PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Got problems with ldk
  2. HP fuel pump
  3. Timing Chain Retiming
  4. Weird throttle issue
  5. Blown turbo, upgrade help
  6. turbo xs downpipe powells rotated mount. go to put stock dp on and won't fit?
  7. Should I upgrade intercooler?
  8. Identify the flywheel
  9. Lnf downpipe
  10. Rotors and Pads
  11. LNF Horsepower/Torque Ratings
  12. Do anybody still making these ?
  13. steering rattle
  14. intercooler issue
  15. Tach signal for 5th inj
  16. K04 times, or K04+.. hell, may as well, why not Zfr or other turbos too? 30-100
  17. enlarged fuel pump lobe
  18. HKS SSQV Opinions??
  19. Auto LNF Dyno
  20. Which route should I go ?
  21. Fuel Rail Pressure after shut off
  22. Pro Tuning Lab
  23. boost issue.
  24. Equinox cam swap
  25. Ebay SS/TC catbacks and downpipes
  26. Brisk Spark Plug ?
  27. RIP Third :(
  28. zzp lnf DP issue, anybody else? Rear o2 bung too far back?
  29. how to keep exh gasket in groove on lnf DP install?
  30. need a tuner in phoenix
  31. Stage 1,2 and 3 LNF
  32. hp tuners/o2sensor/downpipe question
  33. boost problems
  34. random misfire help needed
  35. balancing shaft timing mark question
  36. looking for a full e85 tune
  37. My Solstice build
  38. Owl Chirping noise ?
  39. Is any of this normal?
  40. Looking for an intake
  41. Coolant Leak
  42. What parts after ZFR?
  43. Break in for ldk swap
  44. Is GMS1 really that shitty?
  45. 4.05 lsd
  46. Car did not do cat warm up on very cold start
  47. Possible Blow By?
  48. OTTP stage 3 mounts?
  49. boost gauge reading just under 0?
  50. charge pipe ans bov
  51. LNF Intake Manifold Help
  52. TOB Travel
  53. GM stage 1 mods!
  54. whp and trap speeds 93 octane,quietest catback?
  55. How much power does the ZZP PCM make with boltons?
  56. best exhaust for lnf ????
  57. ZZP LNF PCM Upgrade - Issues?
  58. Going catless without tune.
  59. Valve spring compressor for LNF
  60. Is this cyclical sound normal?
  61. My 08 TC build project
  62. Lnf map sensor problems
  63. Competition mode, switched power or ground
  64. Transmission help.. New to cobalt
  65. E85 worth it?
  66. Trifecta and Emissions?
  67. Bov and charge pipe question
  68. Method Injection Question
  69. blocking off rear pcv
  70. 1/8 Npt fitting thread amount
  71. treadstone manifold fitment question
  72. First Mods, GM Stage 1 DONE
  73. Head oil galley plug
  74. Are these 3 bar map sensors?
  75. Best motor mounts for lnf
  76. 08 lnf what is the easiest way to replace clutch?
  77. Moderate Jerking
  78. 08 cobalt ss
  79. Methanol Kit...
  80. Ingalls adjustable mount?
  81. Weird chatter when accelerating
  82. spark plug question/help!
  83. Issues with knock, semi rough idle, and Greyish Smoke after boosting.
  84. Looking to buy a used SSTC, concerned about porous block issues
  85. 100% stock LNF File
  86. Rough idle/stall. No boost/no power
  87. Installed the Powell Air/Oil Separator today
  88. How many running the LNF stage 2 cams?
  89. Custom CAI with paper filter
  90. LNF Injector Cleaning
  91. Zzp lnf pcm tune worth it?
  92. HP tuners 3 Bar Sensor
  93. my LNF build thread
  94. Upgrading engine internals
  95. problems with Opel injectors?
  96. hahn racecraft BOV help
  97. Running Rough Q's
  98. Oil galley (oil filter adapter) design, what goes where?
  99. Aem cai with zzp upgraded intake tube?
  100. High Boost High RPM Misfires
  101. HELP!!! Please
  102. Suspected air flow issue - suggestions?
  103. MAP Sensor Question
  104. Turbo or BPV issues
  105. ZZP tune help
  106. Car didn't do a cat warmup this morning.
  107. GMPP LSJ Clutch Upgrade For LNF
  108. ZZP stage 1 cam... Does this look normal??
  109. Checking out my CC/TC
  110. 3 bar map sensors
  111. Mysterious misfires
  112. :::(((( new motor
  113. The official "help Padlock get his LNF sedan running on a budget" thread
  114. zzp fmic question.
  115. zzp s256 for lnf
  116. engine prelube before starting new motor
  117. 09 Overboost
  118. Don't know which one!!!
  119. Getting a p2187code
  120. Looking to install 4.45s
  121. Idle Vacuum Level
  122. For all my friends on here that love me so much...
  123. Turbo Opinions
  124. Boost fluctuation?
  125. Possible porous/cracked block...Or just low coolant?
  126. Not building boost, but when i start up again builds up fine
  127. Looking for a good how to video on Valve cover, lash adjuster replacement
  128. Idle/Drive Rough and Bogging
  129. Pre and Post Spark plug analysis
  130. 2010 Cobalt SS turbo boost/intercooler issue
  131. Upgrade question opinions
  132. catted down pipe
  133. Central Ohio tuner shop
  134. Need some help
  135. Downpipe?
  136. Help!!!
  137. Is my pcm reflashed?
  138. Blue smoke at WOT
  139. Racoon causes Varying Turbo Boost Levels
  140. Zzp 1.0 pcm
  141. Trifecta budget tune power? Thread number 999999999
  142. Dilemma..?
  143. brand new ecu questions
  144. good mechanic
  145. What cause porous block ?
  146. Spark blowout during NLS
  147. Thoughts on all catbacks offered for the SS/TC
  148. new hahn charge pipe
  149. EBCM!? Anyone had this happen?
  150. Slow working 02 sensor.
  151. Random screeching at 2700-3400?
  152. Torque specs for cams
  153. I bet you can't figure this one out
  154. Engine mount question...
  155. Fuel rail removal
  156. Reusable Turbo Gasket?
  157. Denso TT Spark Plugs
  158. Looking to buy a tc cobalt.
  159. Powersteering pop up on dash
  160. oxygen sensor problems, I'm stumped
  161. Frustrating Boost Problems
  162. My build
  163. Planning on Modding - Need Help/Opinions
  164. Pressure plate bolts
  165. turbo xs exhaust on hhr
  166. Rebuild f35 or swap it with another? 4.45 gears
  167. Whistle/whine sound.
  168. My first dyno results :)
  169. Porus block patition to Gm for recall or warranty
  170. LNF and LSJ Clutch Disk compabilty
  171. Help Please
  172. Boost issue
  173. Interceptor annunctuator setup
  174. How bad is a injen cai with no tune
  175. GMS1 Map sensor adapters
  176. Upgrading to 252et..
  177. are these cars THAT bad on gas?...
  178. What is E47
  179. Running rich, misfires, RPD no worky, etc...
  180. Looking at 08 g85
  181. Boost Problem
  182. F40 vs F35 w/ 4.45 gear set
  183. ZFR Tuning questions
  184. Best clutch for zfr power
  185. Gen 2 block with zfr
  186. LNF K&N Filter Wrap Review
  187. Turbo Smart 50/50 BPV
  188. P0497 issue
  189. P050a
  190. E85 whp/tq
  191. Cam and crank shaft signal help.
  192. Rear brakes dragging
  193. Wot-tuning or BNR
  194. intercooler comparisons?
  195. Question on installing
  196. loose turbo heat sheild !! what to do ??
  197. ZFR replacement wastegate?
  198. E85 and Boost Question
  199. question about power gains (ss/tc)
  200. What are these for?
  201. Intake and exhaust cam codes
  202. Quick question
  203. LNF Rear Brake Squealing
  204. rpm drop very slowly
  205. front end gone on lnf !
  206. Buying a New LNF Alternator
  207. LNF tensioner maintenance
  208. Superchips tuner with GM turbo upgrade
  209. Rpd help
  210. Cobalt SS Ghost Cam?
  211. Limp mode
  212. omg zzp lower charge pipe
  213. Need help, cel
  214. p0304 when WOT
  215. Holset hx40
  216. front seat question
  217. mechanical bypass valve code help
  218. Let The Mods Begin!
  219. Quick Switch (TriFecta on DSC)
  220. No boost in 1st gear!!!! LNF
  221. Best all season tires
  222. Very close to buying a 09..
  223. MAP sensor 0-5v on LNF question
  224. Need opinions
  225. Need some help please, got codes and smoke
  226. 09 ss p0300, 01 02 03 & 04 codes
  227. LNF Exhaust Manifold Flange Dimensional Specs
  228. ABS + TC Lights = big power, why?
  229. Stock lnf exhaust With downpipe or after market exhaust?
  230. upgraded transmissions
  231. water pump bolt
  232. No Boost (unless I reset the battery)
  233. Heavy Duty Chain Tensioner?
  234. throw out bearing?
  235. Issues during acceleration...
  236. Help with a couple of DTCs
  237. under boost
  238. Clutch acting crazy
  239. GMS1 sensor soldering question
  240. Cobalt SS sluggish :(
  241. Line from cam cover to turbo
  242. ZFR Intake
  243. ZFR: medium or high boost canister?
  244. ZZP can tune
  245. LNF Valve Cover Vent lines.... Quick Question
  246. Stage 1 questions.
  247. What are typical MAP sensor readings?
  248. Knock Retard on stock tune?
  249. GM certified deal dodging work for a simple tune
  250. ZZP Silicone Couplers
