- Hm, So my MAP Sensor DIED....
- Catless dp/NLS
- ABR Tuning
- Best non-slick tire for hooking up at drag strip
- ZZP Valve Springs...
- Just some pulls with trifecta 22 psi ...on video
- RPD not showing boost
- How much is the hpt file for GMS1
- I need help fast
- tc cobalt-how much h.p can they safely handle
- Question
- Question about my car bogging at 5500RPM
- PnP turbo upgrades
- Treadstone Performance manifold!!
- whats the normal vacuum pressure
- Trifecta cable need it in south florid
- another exhaust thread
- Lowering Springs, what do you recommend.
- Opinion on running C12
- Tried out the GoPro tonight. Exhaust videooo
- /muffler
- Aqua Tune Water Injection?
- mods before or after???
- taking my 2010 ss to the track friday
- why no strokers
- redline
- Need sound clip for CATTED DP
- Cheapest 3 inch Catback
- Shift Cable Bracket
- VP100... oxygenated unleaded...
- goin for tune soon
- NLS question
- Downpipe question.. lol
- K&N intake + whacked trims and knock
- car is finally back with zzp kit
- ZZP cold side pipe
- Official Blackmamba Build Thread
- Bit by the dreaded worm gear clamp monster!!
- Mpx exhaust and 1 of 2 intake ?
- Running E85
- LNF Forged Internal Build!!!
- $600 and you can fix the fuel problem?!?!?!
- Ported head?
- hey lnf guys
- opinions
- Running with vettes
- LNF Non-Turbo power
- CEL with K&N Intake
- 3.5 bar map sensor
- Clutch questions...
- mpx catless downpipe
- gms1 sensors
- need a exhaust which is the best
- trifecta $$$$$???
- Premature Rear brake wear
- Boost Dropping - Is this normal??
- UPS just left the house
- Charge Piping/Gas mileage question
- New Trifecta tune
- wacked a/f driveability video...
- Just bought used cobalt sstc
- Treadstone Performance stage kit!
- 1/4 Mile Pass + K&N filter+ Trifecta = CEL??
- turbo timer on zzp kit
- those of you with zzp catless
- Can you burn your stock cats out?
- Driving on cold air intake untuned
- Downpipe question
- ported mani
- Opinions on Charge Piping
- How safe is 22 psi on a stock cobalt?
- Mods $120 or less-Pics
- Where's my coolant going???
- cluch peddle squeek
- Calif..Catted Downpipe?
- Which Catted Downpipe Should I Acquire
- Anyone heard of this company???
- jolt still there between 1st and 2nd gears
- 2 step
- Major backfires, a/f all over the place, randomly boosting at cruise HELP!
- Block Off Plate
- Muffler Question
- ZZP Charge Pipe or Injen Charge Pipe with upgrade?
- hahn PPC tuner
- looking for ic piping
- Air Filter Question
- Who has An Injen LNF Intake on their 2010 Cobalt?
- Megan racing Downpipe question
- kinda a crazy question
- stage 1 rotated mount finally in......
- turbo timmer?
- do i need gm stage 1
- E10 vs Gasoline and KR
- Dejon Manual Boost Valve- Holy Sh!t!!!
- How in the hell?
- question about fuel!
- Trifecta infiniboost
- New pedals?
- Puttin her away for the winter
- thanks byt for meth tune :)
- Dataloging question
- zzp catted downpipe has a cel
- quick question on the stock turbo...
- Treadstone just released..
- wich is faster stock
- bov noise odd...
- Is this normal?
- E3 spark plugs
- lets see dyno numbers with your aftermarket turbo kits
- Is this a waste?
- trifecta gods please HELP!!!!
- Extra cash what to buy
- Blockheater.
- Need help ASAP! Gotta problem
- Lowered with janetty side exit? Anybody have it?
- Aftermarket Stage 2 mounts?
- Selectable Trifecta and Aftermarket Parts
- dashdaq for pc
- redlining
- breaking up after extended highway driving
- Trifecta tune dyno results
- Treadstone Performance Intercooler Kit and Cold Air Intake with Pics
- E-85
- Trifecta Tuned? Please vote!
- Meth
- FINALLY Decided What My Plans Are For The Turbalt
- Deciding on a few things...
- Best handling Car under $100,000 issue
- 5th gear and reverse!
- EVAP system
- Best Cold Air Intake for SS/TC? (w/GMS1)
- Anyone NOT having issues with GMS1?
- Effect of GMS1 on RPD - Please assist those with both
- Help?
- is anyone in east carolina cobalts
- BCM vs ECM vs independant systems (2009 SS)
- Who installed their own GMS1 sensors and...
- Just Ordered Trifecta!!
- Less boost?
- Received new LNF turbo, has metal BPV?
- terminator tune
- k&n intake gain
- ok so i need help figuring this out!
- Tuning in DC/Maryland/Virginia Area???
- Does LNF have heavier steering than base model?
- LNF water pipe
- need clutch suggestions.
- low boost
- Lsj g85 tranny on a LNF
- AM oil pressure sensor install
- You might not want to NLS
- worst labor day weekend ever
- Freebies
- p0300, p0301
- Possible Hahn Cool Ram intake fuel trim fix
- Need Help!!
- Injector Service recommended by dealer - Necessary?
- Rear O2 Sensor
- Is a GMS1 with MPx intercooler and CP okay?
- CEL Galore! HELP Please!
- Why do people think the K04 is so small?
- Can I Do This To My Car???
- torque specs on bolts for ottp mount
- ESC (Electronic Stability Control)
- GMS1 - sticky bypass valve = loss of boost??
- cel just came up help??
- exhaust help
- Cold side ICP Fail!!!
- gm stage 1
- Boost Power loss after the Dyno Run(Help)
- Curious about brake pad wear..
- Detecting a Tune
- replaced turbo in 09 ss...
- hp to boost relationship??
- opinions
- P0236
- Where is ZZP???
- And the verdict is...
- fuel filter ss 2009
- Zzp stage 3
- Critique my plans
- i took your advice!
- newly tuned ss/tc
- PO420 Stock?
- Removing RPD
- To those who think their stock IC is good, think again.
- Stock LNF MAP Sensor
- oil light?
- exhuast
- zzp fmi ship date
- Some extra cash... Now what?
- It's Trifecta time!
- RPD Question...
- Here we go...
- Oil leak
- Trifecta & HPTuners combo tune installed!
- Quaker State Q Horsepower?
- For those who went from a CAI to the K&N...
- burning oil
- Just wanted to say BYT is awsome!! lol
- Just bought hp tuners!
- How does the K04 wastegate/boost controller work?
- ZZP upper intercooler pipe questions
- Bov cel
- Electric Cutout
- My new tune!
- will these rotors fit?
- Devilsown install pics
- Battery Charge Maintainer
- p0100, p0031, and p0458
- high gear low rpm bucking!!!
- How to unlock superchips tuner
- ECU question!
- what are your guys views on this
- ESC problems
- Turbo Swap
- REVIEW:EXEDY vs SPEC clutch
- Hot intake manifold
- When do I put gas in my car?
- LNF with GMPP tune w/ NLS + WOT box???
- GMS1 sensors
- Average Price for Muffler Delete
- Wierd Knock...
- Turbo psi problem!!!
- Does sparkplug gap cause misfire at higher RPM's?
- So what kind of a mess I am into now
- hit a Rabbit, should i be worried
- 30% leak down test????
- need help asap!
- muffler delete...now feels slower!
- Stock ss/tc dyno chart?
- Any info on where to buy cheap cable for Trifecta tune?
- Watching Timing advance
- 2009 SS/TC. How do I get RPD and LSD?
- How to remove stock charge pipe turbo outlet coupler?
- Whats wrong with my car?
- Intermittent loss of power?
- Poll
- Tips for installing ZZP Clutch Rod
- Valve Cover Torque Specs
- GMS1 installed and awesome
- LNF Oil Analysis
- Stock Shifter Light?
- Just got BYT tuned...
- Oil temp vs. oil pressure gauge
- return of steering clunk?
- GMS1 and the trouble at the dealership
- mass airflow sensor
- ECM swapping?
- Need Instructions On How To Intsall BOV!!!!
