- Tuners in Idaho
- GM Sensors
- Cabin noise with A/C
- Borla Catback?
- A+ Service from BYT!
- Your thoughts and suggestions
- Sparkplug question
- p0496 and p2187
- Exhaust help
- Altitude effects NA cars more than FI, but the difference isn't huge!
- Black ss.tc aftermarket intercooler?
- What is this HPTuner Table?? Help??
- Car engine problems need help!
- injen UIC pipe, not the best fit
- hptuner question
- P0089
- EXEDY Clutch Install
- Cool Catch Can, try saying that three times fast lol
- problems need help!!
- boost gauge question
- Vac line routing/boost issues..
- Lsd?
- treadstone blow off valve...
- Fun while it lasted..
- Aem meth kit
- tuning question about mods. plz help
- downpipe with cut-out
- oh noes, whats going on here?
- Aftermarket Intake Manifolds
- Remote tuner recommendations
- Exhaust Help
- Sputter at 4k
- How do you remove the K04?
- axles
- New Tick
- aftermarket turbo setup question
- Just switched to Trifecta. wow!
- zzp intake tube with k&N filter vs k&N typhoon intake
- trifecta select a tune issue
- zzp intake tube with k&N typhoon intake
- removing rear tire
- forged bpv valve vs intake
- More Dirty Valves with pics
- Noob gauge questions lol.
- zzp catless dp question?
- were to buy AEM water/meth kit
- What is the best / quietest 3inch catted downpipe?
- Just Officially Disowned Trifecta....
- Upgrading Rotors / Brakes
- What makes that Cool Turbo Sound when you Shift Gears?
- Precision Turbos Bolt-On Upgrade?
- Thoughts on Muffler Delete
- taking off the bov recirc tube
- what next??
- stupid noob ? bout the whole meth thing
- Locked PCM? Supposed stock tune??
- Custom Oil Catch-Can for the LNF
- q for trifecta owners
- Autowerks intercooler
- Getting Tired Of My Car Running Like Crap Everytime Its Hot Out...
- Q on clutch engageing
- Emissions and Spun Metal Cat?
- Hahn 3" spun metal cat dp/ and MPx 3" exhaust w/ muffler delete
- cel for maf
- Fix for those with HKS BOV flutter
- Can i see a pic of someones ZZP lower cold side charge pipe?
- stock trifecta tune dyno stats
- RPD boost reads 0. No DTC's.
- Just bought 10 SS/T...
- Help Finding A Tuning Shop
- more mods for more power
- cabin air filter
- Oil Cooler for SSTC?
- oil galley
- zzp exhaust noise
- Treadstone Stage 4 Review/Install
- need help to end fight
- K04+ Review by GDUBS
- how much power
- Bulb Check Function
- brembo issue
- LNF tuning questions
- Making pigtails for the LNF Stage kit
- Will this fit
- P0299 and P0030 codes and no boost
- GMS1 Guys
- GM Stage 2 Upgrade?
- p0455- YAY!
- Meth Injection
- limp mode??
- Forge BPV help
- hot and cold pipes
- Rust on my body trying to prevent it!!!
- rough estimate for hp?
- Clutch slip
- p0131 code...replaced o2 sensor
- direct injection fail
- rusting rotors
- MPX lightweight crank pulley
- Turbo boosting too soon
- Bad Mab Catless DP Price Drop!!!!
- Exaust leak sound after catted downpipe install
- tuned LNF speedo lag
- Trifecta tune help
- yup, another MAP sensor question!
- lsj to turbo problems plz help midway threw swap
- LNF Tuning Table
- few mods,few questions
- GMS1 Instructions and Hints / Suggestions
- Front end squeak?
- Favorite/Rcommended exhust?
- P2178. Help!
- stock lnf power ratings
- new to the turbo cobalt..
- LNF Tuning Question
- Installed Ported Throttle Body and Intake
- Installing catch can
- Which plugs
- Quick Clutch install questions
- Spark plugs with Trifecta tune?
- Dumb tune questions
- problem.. looking for answers.
- Sleeper mod ideas...?
- HPTune Cold Start Issues
- Changing valve springs/retainers
- Head/Manifold Porting
- Shifter Issues
- Boost leak check question
- is this worth it?
- GM Stage Upgrade guys, just want to verify...
- hahn exhaust rattle
- Aftrermarket turbo gods come hither please
- Digging this 68 degree night!
- Couple of Dyno Pulls
- Good turbo upgrade for lnf
- trifect air fuel ratio
- Do you need a boost controller to turn up the boost when getting tuned?
- Boost Issues
- a USED k&n SRI
- MPX Muffler Delete
- Vaccuum Lines
- E85 and fuel system issues?
- strange knocking sound in front end..
- Turbo Install question
- LNF stock replacement manifold
- Need New IC and Your Help, Please.
- Low grade fuel question :(
- BEAWARE! dont know if anyone has had this problem
- k&n, DP: no tune
- Intake Manifold
- GMS1 w/ HAHN - Please help...
- GMS1 Sensor Install Question
- Boost issues
- Cams
- Cel p0496
- ZZP Cams Installed
- p0451 and low boost at 7 psi
- Help me out!!!
- Which Mounts
- Woo! Installed my DP today!
- zzp downpipe ?
- Engine ?'s
- 55/57 precision internal wastegate
- AFR Issues and Purge Valve
- hows the dejon intake sri
- Loping at idle on startup...
- Injen intercooler pipe kit
- Dryer hose on intake
- Radiator fluid coming out my exhaust a good thing?
- Hp-Tuner Question
- Show me your side exhaust
- Is there away to make my turbo louder with ZZP ABM?
- bov question.
- Wish me luck..
- tow hook
- This Tick!!!`
- New fuel pump maybe e85
- Corsa Catback???
- Internal or External Wastegate**
- JESEL Rocker arms..
- Cobalt SS Turbo Cutout video
- need some help 2.0 turbo
- Car is a tiny bit hesitant
- Ft Polk Area???
- Ebay Turbo**
- 330WHP Goal
- Motor Build
- Flashing trifecta over HP tune
- Lnf ecm
- loss of top end power with gms1
- What parts or upgrades should i do for my car?
- hahn intake
- Treadstone Stage 4 Kit, Tester Kit avaiable up to 40% off retail for 2nd Guinea Pig
- SS Sedan's with MPx Exhaust STEP INSIDE
- need help with shifter linkage
- ZZP ported head/cams
- Dumb charge piping question...
- used car warrenty
- tick
- hit or miss performance/random boost levels fixed
- Turbo Upgrade?
- CEL codes P2187 and P2261
- best ic between zzp, treadstone and mpx?
- Which exhaust
- how to check a CEL?
- New intake should I ...
- Something in turbo
- updated mix intercooler?
- K&N SRI Coating MAF in Oil
- Paddling noise at start up more frequent
- where can i get a tune in miami
- Megan downpipe 09 cobalt ss
- So, think an easy 375whp with ZZP Head/Cams + Meth is plausible?
- emissions issue/catted downpipe with defouler PLEASE HELP!!!
- what do we need the spring/retainers for??
- The LNF Mitsubishi version stock turbo
- Lowered LNF's w/ HAHN cat-back
- Just installed- Hahn CAI and Pics
- Interceptor Gauge Helppp
- New HeadGasket: Break-in???
- MAF sensor FIX!?
- bpv stuck open?
- Clear Image has intake now for HHR SS
- Noob to bov
- FYI..Muffler Delete
- Noob question
- This is off topic but wanted to know
- gasoline smell
- Stutter while cruising at part throttle
- Key Stuck in On
- k&n intake problem
- Holding boost
- Joining the parade on MAF sensors
- Exhaust info
- Weird, car pulled way harder on my way home.
- Trifecta Tune Needed
- TPMS Reset Tool After Tire Rotation
- zzp stage 1 cams with hpfp cam now p0087
- Bad Mab Catless DP Group Buy
- zzp dp w mpx exhaust
- smoke from exhaust at idle.....?
- Sloppy shifter
- KY Clutch questions
- 09 ss/tc trouble getting into first gear
- HKS SSQV III Fake?
- RPD reading "Data not available"
- BOV problem
- Tuning in the austin area..
- Help me!!!!!!!!!!!!!
- Are there any dyno's proving gains for catback on LNF?
