- Gearbox/shifter bearings problem...
- Do I need a new clutch?
- OEM Shift Knob
- clutchmasters stage 4 for ss/tc
- Upgraded TOB
- new clutch help
- PFYC's one week MagnaFlow Mega Sale - ends 8/24/10
- Stiff Clutch
- tranny going
- WTB new Quaife
- Help me before I sell this car in rage
- clutch kit
- Shifter slop
- F35 transmission issues- Reverse and fluid
- Borla Cat-Back: low price guarantee + Free ship @ PFYC.com
- zzp stage 1 axles
- Need help with clutch
- need help
- Will this fit my car?
- Limited power in 2nd after hard 1st gear takeoff
- Help! no clutch relese at high rpm?!
- Transmition question
- Trany Fluid
- 1st to second- 2nd to 3rd
- please help!
- Shifter Cable Adjustment
- ZZP Stage clutches
- F23 transmission reverse lock
- F35 shaft seal leaking...Help?
- clutch pedal got soft
- LNF flywheel bolts
- clutch bleeding wtf??
- custom exhaust systems!
- Hollow Exhaust Sound
- Hurst STS
- vibration/Noise
- Shifter is loose. Help please.
- Clutch problems?
- TWM Performance SS/TC STS Review
- tranny oil??
- how do u guys like your twm short shifter?
- Curse You Transmission Roll Pin!!
- Wheel Bearings?
- F23 issue
- Random Question - Engine Swap Possibilities?
- Down Shifting
- Need flywheel asap.
- f23 fail
- zzp billet front tranny mount
- Trans Fluid f35/MU3
- strange vibration
- lnf tranny on lsj motor!!!!!!!!!!!!
- %$@%# clutch
- Gmpp clutch issue need help quick
- Lets end the clutch confusion!!
- Auto tranny question
- 2008 SS MU3 tranny fluid plug/question
- tranny problem..
- shift linkage?
- 5th gear disengages when I go to accelerate...kind of fed of with this car
- How to change tranny oil??
- Balky Clutch on start up SS/TC
- Front Suspension Noise
- question about hurst sts....
- lnf TOB/slave cylinder
- cost of a 4t45-e hydro matic fwd tranny
- AEM water/meth kit on a N/A car.....
- loud click from axles?
- Help tranny problem!!! Help!!!!!!!!!!!!!!!!!!
- Shift lever centering
- LNF Clutch swap progress
- automatic shifter
- I need a new clutch
- g85 in VIN?
- LNF Trans Fluid TEMPORARY
- Clutch Bleeding Frustrations
- ACT 6 puck clutch kit = FTW
- tranny...
- Trannys
- Flywheel to crank and Pres. Plate to FW. bolts.
- binding diff??? anyone??
- throw out bearing p/n
- Short shifter feedback needed
- which wheel is the power wheel?
- clutch
- LNF Clutch ZZP or Clutchmasters
- Anyone have a LNF Clutch How To ?
- Help..Wont go into gear
- Is this normal?
- good clutch
- About that time
- stock clutch?
- Replacing left output shaft seal...
- Hello everyone!!!
- tranny..
- Is anyone running an ACT clutch?
- can anyone verify what this is from?
- 2.2 LS automatic transmission problems???
- Problems...Not to sure where to start.
- clutch problem!!!!!
- axels for 2.2?
- tranny cable
- help!! passenger side axle wont come out!!
- Spec's customer service!!!!!
- F23 VSS questions
- what kind of exhaust?
- New clutch feel?
- New 2010 SS T/C 5th gear issues
- Shifter Cables Adjustment - Left Cable?
- clutch not disengaging
- GMPP Clutch Part numbers and supporting parts
- Sh!t
- Help clutch alignment tool
- 4WD cobalt ss??
- Should I get the Exedy hypersingle
- Reverse light switch...
- sequential shifter? not sequential transmission
- Prolong Engine Oil Treatment!!!
- Clutch Choices
- Clutch Question
- ss/tc clutch install price
- Clutch is gone, not sure why?
- clutch ?
- Clutch issues in 2010 models?
- stock LE5 flywheel weight?
- Auto Trans Differential
- Clutch install time
- Clutch engagement feels non exstitant
- F23
- Want my LT to rev higher.. Need Help
- Exedy Stage 1
- Clutch Removal Process, Help!!!!
- How do i adjust my shifter cables? No reverse!!!!
- Problems shifting quick with a hypersingle
- cracked block 2008 2.0 Turbo 62Kmi
- Need new clutch
- Need Clutch Help ASAP
- Transmission Fluid...
- ottp stage 2
- Tranny oil
- Gear oil
- SS/SC shifter question
- Gear oil/trans oil
- changing my clutch
- Check Engine Lighttt = (
- Drain size
- Cheap horsepower
- Broken cv ..............
- Big HP=stock flywheel bolts no good (pics)
- Royal purple
- F35 Part explosion
- Difference in Stage II and Stage III clutch?
- lnf clutch slave distribution block
- What causes the clutch/gear engagement slop???
- GMPP Trans Mounts causing wheel hop ??
- Best clutch for LNF?
- Swap transmissons with a LS to a LT 2.2 ?????
- 6 Speed Trans Options
- why do I grind EVERY time in second
- flywheel part number
- LNF Trans Fluid
- Help with Choice
- Clutch build ??????
- Stiff Clutch Problem
- tranny issue?
- getrag f23 to f35 transmission swap
- Axle Question....I need a part number
- axle question
- how do you detach the clutch pedal from the master cylinder
- everyone with lnf tob upgrade
- sporadic t/c light and hard shifting
- Dist. block/bleeder valve problem
- Thumping Noise
- Doing a Transmission service...QUESTIONS!!!
- Clutch
- Anybody do this???
- clutch messes up
- Feeler: 2.0 Swap.. what you guys think?
- code for 2.2 trans
- Any subs yet for LNF F35 tranny fluid?
- radiator mounts
- Dumb Question
- Whirling/humming noise????
- tc clutch options
- Rear calibers seized up!! wtf
- transmission power restrictions for stage kits
- All wheel drive swap??
- zzp stage 1 axles
- Bent my wheel
- what clutch to get
- 400+whp vs. Ottp stage 1 axles
- Clutch Controversies.. Need Advice
- I know i dont drive a balt
- Car is stuck in first.
- Auto trans fluid flush?
- increasing problem!!!
- How do you like your OTTP mounts?
- shifter is so sloppy
- Clutch info
- Clutch problems pls help
- lsd install ?s
- stock pads 40k later
- hurst or b&m short throw shifter?
- short shifter problems
- luk clutch
- spec clutch
- Clutch Fluid?
- Going After market clutch Master Cylinder
- 4 speed auto t/c help?
- Brembos
- No gears? Transmission help
- Under the knife tomorrow
- need help on shifter linkage/shifter diagnosis
- exedy gmk1016 clutch. any good?
- Please help Competitive mode launch control doesnt work anymore
- New gmp upgraded clutch arrived!!
- vibe awd install ?s
- no power shifting...
- Anyone...4spd auto gear oil & ATF
- Torque Converters?
- Rear bearing change.. question
- where to get new shifter knobs.?.
- shift linkage cable
- OTTP Neutral Balance shafts
- tranny fluid for 2.4s
- shift cable removal from trans
- need a clutch
- so i guess i need a new transmission...
- Axles
- transmission story problems and what the dealer did
- GMPP axles
- Stage 2 clutch
- 2.2L 5 spd Trans Fluid?
- Reverse Grind
- Clutch problems on 2.0L SS/SC
- Double clutching?
- Shifter Adjustment
- Gear Oil....
- Well a stock LNF clutch work in a LSJ car???
- F23 Clutch Diagram?
- OTT Stage 2 Rotated Trans Mounts or TTR STOP Trans Mounts
- Stage 1 axle question
- hurst STS prob fixed?
- Quick HPT Automatic Question
- tranny leaking fluid!?!?!
- manual tranny fluid for 2.2l?
- New Clutch install question
- team green lsd
- Axle/bearing torque spec?
