- LNF misfiring
- zfr vs WERKSracing WR-3 LNF Turbo
- ET Street Radials
- lnf low boost help
- Some new stuff
- A place for sharing & comparing different tunes.
- Anybody knows the part number for a wheel bearings?
- Downpipe questions?!?
- Anyone see the stage 2 LNF cams?
- Learn Down Question
- Need some help
- Sparktec?
- LNF need cooling fan wiring diagram
- Pte 5831
- Turbo XS Downpipe Rubbing/Hitting Under Body of Car
- Anyone run Hahn hotside pipes w/ TurboXS RFL bov?
- retro fit
- Cleaning Valves with Head off
- install zfr on 100k lnf?
- OTTP Intercooler Pipes Kit
- installing zzp dp after being tuned. need retuned?
- Parts for engine build
- Trouble Shifting
- Another broken 3rd gear
- Random car problems
- 3 gen 2.4 info
- hks bov
- Electronic Boost Controller (dyno tuning questions)
- Help with the brembo pins
- Brembo pins siezed. Any ideas?
- Brembo pin problems
- Front brembo pin problems
- Front brembo pins
- Front brake issues.
- Where to go next?
- She goes Boom
- Newbie question. 12.5s 1.4 mile
- LDK vs LNF ..Which one is stronger ?
- How much boost can stock LNF hold?
- HPT map request
- removing head lnf
- Anyone have any experience with a P0420?
- HAHN Company Issues
- LNF fuel efficiency with higher compression ratio
- hp tuners
- E85 FAQ Thread - LNF Specific
- PTE exhaust o2 housing
- TurboXS catback with zzp downpipe?
- LNF twin turbo anyone?
- P0234 Help!
- PCV Install
- V8THIS Big Power Solstice build tread.
- engine build
- Never put regular oil in your cobalt.
- helppppp!
- Need help :(
- Boost Gauge not working
- Low boost, to normal boost
- How to bleed a TOB"if possible"
- LNF "limp mode" engine pwr reduced
- one upgrade installed one to go
- BigBoost954 Motor build
- Faulty Crankshaft Position Sensor ?
- Help installing some parts
- boost gauge readings
- P0304 p0300
- Exhaust Questions
- For those with a Synapse bov...Question about your idle?
- LNF oil cooler hose routing
- Goes lean on stock tune.
- P0010+p0013 and boost issues
- ZZP Trans Mounts - Possible Issue?
- LNF big turbo cooling mods?
- trifecta tune slipping gears
- P0303 probelm
- P0091 ?? - Engine Power Reduced
- Spark plug boots and the Subaru sounding miss...
- Loud whine in first gear?
- need quick help with gas filler vent hose
- radiator mounting.
- Supercharger-like whine
- Need HELP with installation
- max slope per volt of LNF ecu?
- Trifecta tune redline changes
- Wastegate sizing question
- Upgrading the in tank fuel pump
- Im back with a new build ;)
- Future Build Sheet
- ZFR & Dejon Upper CP
- Sway Bar End Links
- Do Interceptor gauges accurately read LTFT?
- k04 rebuild kit?
- ZFR (aka Trans Killer) tuning questions
- There is always an issue
- Upgraded Turbo and Blow Off Valve Info
- LNF engine standalone running, now a question
- New owner of a Cobalt - Few questions
- Misfire when shifting quick or power shifting
- Clocking the K04
- turbo upgrade
- RIP LNF tranny
- Taintedred07's Blown Motor Future Build Thread
- Broke a Lifter today!
- EJ25 in a Solstice?!
- Troubleshooting Vaccuum leak? TB? Idk
- Catted Down pipe or Catless?!
- Anyone running an ldk?
- LNF HP Tuners Questions?
- Hahn Exhaust but ZZP Down pipe? Confused noob!
- Gen 3 2.1
- RPD VS. Boost Gauge
- Wow is this guy a member on here?
- Help with diagnosis
- Is 400 HP and TQ easily obtainable?
- Replacing pistons while engine still in car?
- lnf sounds liike airplane after water pump / balance shaft chain tensioner
- aeroforce interceptor boost read out
- megan racing turbo exhaust?
- OBD port splitter?
- Burning Oil Issue---Ideas?
- Old Tune/New tune issue
- EVAP,02, Cat-
- Oil Blow by / smoking issue
- Keep going to limp mode
- Any interest in smaller zfr?
- Anyone here running with an e-cut out?
- Dry filter to replace K&N Short Ram
- Whistling on high boost
- Shitty cold start
- AEM water/methanol injection kit
- New Build...
- S256et vs zfr turbo swap
- Downpipe+exhaust question
- What Do These Plugs Look Like ?
- SS/TC whine after installing new water pump
- Forge Bypass/Block off plate.
- Stock lnf cabilities? fuel system, block, tranny, etc.
- E85 vs M5 methanol for the compound build
- Gas tank purge solenoid
- ZZP Stage 4 Clutch?
- ebrake issue
- Having some trouble setting up Interceptor shift light
- Bigger turbo or e85?
- Catless downpipe cel question
- And then Fast Happened
- New option for meth?
- Rebuild With Gen 3 Block
- ZFR on a Solstice = WIN!
- Messed up gauges?
- 08 cobalt ss/tc need engine rebuilder
- Turbo fluttering noise and NLS misfires.
- Blown K04 Maybe?
- HELP : possible boost or vac leak?
- Looking for a mount/bracket
- Dynoed Last Night
- Trunk line meth routing opinions?
- 3bar maps = Driveablitly?
- Hahn CAI
- Auto Grimmig Radiator hoses
- Misfire codes at idle or crusing real slow. P0300, 0301, 0302 and 0304. Ideas???
- big turbo, stock clutch?
- After years of trying to fix the slowbalt, the turbo blew up.
- p0017 code help...
- P0501 & P0236 Intake vacume line
- factory vacc lines
- K04+ vs ZFR
- Car runs too cold
- Vacuum line help!
- Does adding a wastegate to a turbo'd car add any HP?
- Woo! I'm back!
- Borg Warner K04 Research
- Still more problems with the slowbalt.
- EVC 6 Install Question
- Need Bore Spacing for LNF
- maybe valve tap?
- Help with MAP/MAF values and car running poorly
- cobalt ss turbo 2008 problems!
- Does this sound right *video inside*
- Uh Ohh Moment...
- What causes shifter to center?
- stage 1 cams
- Opinions for turbo upgrade
- boost control solenoid
- zzp intercooler kit installed pics?
- ZZP boost regulator
- AC delete belt
- cut out vs catless
- Stock boost solenoid how to hook up lol
- ever have you turbo cut out?
- First day to the track
- Hey!
- stock turbo for sale
- custom grind cams for LNF
- Much important needed help with bypass valve stuff.
- Turbo upgrade(s)
- wierd noise in rain
- P0449 code won't go away!
- Timing chain?
- So a couple days before I installed K&N intake
- Meth users! A question!
- The itch has come back...
- Timing chain tensioner....again
- 7670efr?
- Stupid Boost Leak Found ! Help On Fixing it !?
- LNF Fuel Rail Part Number?
- Dyno possible w/trifecta tune in competition mode?
- New to this site
- How do I make these MAP connectors?
- kn sri / gms1 fuel trims
- Major problems, can I still use my warranty?
- code p0010
- Humidity affecting performance?
- question about fuel pump housing
- boost on stock turbo
- Super slow spool among other problems.
- Coolant issues
- wheel hub
- Charge Piping
- Trifecta load interupted,cable wont communicate now
- p2261 issues
- Need Help Please!!!
- looking to make 380hp
- Zmax
- Tune Maybe? Knock!
- K&N SRI DIY airbox: this thing works!
- P0011 & P0010 help please!
- 2011 buick LHU block handle ???
- Crank position sensor
- Re-tune after bolt ons?
- Question about doing my new motor
- FMSR vendor
- Snow performance meth help
- Knock knock again..I need some help here
- ZZP upgraded LNF fuel injectors?
- helllp!!
- SOLD! 2010 cobalt ss
- HP Tuner needed!!
- HELP: Having some fuel / sensor issues
- Tune/Knock Question. Possible Burst Knock
- meth?
- Main Girdle Studs?
- Limp mode on start up.
- EFR 6758 Build and install
- Those who use meth/alky injection heres a fun fact
- Engine Removal
- Code and repair help?
- LNF axles
- GEN 3 block
- how tight should you tighten tbolt t-bolt camps
