- Dry Ice box??
- Smoked Clutch
- lnf engine bay
- stock LNF dyno
- Advice on Tune please!? Ive read alot but still unsure on what to do!
- A/F Ratio on RPD reading high
- need help asap!!!
- Swapping LNF PCM Back after Stage 1
- is there a bov kit that lets you keep your no lift shift?
- Crankcase and Main bolts?!?
- I am getting a Trifecta Tune and a ZZP DP!
- uping my a/f ratio
- whats a good price on selling the k04
- trifecta tune in NH?
- Hahn Charge Pipe Dented Hood
- top speed
- ZZP Charge Pipe!
- Dejon SRI
- Just Curious How Bad Is Running An Aftermarket Intake
- I wanna go stage 2!(noob btw)
- are muffler deletes bad?
- GMS1 Install...
- No Lift Shift! Esc Off
- oil/coolant line specs
- K&N Intake
- Driveability issues
- LNF rocker arms = Billet OR Stamped Steel?
- Guess what? Its back and worst.
- hey guys need some help here...
- steering wheel skaking
- Just ordered a TF Dealer kit!
- Known problems.
- Booooooooossssstttt
- Intake+Superchips?
- Testing AEM's New Intake for SS/TC
- what rpm with trifecta?
- this is a newb question
- So...
- Ugh, boosting problem or no?
- E-3 spark plugs
- Fuel filter Help Me
- HP Tuner or Hahn BSR PPC
- dashdaq 1/4 mile
- Engine Power Reduced...why!?
- Ic pump
- BADMAB Industries LNF Downpipe is ON!
- Best exhaust for ss/tc
- what's causing my car to flutter?
- need help ASAP with car being all weird!!
- some help finding a sensor
- Hard to start when cold
- where can i find 15" brake kit to take the place of my brembo's
- Boost is NEVER the same, GMS1 Tune FTL
- Another reason to use T-bolt clamps ONLY
- i suck
- ttr mounts vs ottp
- new turbo for LNF?
- Just Wondering....
- BOV Question
- P2138,p0122,p0100 help!!
- Contacted APR
- P0451... Again
- Oil Light when NLS
- HELP!! Flutter coming out of inktake
- What should my fuel trims be??
- Twin Charge an LNF
- Went credit card happy today!!
- mufflers!
- Any mod info for 2010 ss/tc>??
- OTTP Mount Vibrations
- P0238 & p0016 help please!
- new guy here with turbo upgrade problem
- P0089 (fuel pressure regulator 1 performance)HELP!
- Need help, no boost P0299
- Resonator delete PLUS Muffler delete =???
- Alternator ?'s
- Headgaskets
- Took my car in for the oil leak fix
- I don't understand what this code means?
- Who has TTR Motor Mount
- Lnf & e85
- muffler delete?
- ZZP Turbo PCM in conjunction with GMS1??
- Which intake to buy?
- Frist trip to Dyno
- Boosting at idle...WTF!?!
- Has anyone run a wideband O2 through their dashdaq?
- Car wants to stall cold???
- What's causing my whacked fuel trims?
- quick in car vid
- WOT Box Install on LNF
- NGK 3787 + GMS1 update
- Hahn intercooler
- K&N Intake Video
- Best Tune
- esc delete?
- how do u make your ss/tc sound like this???
- Cat warm-up DELETE
- Tapping the coldside?
- Quick question on NLS and weird noise
- Big thanks to mkulrye13!
- o2 incomplete and evap incomplete
- Cel on p0496???
- My 2010 Cobalt SS/TC
- Meth with Stage 1, Good Combo?
- LNF GM STAGE 1 Questions
- No Lift Shift Squeal??
- Gm lnf stage 1 kit troubles??
- Problem Need Help!
- Does Anyone know where I can get a New MAF Sensor?
- Is this normal on an LNF???
- Running dp on tune necessary + add't
- Ran my Balt on a Dynojet Today
- Dyno Day
- Dashhawk
- Use Seafoam to De-Carbon intake valves
- GM Stage 1 vs Tune
- P2261, p0497
- Mustang Dyno aka 'The Heart Breaker'
- getting into gear
- Stock Intercooler Size
- Ordered TWM Shifter
- performance auto werks
- Some pulls with a camera near exhaust...(video)
- Injen Parts for LNF Balt???
- 12500 miles = spark plug cyl 2 and 3 bad ??
- How the hell did I lose to a stock Caliber SRT-4?
- List of upgrades for the LNF
- water/meth kit
- Simple mods, simple questions, simple answers, for simple people
- BRAND NEW ENGINE...with a problem, maybe???
- CP-e willing to make an intake for the LNF if 20 people are interested
- MPx Downpipes and Exhaust combo package? Or keep them seperate ?
- looking for some good performace shops on long island new york
- SS/TC GM stg1 w/ mods?
- Quietest 3 Inch Exhaust?
- After Hahn cool ram install
- turbo kits?
- fix for skewed maf readings?
- Throttle acting wierd
- nls sucks sometimes!!!!
- Mounts
- Question on our stock Intercooler?
- ZZP LNF IC is Getting Closer!
- Think we should add this to the DP install DIY post.
- Enkei RPF1 Wheels
- About to purchase a HHR SS Auto
- Down pipe question...yes i searched
- odd issues
- ZZP Catless Downpipe
- Post pictures of you TC on Coil drops
- stage kit: replacing an o-ring and using locktight 262
- Help please
- Who shoots flames from their exhaust?
- noob question i know. but just need an answer
- ss/tc vs 350z
- Cel
- Intercooler/Charge Air piping
- Zzperformance phones?
- ZZP Dyno Tune
- Engine Ground Strap - Where is it located?
- New Stage kit??
- A Little AGP Turbo?
- Goodies came in the mail...but...
- Stupid question... Stage 1 Kit available for Cobalt SS Sedan?
- injen charge pipe
- question on hp tuner =D.
- Just bought some new mods!!
- troubles with downloading trifecta tune
- Fluttering issue!
- Nls
- Charge Piping
- WERKS Racing Turbo Kits
- trifecta tune
- Those who want to relocate MAF:
- loud clunking while shifting hard?
- i think i have a great clutch deal!!
- Solution to misfires
- just ordered dp
- 2010 Stage 1 Self install
- 2009 cobalt ss/tc auto swap
- Front suspension noise!!
- Service ESC
- ZZP LNF Intake Tube- Need Test Fit Car
- Trifecta tune question?
- Rpm signal??
- LNF 1/4 mile Mod thread
- code P0089
- upgrades
- Problems shifting quick with the Exedy
- loud clunk after nls
- Check Gas Cap on Computer display
- Stage 1 Install Suggestions
- madd brake dust
- Lower GM Stg 1 Map Sensor help
- sputtering, backfiring, and misfiring
- P0300, P0301, & P0303 - yeah, I searched. :<}
- suggestions?
- Newber Halp - Spring Instal
- ss/tc transmission fluid
- help with dash computer warning after oil change
- cel
- time to start the mods HELP
- IC Sprayer
- 09 SS/TC Clutch issues
- ZZP lower charge pipe arrived
- GM Power upgrade
- possible bad GMS1 + 1 killed ECM
- how much boost will though limp mode
- Need info for 5W-30 on Royal Purple
- New here
- Rain X and windshield wipers
- Fixing intercooler help!!
- Paintings stock rims
- LNF Trans Failure
- random misfire at idle still
- How much oil 09 SS?
- Low boost running like poo
- Low vac at idle
- tune
- Painted Heat Exchanger
- question
- OTTP Catless Downpipe
- Bypass solenoid actuator ma-bob
- gms1 underated power??
- ZZP Downpipe has arrived
- Question for Swapping PCMs with HPT
- Someone asked about coldside piping rubbing on a bolt.
- Are the stock IC piping clamps T-bolt?
- Injen CP and oil changes
- Is this correct for this turbo water cooling line?
- Finally found my pics of bad Crazy Steve IC fit.
- Deciding on DP and best way to install.
- ?s on performance
- odd ss/tc problem, looking for ans.
- CEL code P1589 help please
- ZZP Downpipe Leak?
- mpg
- popping noises (backfire x1000) lol
- P300 p303
- is this possible...
- SS/TC ECM is available from GMPartsdirect.com
- how much hp can the stock clutch take
- Map sensors stg1 $44
- BOV - The myths and the truths
- tunes
- tail light tinting
- AEM intake
- tial bov
- CEL help
