Iphone 4 and blue-tooth
- At what point do you look at a new clutch?
- Muffler Delete
- LNF head flow benched
- ported tb
- zzp lnf upgrade kit
- optima battery guys
- So is my SS/TC the first to spit a spark plug out of the head
- anyone else have a really hard time with the Treadstone cold side piping
- What would you pay for this ss/tc??
- forge bpv
- 50 trim
- No boost spike w/gms1?
- Nitrous Set-up
- Gas Mileage on my 08 SS/TC
- Turbo flutter/surge?
- Muffler Delete (OR) Straight Pipe
- Clutch Capabilities?
- Engine PWR Reduced NEED HELP
- curiosity with boost gauge and screen with other options
- Fuel Trims
- Tuning software
- Forge bpv noise
- K&N SRI Problem
- cars boostin 30psi out of no where!!!!!!WTF
- Bypass Block Off Plate
- Methanol Injection
- lnf engine swap
- Buh bye K04
- Fluctuating AFR and weird idle.
- Car is running too lean
- oil pressure guage questions
- Cams Question
- oil pressure gauge....fixed
- And So It Begins - Another ZZP Engine Swap
- Finally ordered a damn intake!
- would i need a transmission?
- MPx Muffler delete video
- over revved the engine :(
- Where to buy Forge BPV?
- i want my parts
- SRI vs CAI w/ hydroshield
- garrett t25 on lnf??
- ZZP IC Fitment
- Cel
- Engine Code
- 44k 09' clutch question
- Dyno Tuning Kansas City?
- Hp/tq ratings
- Do i Need a bigger IC if i go E85
- Gm stg1 K n N and zzp dp
- T-bolt clamp inlet turbo size?
- 100 octane
- Vapor Canister Purge Valve
- optima yellow top quick answer
- killswitch
- Really need help me vs dealer
- low boost p0299
- just a few questions
- zzp 256 kit
- Need new clutch
- GMS1 question
- thinkin bout building the balt
- Zzp downpipe
- Would Intercooling Be Nessessary?
- obd2 cable issue
- What new tuning features do you want?
- P0299 :/
- THis has a LNF in it you say??? lol
- Need a new Clutch, idea's?
- urgent help needed.....installled clutch....car won't start
- The weirdest problem
- trifecta data logs
- bnr questions
- Plug change..
- ATI Turbo Balancer - short belt replacement??
- motor mounts vs tranny mounts?
- GMS1 Warranty Info
- ati harmonic super dampner
- Rate my wishlist?
- Where do I go?
- LNF Lash Adjuster/ Cam Follower failure info
- Estimated HP numbers?
- MPx 3" installed
- need coupler help
- All Hanh?
- Exhaust hangers for mpx exhaust
- Stage 1 Installed - lame
- Ecu
- Intake/BOV major issue
- New Exhaust too loud, how to fix w/out losing power
- Which makes more hp 116 octane or e85?
- interceptor scan gauge
- Bov sync issues?!?!
- borg warner difference from mitsu turbo on regal
- intercoolers
- Random misfire codes?
- BNR losing boost top end
- Snow Methanol Kit
- trifecta tune
- Dual gauge pod bezel
- Ky clutch question
- my 2010 ss/tc build
- misfire during NLS - embarrassing
- How to change LNF Transmission Fluid?
- Take a look at this..
- Cobalt SS LNF Newbie! Mods....?
- Thanks Rockenbach and CED !
- Another happy ky clutch customer!!!
- zzp downpipe
- ECM causing a shortage? Does that sound right?
- no boost and CEL
- treadstone tr12 kit installed!!!
- Leaking Turbo
- Potential BNR customers, step in!
- is this a good kit?
- ZZP Cam/Head/Tune or bullseye s252 extended tip
- Will the Zzp triple a pillar fit 09 turbo ss sedan?
- ZZP LNF Dyno/Mod Day Guest List / Poll..
- misfire from 1 and 4...
- Hahn CAI/BOV question
- Radiator shot
- How do you guys have your catch can ran on the ZZP Turbo Kit?
- Hahn PPC tuner??
- byt tuned
- Engine Break in thoughts? (Wiseco pistons, etc)
- BNR swap tomorrow!
- Radiator Replacement
- FINALLY. turbo swap time!
- Worth it to do S1 cams before the turbo?
- help treadstone stage 4 vaccume lines
- cam change gaskets?
- the sputtering is back
- new 2013 2.0 turbo = 259HP in the Malibu , 0-60 = 6.3 sec
- Trifecta..
- How do you guys CLEAN your fuel injectors?
- wot at 3k in 4th
- LNF exhaust
- What psi should our oil pressure read
- differences in crankshafts for our lnf's?
- wiring Gauge??
- Is ZZP still in business??
- The Official Treadstone Stage 4 Kit
- Gm compression specs
- 2.1 or 2.0
- K04+ untunable via Trifecta?
- trifecta tune
- car checkup
- synapse BOV installed w/ crappy pics.
- treadstone tr12
- need intercooler
- Tuned!!!
- Summer Tires
- Intake resonance?
- P2187 12PSI and what sounds like a boost leak???
- Pre-Tune Checklist
- 09 cobalt ss wont start
- Mirror covers
- Pedders Installed on Saturday
- Forge BPV starting to stick a little
- Pushing for 700HP!!
- lower charge piping???
- Parts Installed New problem
- The Dealership.. oil change... and HP tune
- Idea for ZZP
- Invitation (GMTech, CCSS3, Term)
- pink anti-freeze
- Need Help Intercooler!
- LNF Oil Pressure Gauge install
- 2 things. 1 compression test, 2 misfire
- Engine internals qestions
- Bnr 2871
- 2007 ss/sc to tc conversion?
- Quick Help Needed K&N SRI!
- part number needed!!!
- K&N SRI Driveability
- 2009 cobalt sstc reset oil change notification
- Anyone with a 3 pod A pillar move the stock gauge?
- SPL Dual exhaust website?
- exhaust question
- ZZP Intercooler!
- Noise, Bpv?
- Misfire
- Clutch cooked at 15k miles.
- Exhaust from hell!?
- GMS1 sensors
- Help!! P0140
- turbo charge piping choices?
- Problems
- Clutch
- flow rate of stock LPFP?
- what do you guys think of the BNR2871?? (rant)
- I need a tune!
- Me vs Evo 8?
- HP tuners?
- Power gains with 3" exhaust?
- turbo swap in t minus 2 weeks
- Ryan's play to win build
- 2009 Cobalt ss Reliability??
- Compression leak cyl #2................
- mod list, safe with tune?
- Bad alternator?
- Injectors and Lash Adjusters
- Possibly broke my intercooler today : (
- Who's Up fo an LNF Dyno/Mod Day?
- Tuning Help
- Fine, I'll join in too!
- ARC Cooling FIN!
- progressive controller
- stock K04 was actually gone!
- Charge Piping Question
- 110 Octane
- Intake
- afr for e85
- Installed the K&N SRI
- hoping for a little help
- LNF: Ported stock TB vs. 2.4 TB vs. 77mm TB..
- gms1 connector
- zzp fmic install
- Car Making Zero Boost
- Treadstone Stage 4 Dyno #.
- New Dejon Intercooler
- trifecta gone bad?
- Black smoke
- Stock Clutch?!?
- Forge BPV group buy?
- WTB Harness Bar
- Check your turbo coolant pipes
- RPM Jump in 5th
- Increased Back-pressure = Better MPG?
- Just a feeler for anyone interested
- Part throttle is really bad?
- Treadstone stage 4 install!
- 3 bar map sensors
- K&N SRI Best Filter Placement
