PDA
View Full Version : 2.0L LNF Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Benefit of puttin a bigger tb on?
  2. HPFP issue/question
  3. From bad to worse: Help Needed!
  4. Plug replacement
  5. HPTuners Near Toledo, Oh
  6. NLS while tuned
  7. Car Blew a Headgasket I'm hoping...
  8. Exhaust keeps sliding off to the left...
  9. EFR pull to 150mph RPD Video finally
  10. Help me pick an exhaust
  11. Machine gun like backfiring at wot
  12. any suggestions/
  13. fuel filter
  14. Some new stuff
  15. gmtu turbo upgrade boost needs a wake up at times
  16. Any benefit in wraping the coldside pipe?
  17. Knock Retard... need help!
  18. LNF Fuel lobe & HPFP..
  19. How many miles to "reset" sensors?
  20. Meth vs. E85
  21. CIA Parts
  22. "Going against the grain" - K&N Intake filter placement
  23. Electrical reset and Catless DP install Question
  24. interceptor question
  25. We are not alone
  26. Videos EFR Pulls and tuning
  27. Who has Hahn lower CP, GMS1 and rotated mounts?
  28. To gut the cat or not
  29. Few questions
  30. Code 236
  31. am i to the point i need a tune
  32. Exhaust gasket (before Downpipe)
  33. Air Intake Tubing
  34. ss/tc rotor size problem
  35. Upper charge pipe loose
  36. Forge Motorsport BPV Spring
  37. Electric cutout
  38. Bad Fuel Pump
  39. p0101 - need help
  40. In need of a tuner
  41. efr finally running right!!
  42. Boost leak test help
  43. bolt ons/turbo upgrade question
  44. Ecotec Fuel Injector tools list..
  45. FL and RFL turbo xs exhausts
  46. Honeycomb in intake tube
  47. smoking after boost?
  48. LNF 3 Bar Sensor Install
  49. Things 2 buy before a turbo upgrade???
  50. Treadstone turbo kit for lnf? Any good?
  51. Whats next upgrade?
  52. Back fires at WOT
  53. anyone ever replace a feed line?
  54. 09 solstice gxp horsepower
  55. Cold Start Multiple Cylinder Misfires 09 SS TC
  56. what exhaust do ya'll suggest?
  57. Gasoline fuel ? ethanol free vs 10% ethanol
  58. Mpx catch can
  59. Lowering springs
  60. Painting LNF valve cover questions.
  61. how much do you pay for a LNF
  62. Catch Can Air Flow!
  63. Engine Choking
  64. Check turbocharge output
  65. I keep getting the p0236, how do i fix??
  66. turbo outlet size
  67. ZZP S1 Cams
  68. E-Brake Issue (Not Holding even when tightened)
  69. E-Brake Issue (Not Holding even when tightened)
  70. Heeeelllllp!
  71. My Turbo turned into a Supercharger
  72. BOV Question
  73. smoking issue
  74. EFR turbo help, pcv hose question
  75. Which clutch?? Ordering today!
  76. Trifecta budget tune and AFR's
  77. 2009 chevy cobalt tc
  78. Does Anyone have any dyno #'s for Trifecta Budget Tune VS GMS1 ?
  79. New Catch can install
  80. ZZP or MPx
  81. Stock injector threshold?
  82. Tuning Question?
  83. Need a GoPro...but heres a slow shift 60-~140
  84. LNF Issues Need Help
  85. Dyno'ed today :) Vid if you are bored - S256et
  86. wheel spacers
  87. Treadstone Investment Cast 304 Stainless Turbo Manifold!
  88. Tuner near D.C.
  89. Factory Upgrade Turbocharger - GM LNF-Equipped Vehicles
  90. Mod ideas?
  91. meth
  92. HP tune
  93. car running like crap p2297 code
  94. Trifecta question
  95. another no boost issue
  96. Forged bpv or stock?
  97. Show Off your exhaust!
  98. question on some problems
  99. Anyone have Hahn race exhaust(straight pipe)?
  100. New found Problems!
  101. BOV Question
  102. Custom water and oil lines?
  103. Finally Trifecta Budget Tuned!!!
  104. Straight pipe exhaust
  105. friend bought me modern performance dp
  106. LNF Fuel Raid
  107. Cobalt is gone!
  108. Burning oil...at idle only.
  109. Boost Guage saying No data Available
  110. p0300-302 codes
  111. My Build: Project EFR
  112. how big is our stock resonator??
  113. Boost leak testing
  114. Lower or Upper ?
  115. Symptoms of bad throttle body?
  116. catless dp + muffler delete opinions
  117. PA tuned?
  118. Maf Leak
  119. Tensioner Questions.... on my second one.
  120. uh oh!
  121. Is this a safe nitrous kit?
  122. Badmab LNF Downpipe
  123. Where to buy copper plugs
  124. Trifecta Budget Tune
  125. 35 Wet Shot on 2.0L LNF GMS1?
  126. badmab catless dp? on rust
  127. NLS gone bad?
  128. MPX Oil Catch Can Hook Up Help
  129. Missfire/Cutting out under boost
  130. No Spark
  131. misfiring
  132. WOT (Trifecta Budget Tune)
  133. ZZP Tune with GM 3 Bar question
  134. Any product to combat torque steer?
  135. Compound turbo LNF ~700hp goal
  136. oil leaking :(
  137. Sea foam v bg44k
  138. how much vacuum at idle
  139. Cobalt ss/tc vs. The new bread of tuner cars
  140. Thoughts on Pwerks LNF EFR "Raw" Turbo Kit
  141. my efr update
  142. ZZP Intercooler
  143. Gms1
  144. LNF Valve Gunk..
  145. 3 bar map sensors
  146. Direct bolt-on turbo (ko4 replacement)
  147. Treadstone radiator hoses?
  148. Which Boost Gauge should I trust? LOL
  149. MPx Downpipe bung sizes?
  150. forged bpv flutter
  151. Next mod opinions?
  152. Factory stock LNF spark plug images pulled @ 67k miles
  153. Next mod?
  154. P0101 code
  155. Fuel Pressure Problem Solved
  156. what is the best muffler?
  157. .55 a/r exhaust housing too small to run high boost levels on?
  158. Look What Came In the Mail!!
  159. BOV or no?
  160. GMTU in Delaware???
  161. Backfire & Sputter
  162. Why me only push 10lbs of boost!!!!!!!!!!!!!!!!!!
  163. Treadstone FMIC + Piping
  164. KY Stage 3
  165. GMS1 and Bolt ons
  166. Boost problems
  167. Over Boosting
  168. blew up 3rd gear
  169. Charge pipe question
  170. Replacing shift cable rod
  171. gmtu turbo upgrade turbo boost drop ?,s
  172. HP tuner Help.
  173. TWM Cable Clamp
  174. Is tune needed for the K&N SRI
  175. Compression makes me happy!
  176. Stock turbo(Ko4) life???
  177. Can't shift into 5th
  178. catch can baffling
  179. Interceptor Missfires?
  180. o2 sensor?
  181. TOB question for sebleroux
  182. Car=Limp mode?!!
  183. dreaded p0236 and flutter
  184. bone stock to 115mph trap, how?
  185. bolt on build, best combo?
  186. help me... with a wastegate pic
  187. 5th injector?
  188. Possibly trading the SS for a 335i 6spd
  189. Build list/how-to/tips
  190. Adjustable Launch control Via Hptuners
  191. valve cover breather nipple
  192. Time for some Supra rolls!!!
  193. Tune ????
  194. K&N Intake and blow by
  195. boost squeak ?
  196. efr pull and idle
  197. issue with treadstone lower charge pipe.
  198. Need Help - Valvetrain???
  199. Doing modifications in August, need suggestions
  200. Melting wiring loom
  201. Turbo XS 50/50 valve
  202. Help! Car won't run. Prepare for a story
  203. Knock / Octane
  204. Dyno'd my 08' SS/TC
  205. Couple of TC ?'s for the turbo n00b
  206. Catch can project
  207. tires
  208. Future mod questions
  209. Maybe a better way to bleed the clutch.
  210. How many of you guys run E85 on the weekends?
  211. I need a tune!
  212. Best Tuner Competition!
  213. turbo swap question
  214. hey guys thinking of going E85 need input
  215. Anyone ever try this part?
  216. seafoam/spark plugs
  217. GMS1 Funny sound before reflash
  218. New LNF Fuel Injection Possible group buy ?
  219. 2012 Grandsport Vette vs '08+ SS/TC
  220. ok need advice
  221. Oil Catch Can
  222. Major Fuel Pressure Drop on WOT
  223. Dejon Charge Pipe
  224. Photo Required - Fuse Box
  225. muffler delete or MPx mufflerless?
  226. "GM's New Turbocharged Four-Cylinder Ecotec Laughs At Imports"
  227. 2010 Cobalt tuning issues.
  228. Cold start grind/rattle? (video)
  229. Tuning question.
  230. Help
  231. New exhaust ? :)
  232. Adjusting launch control on trifecta tune
  233. Anyone ever pop their shift linkage out?
  234. jmarks's LNF sedan turbo swap
  235. Any thoughts on these turbos?
  236. My e85 tuning
  237. best clutch for 400whp thats nls friendly
  238. Torque Steer ??
  239. Looking for someone who can tune around Dayton, Ohio!!
  240. EFR ready for install!!
  241. Possible bolt on fuel upgrade!!
  242. Meth Install Question
  243. ZZP shortened intercooler on track
  244. Mongorat sold me a few things....looking like its gonna be fun but worth it...
  245. Motor Build?!
  246. I'm just gonna leave these here....
  247. Meth killed my engine.
  248. Trifecta Budget tune Or GMS1 ?
  249. Starting to tune for e47 any advice?
  250. Spark plugs
