- Noise up front tapping from bottom end?
- I'm going to trade it in tired of going back and fourth to the dealer
- Cobalt 2.2L Modifications
- So my audio hates me now
- Anyone know how to do radiator flush for SS/SC ???
- tranny problems and whats that noise??
- short ram air 2.2
- Ive had enough no more cobalt ss for me
- For those of you with the hurst short shifter.
- my car can't accelerate hard until its warmed up...wtf?
- front end clunks and bangs and rattles
- F%^&ing AC Vents!
- clutchmasters stage 2 problems??????
- Can I Have Fuel Pump Problem?(again)
- Wtf brake problems
- Door Key Hole.
- elec door locks
- ABS Problems?
- Trading my car
- it just never ends..CEL P0128
- Wheel problem
- Add me to the broken shifter knob list
- exhaust rattles at idle
- Something blew a hole in my radiator white smoke coming out!! HELP!
- Broken Cruise Control?
- Looked like an ass..help me out plz
- Just great...misfire and now in limp mode
- The Clicking Noise
- Frozen Brake Caliber?
- Tach drops under zero?
- Why I Hate Dealerships!!!!
- 15,000 Mile Injector service
- Fuel Of Choice!!!
- overheating and Fix.. GM is wrong!
- Warranty question
- How do i fix this ???
- HID question
- HID question
- Timing chain tensioner
- My Car Shut Down On Me! Help Wanted
- headlight coming loose....
- Pissed off happenings
- F******g Peace Of S***t
- Tranny Problem Info.
- More squeaks and rattles... (glovebox and driver seat)
- This Damn Clutch
- Possible B/O cat converter.
- Compression test?
- Crunch Sound on Upshift/Some Bumps
- Help, I need this covered under Warranty!
- bogging problem
- hydraulic clutch slave distribution block
- GM wont pay for this?? *long*
- road noise
- Emblem removal... warrentee issue???
- I cant get the head light casing out
- a/c problem
- '05 SS/SC Pass. speaker problems + others
- Effin Dealership!!
- Reduced Engine Mode???
- Is anyone else's Interceptor messed?
- I Need Advice Please
- Question on changing brake pads
- fujita question
- PLEASE HELP ASAP! Install??
- Need Help ASAP. INSTALL ON SEATS!
- Think I need a new exhaust..??
- Sunroof bezel
- steering collum light out
- How do I change the fogs?
- Warrenty Issue??
- New campaign on 07 balts with auto
- quick warranty question... used car
- Engine Breaking
- Check Your Intakes!
- Fuel Rail Leak.
- what brand of oil filter?
- Broken mount?
- theftlock
- P2138=Limp Mode=me angry
- few problems, kinda confused
- Air Conditioning
- P1238 code
- ABS Light stays on.
- Exhaust question
- 2.0 Supercharger Problems
- RPM between gears!?
- Second Broken OEM DP and CEL...HELP!!!
- Clutch to bigger problems
- Psyko tune problem FOUND!
- air pocket in coolant system??
- Problems And More Problems Any One Else With The Same Ones?
- Broke a bolt how do I get it taken out?
- Diagnosis for codes P0101 and P0068...
- GMPP Performance cat-back
- If you hear a clank/poping noise read this!!!
- Clutch is gone.
- runs rough at idle
- clutch tranny or something else?
- projector problem....need help on how to fix
- Cruise control Fixes?
- Painted Headlight Problem
- i'm having problems with the oil life meter
- w$%F is this. warrenty? front rotors problem.
- Hit a cat. need help asap.
- Keyless entry Question
- Anybody else had these problems?
- Slight stutter/hesitation in low RPM's
- Window Seals
- HELP: Headlight Problem!
- When is a good time to have the A/C recharged
- Breaks moving Wheel?
- Clunk noise from transmission
- Outside Temperature sensor
- proplem with door handle (inside)
- Please Help..in Danger Of Goin Stock
- WTF went wrong with my oil change. LIKE REALLY WTF
- Aftercooler Resevior Constantly Empty!!! HELP!!!
- My cobalt ss/sc wont start!!!:'(
- STILL have idle surging after taking it to dealership
- 06 SS/SC Stage 2 sluggish after oil change
- breaks
- Dash Rattle
- GM part number needed for 02 sensor
- Header Bolts
- HELP! smoke coming from dash!
- Head gasket leak on 2 sc's in same spot
- Mini Revs with clutch engaged
- Shifter smoothness...
- Clutch grinds in 2nd
- I'm too girly for the Cobalt
- when to change spark plugs
- Occansional Knocking sound at idle?
- Synchro Problems... need some advice.
- This car seems to hate shifting under 3k...
- confused
- check engine?
- 2.0 hesitation and studdering
- Problems with the Hurst
- What to do with over torqued pulley??????
- grinding gears
- Stage 2 Install Labor Costs
- 2.4ss tuned problems
- Wheel well inside fender gone! WTF?
- Hesitation in the 2.0?
- clunk in front
- boost gauge
- Balts in the hospital
- Most common engine and trani problems?
- SC stage 2 just installed...running funny
- Rattle in exhaust?
- lost power steering
- Trunk Sensor
- sunfire transmission help
- Tire wear issues!
- Problem with Ingalls
- Need some help please
- Anyone having probs stock NGK plugs , like repeated failures .
- No cooling fans at all
- air temp sensor
- Got walked by a stock SS/SC + RSX-s
- Sunroof switch broke.. cross which to close?
- Fixed Tranny Grinding into reverse.. now there's other problems.
- heat and air questions.....done a search
- Break down of the recalls from someone whos personally done them
- Trying to get GM to install stage 2....
- Replacing stock air filter?
- Gunmetal grey finish on rims coming off!
- Dealer Voided my Warranty
- Stiff Clutch?
- First CEL In 2 years...
- Clutch issues...
- axle shaft
- Dealer Quality Of Service Issues
- Low Fuel Warning
- Unusual Shaking
- Neverending Clicking!
- Please help weird vibration
- Paint Chip WTF!!!!!!!!!???????
- Help! How do I re-align my supercharger pulley?
- A couple probs, 1 CEL, dual pass issues, Help
- Mouse nest under fuel rail
- CA stage 3 bog
- Gack...already...
- Speedo's in cobalts
- no valvoline oil changes for cobalts?
- clutch bleeding
- something dont look right
- Weird Sound...
- Broken Traction bar
- HELP!! Wierd Noise
- Rim Damage
- rear view mirror lights problem
- Check Engine Light And T/C Light
- Exhaust Leak Sound
- Who needs brakes done Cheap
- suspension and brake problems
- Sunroof Problems
- engine lean code.....
- Had some warrenty work done
- weird noise
- Door handle Click?
- Ticking noise after shutdown
- Bleeding Clutch
- Took my 2.0 ss/sc car in today for engine noises
- 2.0 issue
- Below the doors....
- Clutch Problem
- Aftercooler pump not workin!
- heat exchanger falling apart
- some g5 issues
- load misfires/start up tick
- Draining coolant...?
- misfire
- Boost Loss after car warms
- noises?
- Reverse lights won't turn off
- engine rattle
- as the dealer say engine shudder
- Motor Knock At 400 miles !!??
- door handle rattle
- Rebirth of my Balt
- weird ideling
- Bad...very, very Bad HELP!
- oil life gauge on 07 ? wtf
- Lights
- So apparently I dont have brake lights
- Cel
- Injen CAI
- supercharger oil question
- Air Box Mod Codes.
- See If You Can Figure This Out....
- Heater Coil leaking after 18k miles?
- engine tapping?
- oil light comes on after oil change.
- bang in trunk
- clutch
- Help me figure out what it is
- Squeak every time I let off the gas
- RPM's Hang @ 1500 w/ Clutch In, Problem or Common?
- Cobalt Is A Pos Lol
- Engine shuts it self off at 120MPH!!!
- ONGOING Problem- Could be an easy fix!! PLEASE HELP
- Front Bumper Alignment
- p0171 with cold air
- 'Engine Power Reduced' After launching car hard.
- Piston Slap, Who's gettin it
- Ticking Noise at Start up
- Blinker messed up
- Knock Noise On Start Up
