- Help build problem
- Problems with car. No codes?
- Remove Evap connection pressed in manifold?
- Any tuners in NYC/Orange County area that will tune my 06 Cobalt LS?
- Big drop in MPG!? Any help please
- 2.2 SC randomly wont start now
- 55-85 run
- 2.2 Supercharged which Plugs do you run
- Bolt on trannys
- Boost leak? belt slip?
- can't find header gasket
- Header install and now o2 codes
- motor swap
- Trifecta Tune?
- Need help again! S/C questions
- Should I buy Auto trans mounts from TTR when I get the upper engine mount?
- SWAP 07 head on 06
- Interchangeability question
- Broken ZZP downpipe? Pics
- Super Charger trade in
- Turbo build parts
- built 2.2 problems... please help.
- sc car not starting
- cant get belt on sc
- 2.2 S/C Intercooler pump question
- engine mounts
- 2.0 throttle body on a 2.2
- Highest Revving 2.2
- Timing guide snapped
- exhaust
- 2003 pontiac sunfire
- zzp rotors
- some questions
- 07 2.2 Turbo and Tune?
- FINALLY! TURBO BUILD need help..
- Is there a difference on L61 from 05-09?
- Supercharger problem
- 2.2 Engine locked up. Have good 2.4 LE5 block and want to use 2.2 cyl head...???
- need a little help
- Clunk bang when acceleration
- 2.2 Supercharger Build
- stupid knock sensor (p0326)
- Piston CR
- Performance chip question.
- rear shocks
- ZZP Dp sensor question?
- what are these wires for?
- possible short???
- What should i do?
- Supercharged or Turbo... Different type of discussion
- 06 LT Front Sway Bar install question
- Mandrel Exhaust & Eibach Suspension
- what compression. 2.2 turbo
- Intermittent coolant issue
- Exhaust Question
- tranny swap
- 07 throwing P0171 after installing LSJ TB
- part numbers?
- 2.2 sc/tc auto, g*d damn wheel spin issue.
- before building for a better motor, few questions.
- 420 codes forever!
- Wanted!!!
- 2.2l Tuning
- 08 le5 intake manifold
- 2.2 turboed, trans swap fit
- intake manifold question
- Help choosing what to do
- Cold Air Intake Problems
- How does the ZZP midlenth combo hold up?
- sc ls 2k-3k rpm loss power fixed and p0300 gone
- 2.2 Valve Cover Help
- Need help with passenger fuse box
- Need Exhaust Opinions
- Spark plugs
- K&n rai 2006 2.2
- Plug gap on an s/c'd L61
- 2.2 cams, 2.4 header
- Loss of Power M62 L61
- Trifecta Tuning in Nashville area?
- Need help
- best stage clutch for 2.2
- pulleys on 2.2?
- 2.4 IM swap questions
- Time to build for more boost...
- turbo decisions
- Rewiring for 2.4 TB
- 2.5 map on a 2.2 sc
- Possible Lifter Tick?
- 2.2l s\c possible build
- Help picking exhaust components
- Next purchase 2.4 TB/Tune
- coolant temps
- TB related questions
- header heat sheild
- running s/c without h/e hooked up
- Car wont start. 2.2 sc
- S/C strange idle and AFRs
- CAI on my 2.2 with ZZP sc kit
- GoofyBalt's Supercharged Build
- just got my k&n rai installed...
- Trifecta tunes?
- Rev limit question for all Ecotecs!
- ecotec-tuning.com?
- Intake Manifold Gasket (SC Question)
- cant decide help me
- Removing Drum to get to hub
- Header Back
- Tsudo No Muffler
- Fresh S/C build. Help needed.
- wrecked the car, info needed
- ecu swapped.
- Burnt valve:( Please help!
- Exhaust heat
- Spark Plugs
- AIT ZEN BODY KIT help
- Turbo or Supercharged
- new member, engine code p0326
- Exhaust questions
- Failed start, now throwing p1516 code
- JET performance MAF sensor
- P0573 code
- LSJ Injector Wiring for Supercharger Build
- Stage 2 cams
- TCM Module/Security issue on 05 Cobalt
- Need a tune?
- Leaking Oil crankshat
- Electrical issue
- Harness
- Has anyone used racingsolution.com?
- new exhaust :)
- ZZP Stage 2
- Ryman416's SC build (For realsies this time)
- Cobalt08ls SC build thread
- I/C Pump Wiring
- Hahn Intake Manifold on 2.2
- Brake cylinder and booster swap question
- Saab
- Good tuners?
- Pedders Coilovers?
- Stance Coilover?
- dual exhaust??
- Air/ Fuel
- Cavalier performance
- bluestreaks sc build be prepared for some Q&A
- 2008 L61 Injector Plugs
- DP emissions legal Thread
- Need help deciding which header/DP to go with?
- 1 step colder plugs
- B&G Coilovers?
- LSJ DP on automatic
- L61 TB Upgrade Question
- 2.2 cams
- need some help getting ready to build for moar boost ..
- Supercharged to turbo???
- Tuner Needed Chicago IL area
- Engine/Tranny Mounts?
- Alt bracket and tensioner for s/c swap
- Injen CAI without tune?
- Supercharger Sensor Plug ??!!
- Help with exhaust?
- ARP headstud torque???
- PO171 Code
- Crank Problem Still
- Emission Label?
- error code help
- Help?
- issues any suggestions
- Radiator Fan
- Running 60s?
- universal adjustable springs & ss header? Base model
- Powell Racing Stage 2 Rotated Mounts
- LSJ manifold swap
- LSJ/LE5/L61/LAP Valve guides?
- 07 engine in a 06 car
- Best gaskets for Bad-mab header & ZZP DP?
- Loud Ticking when car starts
- P2AO1 code?
- Vibrant exhaust vs DC Sports exhaust, Which to go with?
- Reliability to supercharge 115K miles
- How much HP should i expect from these mods?
- valve keeper help please!
- cruise control : extending cable and tucking
- ok fineally building the balt
- Input needed!
- P0420 code after zzp 2.5 catted DP
- Transmission Probelms 4t45e
- Fully Built 2.2L with TVS on 2.6" Pulley and E85
- 2.2 Turbo piping?
- 2-Step for Auto trans?
- Full ss swap for 2 grand what should I do?
- SC 2.2 bent valves/build
- Did my emissions today?
- Need Help with Coupler Size
- wanna turbo my 07 ls but its automatic can i run on that tranny??
- Header/DP Install
- Rear drum to Disc???
- having trouble with 2.2 and supercharging it....
- Patriot Head?
- OBX headers catless downpipe & ss/sc exhaust combo opinions
- 08 ls with SAI
- SAI Delete (Fuses)
- Destroking an L61 and compression ratios
- How to: L61 to LE5 conversion (lots of pics)
- 2.2 Head Options?
- ZZP 3"- 2.5Exit Downpipe on 2.2?
- is there a cat for 2.2 w/o CEL
- Vibrant Header? Badmab Header? DC Sport Header? ZZP Header?
- What is the best header for my exhaust?
- anyone heard from vince(trifecta)?
- Building the head
- GMPP 2.2/2.4 Intake Filter
- boost gauge
- 2.2L High Flow or 2.4L Manifold
- Supercharging Woes...
- white smoke
- Record?
- 2.2 to LNF Swap??? Worth it???
- Vacuum/boost issue
- cold air intake?
- L61 to LSJ supercharger question
- No luck with B&M shift plus
- 18" Motegi
- Help! C.E.L. P107
- Kinsler ITB Ecotech
- Simple Answer
- Stabailizer Link Question
- Down pipe ?'s
- High Mileage Oil
- Turbo Not Spooling
- headlight harness
- Automatic Shifter light fuse location
- ls4 TB on a 2.2
- 06 LS Coupe, Broken Timing Chain
- Will the ZZP Phenolic intake spacer fit on the 2.2L
- Anyone selling a Trifecta Tune cable?
- what to wire ic pump to?
- Header and Downpipe
- Surpercharged or Turbocharged?
- killed torque limiter! Having shift pressure rev issue though
- 2007 2.2 g5 auto trifecta tuned 1/4th mile
- Header with SAI or SAI delete?
- installing zzp 2.5 in downpipe, help a newbie
- T3/T4 or GT45 turbo
- noob alert
- Tsudo Exhaust
- TTR Racing Intake Manifold
- boosted L61's
- Pic: Confirm this is 2.4 Manifold
- SC or TC Build?
