- turbo manifold question
- pully
- Brands
- info
- P0327
- LNF exhaust
- Cold start idle problem
- 2.4 tb
- pix of cam gears/help with timing
- sc tear down and some questions
- 2.2 turbo question
- ahhhh wont start!
- Stock 2.2L Dyno Graph?
- loss of compression
- Thinking about trading in the cam-balt
- MAF & O2 problems
- Ram air hood
- need a wiring diagram for the 2.2 ecotec
- smaller pulley question
- Finally a new upgrade for the balt!
- Pontiac G5 help
- lsj throttle body
- Exhaust piping size?
- new to be boosted LS engine code
- i want to unlock my pcm
- stock air to fuel ratio
- 100k mi maintenance/performance suggestions
- time for a new clutch
- Couple of Exhaust Questions
- Exhaust Swap
- 06 Cobalt LT still stalling out, I need help
- Normal temperature for fan to kick on?
- woooooohoooooooo!
- weird hiss after installing 2.5 downpipe
- Suspension
- 2.2 sc question
- LSJ springs
- rear o2 sensor and emissions help
- Help with magnaflow muffler please
- Motor and Trans. mounts... Whats good?
- 2004 Ion question
- new engine
- Internal Help
- fineally got my car boosted and tuned
- Need a simple answer
- Intake Manifold WANTED
- 2.2l l61 tuning
- serp belt replacement
- New intake, have a question about VC breather
- Parts for Turbo Build
- 2006 ecotech cam
- SLP Loudmouth 2
- my L61 SC cobalt
- More HP Gain from Short Ram or CAI Intake???
- Cobalt LS to SS seat swap
- Need Help!
- LNf rods on a 2.2
- New Rotors??
- 20 psi cobalt turning over not starting
- building for e85 and more boost
- Piston/Rod Build Need lots of advice
- I just got $1750, 2006 2.2 LS
- walbro pump
- TWM Performance Cobalt Short Shifter Kit GROUP BUY! SAVE 15%!
- First EVER FULLY Built Sedan Cobalt With TVS!!!!!!!!!
- P0304 error Code
- Fuel filter
- Massive Oil Leak
- Some clutch issues
- fuel pressure
- Quality Spark Plugs?
- stage 2 colder plugs for 2.2
- crankshaft pulley silicone?
- Bought my first car!! Have Questions.
- ticking.. fml
- Header Back Exhaust Questions
- Wideband
- ottp longtube issues
- Calling on you 2.2 guys for help
- rotten egg smell
- Vibration at 90km/hr
- rush rewire 2L map sensor
- new custom turbo kit
- new turbo ecotec
- Thinking about a turbo -s/c on my 08 hhr 2.2 what parts are needed
- First post here, need help with first repairs/mods to '08 Cobalt LT
- 2.2 HP tuners question
- Denso Iridium Spark Plugs
- Will a TVS fit a hhr
- Ported S/C will it help or hurt
- Cold Air Intake Problems
- Cobalt ls 2.2 muffler delete question HELP
- RPM Idle for cams
- 2.4 intake mani mod on 2.2?
- downpipe and headers, noob
- removing the oil pan help!!!
- 2.2 vs v6 stang
- Main Bearing
- strange header
- performance exhaust manifolds
- How to take off intake.
- header w/SAI
- 07 motor in a 06 cobalt
- 06 vs o7 crank
- springs and valves
- Choosing a turbo
- im a NOOB so help me out.. plz
- Cheap mods for a 2.2?
- Bad Mab Header on 05 2.2's
- Bad Mab Header group buy
- Clutch opinions......
- Exhaust manifold gasket
- Best oil
- Cobalt rear disc conversion
- 06 cobalt 2.2l build questions
- 2.2 vs 2.4 intake
- 3" or 2.5"??
- 21 psi bov problem
- Finishing exhust work
- Performance Chip ideas.
- Strengthened synchros for F23?
- How many bolton 2.2L Cobalts have killed k20 civic's with mods?
- Exhaust help?
- what to do
- Trouble steering
- "Low" gear question?
- l61 guys.... Has anyone been tuned with HPT yet?
- Fitment Problems
- Another S/C 2.2 BUILD
- SS side skirt..
- M62 list price
- muffler question
- Ugh dreaded CEL =(
- 2.2 supercharge question
- looking into turboing l61
- ZZP supercharger kit..... anyone have it?
- tsudo issue
- quick question
- Cleaned Throttle Body, idle surges now
- brake booster delete
- Gen 1 vs Gen 2 block?
- Where I'm at so far......
- Stage 1 vs 2
- Cams?
- Wheel Spacers
- cobaltalex's SC 2.2L build thread
- New Ebay Header, Anyone Tried it?
- hpt tune ecu 08 hhr 2.2
- help with increasing performance
- Rods?
- Anyone have a Progress rear sway bar review
- couple questions
- New Bearings today
- Gas Tank Hole Help
- Intake inner diameter.
- LNF swap?
- Pistons 4032 alloy?
- night_thrones NA build
- AC delete question
- 2.4 header for sale
- p0107
- Painting car help #
- custom turbo kit have a few questions
- beaten bush and a dead bird on boost.
- camshaft position sensor
- Who has the turbo 2.2 cobalt in LAKE ORION MICHIGAN
- 2006 no A/C...please help?
- Couple performance and a Trifecttune question.
- Differences (if any) between the LE5 2.4L manifolds
- Maybe the Third Time Is the Charm? (Another blown engine)
- no more oil pan!!!!
- cat back fitment
- build 2.2 or buy ss ss turbo
- Intake manifold
- 2009 SS/TC seats_ Comfortable?
- Crank Pulley Bolt Size
- my gas millage?
- 2.2 M62 exhaust question(opinions needed)
- And the neverending problems continue...
- Cruze SS
- Next Mod..?
- Will if fit?
- 2.2 with aeroforce?
- What exhaust? Or lowering springs?
- injectors going static??
- How much could i push out of the motor?
- Weird Muffler just curious
- Injen Intake Filter
- Boosted! Tranny upgrades
- What are the cheapest body kits
- is it really "serviceable" with the engine in the car?
- 2.2l comp cams
- how much gain?
- lsj manifold
- internal specs?
- rod bearings
- L61 & e85
- best bang for $ on 2.2 (07)
- spring
- Raiden8816's Supercharged Build
- what is shift plus?
- Loud Pop when turning all the way Left
- 2.2l Turbo Guys Help Me!!!
- looking to add turbo or sc
- a little decision making help.
- 2.2 engine
- what i need options please
- Building up for boost! Questions
- CA V2 header w/SAI
- Injector Question
- My car doesn't like e85? or is my tune bad?
- motor swap? take it thru the top?
- LSD kit for the 2.2 manuals
- LNF Exhaust
- how do i install a water temp gage on a 2.2 eco
- Burnt out light
- Best intake
- coolant temp
- supercharger
- GMPP exhaust and header
- and another 2.2 going turbo
- need info
- Stock DP and 2.5" exhaust Question
- header/dp?
- 2.2l Turbo Spark Plugs
- My car walk around
- Driveby, 2.2L,Pacesetter Header,3",Cat/Res.delete,ebay muff.
- Exhaust in my garage
- Holy hell
- Fuddddggee!!
- 2.2l turbo kits
- Good Shock/Strut Package to run with sportlines
- cobalt cammed
- Need help deciding on spark plugs
- I'm poor...
- Tranny Issues
- I have a 2.2 with the L61 what size pulley should i use
- Looking for a downpipe.
- P0300 code on 08 Cobalt XFE
- 2.4 IM worth it?
- so im confused as shit
- question
- bump steer on 2.2 auto...
- what next?
- Need opinions, turbo or s/c
- Any idea what belt size?
- 500$ what to buy next
- Replacing valve cover gasket after removal?
- Code p0496
- Help!!!!!
