- Programing key for 06 Cobalt Lt
- Not getting full boost
- pulley bolts stripped
- mod problem no boost!!!!
- Car Shuts down automaticly.
- need TSB info
- Need help w/ removing intake manifold.
- coming up on 15,000 miles
- oh boy...
- I hate clutches
- cooling temp question???????
- Hit a median.... Leaking oil.... pics...
- problems at the stip
- F Ing Down Pipe
- Help coolant hose disconnected
- 2.2 tranny GRINDS for 2ND TIME 2006 car errrrrg
- Car stuck
- hissing noise
- GM stage 2 squeak
- Check out this oil filter (56k beware)
- Possible Clutch Problems
- Steering Issue
- After It Rains Speakers Go Out! Radio already replaced!
- clutch
- Key Getting Stuck In Ignition 2.2L
- Holy Crap... 2.2L MAJOR problems
- Reverse lockout on Hurst shifter???
- rich + flames from tailpipe
- Werid Noise From engine bay
- Cel!
- i am having a super weird problem
- No power to Data Link (ob2 port)?
- Headlight Question
- Those with 3" exhaust
- Thoughts on Problem
- having my crank shaft sensor remplaced.
- got this code p0520
- help...
- Water In Trunk
- lost all power
- Sunroof half setting stopped working
- Clicking Noise when accelerating or stopping
- Redline Water Wetter
- a/c pump
- Center Caps
- Reverse Lights Switch Location
- IMPORTANT PLEASE READ CAR WILL NOT START WITHOUT PRIMARY o2 SENSOR
- Obd2
- Slight Chugging
- Car wont start, CPS victim?
- loosing boost
- Oil leak after stage 2 install...
- Curring the factory antenna?
- 06 Cobalt Starting Problems
- SS/SC Tire Wear
- Can't open driver's side door!
- metal shavings in halos
- My door strip paint fading
- Getting fed up with my cobalt!!!
- Little help please
- Anybody else have this happen to them???
- turn signals
- Very Nice Dealership Experience
- clutch pedal clicks
- Damn projectors
- Engine revs at red lights
- DTC 1182 and 1183
- Stock exhaust pulled away from manifold...
- Weird...
- Vibration
- Fuse For Cruise Control?
- Hesitation problems? Not accelerating??
- Oil Change Problem
- Too much Knock?!?!
- SS\SC trouble.
- B M Shifter Help
- Factory lemon?
- P0300/P0302 Misfire code HELP ME!!!
- 2.4L LE5 - Fuel Gauge Issue - Resolution?
- Battery groud
- Engine running hotter and hotter!!!??
- Help Quick! Strut Problem
- Dealer install pistons/headgasket
- huge problem
- Help Asap!!!
- Stage Ii Nightmare! Help!!!
- Color Code
- Name this Substance!
- Its not Goodwrench service, its brokenwrench service.
- What to gapp my pluggs
- Cylinder 1 Misfire
- Cobalt SS Surprise?
- What Smells?
- Crankshaft Position Sensor (car died, no start)
- New ss/sc
- (SRT) Question about problem with tires and dealership
- Car shuddering/vibration?
- need help fast!!!
- Recall 2.2L Guys
- Brake issues galore (caliper seizing/pad noise)...need help
- window switch panels... under warranty?
- new keys made at dealership cost....WTF
- 'POTENTIAL' cobalt owner.. or am I?! Please HELP
- WARNING: RATED R FOR RE-GODDAMNDICULOUS(make sure u have a few minutes)
- Vibrating Noise!! Safe to take a part Off?
- removing the steering wheel
- Seat belt dog warning
- Have a problem, need some input
- Have an issue, need some input
- Another dam projector problem
- brakes...i done a search
- Problem with the vent...
- thermostat help
- That clicking noise
- Dtc 0507
- 3rd gear car wont go past 5000 RPMs
- A couple noises and issues...
- GM Tuning software
- Cobalt is Idleling funny?
- Brand New Oem Shifter Cracked?!, The Dealers Are A Little Shady Somtimes!
- Many Problems
- Turn Signal won't cancel.
- A stage two clutch?
- 2.7 and a P0300 CODE
- Hole In Floormats plz post if youve had issue
- dealer stated the main computer shorted out
- Please I Need Major Help
- I guess I boost to much :D
- 2006 Chevy Cobaly LS 15,000 mile maint.
- Battery?
- Replacing rear brake pads....
- engine light on constantly
- Hid Projector please help
- IAT2 seem too high
- Apex'i BOV help
- New Smyrna Chevrolet - NSB, FL
- Buzzing at 1800 RPM
- Update on my problem
- Red Cap
- 12v Power Outlets not working
- Cracked Flex Pipe
- Slow throttle closing
- Check Engine Light 2.4L
- rattle sound?
- What to look for?
- Whats The Swish!!!!!?
- idler pulley noise
- (SRT4) Problem .. turbo
- Weird "hiss" sound after gmpp manifold and hahn downpipe install
- Autoextend ?
- Tranny died on the highway
- Broken Lug Stud!
- clunking noise when i turn the wheel??
- the G5 broke down
- Flickering Boost Gauge
- Front end / steering vibration while at highway speeds
- Another Paint Problem - Pealing Side Skirts
- hid problems
- Bwoody Sway Bar Links
- So I found out 2 of my 60lb injectors were bad
- Stage 2 problem
- A couple of problems. Could be one whole one.
- Error Code
- My latest service at the dealer
- Car died.
- Ticking Engine?
- fried amp
- O2 Sensor
- Wheel Hop, what to do during????
- Dipstick popping out
- Front clip really flimsy?
- Cruise Control Button Not Working
- ss/sc shift knob falling off
- brakes-lemon
- warrped rotor?
- NEED HELP dont know what to do
- NEW kind of Clutch Problems? NOT Slipping!
- HELP! My ZZP 2.5" pulley doesnt fit on my hub!!
- Heater vents sticking
- Air conditioner panel...
- Rearview Mirror Lights
- Crap Headunit
- Please read and post! Problems I've had with my cobalt like many others!
- Key FOB won't work
- water?
- Exhaust Rattle
- Bad Paint / Recall ? Anyone else?
- Head Protection Recall.
- Roof-Mounted air bag recall
- Piece of crap that GM won't back up!!!
- Vibration at idle with AC on.
- axels????
- leaking... smoking.. argh
- Hissing sound
- 07 cobalt cuts off when turning need help
- LSJ Major misfiring/hesitation over 15 psi
- Oil in the antifreeze....
- For real...
- grrr emblem on steering wheel
- Dome Light
- Anyone take their car in for the head impact safety recall?
- engine noise
- Symptoms of bent rear "twist beam"
- P0030&p0036&p0102&p0443 Help Me Please
- Not sure if this should be like this
- I know I know.....
- Getrag P.O.S.
- cold air problems
- cold air problems
- Perry Chevrolet in Columbia, Mo
- Clutch and tranny ?'s
- New '06 Recall
- Point Me to Correct Thread
- need a clutch ASAP
- Problem?
- Check Engine Light Codes???? HELP!!!!
- A way to start my day off!!!!!!!
- Stock Rim Issue... Help..!!
- Abs Light??
- The car is acting funny
- exhaust is studdering
- rusty tailpipe
- P0442 or P0455
- trouble code help anybody
- Reliable Mech in Richmond?
- Dang doors
- Problem with Projectors
- HELP! what the hell is this?
- Tranny died
- Anyone else have problems with NGA sales?
- Car won't start
- New problem with the Cobalts!!!
- Car Rotisserie Question
- CEL Code P1174
- stinky smell found
- Airbag light and info center...
- Backfire on startup
- car sputtering/surging Help? Opinions?
- Recall on my 05 SS/SC
- P0420 and rough idling
- Help. Evap valve?
- Chipped paint
- spring clicking/ tapping noise
- I hate My Car, im gonna trade it in.
- Fuel gauge moving randomly
