PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Went through my e85 faster than I thought
  2. Would a MPx 3in catback bolt up...
  3. Throttle Body Upgrade: LSJ vs LS4 vs 4.7L truck
  4. Possible Broken Turbo.... Rookie Mistake
  5. Forge Intall
  6. Forge Group Buy Sign Up
  7. Transmission question
  8. 2008 LNF E69 GMPP ECU For Sale...
  9. Had an issue with the Balt
  10. bov AND bpv?
  11. Going full throttle at low RPM
  12. How my motor blew.. twice
  13. Megan Catless
  14. Who makes the best intercoooler?
  15. New tire ideas
  16. Power steering failure
  17. Car dying, no power at all
  18. Charpiping and intercooler
  19. PLX Kiwi?
  20. Question for you zzp
  21. ZZP Downpipe
  22. My airbox mod
  23. GMS1 Flash Times
  24. Side exit question
  25. ZZP FMIC Coldside
  26. Was ignorance really bliss?
  27. 09 SS/TC Sedan?
  28. Bad News...Need Help/Advice
  29. SS/TC muffle delete...pros and cons.
  30. G-force chip??
  31. Random Pulls Video...
  32. GMS1 and the Forge BPV
  33. Turbo Oil Drain Back Fitting -10 AN for any big turbo upgrade!
  34. MAP sensor pad
  35. cruise control not working
  36. Mod Time
  37. E85
  38. which is faster
  39. A/F Ratios
  40. Shuddering and Sputterin
  41. Whp and wtq gusses anyone???
  42. User Cobalt with 2 different sets of tires = ok handling?
  43. Bad-Mab Dp and Cutout
  44. LNF People how are your clutches holding up with GMS1?
  45. clutch will not disengage when clutch pedel is to the floor need help
  46. One of Those Dumb "What Will It Run" Threads
  47. Weird tune/computer issue
  48. Which exhaust for my 08 ss?
  49. Just installed the bad-mab dp and...
  50. bad injector/s
  51. could someone help with codes and other problems please?
  52. Help with turbo
  53. What kind of boost are you guys getting in 1st gear
  54. ZZP lnf intake tube and ic pipes
  55. Wheel Hop... HELP ME
  56. Car is out of commission - need help!!
  57. Aftermarket radiators
  58. oil capacity...
  59. BSR PPC tuner... didnt work... please help
  60. Rattle in neutral
  61. car just stoped working wont start
  62. Any benefit using the ZZP intake tube vs. AEM intake tube?
  63. BNR turbo build
  64. Hahn t-bolt clamps
  65. I need help or advice
  66. resonance/vibration on downrev
  67. Question on the learn down
  68. GMP stage 1
  69. noob question..kinda
  70. Dual Outlet Exhaust FTW
  71. MAF Sencor problems
  72. pics of the carnage!
  73. anyone with a zzp stage 4 clutch step in
  74. Downpipe- 2.5" or 3" ?
  75. boost then CEL flashing - Help!
  76. Stock downpipe diameter, newbie question
  77. Stock IC vs. Treadstone TR12 Pics!
  78. Easy Forge BPV Shims
  79. Treadstone Blow through MAF Pipe, Intercooler and Intake Pipes
  80. Car is Very Hesitant
  81. need help plez timing problems
  82. Tune Questions
  83. 31mpg with ZZP Intake Tube?
  84. Boost trouble...
  85. New Problem....
  86. I want an Cobalt SS/TC..HELP
  87. Turbosmart BOV Problem
  88. Meth is up and running!
  89. Stock Intake Snorkle K & N
  90. question about MAF sensors
  91. Is it time to service my breaks??
  92. Anyone else's LTFT's skewed 10 to 15% with K&N intake?
  93. Dyno numbers don't seem right...??..
  94. Wrote a book...
  95. Byt cai
  96. GMS1 with Trifecta.
  97. How to check......
  98. Tune questions
  99. Nls?
  100. Charge pipes needed?
  101. Where to buy Trifecta tune
  102. 1st gear trifecta boost
  103. ZZP Ecotec Performance Block web page?
  104. Hahn catted dp with stock exhaust
  105. When i break....
  106. Who if anyone has done a E85 tune?
  107. zzp bov?
  108. Got P0131 Code this morning durning warmed up.
  109. GMS1 + Hahn CAI, done...What's next? CP or exhaust?
  110. wisco pistons
  111. Hoodbra
  112. Is this possible?????
  113. Compression test question
  114. PCV -Turbo question
  115. Turbo trashed. Need suggestions on replacement purchase.
  116. Antenna Housing Question
  117. Wastegate problem
  118. GMS1 and colder plugs
  119. Finally got my new Muffler on...
  120. Pacesetter Monza on LNF?
  121. where to buy pedders?
  122. Supertech Valve Springs
  123. bet this isnt good
  124. Oils
  125. Spark advance??
  126. decided to get treadstone exhaust. 3" straight pipe!
  127. Boost pressure from MPX intercooler with no aftermarket tune
  128. Methanol Install Suggestions
  129. Ported LNF Intake and Throttle Body
  130. hmmmm w.. t.. f..
  131. Zzp IC help
  132. i have got to be the luckiest person alive when it comes to cops
  133. Drained more oil than I put in???
  134. Ticking Under Boost
  135. 1LSJ2NV's Build
  136. Any Good Tuners in Ohio? (Trifecta)
  137. SunCoast Creations Ram Air Hood
  138. 265/40/18's
  139. Exhaust popping
  140. p0087
  141. Pre-Build Checklist
  142. meth nossle
  143. Injen couplers
  144. Green Earth Technologies
  145. What is happening with this car
  146. AEM Dryflow filter VS K&N filter
  147. My Build - Tell Me What You Think
  148. Still getting knock...
  149. Anyone Install Racing Seats with a Racing Harness?
  150. Tial bov and spring
  151. Need tune recommendations
  152. Does this sound normal?
  153. Mitsu turbo ???
  154. Missfire on start up
  155. Whats a good price to get the adjustable clutch rod installed for?
  156. whats a good and reliable clutch
  157. 360whp ss tc
  158. Any interest in another forge gb?
  159. Cheapest Stage 1 kit?!?
  160. 1 step colder plug ?s..and clutch
  161. broken ignition cylinder?
  162. HAHN catback 3 bolt sleeve flange
  163. Reprogramming the RPD
  164. Treadstone CAI w/ air straightener GroupBuy
  165. Best Mechanical Boost gauge
  166. 185 misfires?! p0300, 301, 302,303,304
  167. ZZP LNF side exit exhaust interest thread
  168. anyone
  169. Manifold/intake line removal help
  170. Trifecta Tune; How often should I Datalog?
  171. This is cute!
  172. Atlanta area help needed!
  173. gauge bezel pods.
  174. Need help with tune!!!???
  175. Easiest and best place to start power mods?
  176. Raising the Bar!
  177. cold start up
  178. takes awhile to hit full boost in 5th?
  179. Does anybody's rpd do this?
  180. stock paper filters?
  181. Line removal from intake to manifold
  182. HKS Exhaust Sound Clip
  183. Headrest
  184. Please help me discover the mystery behind my car!
  185. need a clutch?
  186. BPV Flutter but not between shifts
  187. i hate cobalts
  188. alot of vibes with ottp rotated mounts
  189. dead spot shifting in third?
  190. Intermittent No Crank/No Start, No Module Communication, MIL, Warning Lights, Message
  191. What wire do u use on maf for meth kit???
  192. Weird Looking Dynos!
  193. Weird noise at idle
  194. Seafoam
  195. No more fourth gear :(
  196. Exedy Clutch installed
  197. I'm thinking about adding a water sprayer to my Treadstone
  198. Talked to treadstone today
  199. maf code
  200. DP o2 Bung Angle
  201. The "MAP Sensor" CLUB!!!
  202. LNF Turbo Flange
  203. Which muffler?
  204. why does my car sound like a subi???
  205. Just curious... What's your input?
  206. looking for a exhaust need some advice
  207. Will the K&N SRI do more for me than Airbox Mod?
  208. clutch or tires?
  209. GMS vs. Aftermarket
  210. Stage 1
  211. TB silicone coupler size
  212. Lets talk about brakes
  213. Safe Boost PSI
  214. Part numbers?
  215. GM Upgraded Camshafts...anyone seen them before?
  216. embarassing story/question
  217. new clutch?
  218. GM Stage 1 and Muffler Delete
  219. Help with downpipe please.
  220. slipping clutch
  221. Calling on Knowledgeable Tranny/clutch people...
  222. Big issue
  223. forge yellow spring.
  224. Spec 3+ installed
  225. Just Picked Up My Cobalt SS/TC!
  226. need help asap
  227. Trunk mount meth kits
  228. LIPSTICK's Port Injection and Secondary Fuel Rail
  229. diesel gas smell at wot?..
  230. Dump valvue leaking??
  231. Bad-Mab Down Pipe is...
  232. MPx Exhaust Clank over bumps and stuff
  233. sparkplug options
  234. Universal BOV Sorry about this
  235. Quick muffler delete question
  236. VERY rough idle - boosting at idle
  237. MPx Exhaust Rattle?
  238. Down pipe and exhaust
  239. Can you temporarily disconnect your cold air intake?
  240. so, i've been awared veterans disability money...
  241. Stock Axle Strength
  242. High Pressure Fuel Pump Mod
  243. Snow performance control settings
  244. Question about e85
  245. P2096 code question
  246. BPV spring causing flutter
  247. LNF Muffler piping size
  248. is there a complete kit
  249. Talk to treadstone today... posisble group buy on their CAI
  250. $2K to spend on......?
