- 09 LNF full moded only boost sometimes while making left turn
- Cobalt SS Supercharger Length
- Boost leak super charger.
- Intermittent lack of proper boost
- 6758
- TR51 Mod
- Is The ZZP S256 Rebuildable?
- Z54 or Z57
- 08 2.0 LNF Turbo issues
- K04/lsj guys I have a question.
- My car is on a 2.7 pulley makes 22 pounds sometimes 17 pounds other
- Baked on Upper Charge Pipe
- 2006 lsj bypass valve helppp!!
- Bypass valve hoses atmospheric vent
- Not maintaining boost
- No power at intercooler pump
- code p2261 supercharger/bypass valve
- Loud whistle at 2-10 vacuum 09 SS Turbo
- 06 SS Not making boost
- Iso turbo
- Little help
- How The Dodge Demon Uses Air Conditioning For More Horsepower!
- TVS 1900 Wanted
- Is there a default Z54 wastegate duty cycle map?
- Looking for stockish turbo suggestion
- S256 vs S257sxe?
- Z54 Findings
- Lnf turbo wastegate actuator
- T3 Turbo Flange Bolts
- Loss of boost
- Zzp pcm or Trifecta tune?
- Stage 3 Boost Leak :(
- Pcv line
- Whistling Sound in Supercharger
- Coolant interface
- 05ss saab swaap
- Hahn 20g owners
- 2.4 SC Cobalt issues
- Cant get into boost
- 08 LNF Boost problem
- Difference between turbos
- Turbo issues?
- Cams for T25 2.2 turbo setup ??
- 2.4 LE5 Supercharged Tune
- 20g Feed/Return
- Boost problema
- Borg Warner 257
- ZFR vacuum lines?
- a/f gauge controller?
- Need help with new supercharger pulley
- swapping turbo Drive train to regular cobalt
- Hahn setup?
- Buying a used blower
- What is this weird part from under my stock intercooler?
- lnf pcm boost control with ewg
- Help whit measures of lsj pulley
- Dimensions for 2005 cobalt SS muffler
- s256et boosting issue
- Zzp down pipe
- Is My Turbo Shot?
- Turbo coolant lines on LNF
- stock LNF safe boost pressure
- Vacuum test help
- BPV issues, trying to narrow down
- zzp s256 install into automatic
- Superchips cortex with k&n intake
- BPV/BOV for the BNR GT2871?
- just got this s/c now what?
- old or new?
- Condensation tripping MAF from Intercooler
- Borg Warner turbo question
- Boost Gauge at Altitude
- T25 for mild HP build?
- Saab part pulling
- supercharger questions
- MAP sensor problem
- Something rattles
- Does anyone know what turbo this is?
- 2007 cobalt ss supercharger problems
- AEM failsfe meth gauge
- vac line issue
- free spin on supercharger pulley
- Exhaust manifold bolt torque specs
- Mass air flow sensor
- Hanh racrecraft Super 20G TurboSystem
- Exhaust/turbo questions
- help with tune
- Super 20G to sell or not?
- Supercharger boost controller
- Help! 2.4 ZZP S/c problems
- wont boost pass 6psi
- Boost Bypass Mod Review.
- Modified K04?
- SC Bypass causing Oil burning
- sc turbo swap
- Precision turbos and their spool times
- Bpv question
- eBay Turbo Kit
- what turbo for 500whp
- anyone dyno a cobalt with this kind of turbo?
- ac delete kit with stage 2 sc belt size
- My spare M62
- ZFR turbo.
- Noob To superchargers
- Intercooler question????
- Just finished Supercharging my 2.4
- Turbo exhaust question
- ZZP PCM question
- GM 4-Bolt Hub Bolt Size
- LSJ takeoff
- Removing rattlecan paint from M62
- boost problems help please
- LSJ turbo intake manifold restriction HELPP
- Quick question
- Which BOV/BPV set-up for the BNR 2871r?
- trying to decide
- How much boost on stock lnf
- oil feed line 2.2L
- Boosting issue
- Agp 3.0
- to4e 50 trim .63 hotside, need some input!
- WANTED: cold air intake pipe
- crack on turbo??
- anyone run a to4e 50 trim?
- Boost bypass seal part #?!?!?!
- Do I need to retune?
- another m112 question....
- White Smoke with Methanol
- Help, turbo coolant lines for lsj
- Zfr dyno 94 pump gas open cutout 24 psi
- dumb question :/
- SC question
- 2.2 IIgen ecotec 400hp a little help needed
- wanna boost my 2.2 lap xfe to 400 hp
- help please
- pulley upgrade help
- 62/66 turbo swap
- Difference in K04 Turbo
- Type of spark plugs
- Tial BOV question
- What a luck with ZZP products
- meth kit tune?
- help with efr install
- Sc+tc
- The Original Garrett Turbo Cobalt - Engineering Development Mule Car on ebay
- 07 Cobalt SS/SC Performance Question.
- 252ET vs 256ET
- Who does tuning?
- Tial 38mm Wastegate assistance needed
- T3 Flange HELP!
- MAP sensor and injector options
- DIY vs KIT
- Supercharger Oil
- IC pump
- Soon to be Cobalt owner
- GEN III Eaton M90 Supercharger
- Wr-3 question(s)
- Help with a turbo build
- Just another turbo question
- Intake manifold question.
- Revised bnr
- FWD performance turbos
- Anyone selling any turbos?
- BOV opinions
- Starting to collect pieces for my LSJ-T swap and have a couple questions! *turbo newb
- S252et question
- 256 non et?
- Dyno Vs. Street Tune?
- Hahn 20g/zfr
- My Turbo Problem
- Please help
- Belt Squeal
- zzp's mock up tial bov ?
- T3T4 Turbo problems
- vac lines for 2.4 turbo?!
- Need help deciding turbo
- best sounding BOV
- quick psi question
- what turbo shall i choose?
- Anybody try running a AGP Zeta 3.0 turbo?
- lsj turbo garrett gt35
- OH GOD vacuum lines question
- Which bov to use for hahn s20g
- Performance Autowerks/Precision K04+ with GMS1?
- 256 turbo upgrade
- Appropriate turbo drain size? m12?
- stupid question!!!!
- BOV on stock SS/TC?
- need help now !!! srt engine
- Precision 5557 or 5857?
- supercharging 2.2l61
- JDM T3/T4 Cobalt Turbo?
- Lsj turbo maf
- 2.2 SC or.....
- ZZP Build Questions
- Cobalt 2.2l sc setup
- wastegate and bov vacuum problem
- Turbo Parts
- Best turbo/turbo kit for LNF
- TVS1900 Question
- Just picked up my ceramic coated Super 20G Turbo
- Turbos
- supercharger wanted...
- OTTP Heat Exchanger
- Best IC piping??
- Turbo or Supercharged
- FOR SALE: Saab TD04HL-15T TurboCharger
- Getting away from mobile 1
- GTE Electric Supercharger??
- Heat Exchanger Coolant
- TD04HL-15t Saab Turbo on 2006 Chevy Cobalt ls
- ++++++++ supercharger kit for sale ++++++++
- Mechanical Boost/Vaccum
- is it safe to run 2.9
- charge pipe/wastegate help.
- turbo recommendations
- Supercharger question!
- building a t67
- Pulley size?
- turbosmart manual boost controller tee questions
- supercharge question. anyone?
- tubro manifolds
- Trifecta Tune - Charge Pipe Upgrade
- AEM TRU Boost
- stock k04 question
- Tial BOV SPRING QUESTION!
- Boost gauge for 2.2
- Injector size for E85
- Quick question for those running meth with a tank in trunk
- 2.4 08 g6
- M62 sc!
- ebay turbo?
- Tial 38mm problem
- Compressed Air??? fail
- Bypass valve modification for twin charge
- Port and polish on m62!!
- Devils Own Controller lights etc
- Turboed l61 help
- s256ET VS. s259ET-.70AR READY GO!
- intake mani on 2.4
- another 2.2 L turbo thread.
- ss/tc SRI on 2.2 Turbo?
- laminova core question
- Injen Charge Pipe Coupler
- Maf relocate!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- what are the diffrences between s20g and BNR2871
- EVAP to Boost Controler conversion
- cant get laminova cores out/dual pass
- Turbo Charging a 2.2L
