PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36
  1. What do I need to take?(GMS1)
  2. Torque to yield bolts
  3. Thoughts On All Intakes Currently Avaliable For the SS/TC
  4. People from Toronto come in
  5. a couple of hp tuner questions
  6. I need wheels!
  7. Recirculating my HKS bov
  8. boost controller
  9. Dejon Why?
  10. LSD question
  11. What would Cause my car to buck.......
  12. Check Engine Light....OH NOOOOO
  13. help!!!!
  14. Crankshaft wobble/deflection? Problem?
  15. gotta big race coming up help me make my car faster!!!
  16. looking for an lsd, can you help???
  17. Any advantages of tune on top of tune??
  18. Exhaust gasket part # needed!!
  19. lifter noise
  20. need some help with oil return line
  21. GMS1 problems/breakage
  22. Help with Charge Piping
  23. LNF stock clutch question
  24. questions about downpipes for lnf
  25. Brand new to forum, need to clear a few things up
  26. resonator
  27. Question about coolant temp???
  28. Compressor Wheel Upgrade
  29. does the maf relocate work???
  30. Fuel Line Pressure&Nitrous
  31. install parts
  32. F35 SS/TC Tranny w/LSD Fluid
  33. Blew my turbo. Please READ
  34. Air Bypass Valve
  35. performance chip help
  36. 1st gear boost on GMS1
  37. new 2010 owner.. gms1 compatible?
  38. ss/tc sedan?
  39. I need advice!!!
  40. bov
  41. 09 TC SS oil?
  42. Spec Stage 3+ ?'s
  43. Upgrades
  44. need some help on clutch please answer
  45. gmpp exhaust on lnf...
  46. Im A New Trifecta Tune Dealer In NC Area...
  47. Something is wrong..
  48. any cams yet?
  49. is there a lnf repair manual??
  50. New 3" cat back system from MPx
  51. downpipe
  52. What tune are you running (General Consensus poll)
  53. Downpipe...
  54. gmpartsdirect.com spark plugs
  55. front o2 sensor
  56. new pics of manifold prototype!!
  57. 2 more cobalts get trifecta tuned!
  58. boost bypass control circuit code, help
  59. tire pressure light still on
  60. P0107 = GMS1 for ummmm Free (at least for my friend)
  61. engine start button
  62. Saab 9-3 6-speed manual
  63. Whistle
  64. best sounding exhaust?
  65. im having a bov crisis!!!!!!!!! :(
  66. air box mod??
  67. Does this look like an oil leak??
  68. Buick Regal GS 2011 LNF
  69. Misfire? What happened?
  70. Tranny...fail and nosey tech......smh
  71. Name this part please
  72. Compatability question
  73. max power handling of stock TC
  74. Help please? (Tunes)
  75. LNF Compression
  76. Help on some info.
  77. Some Pictures of the turbo manifold ;)
  78. New O.E. Spark Plugs by NGK
  79. Upgrading the BPV system
  80. TTR STOP transmission mounts
  81. sport red tint coat photoshop request!!
  82. Best place in north Dallas to install a downpipe?
  83. Spec Stage 2+ Clutch & Lightweight Flywheel
  84. pipping and intercooler
  85. 114 hubs
  86. Stock Dyno Numbers!
  87. Note about FLATS in the Cobalt SS -
  88. Fuel System (Low Pressure side) on modified LNF
  89. My upgrade path
  90. ZZP's turbo upgrade is out
  91. Need help for BOV
  92. gm stage kit
  93. crooked seat???
  94. External gated stock turbo!!!
  95. best d/pipe with gms1
  96. In what order should I do these upgrades?
  97. installing hids
  98. what comes with gms1
  99. GMPP Sport Muffler only on LNF????
  100. Aftermarket clutch
  101. random misfire at idle
  102. 3 Inch MBE Exhaust Tubing Kit
  103. Error code P0107
  104. How hard is it to install gms1 kit???
  105. Spring Question
  106. built in garage door opener
  107. straight up open exhaust dump pipe
  108. Anyone have the ZZP Charge pipe?
  109. Flywheel Question
  110. Brake Painting Questions
  111. Just installed my Injen Charge piping...
  112. Brake Pads
  113. Help Please Need someones input
  114. 0-60 and 1/4 mile times with gms1
  115. o2 problem
  116. Best shipped tune?
  117. rear brake swap from camaro
  118. use antiseize on plugs or not?
  119. Quick question
  120. did the unthinkable.......
  121. people with synapse turbo manifold & people with turbo upgrade please come in!
  122. Rear brakes - EBC part #'s
  123. cold coolant line
  124. I need a turbo manifold!!!
  125. 1st CEL P0451 and Dealer Problem...
  126. coolant flush/ change
  127. Injen SP7027 installed
  128. dejon intercooler
  129. whats the difference?
  130. Tein coilovers for TC
  131. Anyone interested in running meth injection?
  132. help with a cel
  133. Timing chains questions!!
  134. LNF block
  135. Tire Pressure Senor Need Help
  136. exhaust o2
  137. LNF motor build
  138. GMS1 boost dip at 2500rpm
  139. What is the cooler below the intercooler
  140. Lowering Springs
  141. GMPP LNF Turbo Upgrade/Stage 1
  142. Need help.....I have a dilemma!!!
  143. little bit pissed off, need some answers
  144. im back
  145. AEM CAI flutter?
  146. coilpacks
  147. Fuel Injection Cleaning
  148. clear image automotive, CAI
  149. P0100 cel.... ?
  150. Service ESC?
  151. I sent an e-mail too...
  152. lossing power over 5,000 rpm
  153. quick intercooler question
  154. oil filter cap size
  155. 32,000 Miles = Trouble for my car....
  156. Clutch slave cylinder = Throw out bearing?
  157. clutch issues
  158. DDM wiring harness for my 09 Chevy Cobalt SS/TC?
  159. Turbo timer
  160. -22 celsius = 7psi!!!
  161. Even though it's winter...
  162. 3 bar map sensor
  163. O2 sensor replaced
  164. Any one have bwoody mounts?
  165. Does anybody have Injen CAI equipped in their SS/TC's?
  166. Does aftermarket downpipe void factory warranty?
  167. Am I Insane?
  168. brakes question
  169. My epic fail
  170. Oil Life Meter
  171. Anybody have the ageny power exhaust on there car yet?
  172. Steering help!!!!!!!!!
  173. who resells spec flywheel?
  174. Does anybody make SS braided lines for our cars yet?
  175. steering wheel chevy cap?
  176. need help with mods
  177. lnf fuel system
  178. power underestimation?
  179. Tune over the GM STG1
  180. Sorry Dejon Powerhouse, Review time
  181. Spark Plugs
  182. Stock Turbo Upgrade
  183. T bolt clamps
  184. Trifecta whereabouts
  185. Cold Start Issue
  186. wow lnf is getting boaring....
  187. do i have to tune with intake?
  188. Input Wanted!
  189. HOLY CRAP!!! look at this video
  190. Clutch and Flywheel.
  191. Launch Control question
  192. WB O2 sensor '08 SS/TC
  193. Couple New Mods.
  194. heat exchanger
  195. Changing Pistons....
  196. My parts list
  197. Another spark plug thread
  198. Spark Plugs
  199. Catch Can?
  200. SS/TC Caliper Piston Bushings?
  201. Piston Issues =... Forged Piston Group Buy?!
  202. CoT effect on engine performance?
  203. Changing my own oil.....
  204. LTFT and STFT question
  205. Problem with my halo headlights... need help
  206. knock
  207. shifting bushings help asap
  208. sounds like a wrx???
  209. Mechanical boost gauge
  210. What's the difference HHR F35 VS SS/TC
  211. 08 ss
  212. GMS1 settings....... rear brakes.......
  213. clutch installation question!
  214. Destroked
  215. My LNF rant...
  216. What size is the tubing connecting the cold and hot piping to the IC?
  217. Tools for LNF
  218. Another one bites the dust
  219. NEWB Exhaust install Questions
  220. cars only making 3 psi =/
  221. GMS1: only 7 psi boost in 1st gear. NLS sometimes doesn't work
  222. Anti Lag for LNF?
  223. Car Wont Start Help!!!
  224. Help! BPV thingy
  225. Dejon Intercooler Pics and Review
  226. ottp stg 2 mounts and ttr upper engine mount
  227. a/f ratio
  228. Do I need a new turbo???? Please HELP!!!!
  229. AEM Digital Boost Gauge Question
  230. Broken piston list
  231. Gm stage 1 backordered
  232. Would love to know who edited my thread
  233. Superchips Tune Problems?
  234. Best intake filter
  235. #1 ring lands go boom
  236. fuel pump went out
  237. GM Stage 1 + bolt-ons (yes I searched)
  238. Section dedicated to Tuning?
  239. Question about the ECU
  240. Quick Question
  241. tire question
  242. Max HP/TQ on stock motor?
  243. How do you "no-lift shift" properly without blowing your clutch?
  244. Anybody buy and install the gm stage 1 yet?
  245. Rough Idle
  246. 2011 Buick Regal GS?!
  247. injectors & sparkplugs question
  248. Whats everyones recommendation for spark plugs, being tuned
  249. Just curious as to what might have happened
  250. Hahn Chargepiping/Intercooler/Air Intake/Exhaust/Trifecta Tuned
