- I am officially in the 400+whp club thanks to ZZPerformance.
- How long does Vince take for your tweaks?
- New Borla exhaust - Want to learn more please
- K04 stock wastegate psi?
- Education request; LTFT, Spark Plug, K&N
- Trans Mounts - TTR, Powell or ZZP???
- White residue in coldside pipe and TB blade?
- New turbo?
- Anyone Ever Get Tuned By SSKEV?
- Trifecta Problem????
- My first mods and its going to be a good time
- Timing help needed ASAP!!
- Phenolic Intake Manifold Spacer
- Injectors & Boost question
- Car boosting 20psi in first gear, need help
- any issues withe the ZZP intake tube?
- Finally gonna build the balt
- Help!!!!!
- 1st gear problem
- IC piping question HELP plz!
- Another LNF missing an injector seal.
- quick question
- zpp intercooler pics
- ZZP EFR Turbo listed on their site....
- Ok, Zooomer told me that the .5mm Supertech inconel are fine
- check it out..
- Big turbo people or rebuild question?
- Trunk Lock Removal
- zzp intercooler
- options for an intercooler
- I need help, no idea what I'm doing.
- Bad Turbo Fins
- rpm ?
- GM Stage Upgrade sensors installed
- Dejon intake HELP
- Advantages Of Inconel Valves Over Stock?
- Thinking of a new bundle of mods...
- LNF Rebuild
- OFFICIAL Treadstone Stage 4 Install & Review
- Stock Turbo and cold air intake for sell!!!!
- Intake throwing codes
- 94 octane tune
- Anyones car feels "different" in the rain?
- eBay intake
- Turbo Timer
- Nice looking SS/TC Sedan
- Engine Build
- .043 gap and 25 psi...
- Having issues
- Pistons and Sleeves
- RPD not displaying boost pressure
- Bottomed car out , got it back on the road and went into limp mode WTF!?
- Intake help
- What the???
- using a mbc on a turbo swapped lnf
- catless dp
- ok.. need help picking one..
- Turbo Flutter
- Changing an Intercooler on the SS/TC
- Wiseco pistons k635m86 2.0l lnf turbo
- Forge bpv or bov?
- hellppp
- bout to trade it off
- flashing from e85 back to 91
- Typical compression test pressure expected out of an LNF?
- meth pre-turbo
- intercooler make more turbo lag?
- boost controller
- forge bpv
- Radiator rupture
- K&N CIA - opinions
- went with a mitsubishi turbo......
- how to use nls
- devils own stage 2 wiring help
- Treadstone intake
- black friday!
- Another TC with Possible porous block issue
- Grinding going into 3rd
- New Bolt-on EFR Video
- GMS1 Sensor question
- open downpipe/running too lean
- Brand new turbo, what's it need?
- Intercooler Burst and Denied Warranty and Carelessness
- Bullseye Power Batmowheel for Ko4
- Maybe More?
- upgraded from my lsj to a lnf
- PCV Hose
- Boost Leak?
- Turbo gaskets
- Does anyone know this bolt size?
- Wiseco Forged Pistons
- Bov?
- Which catback exhaust?
- Stock block record
- installing new k04 tomorrow!
- HP Tune and the infamous Dealer
- Misses real bad sometimes on Cyl 4 and not the coil or plug
- engine swap
- Sleeves
- Track Testing ZZP Motor and ZZP/EFR Turbo
- Matt at ZZP beats me to it.
- oil pressure at idle
- Turbo Cooling Hose Part Number
- Subaru Mod help!
- Finally got a balt, need a lot of help.
- Turbo question... Noob
- Help!!!!!
- Where to get connecting rod bolts?
- Vote for top Trifecta tuner:
- Free trifecta cable thread
- Final Vote for favorite remote HP tuner
- Don't remove bpv solenoid control!
- Catless with stock exhaust
- Oil life wont reset
- intake California
- Trifecta tune with K&N SRI
- LNF curious?
- NEED ADVICE - Injen intake with no tune
- FINALLY dynoed the car with the tune
- What happens if I put on my intake without a tune?
- tuning values
- Could really use some help here guys!
- Adjusting the waste gate for more boost?
- so i popped my turbo tonight....
- intake
- Squeak from new clutch?
- 501 whp
- 30r on stock turbo
- Zzp turbo upgrade guys...coupler question!
- muffler
- DDM Turbo Upgrade?
- my codes and my story help needed!
- p0299 turbocharger underboost
- Looking for ss/tc
- rpm's are off
- Lsd?
- CEL and acting up.
- Ticking under boost!!
- LNF Turbo Parts
- Soft brakes at 24k?
- Help!!!!
- G85-lsd?
- HHR SS, CAI any out there?
- ZZP Tranny
- Quietest High flow muffler?
- Rocker Arms!!
- Just a feeler.. anybody HAVE the ZZP stage 1 cams/head combo on their car?
- whats the deal with e85?
- so my local muffler shop did a delete for me today :D
- Shifter help!
- So what are you guys getting as far as airflow on the stock turbos?
- Need LNF upgraded clutch in a HURRY!!!
- Screeching when going into 2nd?
- I feel like my car is really slow
- Oil pump Broken
- spoiler hardware help.
- Injen Intake issue
- going from LSJ to LNF, what to look for?
- LNF ECM standalone unit
- new intercooler?
- Bogging/Will not NLS
- ss/tc front brakes help
- realabilty for 400-450whp balt owners!
- K&N intake fitment
- Switching to lsj brake
- svc tire monitor
- Just went to BYT
- Forge BPV installed w/yellow spring
- K04+ Damaged, is there a work around?
- Room mate put gas in my car....
- GMS1 help
- Is this a lasher or im stupid
- taking my car to a dealer for warranty work??
- LNF Turbo Restrictor Installation and Proper Wastegate Adjustment
- Having some issues with my car
- Anyone in Ny tri state area have a good dealer to install GM turbo upgrade stg 1.
- Pics of SS style hood
- Reservoir Overflow hose
- help hp tuner please
- New Functional Ram Air Hood for K&N LNF's
- ZZP LNF IC With Increased Clearance Option
- Pics of Meth Install
- Best Meth Kit?
- GM Readies New 2.0 Turbo Four-Cylinder for 2012
- Engine Internals
- Question about in-tank pump in our cars...
- Meth Wiring???
- Twm sts ?
- What do we gain with a port and polish intake manifold???
- DTC P2096 help???
- Help/Advice
- ruined my lnf tranny
- smoke machine leak detector results
- were to buy premixed water methanol
- Blown LNF motor?
- Random loss of boost, restart cures it.
- Competitive mode and throttle response
- is my turbo gone????
- hp tune
- many mods! but where to start?
- P0299 Dev: 05E8
- Turbo questions
- ZZP Upgrade 252et kit?
- Another EFR turbo kit option...
- Overheating Issues! Any Suggestions?!?!
- bov vacuum line problems
- Slight bump steer and noise in stearing colum.
- Tial bov
- turbo gone?
- Anyone have this?
- Problems with car!!
- Engine Tick?
- Resonator Recommendations
- Injen CAI
- TWM shift kit installed
- Wierd Spark plug Question
- changing plugs
- Seafoam Action
- LNF Wiring
- Wot issue...Sometimes
- Another Problem
- rawtekinc
- Low boost
- best tune
- Running hot
- I can hear an obvious boost leak...
- fried pcm tune?
- hp tuners in NY?
- best intercooler
- In need of a bolt
- N-Tercooler System, what's your opinion?
- maf seansor problem
- Several problems with my LNF
- Wanted - Cobalt LNF owner in Wilmington, DE / Philadelphia PA area.
- LNF Fwd and Rwd Engine Blocks
- intake probem
- Help!! Losing Coolant
- Project Time (input needed)
- sigh cobalt... lol help?
- Charge Pipes bov
- stock turbo compresor wheel
- stock turbo ?
- car almost blew up!!
- E-47 Dyno Results
- MAF relocation with meth?
- Need answers quick...
- These SS Brakes SUCK!
- Cold start sputter and stall
- boost issue - tried everything please help
- Help asap please
