- Are there crank timing marks?
- can i go rear disk on a 4 lug?
- another issue
- parts interchangable.
- Installing ingalls torque dampner on 05 lt
- aftermarket coolant gauge
- optimum exhast diameter
- Where to get Eagle Rods best price?
- tune/new pics
- ZZP on ION? :X
- about flexpipe problem
- Coil on plug questions
- 2.2 ZZP S/C Kit Issue
- option B tank
- does anyone have???
- i need help
- My Dyno Results...
- 2.2 Turbo Fuel Delivery Problems
- S/c for 2.2
- Smaller Pulley on my SC'd 2.2
- 2.2L Mod Capabilities
- Exhaust Help
- Starter or battery
- LSJ throttle body into an L61
- need some added horses
- lowering springs install
- need help.... -___-
- torque specs?
- cars keeps dieing when I give it gass
- F/I cost and problems
- ZZP kit or build my own?
- what to do next
- my opel speedster z22se (L61)
- where to find GOOD parts.
- 06 head on 07 motor
- Tuning
- FINALLY New Exhaust
- my question to U!
- right after winter..
- 2.4 mani
- 07 cams
- Whats The most...
- spark plug mod?
- Trifecta dealer???
- Spray!
- New...
- header to downpipe bolt size
- carbon fiber hood
- cam gears mixed up?
- Will my.....
- thinking about a new clutch.....
- 2.2 s/c people
- this is a tune issue?
- Cam Position Sensor
- Question on K&N Intake
- could my tune be bad??? really PO
- ? for turbo guys
- Standard Eco vs SAI
- help asap! random missfire
- Injector harness
- Lets talk 2.2 sonoma performance.
- Catless 2.2
- TB wiring diagram
- header
- Thinking about QTP electronic cutout....
- Ordering Trifecta
- Fuel rail question
- 3rd gen halos
- I NEED THE 2.4 mani for a 2005 2.2
- ideas on guages
- 2.4 exhaust mani/dp
- Headers!
- Lsj headers on 2.2
- Spark Plugs
- Pros and Cons of Turbo Charing the L61?
- 2.2 auto SC build, Parts list!
- Bigger injectors?
- ful bolt-ons and tune
- engine sale
- 06 LS bogging / speedo issue
- Wideband location
- timing chain hell
- 2.2 Valve cover painting ideas?
- hp question
- 375WHP cobalt tranny problems
- Ls to lsj brake conversion kit
- Spark Plugs???
- high idle help!
- Dyno
- saab 2.2 turbo build
- Well this is a new issue lol **read**
- Next option for most power gain
- Automatic to manual swap
- loss of power
- need help with these codes please!!!
- Has anyone cut there stock maf out and made there own CAI?
- Clicking noise while braking
- Racing Solutions header... performance and MPG
- Bunch of retarded questions..
- Help asap!!!
- weird engine noise
- squeak
- Painting intake manifold
- 2.2 performance valve springs?
- tail light fuse??
- Jet Performance MAF
- 2.4 IM/TB on a 2.2
- SS intake manifold
- Cams
- anyone have an idea?
- Best Headers & Downpipe for the 2.2L
- K&N Intake for 2.2L
- 2.4 Intake Manifold
- CED Intake manifold
- need help quickly!
- trifecta Tune help
- Tsudo exhaust+mpg
- HPTuners beta test for 2.2 reads 07 ecm.
- Racing a Truck
- short throw shifter
- Best time to shift
- Need help like now!
- Head Gasket
- LSJ on an L61
- Tune
- what 2.2 has ZZP Stage 1 turbo???
- Wideband Readings?
- OBX header/dp
- 2.4l intake manifold and throttle body.
- Harrop HTV1320-LSJ Supercharger on a 2.2L L61
- interferance
- Serious Advice On Options
- need honest advice, looking for the next step
- golden eagle sleeves on ecotec
- tsudo exhaust popping
- trifecta dealer
- Gmpp
- Gear ratios
- Spark Plugs
- Tsudo exhaust issue
- Exhaust install parts list... (picture)
- Injen or AEM intake
- Coolant reservoir really low
- stock clutch specs
- secondary air delete
- Compilation thread: Tsudo exhaust
- Simple question
- tune question
- I need a good trouble shooter, HELP! m62 powered l61
- lets be real. Hp and Torque
- Girlfriend wants to supercharge her alero with 2.2...
- wat could cause low vaccum
- Best Exhaust for 2.2L?
- Help please
- surging and misfire issues
- Glowbalt's SC BUILD THREAD
- Is this the tsudo n1 exhaust?
- Tuning AFR question?!?!?!
- Point me in right direction please
- Seeing as I'm cheap... (Tsudo)
- FI on stock internals
- Loud clicking noise..
- Custom exhaust build
- AC Delete on my 2.2 G5.
- LS4 TB vs. LSJ TB for 2.2 supercharged
- Spanky's 2.2 Turbo Build....Stage 2
- how to datalog for trifecta
- oil in inlet manifold!
- auto tranny performance parts
- need help with a few issues on new turbo and engine build
- I need help from a fellow 2007 2.2L L61 owner!!!
- Header Down Pipe Exhaust
- 60lb injector help
- Bad shaking I cannot figure out
- Lsj stock Map sensor Question from Becks M62 install.
- Front cover gasket???
- Mileage Problems
- Possible 2.2 HPTs support
- Help!!! WOT Cuts Out
- Stock engine with trifecta tune?
- sleeves
- baffled/gated oil pan
- Tach box, 31 pin connector
- wanting more hp
- Most powerful l61?
- Anyone have instructions for wiring the Stock Lsj 2.5 bar map sensor?
- Grille
- Ac delete
- trifecta..
- LNF 2.2 question
- Cobalt s/c kit
- 08 Question
- Dam Car Help Please
- Rear Disc Conversion
- suggestions on problems???
- 07 SS guage cluster in 08 2.2 doesnt work
- What CAI?
- Is this the same for everyone? HVAC
- clutch slippage 2.2 SC
- Grindedge
- 2 stage colder plugs
- header/downpipe options
- need some help selecting my tune
- Valve cover breather covered in oil ?!!
- LNF manifold?
- boosted 2.2's sparkplug gapping
- 2.2 2005 Cobalt Misfire. Please Help!!!
- ION Redline springs
- red tipped plugs
- Elm327 Diagnostic is sweet!
- Revels 2.2 LS/SC pic thread!
- Interceptor not powering on
- boosted now gettin random misfire cel???
- The Turtle is back !!! :)
- L61+jetfuel=???
- 2.2 sc people..got a question
- Pistons???!
- Replacing GM Chip Help
- 2.2L alt pigtail?
- MisFire?
- Supercharger Build on my 2.2L G5
- SS Lip
- Weird noise
- 05 2.2 problem.. think i have it figured out but need advice!
- should i get the gmpp exhaust
- any body know the part number to the fuel line??
- Which one?
- quick boost gauge help
- Exhaust Header!! In Need Of Serious Help
- sc swap issues again
- i need a stock rod/piston
- need help
- Saab turbo manifold
- ill give someone $50 to figure this out
- Question ss/sc injectors on a 2.2
- Major electrical problem...
- is this normal with a stage 2 clutch?
- SC kit first start up. WONT START! HELP!
- stock exhast with mufller/resinator removed
- question with 2.2 with 2.4 intake mani and injen intake (automatic)
- HELP! WTF! sparks
- Trifecta tuning question.
- how do u remove the passive tc?
- 8pins to 6pins diagram (l61-le5)
- 2.4L Intake Mani & TB on 2.2L?
- head compatability
- Revels 2.2 SC Build Thread
- naturally aspirated 2.2
- Fujita CAI
- Magnaflow or Vibrant
