- ZZP Turbo....Stage 2...2.2...
- Opinions Plz
- New turbo kit from Treadstone Performance
- whats the ideal
- Valve springs
- cel after fujita cai install
- Downpipe Throw Code
- Downpipe :) By Mandrel Exhaust Systems
- Performance questions
- meth on a 2.2
- piston help!!
- Throttle Bodies?
- trifecta tuned
- 2.2 SC Thread
- i think this is amzing
- get back into the balt n boost or not?
- LSJ Exhaust Mani on 2007 LS
- Quick Intake Mani/TB Help
- balance shaft delete install
- Tsudo catback question
- Trick the computer?
- Half of an exhaust.. Lol.
- quick filter question
- Transmission/Turbo Question
- transmission build
- Vulcan Turbo intake Manifold
- idle fluxuation
- i fukkin hate my car
- vibrant hdr/dp no gasket?
- Lowering spring question
- What next?
- 2.2 trifecta tune ?'s
- bad starter?
- govenor?
- 08 Cobalt 2.2L, Auto Trans, Trifecta Tune Review
- sprk plug question
- zzp turbo kit pics
- ZZP sc kit?
- How much HP can a stock 07 2.2 auto tranny take??
- oil pan question
- Transmission race mounts
- New to the form, but have some question
- How hard is it..
- Heres a question
- I'm stuck guys
- Turbo Tech Racing Question
- 60k service
- Auto to Manual Swap
- brake drums
- exhaust help
- Tuning software
- team green lsd?
- Cams for 07+ L61
- Will this injen CAI work?
- max whp with m62 stock compression
- *ANOTHER* LSJ Header/DP question
- What header should I get?
- Header & Lowering springs
- How much HP gain?
- How to tell the newest Injen CAI?
- WOnt stop misfiring?!
- New fan!
- E3 Diamond Fire spark plugs????
- Where to get a tune (I searched)
- What route are you going? - 2.2 only please!
- 2.2 Tsudo Exhaust
- 2.2 L61 SC question
- Lookey what i got for my sc!
- 60lb injector help
- so small issue =/
- Header and DP Combo??!?! Vibrant = a little to much
- new exhaust
- Gains from certain mods??
- Need help, new clutch
- Codes!!
- Possible?
- Oh S$%^ Oh F%^& .......Please help asap!!
- Exhaust and Intake Question
- 2.2 sc build thread
- trying to sc this cavy
- Bad luck!
- lsj supercharger?
- 2.2 sc compression options
- Spark Plugs?
- Supercharger may be coming my way!
- P0480!!!
- Going to the Dyno sat. Any guesses?
- Need help and opinion
- Magnetic drain plug.
- 2.2 Turbo Kit
- Walbro 255 Pump
- exedy stage 2 clutch
- part are finally coming together
- Options....
- blinker module?
- f23 tranny question
- Oil in the intake?
- Adjustable tensioner on 2.2?
- Who can cryo a F23 and $$$?
- my door would not open?
- been a long year so far for the balt
- engine build time!
- cross strut tower brace?
- Filter for my Injen intake?
- My new exhaust setup.
- 2.4 tb
- Speed Limiter
- Installed Tsudo Exhaust =)
- You guys are my last shot.
- Help me i am SCing!!!
- Clutch question
- Goodyear Gatorback
- trifecta
- Code thrown!!
- 3rd day in a row im having problems with my car. overheating
- help with lighting
- battery dies/ key stuck in ignition?
- 2.2 throttle body on a blower
- Engine Loping Issue with 2005 stock
- 05 ls 2.2 motor blown. will 07 2.2 swap
- stalling ??
- stalling ??
- power steering problem
- 2.2 Alternator output
- i need a motor
- injector boots
- SUPERcharged!
- my alternator is making sounds
- cheapest place for blower cams?
- Replacement filter for injen filter
- upper motor mount help!
- Cold Air Intake Problems (Engine Choking?)
- engine breakin?
- online retailers.
- cobaltracr's car rebuild
- making her whine
- MRZ Redesigned crank pulley
- Difference in numbers
- Thinking of Turbos. Whats suited for my application?
- Typical Problems for our cars?
- 2.2 throttle body spacer?
- Service Air Bag light
- 2.2 manual upgrades
- Do You Regret Camming Your Balt
- 2.2L blower cams..
- break in period
- supercharged project question
- supercharged build problem
- serpintine belt for sproket driven
- Grille question.
- pullys
- Pros of NA Build?
- viper security help
- How is this sounding so far..?
- Rebuilt Turbo Kits?
- comp cams
- 00-04 ecotec head work for 05-06 ecotec head
- Grinding going into 3rd
- custom intake manifold
- anybody running this...
- l61 auto to lnf 5 speed
- t3/t4 piping setup?
- Is the Pacesetter header CARB legal?
- Went to the track
- Trifecta Time!!!
- co2
- been looking at these...
- 2.2 Power Windows
- Is meth worth installing???
- MRZ Crank Pulley and others
- ZZP Supercharger kit
- lean code
- LNF is need of assistance from a 2.2 brother
- underdrive or overdrive?
- Is this shit for real!?
- simple question...
- Simple and cheap mods
- Fonzi1289 turbo build commencing!!!
- is it possible to run spark plugs
- Headers!!
- quick brake booster question
- Serious thougths only
- installed the 2.4 mani tonight
- 3 Month history of my car....
- control arm bushings? who has em?
- Performance Seats
- installed d/s rotors...looks awesome :)
- low voltage issue
- can a 2007 2.2 w/o SAI be tuned?
- Will this fit?
- is it possible to move
- performance advice 06' LT auto
- gauge cluster
- CAN ANYONE ANSWER MY FREAKING QUESTION :confused:
- Preparing for SC, which internals should I upgrade?
- 2.2 liter ecotec engine MPG.
- 2.4tb.......got torque?
- Stage 3 Comp Cams....Anyone done it???
- 2.0 map sensor in a 2.2?
- Painting the spare valve cover
- RPMs surging while driving, any thoughts?
- header gasket question
- Stock engine takes it like a champ
- Pulley FOR 2.2?
- 2.2 stage 2 cams
- need opinions...cheaper wise..blew motor
- New Exhaust
- I need help ASAP!!!!!PLEASE!
- supercharge a 2.2
- MAF swap?
- Best/Most Efficient Engine Mods
- LS4 Throttle Body
- Trans Am muffler popped onto my 2.2 Ecotec videos
- Interesting Thought
- I just love check engine lights (help)
- just got a reply from colt cams...
- anybody using
- ? about our valvetrain
- Did a compression test..
- Xmas present for a buddy
- Need Part #
- Trans cooler
- Gas mileage drastically affected with Circle K gas?
- Does anyone have this header?
- JDM srs exhaust? who has it?
- Rear Drup Brake replacement
- two questions...
- RPMs spiking 300-400rpms whilr driving...
- 07 2.2 Exhaust Manifold
- Cleaning Injen filter with K&N cleaning kit
- Tranny question. Need help quick...
- Megan Racing Exhaust
- Jet Chips
- can i do this?
- what crank hp and 1/4mi time
- Muffler Dimension Question
- Self-Tuning Software available?
- Question about our Catylitic Converters
- Does the fuse for the SAI affect anything else?
- Anyone have GM Part Numbers for SC parts?
- Real quick question
- need help plz
- Totally new!
- trifecta help plz
- Anyone turboed or supercharged please chime in!!!(or if you can help lol)
- Cobalt headers
- 05 euc work with 08?
- high idle
- looking for a custom 2.2 intake
- how does it work?
