PDA
View Full Version : ADVANCED Performance Modifications
Pages : [1] 2 3 4
  1. new turbo banjo bolt problems
  2. L61 to Lea swap
  3. Ecotec Head Flow comparison
  4. Built Engine Suggestions
  5. block mods for 700hp +
  6. Turbo A/R and backpressure discussion for nerds
  7. I'm nuts and need help with a swap
  8. GM Performance l61 cams 88958648
  9. Ecotec big block, do you need it?
  10. Curiosity kills
  11. LS3 swap 06 cobalt ss/sc eventually.
  12. Ecotec Cylinder 4 wear - common issue problem in performance applications?
  13. Mods from LSJ onto LDK?
  14. F23 swap speed sensor question
  15. F23 swap in ss
  16. Anyone tried Total Seal Gapless rings
  17. AWD Swapping a Cobalt, Yeah Its happening.
  18. help with engine swwap
  19. FYI - Devilsown Brew methanol frozen solid, 0-25% content
  20. Water/Meth failsafe system
  21. water/meth based on injector duty cycle
  22. Do we gain any power by using an ATI damper?
  23. LDK swap in my SAAB 9-3
  24. Brens Cobalt Project
  25. 2.2 L61 coolant temp sensor relocate?
  26. ECU swap
  27. Ecotec 2.0 LDK swapping into a 240SX S13
  28. Tuning lsj passed 2.5bar map?
  29. regapping stock rings
  30. 2.1 Timing issues
  31. Zfr and injen upper pipe
  32. Going to Turbo. Parts list
  33. Full f40 conversion
  34. My ported 8,000rm LNF head with Stage 3 cams
  35. "SHORT BUS" LNF Sedan Build Thread
  36. Help on a manifold for my lsj
  37. Bov questions
  38. G6 radiator fans
  39. Looking for E??
  40. Looking for new exhaust
  41. Looking for mechanic DFW area. 2006 ss 2.0lsj
  42. using carburetor on Ecotec
  43. My ZZP stage 3 cams
  44. LNF Long block swap
  45. TVS supercharger lsj build!!!
  46. what valve springs to replace bates?
  47. F35 - Project 6k sidestep
  48. Accessory power wire from BCM to ECM & TCM
  49. Boost problem
  50. n20saturn's RWD LS swap thread
  51. Should I???
  52. Wpc is it worth it?
  53. Rota's LNF Holset HX-35 Build
  54. Value of billet CW
  55. ottp turbo kit review
  56. Would you mill an ecotec head?
  57. airbox mod troubles?
  58. 2.4 ecotec to 2.0 lsj conversion
  59. Balance shaft removal? Electric water pump?
  60. Ballpark on numbers?!?
  61. Irritated! No TVS 1900 info.
  62. LSJ z-body swap info/thought thread
  63. A new idea for PCV
  64. Exhaust question
  65. Give me some "Pro" tips for Meth Kit Install
  66. Exhaust sound
  67. the because I'm bored build
  68. 2.5 catback exhaust and header
  69. RWD LSJ Truck Build
  70. Aftermarket front mount oil cooler
  71. Devils Own Wiring Problems on LNF - Pump always spraying
  72. GM perfomance exhausr system
  73. Will it blow up?!?
  74. What to upgrade next.
  75. oil filter housing removal
  76. Oil Squirter blockoff
  77. Official Gen III Block Thread
  78. FIC 1200 Review
  79. Alcohol fueled
  80. I am swapping a LNF into my MR2
  81. Swapping my LAP for an LE5
  82. Info on hybrids not covered in the sticky?
  83. Meth push to AN fitting
  84. unknow injectors some help
  85. Block Filler???
  86. Red's Hybrid Engine Build
  87. LE5/LSJ build ?'s
  88. l61 Cam Sensor Clocking
  89. Gen 3 short block
  90. Unclear information on block generation.. newer L61
  91. Crank mods
  92. Anyone Running ZZP Cams?
  93. ZFR turbo manifold cracked
  94. Lnf intake manifold for lsj turbo swap
  95. Engine Swap
  96. Adding turbo to a stock LS
  97. Neutral Balance Shafts and ATI Balancer
  98. 2.0 LSJ Swap into NA SS simple question!!
  99. IC PUMP pin out from LE5 ECU ??
  100. Gen 3 2.0 Project
  101. AN Braided Hose info thread
  102. Winter project
  103. Suggestions for turbo kit
  104. Ecotec into Porsche 944
  105. What other cars can you swap an LNF into?
  106. engine internals
  107. LNF ZZP ported head and cams
  108. 2008 2.2 to 2.4, to go vvt or not?
  109. LNF on Meth...
  110. LNF Turbo Kit on LSJ, Cooling Problems
  111. Meth injection problems
  112. LE5 swap into a LSJ car possible
  113. Looking to build a 500hp lsj or lnf rwd set up for a '37 Chevy pick up
  114. ecotec hybrid information
  115. "Knightmare" Build
  116. Going turbo on my lsj
  117. ZZP Major Build
  118. cobalt 3800 swap?
  119. AWD Cobalt SS
  120. New twist on CAI!!!!
  121. 5.0 coyote SWAP in progress....
  122. Bluelightning's Build V 2.0
  123. LNF Block With LSJ Internals And Head?
  124. MR cobalt??
  125. LNF Swap in LSJ Cobalt
  126. Sleeve-less Ecotec Block - LHU
  127. swap lsj turbo
  128. Its official I am going Turbo
  129. Building my turbo LSJ Q and A
  130. Boost concerne
  131. 06 ss sc supercharger boost
  132. Its All-Motor......just with a Turbo.
  133. Ported and Polished Intake Manifold
  134. Timing Between Engines
  135. LS4 TB to LNF IM?
  136. Head broke.
  137. wanted sleeves
  138. Refridgerating methanol?
  139. Random complete loss of power while accelerating. Need help.
  140. bigger charger
  141. LSJ Mini Build ;)
  142. Noise from pump for meth
  143. Coolant issues on turbo LSJ...
  144. my LSJ build :D
  145. Lsj internals for 450 hp - turbo'd
  146. 20,000 rpm eaton blower........Civic si.
  147. Fluid level sensor for AIS meth tank
  148. question about zzp throttle body spacer w/ meth inlet
  149. How do you seal a tb adapter LSJ?
  150. Devils Own brew/shipping rip off
  151. Water/meth jet stream
  152. Project Super SAAB (SWAP)
  153. treadstone air straightner..... a++++
  154. Turbosmart bov ?
  155. zzPerformane
  156. Frankenstien L61
  157. Oversized Pistons!
  158. lsj head on le5 bottom end
  159. Decisions... Advice?
  160. Quick question about a pulley
  161. Cam numbers -LAP
  162. Performance Mods: Adding TVS
  163. Just need a little advice.
  164. New power goals
  165. Break In Oil
  166. new guy ??
  167. swap help
  168. Wasn't sure where to post this exhaust pipe question...
  169. E85 VRS Meth
  170. How to make a Mod cold air?
  171. tq specs
  172. Why no "Power Commander" for the car?
  173. 2 bar MAP for 2.2l?
  174. ls1 coils
  175. new turbo..what do I need
  176. TVS issues
  177. motor swaping
  178. centrifugal supercharger
  179. rear diffuser
  180. LSJ Build Meets BW EFR 7670
  181. 09 Colbalt Lt modsss
  182. e85
  183. Research Build
  184. 4 o2 standalone?
  185. Fuel Cooler
  186. SS Clone
  187. best place for meth nozzle
  188. Meth install ideas..tank/controller
  189. Jeep Wrangler Mods
  190. oil filter relocation
  191. crate motor swap.
  192. Meth/Cooling mods
  193. starting fresh
  194. Le5 head on lsj
  195. Basic Tune TVS
  196. Engine Size
  197. GMR intake manifold measurements
  198. Active intercooling.
  199. doubled core intercooler.
  200. Brags 2.2 Werks 5557 turbo/engine build
  201. LE5 cam swap into LAP
  202. Proper A/F ratio reading
  203. UPS just dropped this off :)
  204. 2.4 LSJ Swap. NEED INFO
  205. bov-mbc-wastegate vac line routing
  206. Need help oil galley plugs stripped/bit broke inside!!!!
  207. Stock to TVS overnight!
  208. market for "built for boost" 2.4???
  209. Been layin low for a while
  210. cryo2 spray
  211. What happened to the lysholm thread
  212. Meth injection tube tap!!??
  213. Meth Pump Wiring??
  214. Tvs help
  215. Cooling issue
  216. turbo or tvs
  217. Need honing tool
  218. 2.2 l61 supercharged idler issue
  219. LSJ + Air to Air FMIC
  220. Stage 3 clutch and lightweight flywheel
  221. Easy way for additional 60 HP???
  222. Turbo setup
  223. Roof swap
  224. Turbo kit for the Camaro SS
  225. need some advice from you metal fab guys
  226. AjSS Build Thread
  227. "LEJ" Hybrid Build/2011 Build Thread
  228. Need opinions
  229. Interchangeable valve covers
  230. Destroke
  231. Getting forged internals
  232. predictions of my lil 2.2 ls 1/4 mile
  233. Intake manifold questions
  234. SCcobaltSS Twincharge Build
  235. Rd fabs turbo + s252et
  236. Mild Build Done
  237. Turbo Help
  238. 06 twin-charged in the works
  239. best cams for turbo car
  240. wideband comperison
  241. serious weight reduction
  242. Turbo Meth Set Up
  243. 2.4 crank 2.0 block???
  244. Lsj + mp90 supercharger
  245. 0.020" shaved head
  246. Brake swap
  247. Direct port meth a good idea? Not for me.
  248. How long does methanol last
  249. Boost a Spark
  250. Need help building my 20"7cobalt ss/sc
