- l61 crankshaft
- #60 to big???
- Bearing clearances?
- Jbody L61/M62 Vacuum Ideas.
- Car troubles... Help Please!!
- Andrew's Cobalt Build
- 08 Cobalt LS burning coolant
- 2.4TB not the only option?
- where on earth?!
- exhaust setup
- walbro fuel pump
- Muffler Length
- cranks from a 2.2 cavalier
- Need some help
- question for guys with megan catback
- 2.2 to 2.4 IM ?
- tuned 2.2 auto with 2.2TB vs 2.4TB
- 02 Sunfire 2.2 ecotec
- BadMad Shorty Header Concerns
- SAI tricky?
- Rims and breaks on a 2.2 Sedan..
- Body Roll!!! suggestions?
- Oil pressure gauge install
- TTR 2.2l Ecotec Intake Manifold & Injector Question
- what to do.
- Weight Reduction
- Coil problems
- Need help!!! Fast!!!
- Need more for my turbo build
- need help finding stock size exhaust
- Good Deal
- HELP!!!What Parts for a Engine Build
- engine rebuild soon
- Turbod 2.2L w/SAI?
- Need a tune in NJ
- LSJ head on L61 block question
- 2.4 tb/intake mani
- Just installed the LE5 manifold!
- 2.2L 07 Cobalt Sedan Turbo?
- adjustable tensioner
- Does the motor pull out the top or bottom?
- New TTR Manifold
- TB Problem
- Mandrel Bent Exhaust Systems
- Gmpp Catback
- broken timing chain, valves trashed?
- oil change problem
- 2006 Cobalt Automatic, I want a Turbo and 400hp! Anyone wanna help?
- Cobalt Fe1 to Fe5 Suspension Upgrade
- header and downpipe.
- Crankcase Breather on S/Ced cars
- What's first!
- will LSJ parts help
- Boosted 2.2 IAT
- Question about dual pass endplates
- radiator help
- Helping a friend diagnose codes.
- noisy 2.2 help
- will this fit our 2.2l
- I have ?, will a ss stock exhaust fit
- Bought Wrong Turbo is Project Ruined?
- NEED HELP!!! Throttle Body wiring
- 2.2/2.4 sc/tc brake
- Sai
- 2007+ JBP cams
- Got my exhaust installed last night :)
- Help! 2008 L61 idle problem.
- ss headers
- supercharge build problem
- top speed in gears?
- Exhaust expander?
- strange exhaust issue while driving in rain
- P0102 Error Code
- 08+ 2.4 intake manifold
- installing new cam need help
- ZZP LT Header: Code P0133, and P1133
- silicone coupler question
- i have a clutch question
- So I'm gonna replace my oygen sensors....
- Will the LSJ valve cover fit on a 2.2?
- looking to upgrade performance
- Cam up grade
- 2.4 throttle body problem
- colder plugs?
- Turbo question.
- Electrical problems with 05 cobalt
- Intake mani for 08 2.2???
- Airbox Mod
- 2.2 dyno'd
- What to do
- re-re question
- Why do our engines run hotter with the heat on?
- How do I make my car run cooler?
- sso my cel and traction control light is on
- PCM Interchangability
- Fuel Economy
- Torque Specs for Cobalt LTZ (2.2L L61)
- tsudo exhaust
- 07 2.2 auto sc or tc kit?
- Coolant Temp Sensor
- turbo options
- my supercharger build
- Need some quick help?!
- All N/A motor build
- Serious info on the L61
- Upgrading internals
- 06 head on 07?
- headlights question please help
- super charger intake questiom
- Kinda Scared O_o
- comments on exhaust
- Control arm bushing
- 2.2 eco oil filter relocation kit questions
- Help Guide a 2.2
- Sc
- valvecover
- Cams
- chips from GF Performance
- read my CEL...
- injectors fitment
- 255 walbro
- Bottom End Of L61
- lnf head
- Ice?
- Downpipe Flex Joint Question
- Anyone have the zzp supercharger kit?
- Worth it?
- Popping sound from aftermarket header
- Best spark plug for stock motor
- Exhaust Question (Sort of)...
- Perfect launch
- Easy Question
- programmer
- Vash90909's first build!
- wanna build my 2.2 up for more boost!
- totaled 08 ls
- p0171 with intermittent surging
- My 1st Cobalt & brand new to this awsome site
- Anyone who has the tsudo N1 wunna chime in? Need some helpp
- option racing exhaust
- Catless?
- Cobalt Injector Harness for cavi
- vacuum line?
- got a question about the starter....
- Problem with installation
- Car Alright?
- My car is acting crazy! Please help!!
- Please Help!!!
- supercharger from ss to ls?
- 2.4 Mani Help
- Need some help with my SC build
- this gonna fit?
- Header Question
- 2008 2.2 LS Remote Start?
- OBX header
- Who's rockin' the Vibrant Exhaust :D
- Help!!!!!!!
- 2.4 tb fooorrrr sale !!!!!
- Engine Tapping Noise?
- 2.4 TB wires
- need a hand with a how to
- Cobalt Exhaust
- Injector misfire.
- Fuel line bolt size
- Rear Defogger Out
- Zam's first mod- K&N intake
- Tranny code!
- Looking for stage two parts
- Wat upgrades?
- EVAP Hose Replacement
- Supercharge or Turbocharge
- 2.4 intake swap
- 2.2l vs 2.4 tb
- anyone have access to 2.2 ecu pin chart
- bolt ons before FI
- Show off your exhaust
- trifecta or hp tuner
- My 2.2 Build Thread
- Supercharge 2.2 Questions
- Different cobalt exhaust
- Fml wtf!!???!?!?!
- comp cams stage 1 or 2
- valve to piston clearance?
- pacesetter fabrication?
- GMR cams
- help with master cylinder
- Coolant Temperature Sensor
- Front brakes, Rotors and pads
- header/downpipe
- camshaft?
- throttle body
- watcha say???
- Vibrant 2 3/8 Exhaust Leak
- high idle
- hesitation on startup 08 LS
- probably not a big deal, but thought i would check anyway
- Steering interchangeability and difference
- Engine swap?
- Bye Bye Cobalt
- clutch?
- question?
- twincharged question
- cavalier header
- rear brake job
- CobaltSS.net's 2010 Holiday Charity Drive!
- 06 2.2l header
- SC/TC catback exhaust
- replacing parts for Turbo
- #32 injectors
- Stg 2 zzp bolt on too much?
- installing a air fuel ratio guage
- Spark plug wires?
- Should I get the extra O2 bung?
- ZZP LT header
- is this correct
- 06 2.2 engine
- best sounding 2.2 muffler
- Vortex generators
- been a while/ZZP SC KIT
- 6-pin l61 to 8-pin le5 TB
- Turbo charge 08 ls cobalt
- Thinking about the QTP Y-Pipe...
- GM racing valves
- super bad oil leak
- big afr change?
- ZZP SC Kit?
- zzp 2.4 swap to 2.2
- Jason_42003's turbo build
- car shakes after 80
- My s/c kit
- walbro 255 fuel pump
- Trifecta Tuning...... buzz
- Need cop pinouts
- zzp downpipe
- E-brake wont stay up
- transmission fluid type
- Thermostat
- narrow band wiring help
- 2.2l block
- Balance shaft install
- K&N Typhoon Intake
- Pulleys
- quick question about flex pipe/header
- 2.4 cold air to a 2.2??
- Exhaust Question
- New to the forced induction family(vid)
- Exhaust help!
- fuel pressure went to $%!&
- 2.4/SS downpipe
