PDA
View Full Version : ADVANCED Performance Modifications
Pages : 1 2 [3] 4
  1. LSJ Headwork
  2. 2.2 Supercharger Build
  3. Ported head
  4. Transmission options
  5. HP of a normaly asperated engine?
  6. Performance/no Tune?
  7. Cooling Down Meth in Freezer before using?
  8. Turbo Advice
  9. motor&tranny swap going from 2.0 to 2.2 ? how can i do it
  10. Need help from injector expert
  11. Inlet manifold ideas..
  12. Finally can beat a GTO
  13. OFFICIAL Turbo06Sedan Build Report & Progress
  14. Hot IAT temps - lots greater than ambient
  15. wideband is a little confusing
  16. LSJ crank trigger ring
  17. ZZP Twincharge kit making 440whp now
  18. Gm Daul Pass!!
  19. Gmpp sport cat back
  20. quick gasket question
  21. Another Turbo Cobalt just about on the road
  22. Intake Manifold Options
  23. Auto Cobalt converted to 5 spd...the computer..
  24. Gen 5 Blower
  25. valvetrain noise with bates springs
  26. Cooling intake air
  27. anyone interested in connecting rods check this out
  28. Ported M-62
  29. What will it take to go 400+whp
  30. throttle body upgrade question
  31. Rear mounted coolant resevior
  32. lifter dimensions
  33. 2 pcm's
  34. anyone running straight meth?
  35. 02 sensor Q&A
  36. 2.2 All motor build
  37. eaton supercharger on 2.4
  38. Engine Compression and Clutch Question
  39. Neutral Balance Shafts
  40. Balance shaft elimination kit
  41. Return style fuel system
  42. More Torque than HP mods
  43. Those who have tuned 79lb injectors
  44. boost controller????
  45. MAF sensor bung?
  46. Harrop releases HTV1320-LSJ. Orders being taken now.
  47. Cobalt SS Vortec idea!!
  48. Final Gear Ratio
  49. My HTV1320 dyno #'s
  50. Stage 2 upgrade and a jumpy front
  51. H/e With A 50 Degree Drops In Temp
  52. tvs 1320 graph
  53. Engine Internals Pistons
  54. My Harrop TVS HTV1320LSJ installation - Saturn Ion Redline
  55. oil feed fitting size in block
  56. Harrop HTV 1320; Finally Installed (Pics and tuning vid)
  57. Engine swap idea
  58. need help figuring on injectors
  59. htv
  60. Mike25's custom 2.4 turbo build
  61. gotts to love uncle Sam for this one!!new mods
  62. Inline fuel pump?
  63. Yet, another TVS received!
  64. Oil for turbo
  65. comp height for the stock pistons?
  66. snow performance install help?
  67. HELP ME OUT! Cobalt ss/sc build !
  68. waddup peeps, twin turbo diz biatch
  69. Harrop/Eaton TVS R1320
  70. first htv 1320 received
  71. 950 hp .. Eaton TVS
  72. Street Dreamz OFFICIAL big ass turbo build thread...
  73. MAF over run/limit, C.O.P. ignition, few questions.
  74. Swaps? LK9 & MO9 or MU9
  75. Spike's build thread
  76. Harrop Swap onto Stock LSJ
  77. inline fuel pump?
  78. fantasy build thread
  79. Harrop HTV1320 Supercharger...
  80. Turbo vs. Supercharger
  81. Procharged SS/SC new video
  82. need some of your opinions.
  83. shawn's s/c build
  84. what pistons
  85. Anyone advance there cams on the lsj?
  86. What does a hole in no 1 piston =
  87. Meth level indicator Idea
  88. Converting to RWD/ LS1 road race car
  89. ATTN Supporting Vendors: Request for custom engine mounts
  90. Methanol Half Life
  91. '03-'05 cavy tranny
  92. replacing m62 housing (how hard?)
  93. 2.2l turbo ecotec build diary
  94. ALL ECOTEC LSJ and LNF GUYS LOOK CONNECTING RODS
  95. anyone do a clutch swap on a 2.2/2.4
  96. Harrop HTV1320-LSJ using Eaton TVS technology
  97. cam idea's
  98. balance shafts and oil squirters
  99. Flowmaster Exhaust
  100. Need help w/ wideband install
  101. I know its been discussed
  102. phase 1
  103. meth injection?
  104. help blown engine need parts
  105. Monza
  106. exhaust gas temperatures?
  107. Machining questions
  108. Intake System questions
  109. fuel pump
  110. LSJ rods....... How strong are they really?
  111. Info on Fuel Pumps I found out
  112. nitro
  113. Will this cobra HE fit the 2.0 LSJ?
  114. help with 2.0 parts on a 2.2
  115. how strong are lsj crank's?
  116. block difference
  117. 3 inch exhaust
  118. Eaton SuperCharger Simulator
  119. does anyone have a "twin" or "duel" charged cobalt?
  120. Traction control
  121. request: Open loop
  122. are you a knowledgable tuner?
  123. Custom ice box
  124. Engine Swap
  125. e
  126. 2.4 block
  127. Piston question
  128. Just a hypothetical...
  129. jimbos'ss turbo build
  130. Heat exchanger ????
  131. Official Water/Meth Injection Thread
  132. Boost temps...
  133. Est. HP from Water/Meth injection
  134. Water Meth Injection
  135. which exhaust
  136. find the max efficieny
  137. Experience with F.A.S.T. XFI and MSD Digital Programmable 7?
  138. meth evaporation
  139. engine builders?
  140. Dual Pass Opt B with Cobra Heat Exchanger Help
  141. intercooler upgrade
  142. LNF swap into Older Car?
  143. Eaton TVS Superchager - Any info?
  144. stroker motor
  145. FWD to AWD
  146. 2nd heat coolant resevoir help pls
  147. Calling all Internal Gurus
  148. *****Advanced TOPIC ONLY***** No stage2 or intake/header/exhaust questions
  149. saab six speed
  150. Help with Cobra H/E
  151. Pic Request: 5th Injector
  152. Previous EVO owner w/ Questions
  153. main stud limits??
  154. Intercooler Spray?
  155. Headwork Question
  156. stage 2 axels or full mounts?
  157. ARP Head Stud Specs
  158. plumbing for dual pass
  159. t- fittings
  160. TB upgrade for the balt?
  161. Piston ring gap sizes
  162. Making my Cobalt LS an actual LS
  163. Questions, concerns, and discussion about Meth Injection Kits
  164. dual pass question
  165. balance shaft delete kits
  166. aftermarket radiator for cobalt
  167. How much can the LSJ be bored out?
  168. 2L LSJ to 2.4L
  169. Maximizing Engine Response
  170. ZZP fitment problem
  171. Will this TC setup work?
  172. All with Sleeve work done...chime in
  173. stg 2 problem
  174. Modified cars and Oil
  175. Cooling tank project
  176. intercooler pump
  177. OFFICIAL Blown 4-banger build updates!
  178. Cobra HE & GM dual pass 'option B' installed
  179. Running 10.5:1 pistons
  180. torque ratings
  181. boost
  182. delete balance shafts
  183. upgrade fuel system for cobalt ss
  184. lifters
  185. OFFICAL 06blackg85ss Build (some new toys arrived this week)
  186. coil packs
  187. Trunk Ice Box
  188. Help making my 2.4L SS faster
  189. 2.0L Engine Build
  190. Tuning my 2.4
  191. Need Help!!!! Loss of Power for no reason!!!
  192. ECU swap?
  193. Good Technical Reading
  194. No Start
  195. Should I bUy
  196. Need help! Doing a turbo swap.
  197. ***Help. Clutch Install gone wrong***
  198. 8.5:1 Pistons!?!?
  199. 2 battery hookup question
  200. so.. i need boost, help me!!!
  201. turbo questions
  202. Intake manifold removal - Help
  203. quad pass intercooler?????
  204. Rods
  205. The Official "Major Project" Thread!
  206. laminova cores
  207. my balt again
  208. GM's Spare Reservoir Cooling Option
  209. Neutral balance shafts
  210. Chain Tensioner
  211. Breather provision
  212. I need some help with the suprentine tensioner pully
  213. Throttle Body bore sizes
  214. Wierd Issue
  215. turbo question
  216. ecotec power tuning
  217. Cooling
  218. New stuff came in
  219. Valvetrain kits
  220. RPM Signal output
  221. Pics Needed!
  222. Beefing up for 125-150 shot...
  223. damn car... broke an axle
  224. fuel rail?
  225. Stage 3 Intercooler
  226. New treating process may give us alot added durability on couple parts
  227. Stock flow bench #'s
  228. and the project begins
  229. Turbo Swap Numbers, Posting for an Old Friend...
  230. My car is cursed
  231. Neutral Balance Shaft Question
  232. How valve timing works
  233. New problems
  234. My build wants your opinion
  235. Turbo Options
  236. cheap blower on ebay (canada)
  237. Anyone doing major engine mods.....here ya go!
  238. My Slowbalt .... RUNS!!!
  239. Building up the 2.0 internals - bulletproof style
  240. Tomorrow starts my build!
  241. GMPP adjustable cam gears...anyone???
  242. Firing Order?
  243. New MSD ignition product for Waste Spark Coil Packs
  244. [PCM] P0230 - Fuel Pump Relay Control Circuit
  245. It wont start
  246. Bleeding the clutch
  247. The long awaited Picture
  248. this throttlebody plug and play ??
  249. The Motor is IN!!!!!!
  250. Those with the SnowPerformance Kit
