- Boost controller help
- Won't hold past 21psi
- Scraping sound....help?
- Car will not help, looking for advice
- Dual Interceptor LED Settings
- CEL, engine misfiring
- which tune
- Dyno Numbers?
- MPX catch can install question
- LNF valves?
- Need Help with MBC
- Tuned guys chime in
- Wanting to swap my l61 with lnf In my saturn ion
- Does anyone make a TB spacer for the LNF?
- Single pop/stuter Climbing RPM's
- LNF issue
- Can O2 sensor after the cat cause Limp mode?
- hp tuners in or around the new orleans area
- Trifecta Tune In NY
- No lift shift question - NO "POP" anymore
- back to stock for visit to dealer... help?
- Quick question about secondary O2 sensor and I can't catch a break
- are these PCV passages or what???
- downpipe ?
- Need help identifying a part!
- RPD Accuracy????
- engine power reduced, no codes, wierd boost
- Is this correct routing for catch can?
- Parts On Order - Finally I'll be back on the road!
- Ordered the wrong bung!
- MAP sensor location
- Pics of Lower IC Piping and MAP sensor
- High altitude (4000ft+) SS/TC owners - no "learn down" for mods?
- Boost lost and p0101 code
- Catch can POLL for LNFS
- Upgrade for LNF
- Megan racing cat back for lnf
- Hahn Modpipe
- Oil catch can
- cams
- GM Turbo Upgrade Kit
- Bad intake cam actuator...
- New Motor Break in Period
- weird clutch problem
- NOS Sniper?
- MPX exhaust question
- Bank 1 Rich Idle CEL
- Mixing E85
- Fuel pump output volume
- K and N sri
- bolt-ons
- Coolant help
- Not Boosting Past 5psi
- Compression test - Subaru of death noise
- i'm afraid of the corn
- tune worth it?
- Misfire Detection. What sensors?
- Opinions on stripped meth fitting inlet
- HP Tuner in Northern California
- Do I need a re-tune?
- Most Important Things to Keep an Eye on after a tune
- Sprint booster ??
- Boost Problem again...
- Cel
- Blow Off Valves: Everything You Need To Know
- Intake Ideas.
- Finally got the car running perfect!
- P# for WB O2 - 09 SS
- New Motor
- Swapping rear view mirror?
- HELP Turbo flutter + no boost
- Getting Tuned Tomorrow
- SS/TC Rear Brake Problem
- quick answer please
- installing downpipe
- IAT Temp's 30 degrees higher after ZZP upgrade
- Good Deal
- superchips lnf
- Catless downpipe and emissions
- Should tire spin in 2nd be easy with gms1 ?
- vacuum issues?
- Is this the oil bolt?!
- 3in exhaust ?
- K&N Clarification
- Resally wierd issue yesterday.
- What does a 360 Whp LNF on Corn look like ?( blown up )
- Boost Issues
- Eng size ?
- Football size?
- stealth intake?
- Dejon Kits
- Bucking!! Help!
- oil in intake
- Weird throttle/turbo reaction
- trouble starting?
- HAHN vs. Injen vs. AEM vs. K&N
- c02 intercooler sprayer... yay or nay?
- Which tune do I have
- Stock DP, Punchin out the cat
- injen charge pipes
- Motor Toast...
- Intercooler
- need help again guys
- What to do next
- cel
- Goal is 350-375whp for my daily driver
- tune corpus christi tx area???
- IC Spray
- Blown engine
- uh oh....
- Slave cylinder
- How's my Logs?
- Bov
- Hahn Intake Fitment Issue ---- NO MORE!!!!
- weird problem?
- LTFT/STFT Ethanol Discussion
- LNF guys in MA and other emissions states
- Power Loss!
- CIA parts, they any good?
- "Estimate on Power" from these mods
- talkin down on my cobalt
- Anyone have the AEM meth kit installed
- Help ASAP
- Ny tuning
- mpx down pipe and catback?
- Are you Running E85!?!?!?!?
- What Does a 625+ WHP LNF Look Like?
- Fuel Pump
- Secret Services Auto Turbo Kit for 2.0LNF's
- What does it take to trap 120-125mph?
- turbo cobalt tunes
- hans racecraft intake? 09 cobalt ss
- How to install Forge bpv
- E-30
- How to Oil Forge BPV O-ring?
- finally made my mind up
- hmmmmmm?
- LNF injectors, where to get them!! HELP!!
- Obd II port splitter with interceptors
- Scythe_Snake Visits ZZP...AGAIN!
- "Turbo Flutter"
- GM Flexfuel stoich table?
- MPx Oil Catch Can
- AEM Intake - Improved
- Tranny problems!!!! (2008 w/39,000 miles)
- Coolent Leak Problem
- Gas pedal Harness removal..help
- Plugs to run with Meth Inj
- GMPP GAS Pedal
- do they make
- LNF exhaust manifold wanted
- worth modding?
- HELP please!
- silicone couplers
- OTTP LNF Intake
- So I might have stuff for sale...
- Odd question. Non turbo LNF
- Maf sensor block off plate
- Valve springs for LNF
- Where to put gauges
- Aluminum flywheel = CEL p0300 p0301 p0302?
- m62 on lnf?
- Which downpipe is better, Megan racing or badmab?
- How can I flash to stock on a non stock ECU?
- Starting Problem with Cobalt ss/tc help
- sorry for all the threads
- what spring for forge bpv?
- Short Trim/Long Trim
- coolent leak
- Timing and AFR
- 2009 Cobalt SS - tuned the car in amazingly and then...
- trifecta tune
- dashdaq ??
- Amount of Boost does NOT kill Map Sensors
- werksracing Ecotec 2.0 LNF Valve Cover
- What magazine do we pick!?
- Has anyone else had this stock shifter problem?
- Bolt on Mods
- Meth Injection?
- catless or catted
- Tial BOV install
- Weird cold start issue, *vid* need some thought...
- SS/TC map sensor and boost
- bpv install
- installing MPX catless downpipe, NEED HELP
- Vaccuum By Pass
- short shifter, they worth it?
- throttle position help
- vibrant foulers?
- hooking bov
- COmpressor surgeeeee
- forge bpv ??
- question about the superchips programer
- whats a safe boost number?
- Question about Charge piping...
- what is the problem here
- help modding
- hp tuners beta
- oil around my valve cover
- Sound problem with K&N intake. HELP!
- will a intake and downpipe
- Tips for n2Mb WOT box install
- meth kit always on- help
- Please help .. p0100
- Help help heeelp!!
- Thinking about trying EBC out.
- Clutches.
- E-85 dyno
- Coolant leak thanks to Hahn CAI
- oil catch can?
- 50 trim! Swap or pass?
- ebay intercooler?
- question about our motor
- help a brother out
- Treadstone question
- CEL code
- thermometer
- Went to the track with GMS1
- Intercooler HELP!!
- Crank case breathers
- Maf extension
- Intercepter showing knock on stock tune??
- explain the whole trifecta
- Newb Questions: What is the purpose of CASE Relearn?
- Ceramic Painted Calipers with Nickel Alloy Decals + Grill Delete
- o2 housing
- Picking up the GMS1 kit today... Anything I should know?
- what are safe numbers to shoot for when geting a tune?
- ZZP Intercooler Goup Buy
- looking for a downpipe
- Rumbling during NLS?
- Forge Install
- GM Parts
- E-85/E-10 fuel question
- Thinking about a mild build
- IC install issues
- Got my zzp intake tube and ic pipes on the way...
- High Coolant Temps?
- Custom Catback installed video.
- iat2
- help
- Best Intake?
- Got some extra cash. Help on mods?
- Stock Clutch Pics
- Drive By Wire Delay or Turbo lag
- Minor Problem After Carwash
- water wetting
- Wanted to see if I was the only one
- Air Fuel Ratio
- Hahn charge pipe install
