- just a little help
- Improving the 2.0 liter Ecotec DI-VVT Turbo (LNF)
- nitromethane
- ok here we go ideas
- bykryder83 build thread
- Research and Development
- Methanol problem/question
- LIPSTICK's 800hp first LNF compound turbo/engine build!
- Stage Kit??
- Saab intake mani vaccum lines?
- wastegate problems, HELP!!
- list of parts to piece together a turbo build?
- IC piping question
- supercharger coolant system on turbo?
- Is there a new tvs design being made?
- Horsepower Estimation
- Rpm
- please help with this advanced mod.
- TVS and E85 questions
- looking to turbo
- Turbo conversion
- No More Ideas
- fixing turbo surge
- PCM swapping for L61
- Dual Supercharged Cobalt SS
- stage 2 clutch
- wtb heat exchanger!!
- What a journey!! :)
- Dual Intercooler Pump Opt B...is it possible
- Question about twincharging
- Who's got fullthrottles/mvps old LE5/LSJ Hybrid engine?
- My Hybrid Build
- Ls to SS Rear Brake swap?
- Idea on how to get the TVS off the intake??
- SCcobaltSS's Engine Build
- sudden enrichment!! help!!
- Will I have fuel issues?
- Looking for a GMP touring exhaust
- equinox Engine Bay
- What to do?
- Turbo Setup V 3.0
- High Boost Build Question
- 07 SS/Sc cam values...
- Injector choice w/ 2.2 Patriot Head??
- cobalt-to-saab parts
- Strut Bar?
- How it's supposed to be done.
- E85 and Meth
- Got my new water/meth kit
- 300~350hp?!?
- Turbo
- what size meth nozzle?
- L61 cams in LSJ
- turbo swap
- Which stage 2 kit...
- AC Delete Kit
- gm racing ecotec valvetrain question
- DevilsOwn 2.5 gallon sumped tank
- Turbo Kit
- Gathering parts for my future build
- Anyone running a Air to water on there boosted 2.2?
- 17.52psi and then what?
- bolt broke off in head. . how to fix? (w/ pic)
- Remote oil filter/cooler
- What methanol nozzle size?
- What kind of headers are best for my car?
- opt b kit ?
- Aem ems
- high compression pistons in a 2.2
- Bearings
- No accesory chain
- Cefaln452's Unexpected Build
- electric cooler
- Bypass Actuator
- Separate fuel cell suggestions, tips, tricks, pros, cons, hate it, love it?
- 4 gallon flow thru tank OPTION
- 2.0 turbo build
- TVS 1.37 w/ 2.7 question
- Muffler?
- SMG Cylinder Head Porting and Cylinder Head Services
- non catted DP question
- porting the exhaust ports on my head
- Need Some Help.
- Installing big engines into the cobalt
- wrist pin clips
- GM performance exhaust system
- oil pan
- LNF turbo dump pipe gasket groove dimensions
- 300 HP NA build
- E85 Review: Wicked Gets Gets Corn Fed
- Anyone ever remove the oil filter housing?
- MP 1900 TVS Blower
- Who has actually done a 2.2 Darton sleeve install on a 2.0L
- meth ?
- barbed fittings
- LSJ Turbo guys, question for you!
- engine swap
- LSJ Solstice?
- Swapping an LNF
- 2871R.......how much boost can the engine take?
- i wanna make an ss out of my ls
- Intercooler problems
- blower porting info
- Exhaust
- boost guage and piston ?
- fabbing an aluminum exhaust
- NEW COGG set up!!!
- Experiment: LSJ using E67
- StreetDreamz goes E85. Is happy :-)
- Installing Pistons
- 2.2 Vulcan Turbo Intake Manifold Help
- Misfires at idle?
- HARROP TVS, What You Need To Know & FAQ
- Oh my, look at how big you are...
- help
- sc wo a/c
- LNF Supercharger Kit
- something slipping after tune
- White Smoke from the exhaust
- Additional Intercooler Info
- Turbo sizing??
- pulley injector ?
- All Wheel Drive?
- BoostHard05's official build thread, if you have twincharge info i need it!
- People With TVS...
- LSJ Turbo guys...one final question!
- N/A Exahust Theory
- lsj air to air problem
- RWD: Farfetched or not?
- Interchangeable questions
- lsj cam options
- turbo build question
- Back pressure, myth or reality?
- Your methanol setup
- Turbo Issues
- So i am very curious. about trap speeds
- Problems with GM neutral balance shafts?
- NEW BLOWER OPTION! Magnuson TVS 1900, 372hp
- lnf lsd install
- SuperChips?
- 2006 cobalt ls turbo
- Where do i go to find an upgraded fuel pump for my turbo 2.4?
- exhuast system
- What parts for the SS/SC are interchangable with SS/TC
- Vulcan
- 2.4 -> 2.2 car
- zzp valve springs
- how to make steering rack and rear trans mount spacers for $6
- Battery up front......?
- Compression Vs Boost
- Methanol Injection
- Cam Install Question
- Dual pass endplate worth the hassle/money? I already have most the other cooling mods
- which spark plugs for a 6-7 psi set up (turbo)
- Turbo Experts
- 2.2L to 2.0L SC swap?
- Twin Charged engine
- Torque specs.
- Hahn's "No Tap" Oil system
- SloBalt Rider: LSJ GT3071R Turbo Swap
- building the engine, anything else i may need?
- Solid lifters?
- N e one swapped cams out yet
- Cobalt ENGINE Swap
- improved throttle reponse
- need opinions on what to do
- question about dual pass endplate.
- Motor Swap
- Ceramic Header Coating.
- Slowbalt_06 Going Turbo.......
- N/A Intake Design
- dual pass endplate
- 2.0 LSJ Stroker
- pulley question
- few crank and piston questions
- AEM fi/c
- How to: LK9 manifold with lsj TB
- WOT box and other stuff....
- balt wrecked. engine swap?
- 2005 SS s/c swap....
- Supercharged or Turbocharged?
- Injen Cold Air Intake Help
- wire connectors
- Help!!
- cams
- HeadGamesMotorworks.net head porting
- diftpin trouble
- air intake help
- Head porting
- has anyone done it?
- twincharged
- New Misfit Cobalt Intercooler Setup
- Launch control on ss/sc
- Transmission builds
- Where are my SoCal turbo SS/SC
- How many hours for engine rebuild
- hahn turbo
- Soon to be another 400 hp turbo lsj
- turbo issue?
- k next whp goal... 300
- CR difference between .040 and .027" head gasket
- Need pic of AEM Uego 6-pin connector
- Wanting some help modding 2007 SS/SC
- hahn racecraft intake manifold
- LE5 blocks
- FAQ: TVS/Harrop-lsj1320 & You
- Huge Sale On AIS Water Methanol Injection Systems Till The End Of The Month
- 5.3L or 4.6L northstar engine swap possible?
- Twincharged/ Turbocharged SS/SC
- lnf head on le5 it is possible?
- Mod Questions
- probably a repost..but.....anybody running this? STS rear turbo...pics on cobalt....
- Debate - Why not to polish a head!
- Thoughts on GMR Cams
- Vulcan Equal length Turbo Header
- how many ss/sc to turbo are out there?
- Is anyone addressing the biggest issue with ecotecs... The head?
- Tuners input needed ASAP
- Eaton M62 replacement blowers
- Twincharge pressure mathematical formula
- question for hatrick and others who have s/c coolant tank mod...how hot is your fluid
- 2.4 intake manifold/tb on LSJ
- Those of you who have the Harrop TVS 1320...
- Which color wire from the header o2 sensor reads lambda?
- I'm at a loss.
- SS twincharged
- Pulley drop = how much flow % gain?
- Base Tune for TVS 80mm 60 lb injectors
- OMG You HAVE to read this FUNNIEST IDIOT ALIVE
- 2007 2.2 tuning question
- L61 & LSJ connecting rod lengths
- Turbo progress is finally underway. Gutted engine bay pics inside!
- piston compression ratio
- making it go fast
- Wtf!!!! anyone with a lc-1
- Lower intake port and polish project
- laminbva core removal
- just got my balance shafts installed
- Nitrous
- HTV1320 Requirements
- Turbo-MISSING LINK!!
- Question on a/f ratio with return fuel system
- PCV valve options?
- DEVL Heat Exchanger,anybody use this
- 2.2 using bigger injectors
- timing question
- build complete
- GM Part Number for 2.5 bar MAP/AIT sensor
- LSJ Headwork
- 2.2 Supercharger Build
