PDA
View Full Version : 2.2L L61 Performance Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Clutch issues
  2. Looking for HpTuner
  3. engine won't crank.
  4. M62's turbo build
  5. ZZP 2.2 Supercharger kit?
  6. Deal on ZZP Midlength combo for 2.2 autos
  7. mysterious ticking
  8. Engine not starting, Turns over but doesnt run
  9. Bogging at take off
  10. Favor to ask anyone with a 2.2
  11. 07 block in 06 cobalt
  12. Looking for complete How-To Supercharge
  13. Old rings on new wiseco pistons?
  14. LSJ or 2.4 Throttle body?
  15. Need help
  16. Trifecta Retune?
  17. 2005 Cobalt LS no start
  18. Aem Infinity ecm on l61 for boosted build?
  19. 2.2 s/c power surge/idle issues HELP PLEASE
  20. how safe to supercharge 07 with new timing chain set
  21. weird sound coming from intake and sputtering
  22. OEM SS Exhaust on L61 Coupe
  23. My engine build
  24. Dual Pass Diagram?
  25. stock pulley on 60s
  26. when shit goes wrong
  27. Few questions about my 2.2
  28. lsj exhaust cam in l61?
  29. LS4 TB with vulcan intake mani for NA
  30. Lsj tb
  31. 2.2 L61 Ecotec P0301 idle dropping
  32. Difference between 05-07 and 08+ stock exhaust
  33. 2.2 supercharger questions
  34. cobalt probs
  35. 25 mm spacers , car feels slower
  36. No name eBay cat back review
  37. Zzp 1.0 in non ss or tc 2.2?
  38. 2.2 auto SC tune? 60lb injector set up?
  39. vulcan intake manfiold on n/a 2.2
  40. LOUD squeal from engine bay HELP!!
  41. Right spark plug? T0.1
  42. Exhaust set up
  43. lsj/lnf internals
  44. Supercharger
  45. Failed test on Mode $06 report Help!!?
  46. For all the N/A 2.2's out there!
  47. Hmm
  48. Stock LSJ Catback Exhaust
  49. Speed Daddy Exhaust Question
  50. Supercharger kit 2.2l
  51. Coil and fuel rail covers
  52. Oil Pressure sending unit location?
  53. weird smell
  54. Exhaust... Yeah, Imma be that guy...
  55. why does this happen?
  56. LAP Dipstick tube
  57. Sandman's because basemodel build
  58. New O2 sensor, still getting code
  59. tomorrow is the big day.. need help!
  60. Bluebalt1113's Supercharger build
  61. ok whats my options
  62. MRZ crank pulley
  63. intake manifold
  64. Intake mani
  65. intake installation help!!!
  66. More hp
  67. Exhaust
  68. Exedy stage 1 clutch?
  69. Ev6 injectors
  70. backfire
  71. brospeed muffler
  72. p2138 engine code
  73. Need some input
  74. Wideband bung location?
  75. label on valve cover?
  76. Another 2.4 IM thread
  77. L61 to lsj swap
  78. 2.2 ls stock exhaust
  79. Full Exhaust?
  80. Engine Build Q's...
  81. 2.2 to 2.0 valve cover
  82. Turbo'd f23 2.2l auto swap?
  83. Resonator probz
  84. NewGuy to this
  85. 4-1 dc headers
  86. New cam?
  87. Intake to Throttle Body connector
  88. 2.2 L61 beginners engine build
  89. lsj cam in a l61
  90. Stock rev limter ?
  91. Suspension Recommendations?
  92. Zzp 2.5inch catback exhaust
  93. 2.2 Header/dp +? Exhaust thread vids
  94. Maxing out NA L61
  95. Full 2.0 swap in my 2.2 sedan?
  96. 07 Cam Sensor Delete?
  97. supercharging 2.2
  98. do i have the wrong head?
  99. Engine Differences
  100. Just Trifecta Tuned my Cobalt?
  101. HELP! Timing tensioner promleb
  102. Question about Hahn Turbo Kit
  103. difference between 05-6 and 07-8 L61
  104. Lifter Adjustment
  105. L61 and LSJ head question
  106. Ecotec Head Build/Porting
  107. m62 Supercharger
  108. 2.3 l61?
  109. 2.2 input
  110. 2.4 l61? Stroker?
  111. Engine knock
  112. engine problems?
  113. Timing belt tensioner?
  114. building a 2.2 turbo
  115. ZZP shorty header vs Midlength&DP combo
  116. L61 No start, Suspect bent valves.
  117. Question for those with a 2.4 tb
  118. where can i find the cheapest price for a badmab header?
  119. Who's replaced the oil pump in car?
  120. Personal service thread - motovation
  121. supercharged l61
  122. Ecotec motor platform interchangeability
  123. Bankerbalt Build Thread (PICS!)
  124. I smell burnt oil!
  125. Trifecta Tune with Windows 8?
  126. 2.2L Supercharged
  127. trifecta tuning 06 ls sc
  128. supercharged my 06 LS
  129. reliability with cams
  130. quick question
  131. Torque setting for head E-torx bolt?
  132. Installing sparco steering wheel. airbag question?
  133. Upgrade from 2.2 IM to 2.4.. a bit confused with one thing....
  134. bad cv axle?
  135. Turbo ls
  136. Injectors with cams
  137. Finally lowered my 06 ls
  138. Connecting Rod Bearing Size
  139. High mile maintenance help.
  140. exhaust manifold bolts
  141. Engine cover and header?
  142. piston
  143. 2.0 block
  144. Help help
  145. engine mounts
  146. exhaust
  147. newbie here
  148. 08 ls 2.2 hi flow cat.
  149. 2006 Cobalt LS upgrades?
  150. F23 Transmission Problem ! ! ! Cant figure it out....PLZ HELP
  151. 2.2L to 2.0L turbo swap
  152. Sparco Seats?
  153. 2.2 08 ls cam
  154. Air movement in engine bay
  155. went to track yesterday
  156. Tired of my solid engine mount
  157. U0073 Code?
  158. how do I change the coolant in an 06 2.2 L?
  159. engine swap
  160. jdn902's sc build
  161. Type of timing chain tensioner
  162. need some info please..
  163. ZZP downpipe question
  164. exhaust mani/header
  165. Trifecta tune adjustment
  166. Front bushy
  167. head gasket leak? looks like engine build time
  168. 8 pin to 8 pin throttle body adapter l61 sc
  169. Camshaft and spring compatability?
  170. FE-1 -> FE-5 Suspension Swap
  171. looking to change exhaust sound a bit
  172. Ppe dp and header
  173. Tc exhaust on ls ppe dp header
  174. Exhaust again 2.2 lol
  175. Exhaust on 2.2
  176. TPS 20% at idle, but idling fine?
  177. Clutch Pedal Stuck Down... Help..
  178. 2.2 engine swap
  179. O2 sensor
  180. Am I screwed? UO100 after being cut off from a tune.
  181. Car overheating at speed / fan runs for long time after engine is turned off
  182. 2.4 mani and tb on 2008 HHR
  183. Full exhaust system question
  184. My girl is giving me a hard time
  185. Starting my Car Issues
  186. What is this creature that I removed from the cooling system...
  187. may get a balt but need something answered
  188. Question about GMTech 2
  189. Exhaust question
  190. LSJ downpipe on a L61
  191. Saturn LS1 with L61 2.2L
  192. Logical opinions please!
  193. trouble codes annoying help
  194. Alternator?
  195. whats happening to my MAF?
  196. Turbo 2.2 tuner
  197. 2007 2.2 Tuning questions--
  198. 08 2.4 Manifold details
  199. supercharging
  200. opinions needed for future 2.2 tvs build
  201. Why is there 2 K&N intakes for 2.2 and 2.4?
  202. RWD swap
  203. rods
  204. Performance heads
  205. Manifold Leak?
  206. LSJ Swap
  207. P0171! Wtfff
  208. Lsj heads
  209. my build so far
  210. Not happy with Midlength gains
  211. For those with badmab header...
  212. tcm
  213. climbs zzp stage 2 turbo build and questions
  214. Powell Rotated F23 Tranny Mounts
  215. 08 2.4 intake manifold
  216. Clutch question?
  217. re ring kit?
  218. EV1 to EV6 injector adaptor
  219. thermostat issues
  220. 07 lsj/2.4 tb
  221. Another potential 2.2 turbo build
  222. good 2003 sunfire progamers?
  223. L61 supercharged IAT2 question
  224. crank case relearn
  225. Anyone running catless dp with Gmpp touring catback?
  226. stage 1 comp cam for l61 part #
  227. Mid length vs. Long tube header
  228. suspension upgrade
  229. What muffler to use with ZZP Header back?
  230. 2.2 Saturn Ion Clutch options..
  231. Raiden8816's Hybrid Ecotec Build Thread
  232. advise on supercharger kit zzp
  233. iat reads -40f. Need Advice
  234. OBX, will this thing fit?
  235. M62's 2.2 L61 Build Thread
  236. exhaust manifold studs/bolts
  237. clutch help/advise
  238. Rk G5 Rear Lip
  239. Rk G5 Rear Lip
  240. Tri flow cams for early L61 NA?
  241. Air Fuel Controller Gauge Gen 3
  242. Rear Mount Turbo
  243. cobalt 2.2T vs wrd drag race
  244. Caught between a rock and a hard place with exhaust
  245. adding catted midlength to tsudo exhaust
  246. Detailed dimensions/figures of the TTR intake manifold?
  247. Klutch's Turbo build v2.0
  248. Self-Tuning
  249. 06CobaltLS's Turbo build thread
  250. Need some help, smell gas vapor...
