PDA
View Full Version : 2.2L L61 Performance Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 2.2 to 2.4 intake Tuning Questions
  2. 2.2 ecu
  3. 2.2l l61 intake manifold bolts
  4. Improve oil flow at idle
  5. 2006 2.2 Ecotec ecu tuning
  6. G6 3.9v6 interchangeable parts with 2.2L L61?
  7. Playing with the programming
  8. Need Photo of 07-08 L61 Intake Cam w/ Reluctor
  9. 2005 L61 Build
  10. 2.2L 10:1 boost suggestions
  11. ITBs, modified head and cams
  12. Missing ground???
  13. 08 g5, rattle at wot
  14. What is the 2.2l crankshaft made of?
  15. Can't find aftermarket header!!
  16. 2007 Chevy Cobalt LS 2.2 Valve Cover Replacement
  17. 08 2.2L without air check valve swap to 07 2.2L with air check valve
  18. Probably a dumb question
  19. 2006 Cobalt LS 2.2L L61 Engine Rebuild
  20. p0480 check engine light (CEL)
  21. 2.2L Factory Rev Limiter - 2008 Cobalt XFE L61
  22. BSD question
  23. 06 cobalt cold engine stall at lights?
  24. Cobalt 2.2 no start after ecm install
  25. Need help
  26. Broken Rockers
  27. 06 ls stalling when stopped at lights and stop signs
  28. Turbski manifold opinion
  29. 06 cobalt ls slight rough idle getting worse
  30. Valve cover interchangeability for 2.2
  31. Will these plugs work with my 2.2 cobalt?
  32. Trans fluid
  33. Fuel injector splicing
  34. Looking for ideas because I'm bored
  35. 06 cobalt ls 2.2 engine sometimes stalls when coming to a stop?
  36. L61 Supercharged Won't Start Twice
  37. Thinking about getting a Pedal Commander... anyone got one?
  38. Clutch replacement parts list (l61, 2.2L)
  39. Auto to manual trans
  40. 2006 Cobalt (2.2L) p0340
  41. Trifecta or AEM
  42. 2009 pontiac g5 p0016 p0017
  43. Turbo 2.2 questions
  44. 2.2 L61 Forged Crank?
  45. Fuel pump upgrade?
  46. 07 2.2 Ecotec build
  47. Installing ZZp stage two kit
  48. Running a clear filter before fuel rail?
  49. oil level fluctuation?
  50. Replaced Ecu and now car is running more agressive?
  51. 08 Cobalt VVT swap
  52. Relearning Crank Sensor Issues
  53. Speedometer spikes when revved??
  54. 2010 cobalt 2.2 short fuel trim
  55. Loud fuel injectors and fuel pump?
  56. Coolant spill into oil pan?
  57. N2MB WOT Box
  58. A few simple questions
  59. Catback exhaust 2.25" w/ 2.5" DP and cat
  60. In search of 6plus1 external reluctor wheel
  61. Cam sensor
  62. 04 classic 2.2L61head on a 2009 cobalt2.2.block?
  63. 02 gen1 2.2 swap to an 07
  64. P0300 ONLY @ Less than half a Tank of Gas
  65. 2.2 supercharged?
  66. Can you tell a 2.2 from a 2.4 VVT from the outside?
  67. Saab b207r turbo scavenge
  68. Bad O2 Sensor P0130
  69. cel p0420
  70. Has anyone seen a pinout diagram for this?
  71. 08 supercharged build questions
  72. Supercharger bypass valve
  73. Megasquirt
  74. Starting to further my build and had some questions regarding frankensteining
  75. clutch question
  76. added supercharger.. and nightmare..
  77. Piston to wall clearance?
  78. wiring in the t-map to maf
  79. 2008 cobalt wont start
  80. Will max bolt-ons plus a ported TB throw a CEL?
  81. 07 Supercharged Build
  82. ZZPerformance Blocks
  83. Christine the cobalt
  84. Jesse's super ghetto "I don't care anymore" carbon G5 body build
  85. 07 2.2 lt p0340
  86. pulling motor this week... any pointers?
  87. Lnf turbo manifold on l61
  88. Exhaust question
  89. Piston tapped plug?!?!? Uggghhhhh
  90. Cobalt 2006 rought idle and misfire
  91. L61 build in progress
  92. 2007 L61 CAMS help
  93. Throttle Body Porting
  94. '06 Supercharged boost problems
  95. Exhaust port matching
  96. Block interchangability?
  97. Engine swapout question L61 to LSJ, N-Body 03 Grand Am
  98. DIY Cold Air Intake
  99. need oil pan... aftermarket or junkyard???
  100. ECM swap 05-06 to 07-08
  101. Trifecta Tune 2.2?
  102. Wire sizing
  103. Exhaust Manifold
  104. Help with lightbar install
  105. Oil Drain Plug Question
  106. 05 Cobalt Cam Shaft Position Sensor ??
  107. The Phoenix Rises Once More
  108. Help with an oil temp sensor adapter?
  109. Help please 2.2 l61
  110. 2006 L61 PCV operation with LSJ intake manifold and gasket
  111. Transmission Fluid tool tip
  112. Cams
  113. HELP: Snapped bolt on valve cover
  114. P0013
  115. Oil leak ?
  116. Spark advance table for boosted L61
  117. Turboing 2.2
  118. RPMs going crazy
  119. Supercharged-Swapping to 6-rib LSJ belt completely
  120. jdbaugh1 official "build" thread
  121. 2.2 question for a cavalier.
  122. Blower Motor Not Working?
  123. defouler fitment
  124. thoughts?
  125. Engine codes
  126. Injectors
  127. I have my 2.4 manifold ready
  128. Engine seems like its hiccuping at idle.
  129. Water/Methanol injection SC
  130. TVS owners, what pulley are you running with what gas/cooling mods
  131. TVS 2.9 belt slip
  132. looking for info
  133. Basebalts slow build
  134. Sleeperbalt-Forged/TVS - break in
  135. L61 to LSj Head swap.. worth it, or big headaches?
  136. Cylinder hone/deglaze-what grit-flex-hone
  137. L61 2.2 turbo gasket.
  138. zero emissions cobalt??
  139. Getting ready to remove the head
  140. Tvs1320 l61?
  141. Stock to ZZP LT header, retune?
  142. Is it worth building up to tune for more power
  143. L61 Camshaft ID Help
  144. Base Model Sleeper build (long time lurker)
  145. L61 tune. 05-06.
  146. Putting LNF exhaust manifold on L61 with SAI
  147. Need Help! Cracked Exhaust Manifold
  148. Help! Timing Chain Tensioner
  149. Thewafflesareburnt's Toasty Fresh Build Thread
  150. Supercharging 2.2L LS Help
  151. Any base model guys installed a ZZP Stealth heat exchanger?
  152. 5 lug on 4 lug car?
  153. 2.4 to 2.2 swap problem.
  154. Cobalt exaust
  155. brake help
  156. 2.2L swap to anything else?
  157. 06 2.2 Turbo Build with LNF stuff: questions
  158. Overheated block, cylinder sleeve pulled out when machining
  159. Tuning for 2,2l engine natural aspirated, more rpm
  160. Tuning for 2,2l engine natural aspirated, more rpm
  161. Base model m62 build.
  162. 2.2l LT mods?
  163. what upgrades to do on 2.2k ls
  164. 2006 pcm and bcm swap to 2007
  165. SS exhaust on LS
  166. Fitting a bigger exhaust inlet
  167. Possible build? 90 psi 2.2 ecotec?
  168. Going quiet, need some opinions
  169. Throttle Body Questions
  170. Trifecta
  171. reluctor wheel teeth
  172. Na STG 2 Comp cams installed Instead of turbo grind
  173. Ticking sound
  174. Things I discovered about ethanol and NA engines.
  175. can we use the n2mb wot box?
  176. throwing cel codes
  177. zzp 80lb injectors
  178. Zzp header
  179. Why are valve locks/keepers so hard to find?
  180. Upgrades that won't void warranty
  181. hptuners delete sai?
  182. l61 na build
  183. LSJ Head onto L61
  184. 2.4 Malibu intake mani
  185. 2.2 2007 into 2.4 2006 Ion, Help?
  186. Clutch issues
  187. So you want 2.2L cylinder head data
  188. help with using solid lifters in my l61 head
  189. 2005 slow build help.
  190. Lscobalt07's 2007 L61 supercharged build
  191. Slowbalt2000's SmallturboL61coupe Build
  192. 05 cobalt brake lights quit working.
  193. What turbo should i run
  194. Planning to build a 2006 L61, looking for advice / help
  195. 2.2 rocker arms and hydraulic lifters
  196. EVAP line and boost. Need help
  197. zzp 2.6 pulley?
  198. problem engine 2.2L
  199. need help on Knock sensor
  200. Downstream O2 Sensor
  201. 2.2 s/c bolt on
  202. Supernovanator's "what did I get myself into" build thread
  203. Balt might need new engine need help!
  204. supercharging 06 lt questions help please
  205. 07blackg5 Build Thread. Operation Moneypit
  206. Coolant, Rad., frozen.
  207. Retune and catless downpipe?
  208. Exhaust port matching when going turbo any good?
  209. Soooo, who is S/C or turbo with a stock ECM and HPTuner?
  210. Struggles to start when warm
  211. Almost time for a tune
  212. 2.2 ls crank no start
  213. Just A Slobalt's Build
  214. Question about Koni Rear Adjustable Shocks?
  215. bank 1 sensor 1, 2005 2.2 manual
  216. Thoughts on the ZZP catback
  217. Stage 2 belt question on 2.2
  218. What would you do?
  219. 2.2 supercharged hp
  220. Check Engine Light
  221. How to: fix a terrible idle when turning on A/C using HP Tuners
  222. Pnp throttle body. Choked upon start
  223. Ethanol free 91
  224. ZZP 2.2 SC Idler pulley part number?
  225. Y-pipe (cut-out)
  226. Wiper shutting off ignition
  227. What are the consequences of running 10:1 with a supercharger?
  228. Turbo
  229. Cat delete
  230. Can i just add this to my steering wheel
  231. Air Intake
  232. what tire sixe should i run?
  233. Engine broke, time to build, but how much?
  234. converting a CAI to a SRI?
  235. Good Header/DP
  236. what goes here?
  237. Rough idle with a/c
  238. lobalt2.2 s/c build + other stuff
  239. Stock exhaust specs
  240. P0230 Help?
  241. SC tensioner question
  242. Spanky's back on da boost
  243. Bad Relay? Help?
  244. HPtuners on my 07
  245. Zzp headers on 2.2
  246. No Acceleration Power!!
  247. New to the Board... I have a few questions.
  248. thermostat and cooling questions
  249. Steering wheel control
  250. 2.4 throttle body
