PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36
  1. t3/t4 turbo swap
  2. daaaam!
  3. Is this a newer Hahn intake?
  4. GM LNF Upgrade Kit Redline
  5. New Track Numbers for ZZP Turbo Swap
  6. Who has wot box on a TC?
  7. Accuracy of RPD
  8. Went to the track yesterday
  9. wtf is up wth my boost!?
  10. driver side mirror
  11. Map sensor
  12. HP tuners vs trifecta
  13. ecotechnik synapse turbo kit
  14. Trifecta gets it done: Fuel tables unlocked
  15. FWD vs. AWD Pull
  16. buying a 09 or 10 SS turbo. question about upgrades
  17. Anyone have the lowdown on turbochargers.com
  18. Misfire
  19. Anyone with trifecta tune only?
  20. Clutch Slip
  21. Muffler Delete
  22. Boost Cut + Alignment Questions
  23. Aftermaret intake problem poll!!!
  24. Whats The best LNF Intake ?
  25. Broken Shift Linkage Cause
  26. Just got new 09
  27. Look what came in the mail today...
  28. Calling Everyone With An AEM Intake for the SS/TC
  29. blacked out tail light help ???
  30. Where to get LNF kit installed in San Antonio, Tx.
  31. The Tuning School is looking for a Cobalt SS
  32. Important Question
  33. New Hahn Intake?
  34. Question for those who've done a clutch on a Cobalt
  35. P.o.s.
  36. what did i break
  37. stage 1 for $150
  38. stock ss/tc dp
  39. Strange issue on cold start-up
  40. k04+ questions
  41. Can we make 650 or 700 WHP LNF a possibility by spring 2010??
  42. Got a big slap on the hand for finding prices for cobalt members.
  43. broke shift linkage...
  44. Stock LNF Tuned by HP Tuners
  45. Available Flanges for GT28/GT30 series turbos
  46. Stage 1 badge emblems
  47. Will i need a retune??
  48. New Product @ TTR - Turbo Tech Racing BOV Block Off Plates!
  49. how to on hot side charge pipe with bov??
  50. intake question help please.
  51. sweet gauge cluster
  52. Built Motor Parts?
  53. Running rough and breaking up!!!!
  54. Hp tuners??
  55. Mods?
  56. IC piping
  57. ZZP downpipe and HP Tune
  58. need help with boost numbers.
  59. Another stage kit thread
  60. Security/comand start/car audio/ect...
  61. spark plugs for LNF
  62. What tool is required?
  63. Winter Floor Mats
  64. P0107....Again but this time....
  65. LNF head pictures needed...
  66. GMS1 Dyno'd!!!!
  67. Driving the GMS1
  68. Issue starting the LNF when adding fuel
  69. ss/tc back brakes...need suggestions?
  70. Atmospheric BOV, relocate MAF & Tune Re-map
  71. Lamborghini Gallardo vs 08 Cobalt ss/tc
  72. 2 small problems (HELP)
  73. Rattle under dash/apiller on pasenger side.
  74. Timing and head bolt tourqe????
  75. GM STG1 kit what is the dealer charging you?
  76. New Front TC Rotors
  77. diablo tuners
  78. buying a clutch???
  79. hahn CP with bov
  80. What is the problem?
  81. Correct OEM Front Pads?
  82. help
  83. maf relocation
  84. ZZP LNF Turbo Upgrade- First Dyno Session
  85. Is there a laptop program available to monitor ecu?
  86. WOT problem
  87. Best place to buy PF-457G oil filters?
  88. Help with these codes please!!
  89. The pill and vacuum tank delete
  90. ZZP catless DP install
  91. Ecu?
  92. Stock Manifold Flange
  93. p0451 and p0497
  94. lnf fueling issue
  95. Hahn CoolRam intake Cobalt LNF
  96. Automatic Transmission swap?
  97. HEEELP! its geting VERY weird!!!
  98. Broke shift linkage, rear breaks
  99. p0138!
  100. Anyone with Synapse intercooler chime in!
  101. TACH Not Registering Correctly!! 09 SS/TC 100% STOCK!
  102. Clunk Noise in steering column when going
  103. synapse turbo
  104. coolant question
  105. Throttle Body Clamp???
  106. Phones and USB Interface
  107. Bypass valve testing results.
  108. GM Stage kit Dyno proof
  109. Battery dead after 2 cold nights of setting.
  110. CEL for inefficient catalytic converter HELP!
  111. Boost Guage Malfunction
  112. clutch problems
  113. What would you like to see in your performance parts?
  114. LNF dyno sheets?
  115. Afr's
  116. what size is the axle nut?
  117. too good to be true?
  118. Colder Plugs
  119. Bolt on dyno numbers?
  120. Where does Bypass valve air return to
  121. Mandrelexhaust systems piping??
  122. problems with my kar ={
  123. T/C sounds like a wrx...
  124. boost controler
  125. silencer for a side exit exhaust
  126. What size intercooler would you guys like to see?
  127. Help
  128. building my motor
  129. Why is the LNF shifter so damn notchy?
  130. what vin digit shows lsd?
  131. keeping the exhaust more quiet during startup
  132. Slave Cylinder problem
  133. Clear Image Automotive Cold Air Intake Install
  134. Anyone order these rotors??
  135. whats crazy steve intercooler website??
  136. NEW MEMBER of the f'd up rear brake club!!!
  137. Blow off valve help...
  138. need opinions
  139. MRZ UD pulley install on LNF
  140. Gutting my cat?
  141. Hahn Catback Clunk?
  142. cold air intake
  143. Help with Wideband
  144. Cattless is CA?
  145. Bypass Valve fix/Possible Boost Mod
  146. Still waiting on the S1 kit, need advice
  147. Whistle During Boost! NEED HELP! Part2
  148. BPV Spring?
  149. Anyone used Marvel Mystery Oil for their Valves ?
  150. Plugs....
  151. Fuel pressure sensor
  152. Spectre Mass sensor
  153. exhaust cut out power gain??
  154. Clutch install
  155. Muffler choice??
  156. car fax history check
  157. Kind of a n00b
  158. GM sensors
  159. ZZ Performance downpipe
  160. NAPA Auto Parts can get rear pads and rotors for ss/tc
  161. New Owner With a Few ??s
  162. Bad rattle/knock on driver's side...
  163. GM Stage kits....
  164. Low cost clutch upgrade?
  165. car is back
  166. Keyless Entry clicker
  167. Ideas
  168. Spark Plugs
  169. Crazy Steve Install Pics
  170. GReddy type r, type s, or type rs...
  171. friends 09 sstc or evo 9
  172. axles
  173. Intake Idea...Maybe?
  174. Is anyone limiting boost in 1st gear?
  175. is this any good?
  176. Air Box to snorkel Foam
  177. Whistle During Boost! NEED HELP!
  178. infiniboost 26 psi rpd wacked out
  179. How many cats?
  180. cobalt ss/tc vs procharge SRT-8 300c
  181. Belt slip when using NLS
  182. 08-09 tc air box mod???
  183. major boost issues, and CEL
  184. plz help!!
  185. Is it normal for a turbo to have a little play at the wheel
  186. Anyone log an Injen CAI yet?
  187. Update to engine noise.
  188. muffler delete and downpipe anybody have a video?
  189. rattling noise
  190. how much boost froma 2871R can a LNF handle?
  191. rattle
  192. NEED HELP GOT A CEL p0107
  193. Kartboy Exhaust Hangers WOW...(LNF Exhaust Squeek Fix Part 2)/HOW TO WITH PICS!!
  194. My Interceptor broke! help!
  195. dejon bpv spring
  196. Thanks Tofu!
  197. SS question
  198. let me know what the out come will be
  199. BadBolt hahn 20G turbo? bro is this you?
  200. need answer quick
  201. Floater (rocker arm)
  202. 17 inch slick..will it rub?
  203. Vac Line?
  204. hks bov problems and questions!!!
  205. help CEL!!!! p2261
  206. Need all LNF guys help w/ wiring harness pictures:
  207. E85???
  208. Clutch/tranny question
  209. How many people are still waiting?
  210. Open Source Tuning?
  211. turbo
  212. stock CFM
  213. air intake
  214. infiniboost wont tune!!! help please
  215. Exhaust Cutout
  216. turbo sound??
  217. LNF powered track car
  218. Anybody else showing clutch slip in the cold weather?
  219. Downpipe bolts
  220. airbox mod ?'s
  221. Intake Mods ?
  222. 08 SS trans problems...?
  223. home brewed octane booster
  224. Why does hot lapping improve my times?
  225. Trifecta helllpppp!!!
  226. Trifecta tune+ Hahn CAI= NO COOLANT?
  227. what muffler????
  228. charge air pipping...
  229. cant get brembo pads off!!!!!
  230. stock turbo
  231. thinking bout picking this up
  232. i wanna go lnf meth need help
  233. snap crackle and pop on WOT gear changes
  234. cleaning lnf motor
  235. SAFC Tuning
  236. Stock Intercooler size??
  237. Stage 1 Upgrade ?
  238. rattling problem
  239. Shifter ball wiggling???
  240. Got stage 1 installed, and wow....
  241. Anyone with aftermarket intakes LOOK!!
  242. PTE 6057B turbo kit
  243. Downpipe effects
  244. Cat modification
  245. Just got my new exhaust on...!!!!
  246. Fluke?
  247. Odd issue with lnf.... HELP!!!!
  248. Anyone looking to get rid of your hahn intake let me know..
  249. What Size Turbo Kit Would You Want?
  250. Anyone selling parts for an 08 ss/tc+?
