PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Mobil 1 0W40
  2. got a scan gauge... see knock retard
  3. Tuners in CT?
  4. Am I hurting anything by installing piping w/out a new tune?
  5. Intake issues
  6. ATI Balancer ?
  7. 94 octane
  8. What up with my boost
  9. fuse box cover
  10. Ecotec 2.0 LNF Valve Cover
  11. Problems that may occur after a tune? Tuners chime in!!
  12. Best way to wire up boost gague?
  13. lower charge pipe with MAF relocate!
  14. Gms1 & k&n sri
  15. Boost leak or just the computer?
  16. Clutch slip in 3rd 4th and 5th under boost... sooo
  17. Power Stop Brake Pads?
  18. ZZP and BNR build
  19. Removing headliner
  20. Fastest GMS1 cobalt
  21. what plugs do you use?
  22. Bad Day on the Dyno :( help?
  23. BOV Option
  24. byt tuning
  25. HAHN 20G Turbo
  26. About to install a LSD transmission into my SS
  27. Cracking IC Questions?
  28. Fully Bolted E85 Tune
  29. LNF Breakdown Photos
  30. Mpx muffler delete
  31. zzp upper mount
  32. Thinking about buying a cobalt
  33. exhaust experts?
  34. 33k on stock plugs pic
  35. CCSS3 Tuned - Just got Dyno'd...
  36. devils own dvc30 help.
  37. Try this again.
  38. New Cobalt SS/TC owner, what to get
  39. LNF wot box help
  40. Lash Adjusters?
  41. Can someone tell me what I'm doing wrong?
  42. took off a bunch of stuff...
  43. Performance Autowerks K04+ Dyno'd
  44. Can ported heads cause KR?
  45. stock manifold question
  46. new turbo ideas
  47. So we're.....
  48. Turbo XS IC??
  49. Help please!!! Cobalt ss/tc will not start with maf sensor connected
  50. Running meth?
  51. Treadstone Stage 4 Turbo Upgrade Kit
  52. Exhaust questions.
  53. has anyone sent their oil for oil analysis?
  54. Clutch slippage
  55. rear clunking caliper
  56. Question about a catless DP.
  57. Question about my mods
  58. My SS/TC Sedan Build Thread
  59. bnr 2871 or zzp s252
  60. Intake vacuum line
  61. 2 Step Box for ss tc?
  62. Bad Cam Actuator
  63. Motor Assembly Pictures
  64. Crankcase Ventilation Block-off Plate for K04?
  65. p0100/boost leak/running rough
  66. t25 manifold question
  67. what is the wrx mod?
  68. LNF "factory oil leak"
  69. lnf head on lsj block
  70. Needing some help
  71. Pacesetter Header Install Cost Issue??
  72. Anyone got the specs on the o-ring for the GMS1 sensors?
  73. Greddy BOV problems
  74. MAF Relocate
  75. Torque Management
  76. Pumping Brakes = Air Fuel Drop?!?!?!?!
  77. wheel clearing brembos
  78. Ss/tc in oak lawn, il?
  79. Boost spike problems
  80. hahn lower ic pipe with meth bung
  81. A tertiary noise coming from under the hood.
  82. ZZP Fifth Injector Part 2
  83. downpipe install help please
  84. Tire help
  85. cat warm up
  86. Best Clutch for NLS
  87. Motor and Tanny Mounts
  88. Trifecta PCM Flash Questions..
  89. How do we get traction?
  90. heres a video of my new issue
  91. Things to get before a tune?
  92. oil pressure grrr
  93. ChevyCobaltSS3's tune response time
  94. BYT Tune Response Time
  95. Turbo LSJ help
  96. Looking for a tuner near the Gulf Coast!
  97. ZZP Fifth Injector.
  98. Lookin for an Exhaust setup
  99. Borrowed Hp tune is it gud?
  100. LNF zzp intercooler kit
  101. having an idle issue
  102. Spark Advance
  103. Should I install my intercooler?
  104. trouble starting after getting gas
  105. front tow hook
  106. LNF Oil Capacity Issue.
  107. can i go full E85?
  108. GMS1 From CED
  109. Exhaust Manifold Question
  110. How Bad is it Broken???
  111. Turbo XS Catted downpipe question
  112. Nothing in catch can?
  113. anyone want a hahn lower ic pipe with welded in meth bung?
  114. So mad at myself
  115. Should I have my intercooler welded up?
  116. batmowheel for k04 or bnrgt2871r
  117. Minor issues
  118. K04 oil... and water lines?
  119. boost leak
  120. forge bpv question
  121. Speedo vid!
  122. GM Throttle body service.
  123. Finally found the issue!
  124. ZZP s1 cams w/ big fuel lobe + PORT INJECTION = enough fuel for 80 lb/min?
  125. GMS1 Question
  126. Tuning issue (Trifecta) or something else?
  127. 1st and 2d Gear "Whine?"
  128. Cobalt SS/TC Charge Piping Reviews/Pictures
  129. Chevycobaltss3 + E47 = I Need A New Clutch
  130. Charge Pipes - Worth It? If so, which is the best one?
  131. tirers ?
  132. Oil leaks at 35K miles
  133. K&N drop in
  134. Southbend Clutch Vs. ZZP Vs. KY
  135. clutch pedal
  136. Help wanted on some info
  137. Stock Modification Help
  138. treadstone lower intercooler pipe.....pissed
  139. Intercooler Mock Up.
  140. intercooler choice
  141. Hks bov?
  142. A topic beat to death already D:
  143. Cobalt ss Tc Intake?
  144. hahn super 20g turbo?
  145. turbo timer help!!
  146. turbo whistle!
  147. I want one of these!! LOL
  148. MAP Sensor issues and injector seals?
  149. RPD Install ?
  150. Troubles with turbo xs charge pipe
  151. ZZP LNF Cam Back-order Update
  152. throw out bearing bleeding problem
  153. Exedy Hyper Single or ZZP Stage 4?
  154. BOV removal
  155. Should i run more than 23psi on my E47 tune?
  156. couple of brake questions
  157. in a jam
  158. Turbo XS Catted downpipe
  159. Blow by from around gms1 sensor?
  160. ZZP Hot Side Problem
  161. Excessive noise coming from Purge Valve Solenoid?
  162. Is this right?
  163. Rear Axle
  164. Lost boost but no CEL
  165. P0011
  166. MRZ crank pulleys
  167. No boost, cel
  168. Hahn Downpipe to Stock Cat-Back?
  169. Random low boost?
  170. Competitive Mode?
  171. fuel system
  172. Charge pipe color?
  173. No Idle, Now with video!
  174. new pcm needs calibration?
  175. Exedy Clutch
  176. Need Help With Tune/Boost Issue
  177. Rattle now after installing badmab dp
  178. got a treadstone intercooler TR8 for christmas... question..
  179. Intercooler Sprayers
  180. treadstone lower ic pipe
  181. boost gauge
  182. gaskets on downpipe?
  183. Blown turbo or boost leak?
  184. Motor bad already!!!!
  185. To those with Interceptor gauge(s) installed...
  186. open turbo?
  187. Header question
  188. Ported Compressor housing outlet.
  189. e85 on gms1?
  190. Whats the best clutch and flywheel?
  191. Standing mile results...POST'EM
  192. turbo options ....please help
  193. Rocker is still there but the roller isn't.....
  194. This Is How The Injen Pipes Should Have Come
  195. dyno
  196. Trifecta Tune/clutch slip
  197. K&N Typhoon Installed Pictures
  198. Rods/Wiseco pistons
  199. opionons on the BYT throttle body spacer?
  200. Brand New Unused K04+ for real this time!
  201. Possible Turbo Upgrade
  202. 3" downpipe opinions please
  203. THE absolute best Ecotec/EFR turbo manifold on the market...
  204. ZZP Stage 4 / South Bend Clutch
  205. 600+ hp
  206. Tip in KR and question about LTFTs
  207. i think she's back
  208. Mpx exhaust
  209. Treadstone or ZZP intercooler......... fitment & quality ... GO!
  210. Aeroforce Gauges Have Me Paranoid Now
  211. No Idle, please help!
  212. Busted Intercooler symptoms?
  213. 08 SSTC, Rksport Ram Air, K&N SRI?
  214. Who's no lift shifting
  215. LNF e47 injector limits
  216. NOS on the LNF
  217. Codes since HP tuned
  218. oil pressure
  219. How high can you rev
  220. Torque steer anyone?
  221. HP gain from trifecta
  222. Random nose over during cruise, hard to boost...
  223. Serp Belt
  224. LAF bottom end........
  225. Short Throw Shifters and Reverse Lockout
  226. Compression Test
  227. 5psi issue again with possible fix's?
  228. Intake camshaft oil leak
  229. ZZ performance Re-wire kit
  230. Trifecta Boost issue
  231. Boost Problems..........
  232. Ecu pcm ?
  233. ZZP downpipe
  234. Turbo Timer?
  235. Quick video of catless and catted LNF
  236. Odd code problem please help!
  237. Dual Disk Clutch Research Almost Complete!
  238. 1/4 times and hp estimate
  239. Lash Adjusters?
  240. S256et vs EFR 6758
  241. What tune are you?
  242. ACDelco EP1029 OE Service Mechanical Fuel Pump
  243. My bsr ppc tuner...
  244. Fixed a P2177 Code.
  245. Engine Mod Questions
  246. Thought this was odd...
  247. Efr turbo kit
  248. ZZP girdled block
  249. Trifecta Tune
  250. Oil Smell In Exhaust
