- Turbo guys, I NEED UR HELP!
- surging
- forge bpv..
- Thoughts on LNF Turbo Ugrade
- cels thrown with 100% e85 please chime in
- Tried to put my DP on
- n2mb wotbox question
- water catcher broke off intercooler
- Random Misfire
- not boosting all the way, and feels and sounds weird. help?
- Upgraded HPFP? Hello ZZP? Anyone?
- What do I need to make 350whp (stock turbo)
- This is about a Regal 2.0 turbo, not an LNF, but...
- new borla cat back
- what is there for turbo upgrades these days?
- redline transmission fluid
- Exhaust got quieter?..
- for those of you with a 3" side exit or 3" straight pipe exhaust
- CEL, 5 psi, Need Dealer Mod, Knock Retard and a fix.
- ZZP Catted DP
- Warranty Problem! Possible Rebuild
- Have this weird noise coming from passenger side.
- Head
- hp tune
- Summer spending time!!
- Ordered foege bpv..
- HP tuners LNF release
- Zzp stg 1 cams
- need help!!
- Car is messed up!!!
- how to modify oil filter
- zzp vs. mpx vs. bad-mab
- Ordering new ZZP toys..
- Stock Boost Gauge signal?
- Stock Exhaust
- Advice on Tune
- limp mode?
- Horrible mileage, minor knock retard, misfiring, should I worry about my motor?
- Just Getting Ready to Build!
- Nitrous on GMS1 tune....Anyone?
- ideas for how to prep valve cover for paint
- what should the peak bost be
- Misfire Cylinder 1, 3, & 4 ? Diagnosis Assistance?
- Does this seem like a healthy pull?
- zzp intercooler vs treadstone
- popped my intercooler end tank after ottp mounts
- Trifecta tune and high mileage.
- hahn CP question
- i've decided on the k&n intake mainly because of this.
- white smoke??
- What else can I do?
- To get KY clutch or not
- need some tuning answers please.
- ebay catch can
- best CAI ?
- a how to????
- What in the @#%^ is a "TURBO" MUFFLER?
- my trifecta tune vs area47 hp tune
- rpd question
- 3 bar map sensors
- Trifecta adjustable launch control
- 1/2 E85 1/2 93 Octane
- Getting Trifecta tuned April 9th!!
- Megan racing ss/tc exhaust
- Considering a Combo Tune
- glowshift!!!???
- It's been a busy winter....
- Reliabilty?
- tired of taking out my head light to service my filter
- getting gms1 installed, any advice?
- Bov conversion
- flashpaq ?
- zzp intercooler kit
- Help!!!
- Where is the "All You Need to Know About Exhausts / Catbacks" Thread
- Questions about a California Emissions Car
- Which meth kit should i go with?
- ZZP Builds The Best LNF Mod Ever!
- intake install help!
- just got some mods..
- Clutch Pedal Stuck to the Floor
- Anyone Use MSD DASHHAWK??
- catch can
- exhaust
- meth kit mount
- Question Synapse IC
- 2008 cobalt ss new owner was a ls1 v8 guy have lots of questions??
- Port injection: 100% meth vs. C16
- LNF Sludge
- GMPP Upgrade Kit & GMPP Dealer in Jersey?
- ZZP Turbo Swap Time!!
- OTTP charge pipes?
- 2010 cobalt ss
- Help
- Cam Removal
- WARNING... shelf life is only 60-90 days !!!
- Treadstone intake
- No intercooler upgrade needed when using E85
- Best bang for the Buck
- Question on converting to E85
- Anyone notice this?
- Boost leak
- DP gaskets and o2 extension
- Question on Charge pipe, ect.
- Hahn DP warranty issues
- SRI fears.
- May have solved 100% E85 on LNF puzzle
- Dear Vince at Trifecta
- Horrible noise shifting into 4th
- Changing launch control with HPT
- Airbox Mod question
- Hahn CAI and Hahn Charge pipes
- TRE TR8 diy Install
- zzp catted downpipe problems
- K1 crankshaft group buy
- MPx with Muffler Delete sounds mean!
- installing greddy boost controller on ss/tc
- Darton Sleeves
- 2 birds 1 stone!!!
- How are the Avid Transmission Mounts?
- Check Gas Cap followed by performance loss
- what I have done & problem I still have.....
- My first mod will be a ZZP IC.
- Help cel code.p2187
- zzp exhaust
- Knock and Misfires
- Need p/n for front downpipe gasket!
- quick help please
- Synthetic Oil Change Interval? 3k / 5k
- ? about turbos
- car is messed up again need help please!!!
- Lower boost after catless
- help plez
- LNF Adjustable Launch Control by Trifecta
- Bov questions
- Bov questions
- TreadStone TR8 IC comparison to Stock.
- snow meth kit
- Well heres my list
- Bad week
- Piping opinion
- MPx Pulley
- help please! hub question
- Thinking about ZZP Turbo Upgrade kit...
- mods question
- Hks Bov leaking oil!?!
- Drewbroo's Tune review Part II - Superchips, HP, TF (With Dyno comparrison sheets)
- Car running weird at times
- LE5 throttle body on LNF engine?
- Trifecta Activation button
- IMO........Lest clean this place up
- turbo outlet ?
- P0455
- Just got back from the dyno
- Best Spark plugs for GMS1
- TreadStone IC GROUP BUY!
- warranty work
- BPV Plunger
- clutches
- Dyno #'s?
- option b kit
- Charge Piping
- zzp intake tube gain
- Forge BPV Green vs. Blue
- Trifecta tune and MPG
- My forge motorsports bpv looks different!
- LNF - from dead to zombie status?
- Running hot all the time
- motor is apart
- Injen Package
- How-to Air Box Mod?!?
- Yea... new higher flow injectors & a new sand cast block
- Stock Intake vs K&N SRI Video's
- Delta I platform vs Delta II platform
- Is the Clutch Master Stage 3 gonna be enough for me?
- Forge BPV Group Buy #2!!!
- boost problems...could it be the wastegate actuator????
- porus block
- My dejon bypass valve spring caused a CEL
- Boost=No Data and Three CEL codes HELP
- does yours look like this
- Do you need a new gasket with a new Down Pipe?
- 2011
- Best Alcohol Injection Kit
- Finally broke down and bought GMS1...
- whats the specs between the s252 and the s265
- Blow by? or turbo seals
- only getting 6 lbs of boost
- Code P2096
- Fuel effeciency
- Engine Disabled - Eng Pwr Reduced
- intake question
- GMPP intake?
- Ideas for Turbo upgrade
- Demand for OE replacement IC
- Cobalt Rap Music Video
- help
- where can i find slotted rotors for the LNF
- Trifecta Tune On its Way!
- Treadstone Front Mount Intercooler Kit, Beta
- Trifecta dealers - Comprehensive list of features
- New Intake!!
- ZZP Mail Order Tune Dyno'd with bolt ons
- Dejon Upgrade Spring Surge gone
- vendors doing a group buy on a catted dp?
- HP Tuners Demo software
- P0089 - Fuel Pressure Regulator Performance
- Ferrea
- spark plugs
- BYT...Jump on in here!!!
- DEJON 3” Exhaust for Cobalt SS
- Palmer XLscan + Trifecta cable dataloging
- OTTP rotated stage 2 trans mounts compatible with ZZP solid engine mount?
- Putting on the parts today, any advice?
- Can I??
- CEL BYT or Term2 Chime In Please!!
- popping issue
- Gms1
- manual datalogging today.....long post...
- Help oil pressure Gage instal
- Those who have replaced their rear brakes...
- Bolt on question
- LTFT & STFT info needed.....
- Treadstone DP with Bear River 79130 cat.
- Big Power Additions?
- Can someone tell me exactly what I need?
- Shift 1-2, now throwing code p0300 and sounds terrible
- bigger TB??
- Ordered some new goodies!
- bpv or bov
- boost @ neutral!!
- engine start button
- term2 tuned!
- question about gms1
- Treadstone Cold Air Intake, w/ Honey Comb MAF Airflow straightener
- What's the Next Step
- Will these fit my ss t/c?
- present to myself
- hahn or corsa
- just ordered megan downpipe
- relocating maf
- Stainless Steel Brake Line and 78# Valve Springs?
- what brand washer fluid should i use for meth?
- ZZP Ported Head and S1 Cam Combo Package - debunking thread
- Catback
- Umm, what's this? Lol
- Wtf?!?!?! Video
- Oil in Turbo & Intake
- REVIEW MPX Light Weight Crank Pulley
- Spark Plugs or Map?
