PDA
View Full Version : 2.2L L61 Performance Tech
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. lsj trans mounts
  2. wet shot to manifold
  3. compression check today:
  4. stronger cv shafts/ axels????
  5. Exhaust
  6. What do I need???
  7. ZZP 2.2/2.4 SC kit installation CD
  8. which brake pads
  9. Squeaks!!
  10. Help with code P0496
  11. need plug for m62 map sensor?
  12. map sensor
  13. wtf car feels slower then normal
  14. help with cluster
  15. Advice...save for 240sx or keep the ls and put more money into it?
  16. Quick Help! Wideband buying option
  17. New Fuel Injectors???
  18. 1-5/8" OTTP LongTube Header on 2.2L count.
  19. Tsudo sounds like?
  20. Need some advice...
  21. Axel help
  22. idle stumble NEEEDD HEEELPPP
  23. Still confused about Option B
  24. Where can i buy this?
  25. what dp is everyone running on there autos
  26. stock electric boost gauge on 2.2
  27. bouncey idle s/c 2.2
  28. Throttle body for a 2007 2.2
  29. Question regarding Rockauto Part Listing (noob)
  30. Do I need a tune....
  31. not boosting like it should?? uh oh!!!
  32. How (UN)Lucky Am I?
  33. I'm looking for a short shifter
  34. need help with 2.4 intake mani
  35. Upgrades
  36. 2.2L Exhaust Help PLEASE!!!
  37. GMPP Intake + GMPP exhaust or Magna Flow catback
  38. 4000 rpm stalls
  39. tsudo
  40. ok HUGE PROBLEM
  41. thinking about a DP on my 2.2
  42. low idle issue
  43. Quick question! URGENT!
  44. I have a jerk in my car
  45. GM Performance air filter?
  46. cold air intake problem?
  47. adding a supercharger?
  48. 42 lb injectors
  49. question?
  50. L61 head on LSJ block??
  51. radiator fan
  52. New Guy...Technically
  53. Stock intake NOS-safe?
  54. question???
  55. MY car finally gave out last night
  56. Need help!!!!
  57. Weapon-R oil catch can not working
  58. 2.4 intake mani
  59. Spun a Rod Bearing
  60. TB mod!!!
  61. 10:1 vs 9.5:1 forged...Boosted 2.2L
  62. o2 Sensor
  63. exedy stage 1 and lightened flywheel
  64. GMPP Honed Exhaust Manifold?
  65. Intake Question
  66. ? for thoes who have been tuned
  67. balast resistor
  68. AEM UEGO Oxygen Sensor Location
  69. ZZP Mid-length Combo and Vibrant Exhaust
  70. LSJ Ex. Mani and DP
  71. exhaust for 2.2L Sedan
  72. 2.2 MAP sensor
  73. Anyone with a 2007 Cobalt??
  74. Problems, please help!!!
  75. Stock ss exhaust vs stock 2.2L exhaust
  76. Header for 2009 LS?
  77. temperature fluctuates 183-218 degrees
  78. spun rod bearing
  79. Motor/trans mounts
  80. Gas mileage drastically different by brand
  81. Coolent
  82. Wtf?!?!?!? Whats wrong?!?
  83. Rockstar's SC build thread
  84. Fuel Pump Not Working after Tank Swap
  85. Disc brakes?
  86. 2.2 upgrades
  87. Exhaust Cut-Out
  88. exhaust manifold question
  89. Hydroshield Question
  90. First Mods/Photoshoot
  91. 6 to 8 pin lsj tb conversion
  92. U0101 ????????? help ASAP
  93. AEM Boost and Wideband ?'s.
  94. what is the purpose of the hole?
  95. When i check my oil it has a milky color?
  96. Hot Supercharger!!!!
  97. Exhaust
  98. Widest tire (stock steelies)
  99. if you are N/A stick with 1 5/8 prim 2.25 exhaust for maximum hp/tq
  100. ZZP S/C Kit?
  101. krautsalat 2.2 sc build canada
  102. gm book?
  103. Crankshaft Position Sensor Waveform- needed please
  104. Throttle Body Help
  105. lsj to 2.2 l61 throttle harness
  106. New clutch, lightened flywheel Y/N?
  107. wot box help
  108. clutch
  109. 2.4 manifold crank seal
  110. just wondering what you think..
  111. Spark plugs
  112. Anybody notice...
  113. bigger injectors
  114. OTTP axles
  115. Cosmo Short shifter
  116. Rod doesn't fit in Piston???
  117. Couple questions, new to the scene
  118. 2.4 Intake Manifold/TB Questions
  119. Do I really have to do this?
  120. upgraded axles
  121. power?
  122. supercharger mount question
  123. ADVANCED: Idea for Dual exhaust on F/I 2.2's
  124. Do I need this?
  125. dans build
  126. exhaust question
  127. objectif 13s' N/A
  128. My Build.
  129. belt change
  130. ecolag power
  131. check engine light, but no codes?
  132. 2.2 supercharger or turbocharger
  133. Excedy stgII clutch install
  134. Exhaust and header?
  135. cams?
  136. 2.4 IM and TB for MPG's
  137. SS Valvecover
  138. Governor?
  139. What is a good super charger kit
  140. loss of power
  141. Biggest tire?
  142. Turbo Vs. Supercharged.
  143. 2.2 tune
  144. Piston oil cooling jets on L61
  145. Do I need...
  146. LSJ or LE5 Throttle Body
  147. Gas Tank Problem
  148. ATTN: L61 Members running a 2.4l Throttle Body
  149. Don't know what to do first...
  150. A/c compressor fitment question
  151. Fast 2.4 IM Help Please
  152. Magnaflow or GMPP Performance
  153. 6 pin to 8 pin conversion help
  154. Lsj dp and header
  155. need some help
  156. machine fly wheel? throw out bearing??
  157. piggy-back ECU
  158. Transmission Swap
  159. backorder!!!
  160. 2.2L ZZP SC Questions
  161. N1 catback exhaust system
  162. Ordering some parts.
  163. Crate Engine?
  164. Will this work?
  165. 200whp N/A?
  166. Need help..
  167. exhust
  168. Final clutch post from me
  169. Most power i could push safely before having to rebuild
  170. downpipe for the 2.2 auto
  171. 2.4l Intake Manifold Installation Help
  172. Sh**ts and giggles. Top mount intercooler?????
  173. Excedy stgII arrived
  174. Getting CA XTC 2.5" Downpipe. :)
  175. help with sc build
  176. Cooling system question
  177. Running lean... help. pls
  178. had anybody heard anything
  179. will fit?
  180. Exhaust help
  181. 2.4 intake mani and LSJ exhaust mani?
  182. Quick Fuel Question
  183. Pulley Question
  184. Nitrous Set Ups
  185. SC kit on ebay!
  186. Engine Dampener
  187. DownPipe?
  188. Clutch help.
  189. 2.2 l61 internal limits
  190. cobalt intake work with sunfire?
  191. header
  192. Clutch suggestion
  193. need help or idea
  194. Dual Exhaust
  195. turbo
  196. need a clutch kit
  197. Hahn Intake Manifold
  198. Vibrant head/ DP combo
  199. D/S rotors
  200. fitment question
  201. The Perfect 2.2 Exhaust (06 to be exact...)
  202. Turbo Mani for a 2008+ 2.2
  203. Trq spec for tensioner?
  204. Bad MAF?
  205. 4-lug gm wheels
  206. L61/LAP Turbo/Super (Forced Induction) Build Thread
  207. 2.2 exhaust swap.. loss of power?
  208. last minute checks
  209. power windows
  210. control arms
  211. Help, Decision!!!!
  212. How much power?
  213. Raspy exhaust!!!! Help
  214. 2.2 to 2.4 conversion
  215. 2.2L 5 speed shifter
  216. 2.2L intake manifold vs a 2.4 L intake manifold
  217. 2.2L underdrive crank pulley
  218. The Luxurious Cobalt
  219. Suprised!
  220. Pulley Question!!
  221. cobalt 2.2 s/c question
  222. LSJ On l61
  223. transmission fluid
  224. downpipe 4 a 2.2l
  225. 2.4L cobalt manifold on a 2.2l cobalt
  226. running injectors from a 06 2.0 supercharged cobalt to a 2.2 ls cobalt
  227. Belts and Hoses
  228. New parts for the cobalts :)
  229. Supercharged 2.2l vs. Turbocharged 2.2l
  230. 07 Valve Cover Part Number
  231. s/c install help
  232. Mounts worth it?
  233. I love zzp!!!
  234. Strange Clunking Noise
  235. Going to the track tonight
  236. Possible TPS failure
  237. Attention 2.2 supercharged
  238. oil
  239. This wasnt what i wanted to do
  240. taken her apart
  241. running lines for ic pump on zzp turbo kit
  242. Help me!!
  243. Rattling noise
  244. zzp stage 2 kit
  245. DragonkingG5's Supercharger Build
  246. 2.4 TB on 2.2 help.. YES/NO
  247. Need Help Installing GMPP Intake.
  248. 2.2 head
  249. insurance cancelleddd!!!!
  250. Synthetic Vs. Regular Oil in a 2.2
