View Full Version : Drivetrain
Pages :
3]
13
14
- Scary Special...
- Clutch time soon :(
- New Clutch Precaution
- F40 question
- Axle Riding Condition on seal, leaking
- zzperformance cv joint?
- droning rubbing sound while driving
- Bad Axle???
- F23 LSD OBX vs Quaife
- New clutch time.
- front wheel bearings
- dealer installed clutch master clutch and I need help
- F35 Tranny Issues
- Disk Hunt for my exedy clutch kit
- What size axle nut?
- Exedy Hyper Single Clutch plate only
- Pretty sure my clutch is shot. Help!
- Aftermarket gear oil in F35. How urgent to switch back to OEM?
- F40 swap info
- Almost impossible to NLS from 1st to 2nd
- Where to get a F35 Trans
- Does this make any sense to you?
- Leaking transmission
- Trying to change clutch
- Helpful hints for people installing TTR automatic tranny mounts
- Hurst short throw shifter on ls cobalt?
- F35 sintered metal filter?
- Resurfaced Flywheel
- LNF Cruise Control Function with MU3
- 07 work in 06?
- Torque limit of intermediate shaft
- F35 Trans Question
- beating the 4t45e / 4t65e dead horse
- Clutch time
- Replaced clutch and tob. possible input shaft noise?? need help
- Possible transmission issue, help wanted.
- Rotated mount opinions
- help with part number for subframe bolt
- Trans fluid help
- wheel bearing and cv joints
- 4t45e final drive ratios
- Replacing LSJ Slave Cylinder with LNF
- 4t45e -> 4t65e wap
- F23 trans throwout bearing install
- Illustrated backyard Exedy and Fidanza install
- Turbo problem
- Trans question
- Shaking Under Acceleration
- Noise from transmission????
- Noise from tranny
- LNF Bad trans bearing?
- 2nd gears grinding :/
- 2.2L Auto to Manual.. Here We Go..
- 08 sport cobalt clicking aftrt shifting
- Hmmm. Drive Noise. I Dunno.
- Clutch pedal issue? TOB/Slave?
- Problems getting in gear WOT
- Parts for new clutch
- Exhaust
- Opinions needed - Pressure Plate & TOB
- Bad throw out bearing listings
- Service Esc Need Help
- Trans maybe clutch problem?
- Driver side Axle seal/LSD question
- LNF trans options
- Options for exhaust?
- Hurst Shifter
- Help with 4.45 gearing
- 2nd gear syncro
- F23 parts availability (synchros etc)
- OTTP Short Shifter 08-10 LNF
- Bicycle Peg shift knob!
- Clutch grabs low after a high rpm shift
- Need help for Russian Bolt!
- Help!
- Throwout Bearing bolt size
- local dealership says both trans fluid are the same??
- Anyone got an engine laying around / Ecotec dimensions
- Billet Pro Shop 50% OFF Shift Knob Sale
- Modern Performance Rotors
- LNF Rear Tranny Mount Sitchiation
- LNF Transmission Options
- LSD Transmission Swap
- Full throttle torque steer, and lots of it
- ABS Light on after Transaxle Work
- Help! For my LNF
- GM sending out bad tranmissions?
- Clutch not disengaging?
- Drive Axle reinstall HELP
- Trans Axle Grease, NEED QUICK ANSWER
- What is a typical life span of an F35?
- God awful clutch squeak.
- Looking to upgrade auto trans 4T45-E with a 3.29
- Shifter moves!!
- Clutch Replacement Help
- Intermediate shaft hard to get out?
- Transmission not holding when the car is not running, is this normal?
- Jerky 2nd gear
- Loose flywheel?
- Leaky axle shaft seal.
- need help! !!
- lsj vibrating while in gear?
- Bad Axle and More? Help!
- GM F35 Transmission Rebuild... Questions
- Transmission /clutch repair ops
- Newbie needs tranny help.
- built 4t45e or 6 speed swap
- Fidanza Flywheel or OEM with ZZP
- Break in
- Tranny questions
- trans help! anyone put a ss/tc trans in a ss/sc?
- clutch rod?
- Bad left axle?
- Will it Run Rich?
- F40 install
- exedy clutch/flywheel
- Clutch chatter, vibration, slipping clutch. Pics!
- exedy clutch with fidanza flywheel
- Need Help ASAP
- need help/ opinions and things.....
- Car will not engage any gears
- 2.2 to 2.0 Shifter
- any benefit to using LNF upper engine mount on LSJ?
- Clutch job!! What am i doing wrong??
- clutch questions
- Pop out
- 3rd transmission mount
- Ebay ( or other ) Shift boots, anyone try?
- Occasional Reverse Grind
- Dorman TOB question/comments
- Cant sfiift into 2nd smoothly, getting annoyed
- Hard to shift into gear SS/NA
- Do i need to upgrade trans after big turbo if i have G85?
- Transmission question?
- F35 rebuild
- Need help with 05 cobalt shifting issue
- ZZP Now has GM Upgraded Axles
- Clutch help!
- final drive
- Solid mounts F23 trans
- Falling out of 5th gear on right turns
- OTTP vs BPS STS
- 2.2 clutch suggestions!!!!
- Ottp sts review
- Need a performance rebuild shop for LNF trans
- Rear wheel hub with abs on non-abs cobalt?
- is it my clutch??
- A thought on Air bags....
- help with clutch
- what is it? Please help.
- SS/TC Trans ID plate+Opinion.
- Broke 5th, Options?
- Knocking noise front
- Need clutch help
- Duralast clutch kit
- OTTP Shifter review
- Shifting issues in the cold
- need the name of a part
- Ottp Shifter Review
- Roll Pins
- OTTP Short Throw Shifter
- Vibration during acceleration cured
- **NOW AVAILABLE** Shift Knob Adapters for OEM SS Shifters!
- f40 franken clutch
- Lets Talk About Gm Auto Transmissions
- leaking trans
- lets play the 'whats that clutch / transmission problem' game!
- clutch wont disengage
- Horrible sound on acceleration
- Powell mount + LNF rear and motor + ingalls = wow
- quick question regarding a potential purchase
- Somebody pleease heeeellp!!!! Tranny
- Cavalier short shifter.
- transmission
- Please help! P0017 and P0016!
- Any LNF with the GMPP clutch for the LSJ?
- Any tips for a trans rebuild??
- GM LSJ Upgrade Clutch
- cobra HE
- Turbo lsj power limits?
- Transmission noise!!,Please HELP!
- Hard shifts & RPM spikes
- New Exhaust?
- clutch is slipping
- Hard Shifts...Sometimes Traction Light...Clicking on Braking
- Trans bearing failure...
- Good shape LSJ transmission casing
- 4.45 gears UPDATE
- Shift Cables
- zzp f40 swap vs fmsr stage 2 f35
- 2005 cobalt ss has tough time going into second from first
- bleeding BIG problems No clue whats wrong
- Is this bad?
- Shifter cable change, how hard?
- Auto to Manual
- 2007 Cobalt ss/sc noise problem.
- Engine Swap
- Jackstand Clutch Changers Thread
- SS TC trans bearings keep going out
- Cleaning and Painting F35 Trans.
- Engine swap help
- Custom Wilwood clutch master cylinder install/fab
- Transmission problems
- e brake plastic cover slides off
- F23 shifter side to side play
- changing gears on auto
- Short shifters
- Powell Stage 1 Mount - Vibration at Idle
- 4.45 trans explosion
- 2nd gear and 4th gear issues!!!!!
- How to check manual tranny uid level lsj
- zzp axles vs ottp axles
- where to find 2.4 replacement clutch
- 08 cobalt 2.2 supercharged transmission problem
- getting axle knock please help!!
- 2.4L: Cosmo Racing STS review
- What are the stock LNF clutch specs?
- Where to buy a new clutch?
- Problem with shifting into gear
- ottp trans mount tore
- FMSR Built F35
- 2.2 tranny sounds
- Replace the serpentine belt?
- Noises from one wheel when Turning
- clutch kit/slave unit??
- Clutch Lines
- On to throw out bearing 3
- Throw out bearing. LOUD!!!
- Need some help, ASAP
- Serpentine Belt
- Here we go again TOB went
- clutch peddle losing pressure under hard shifting
- Cobalt SS shifting is hard??
- Transmission Problems
- 05 cobalt ecu question
- Clutch position sensor help
- thread/pitch?
- 4t65e
- How a diff works in simple terms - awesome video!
- help with transmission diagnosis
- shifter wont move
- Slave problems?? after clutch/tranny replacement
- Front End Issues
- Have clutch issues need info asap!
- Best Clutch for 2007 LSJ
- Broken Axle! Fixable?
- Front end drivetrain noise help
- Blown Trans?
- Am I missing a bolt?
