PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Spark Plugs
  2. Car rich at idle
  3. Has anyone had the injector tip break off?
  4. Intercooler help!
  5. My fellow members with the turbo xs fl exhaust
  6. Major problem 09 cobalt ss
  7. boost issue underboost ?
  8. p0016
  9. scondary o2 delete
  10. Theft/clutch relearn used pcm
  11. PO101 not quite
  12. po128 code.
  13. 3 bar map without retune
  14. Displeased with Performace Autowerks
  15. 2009 LNF Missfire issue
  16. P0101.... not a boost leak
  17. New LNF owner - some questions
  18. Tuning KR in cyl 4 only
  19. P2195 and P2096 - 2009 LNF Sedan
  20. clean throttle lnf ?
  21. 2010 LNF issues
  22. P0267 Injector control circuit
  23. Cold start issue and STFT
  24. Installing an LSJ in my 06 LT
  25. Where to buy LNF Injector seal installer tool?! EN 48266
  26. Route to 450+whp?
  27. Underboosting and AFRs all over the places.
  28. Is my sensor wiring correct please help
  29. Upper transmission mount
  30. Looking for a better hot side charge pipe with stock look
  31. GMS1 Kit getting installed
  32. Transmission
  33. Squeak noise
  34. issue with cold start
  35. tune
  36. For those with Forge BPV
  37. Best recommendation for simple tune for non enthusiast?
  38. Weird experience from a noob mistake
  39. Oil Advice
  40. Need help with cel! P2261-bpv
  41. Loud rattle on start up with VIDEO update. Please see
  42. Trifecta tune and spark plugs
  43. Unable to NLS.
  44. Turbo noise?
  45. Taller lash adjusters?
  46. Posting a video of a problem
  47. proper seondary o2
  48. KY Clutch Good/Bad?
  49. Loud rattle on start up
  50. Bought an '08 SS/TC with problems
  51. Leak down test
  52. stock lnf clutch
  53. Any LNF ATI damper users? Have a question.
  54. Issues with LNF with Vac and random KR
  55. No power and a flutter sound
  56. Bad idle.
  57. Powell Upgraded PCV system
  58. HELP please
  59. HELP! Code U0073
  60. K04 mod to make it last longer ?
  61. LNF Redemption Build
  62. Popping noise under acceleration
  63. CEL for Air/Fuel ratio
  64. U0073 Cel!!!
  65. 09 Cobalt SS TC - Serious Issues
  66. Is it worth rebuilding my lnf longblock? Cyl.#4 Piston ring is damaged.
  67. Linkage and shifting
  68. Need help with exhaust
  69. Flashing to stock from Trifecta
  70. Cobalt ss turbo air leak through PCV
  71. Please help .
  72. Joined the ZFR Team
  73. Engine Reduce Power after LDK swap
  74. Nitrous Setup Help.
  75. tuning Upstate NY
  76. Ko4 oil feed threads
  77. Meth Injection??
  78. Car wont start/crank/turn
  79. Just went HPTuned
  80. boost control solinoid issues
  81. some issues need help!
  82. Shift 1st to 2nd
  83. high pressure fuel pump
  84. P0442 ( Evap leak detected - small leak )
  85. Ecotec bolt pattern
  86. Help and opinions of the future of my LNF cobalt F40 Swap/ZFR
  87. Anyone ever get P0331 code ? If so, what did you do to fix it?
  88. Need boost help
  89. ATI pulley: honing required?
  90. LNF Wiseco Pistons stock rods
  91. Wiseco Piston install quick question
  92. Engine Power Reduced
  93. Loud squeaking noise at low rpms
  94. LNF need clutch expert and opinions
  95. Check out this vid.
  96. ZZPerformance engine replacement
  97. Rough idol and missfire under wot
  98. p2261 and p2177 problem!
  99. Engine replacement
  100. Porous engine
  101. Check Engine
  102. P0301 fireballs and lots of smoke
  103. Fuel pressure question
  104. Lnf problems :(
  105. Buying a used hahn 20g
  106. Dpt Motorsports (ebay) Catback exhaust anyone tried it?
  107. P2261 issues
  108. Hard to shift
  109. Zfr and clutch question
  110. Help
  111. GMS 1 Performance Upgrade Kit Install
  112. Forge bpv
  113. boost guage not reading
  114. Terrible Missfire
  115. Alrighty people, car going back together soon.
  116. Forge BPV
  117. Turbo swap on 09 lnf
  118. Mystery M14 plug on LDK
  119. Did anyone know this ?
  120. Term2 vs?
  121. top speed ecu will see
  122. Trifecta switchable $320 tune. Anybody have it?Researching tunes.
  123. 60,000 miles
  124. Lnf valves possibly bent?
  125. E47 long term results
  126. Alright guys.. need help (boost issue)
  127. 08 lnf running like crap Please help!!
  128. Lots of Smoke after ZFR Install
  129. Ported exhaust manifold
  130. Bad torque steer
  131. Full Throttle Boost Issues
  132. Shifted from 2nd to 3rd at peak boost, bang, now no boost.
  133. going mad....
  134. Downpipe installation time
  135. any technitians who have experience with 09 cobalt ss tc?
  136. Hahn exhaust rattle.
  137. Valve spring install compressed air
  138. Best clutch for 400hp LNF ?
  139. Fellow GM tech assistance on GMS1
  140. Cobalt sounds... Different
  141. ill just leave this here
  142. Po299 code and running rich 2009 cobalt
  143. Oxygen Sensor
  144. ZZP canned tune 25psi!
  145. Third cat delete questions.
  146. wierd sounds and code p2227
  147. LNF TOB Spacer ?
  148. I need some input
  149. Would this be a good purchase?
  150. screw size
  151. Engine Sputter
  152. ZFR 6758 Boost Tapering Off
  153. Turbo Flutter
  154. Clutch Choices....
  155. Car wont start
  156. TurboXS Catless Vs Catted downpipe?!
  157. wrong MAF Sensor?
  158. Transmission Problems
  159. Best Intake for GMS1
  160. Trouble Contacting Companies??
  161. boost drop
  162. Significant boost drop off
  163. ZFR on stock block
  164. Questions about ZZP catless downpipe.
  165. Adding more gauges to the a pillar?
  166. 3bar map sensor upgrade questions
  167. Timing Chain Repair
  168. Dedicated Intercooler Fans?
  169. Intercooler Question
  170. Urgent need help asap
  171. p0131 help with p/n
  172. Need some help
  173. Radiator replacement question
  174. LDK long block came!
  175. Sounds like a wheel bearing...but it's not. Other ideas?
  176. Intakes?
  177. Turbo Whine...yay
  178. 08 Lnf revs drops
  179. Trifecta Tuner Lock
  180. Hptuners guys
  181. Stock BPV mod
  182. Max boost at lower RPMs
  183. Crazy maf spikes with relocate----water in lower chargepipe
  184. LNF issues, please help!
  185. balance shafts
  186. k04 spec question.
  187. Remove hose to bpv
  188. ZFR Dyno
  189. Best downpipe
  190. Guys running E47 teach me
  191. Underboosting a bit, tried a LOT of things...
  192. Big Turbo Coolant/Oil line install
  193. P0300 p0304 p2261
  194. Removing broken bolt
  195. Lnf lsj transmission
  196. Air box mod gains?
  197. Blown turbo seals
  198. lnf cam removal
  199. Beryllium Copper to put in spark plug boot ?
  200. BOV Location
  201. Competitive Mode / Launch Control
  202. 2nd Kicks out When You Push the Clutch..
  203. Boost issue
  204. Sputtering under boost
  205. Boost Issue
  206. Redline Transmission Oil 75w-85
  207. please help, worried
  208. Happy with the basics! Budget tune is great.
  209. Need help.
  210. Non Cobalt turbo question.
  211. Misfire and fluttering
  212. That white smoke tho
  213. No boost
  214. Intercooler Issue!!!
  215. Really High LTFTs
  216. LNF CV Axle Shaft?
  217. Data logging with Torque and OBD-Bluetooth Dongle
  218. surging idle / oil in exhaust
  219. Funny turbo noise.
  220. Best exhaust to get?
  221. Cobes Baby Build
  222. LNF cam grind
  223. Boost problem
  224. P0089
  225. Secondary O2 Sensor CEL
  226. Cobalt ss rough/strange idle
  227. Welp, time to do some maintenance
  228. K&N Stainless Oil Filter!?
  229. Neat Pictures / Diagrams of the LNF
  230. Blowoff valve help!
  231. 1/4 Question
  232. Couple questions for e85
  233. LNF Basics for making more power
  234. Looking for hp, best bang for your buck .
  235. The LNF Block
  236. KN SRI Random Boost Issue
  237. CAI to SRI Retune Needed?
  238. Torque App. Help
  239. Reving High then engine stalling
  240. Electrical issue? HALP
  241. Electronic Boost Controller Help
  242. Spark plug indexing
  243. 2008 cobalt ss TC p2261
  244. Upgraded Exhaust Camshaft ?
  245. possible leak
  246. ZFR 6758 or 7163?
  247. LDK intake on LNF
  248. horsepower question.
  249. ZZP tune knock
  250. 3map sensor swap need a tune?
