PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. LHU/LDK can't hold same or more than LNF
  2. ZZP Intake Tube and Air Horn Mod
  3. High Pressure fuel pump
  4. Random Codes 0099 0098 0238
  5. 4.45 gears question
  6. my stock turbo
  7. Saturn Sky Redline
  8. Air filter straight to turbo
  9. Help- boost issue
  10. Help with boost leaks
  11. Did they stop making ARP flywheel bolts?
  12. LNF vs. LSJ Flywheel
  13. Stealth-TC's Official Build Thread
  14. Turbo Timer
  15. master cylinder
  16. Where is the pcv?
  17. LNF Valve cover and intake lines... Catch can related...
  18. CharGe Pipe question
  19. Need help... p0101 issue
  20. Leaking Oil out of Oil Return
  21. compressor map efr 7163
  22. Intercooler Damage - Pics - What are my options??
  23. Anything I should do prior to getting my 08 ss tuned?
  24. Time for a few upgrades!
  25. How accurate is the RPD hp and tq gauge?
  26. best mechanic??
  27. p0243 wastegate solenoid
  28. My stupid blown up car thread
  29. 09 LNF Fuel Pressure
  30. Stiff Shifter
  31. ATI damper and ZZP neutral balance shaft on stock block?
  32. You know how the car likes to "Take off"
  33. Brake boost on ZFR?
  34. P2237 help
  35. Power curve dips and spikes?
  36. FTW-k04R vs ZFR In need of turbo swap!!
  37. Highest Rail Pressure anyone dared run???
  38. Stock LNF intercooler weight?
  39. backfire tuning
  40. Anyone buy stock LNF spark plugs lately?
  41. Headed to ZZP
  42. What are the 2010 AFR's supposed to be at?
  43. Ordered some goodies from zzp!
  44. Does thw LNF have a turbo silencer ring? If so, has anyone taken their's off?
  45. P0690 09 lnf
  46. K&N SRI worthwhile on e47 setup?
  47. who is running meth on a LNF with full bolt ons and stock turbo with gms1 sensors?
  48. help - boost issue
  49. Additional Tune Needed if Charge Pipe Changed ?
  50. Doing the unthinkable
  51. N2mb wot box hookup
  52. BOV Swap Questions (Yes another thread I'm sorry)
  53. Configuration file
  54. K1 rods = max boost? max whp?
  55. 3" Exhaust Rasp
  56. my goals for my balt
  57. gas and tuning questions.
  58. Pretty sure piston 4's rings are gone
  59. tires tires tires
  60. Broken HPFP connector.
  61. LNF valve cleaning
  62. Wastegate Actuator
  63. Plug Gap for 09 Turbo with GMS 1
  64. overboosting stock tune
  65. What kind of performance with my mods am I looking at.
  66. Charge pipes question/observation
  67. What turbo?
  68. My trip to ZZP
  69. 2009 LNF problems, please help
  70. torque app evap
  71. New oil and a 15psi pressure jump
  72. 09 ss wont stay running.
  73. Help Engine Noise
  74. Cold or Hot Spark Plug Removal
  75. ZZP Big Brake Kit
  76. Vented bpv, does it require you to relocate your maf?
  77. First Dyno after putting the K&N SRI in
  78. about charge pipe
  79. PCV system question.
  80. MODS for 2010 Cobalt SS - Trial and error outcome.???
  81. how are these numbers?
  82. Wideband???
  83. smoke under boost
  84. Proper Amount Of Rear Brake Drag
  85. In need of return line
  86. P0016
  87. Stumbling at Highway Speed.
  88. Help connectors
  89. LNF head removal
  90. 09 SS Coolant Hose
  91. About to MOD my LNF
  92. Winter Changes!
  93. Ethanol/general tuning
  94. Squeaking issue at idle
  95. ZZP Stage 1 or Stage 2 Cams? Which is best for stock turbo?
  96. finally bought zfr
  97. installed zzp bov question
  98. 5w30 compared to 0w30
  99. 0 Compression?
  100. I need ZZP intercooler help
  101. Map sensor advice
  102. how long did your transmission last on zfr?
  103. Wheel adapters
  104. Ky or clutch masters stage 3 clutch? Also findaza light weight flywheel or oem?
  105. bad results
  106. Just a stock motor dyno pull
  107. Zfr swapping my balt, what else is required besides extra tranny funds? 😆
  108. Getting close to my MODS month.
  109. another piston thread, which option to choose
  110. Questions regarding zzp dp.
  111. Boost Stutter / Surge issue
  112. forge bypass valve
  113. GMS1 lower pipe wiring harness color guide
  114. cylinder 1 - 2 wet plugs?
  115. shaft play
  116. Engine Replacement
  117. MAP Sensor
  118. upper charge pipe bov flange blocked off
  119. Billet s259et
  120. RIP Piston.
  121. 2008 2.0 LNF P0302 Misfire when Cold...
  122. Zfr reving problems
  123. intake and dp tuning question
  124. rear main seal question
  125. lnf stuttering bad with accelration
  126. Ticking sound under boost
  127. ZZP PCM vs GMS1 Question
  128. Spark plug question.
  129. Question about boost!
  130. zfr boosting sound
  131. Cam install without holding tool?
  132. 50k miles general maintenance and tune Qs
  133. Need new engine
  134. p0336 car will not run or idle
  135. bad bcm
  136. Hptuners not working
  137. K&N SRI/MAF Pin out
  138. So What Is The Most Famous Line The Terminator Ever Said?
  139. ZZP intercooler kit but higher AITs
  140. where to…. meth injection
  141. 09 SS/TC Thermostat replacement
  142. P0030 code anyone?
  143. Look what came in the mail!!!
  144. What to expect in a 95k mile 08 cobalt ss?
  145. P0030 code HELP!!!
  146. what vacuum line for nov
  147. ZZP LNF turbo upgrade kit
  148. HELP!! oil in CP and IC!!!
  149. 3 Bar MAP Sensor Plug & Play Question
  150. Cleaning valves
  151. Opel Injectors or Nah
  152. Where did the K&n SRI option go for ordering ZZP'S PCM
  153. 2009 LNF Wont go into Boost?
  154. ZZP's Complete LDK Engine in a 2007
  155. Big Turbo Ventilation systems
  156. Options for meth
  157. hahn intake install
  158. Tuning my SS
  159. ZZP camshafts question
  160. Oil in Turbo
  161. 2014 turbo swap
  162. PCM Relearn
  163. Main engine harness
  164. My ZFR review
  165. Can I put a 2009 turbo engine in a 2007
  166. Your opinions on whine
  167. F40 gear ratio options.
  168. Blackstone Oil Report
  169. shift selector snapped
  170. Quick Powell oil separator review
  171. 2014 Goodies
  172. 2.0 supercharged and 2.0 Turbo QUESTION BOlT PATTERNS
  173. Installed new Boost Gauge
  174. nls 2-3 blinking engine light
  175. Cam phaser question
  176. Please help!!
  177. Just for good measure...
  178. Anybody know what turbo this is?
  179. how unsafe is 25psi?
  180. A question about 4.45 gears
  181. blow off valve question
  182. zfr bolt torque coolent pipes.
  183. aluminum flywheel
  184. Replaced K&N intake =+fuel trims lol
  185. Boost leak tested my car ...
  186. spark plugs after putting bigger turbo on
  187. lnf reliable tuners
  188. not boosting at set psi
  189. HAHN charge pipe+Boost leak?
  190. ZFR high pitch BPV squeal?
  191. Random short term misfire
  192. downpipe/exhaust rubbing heatshield
  193. hp tuners
  194. 5k loan for parts.
  195. Upgrading Trans Timing
  196. p0101 problem
  197. Is 24 psi 24 psi?
  198. 3rd gear shattered. Yes another one.
  199. rotated mounts x turboxs downpipe rubbing heat shield
  200. Hahn Intake
  201. Stalls when very cold outside
  202. EFR6758 & intercooler installed, coming down to idle rich stumble
  203. 2.4 TB on LNF
  204. soo what mods first?
  205. Is valve Coking covered under warranty?
  206. Tune?
  207. Turbo Pics
  208. blown trans on 256 extended tip, 262?
  209. where can i get 2010 injector seals?
  210. Cylinder 1 and 4 misfire...help
  211. Cammed sounding idle?
  212. Cammed sounding idle?
  213. zzp rotated trans mounts vs ottp
  214. p0336 code car will not run
  215. Gen 3 Oil Cooler Location
  216. Low RPM Knock, and Lots of it
  217. o2 sensors going bad.
  218. Blown Turbo?
  219. Another E85 thread
  220. full bolt ons no catback?
  221. Oil loss after ZFR swap
  222. ko4 trim
  223. What is your hot/coldside piping setup?
  224. MAP Sensors
  225. zzp order
  226. Trifecta 23 PSI Tune Problems
  227. K&N Blackhawk
  228. Cold side cp
  229. Ottp
  230. Review mod list please
  231. Low boost problem
  232. lnf low boost help
  233. 2.0 lnf 2009
  234. spark plugs
  235. The Lovely Clutch Opinion Question
  236. Seafoam vs B12 chem tool ????
  237. Misfire......from PCV?
  238. finding the weakest link (trans/motor mounts)
  239. I need camshaft position sensor
  240. Straight cut gears for the F35? Calling Mr. Powell....
  241. Crank sensor location
  242. Looking to upgrade turbo
  243. 40/100 kpa on stock tune and 110/150 kpa on select
  244. low boost?? 12 psi
  245. CEL/Problems After Clutch Install
  246. Evap purge solenoide can cause a P0101
  247. ZFR longevity and durability
  248. CEL still on
  249. how does this flywheel look, thinking of scuffing and reusing
  250. Equinox cam options for LNF
