- Driver door creaking
- My brakes are starting to squeak does warranty cover that?
- quick dealership rant
- Service Bulletins?
- Check your nuts some more
- clunking comming from the rear
- First problem with my 06 SS/SC
- Downpipe Cracked
- NEED HELP!!! warrenty probs!!! HELP
- Finally Got It Back!!!!
- NOISE from Driver Leather Seat
- Wheels Flaking
- does any1 else got a hole in their muffler?
- Oil Changes
- What temp should the fan kick in when stuck in traffic
- Car stalling
- PCM Fried!
- Problem matching the paint??
- driver side headlight?
- SS 2.4 Fuel Line?? Hanging Down
- Calling the dealer tomorrow...
- My SS/SC headed to the shop. :'(
- Why do the doors open so wide??
- Gas Problems?
- Dealer ruined my car !!
- Spec Clutch owners please READ!
- Finish on rims failing!
- Problems Fixed for 2006?
- Just Lemon lawed my cobalt ss
- HELP on B&M shifter install`
- Running Lean with CAI
- DTC P0606 Control Module Internal Performance
- Oil and Warranty work Today
- Front license plate holder.
- Exhaust blowing out
- My Service History
- clunk in steering
- skirt top in wheel well rubbing
- SS\SC Studder
- Throttle Delay/Weirdness
- Stupid problem
- 4- cel codes! agh!
- what to do
- Oil changing question.
- Dash lights gone crazy!
- Fuel filter change
- Rotors warped at 3k?!
- Check engine light, machine gun...
- Power windows freeze a lot?
- Problem, Smells like something is burning?
- My 1st Oil change Story
- GM Took The Cobalt SS/SC Back
- Front Bumper
- Air Conditioning
- Car Won't Start Pt.3
- Exhaust Ticking...
- power windows broke
- boost guage not working?
- Cruise Control not working
- What next????
- My car is two colors!!
- Car Won't Start Pt.2
- No speaker sound
- 18" Gunmetal SS wheels ....is anyones paint starting to bubble off wheels
- radiator part number
- Official TSB Guide
- Steering adjust stall: Problem solved
- Roof trim piece lift
- G-dang Flipin Belt Squeek!!!!!!!
- RPM's Jumping?
- Turn Signal Problem?
- Brakes gone @ 9700 miles
- Anyone with same problem?
- Cobalt Broke
- Sudden Gas Milage problem
- Squeaky fan???
- Brake lights staying on?
- Gas Pedal Stickin?
- Cel
- cel code
- Yes!!! Car Won't Start!!
- Problems with stock clutch
- Fuse box
- Cruise Control add-on
- Hood Paint Chipping
- A different rattle...
- Cracked Driver side window
- Well, I've about had it!!!! (06' SS/SC)
- Idle Fix In The Works ?!?!?
- Chevy Cobalt Recall
- Back to the service department
- Security Lock Light in Dash
- Crank sensor
- having problems with the windows ?
- steering wheel bowtie
- 2.2L rattle in higher rpm
- Road noise / wind noise?
- Stereo is possessed
- Going back to the dealer
- Weird check engine issue...
- Proplems with TQ Brace
- Dealer raw hiding in my CAR !?!?!
- A Problem i have noticed with cobalts
- Boby Myers (Ajax, Ontario) F'd My Radio
- Limp home mode sucks!
- Armrest
- Am I Retarded?
- Change Oil Soon
- has anyone got there idleing problem fixed
- intake and exhaust
- Catalytic Converter Problems....
- Factory Service Manuals
- Scraping sound from rear
- cracked windsheild
- Help!! Pulley swaps problems!!
- Deep fried my brakes!!
- Sunroof button
- Onstar Noise
- Dealer Replacing Steering Shaft
- just did first oil change
- Tweeters blown....
- interior rattle
- some weird things happend
- Extended Warranty? Anyone buy it???
- Squeek/ squeal above 4000
- Foglight Proplem
- clicking???anybody?
- The linkige may not fix your trans problums!
- Missing Part from K&N Intake WTF
- Check Engine light on 3 times in less than a week!
- Sticking Key
- Wiper delay being dumb?
- Sunroof Leaking
- Interior Trim Problems
- Dc strut bar wont fit
- stalled in top of 3rd
- My SS wing starting to fall apart too
- DIC..."Low Coolant"??
- A/c System Wiring Or Dual Stage Airbag Module Wiring
- my service dept sucks!
- Recall Information Received...
- rim paint peeling on the 18"s
- New Clutch and flywheel =...
- shaking headlights
- Passenger door panel
- just to let u know
- Stealership B.S.
- starting problem
- clutch problem on normal driving (recall?)
- Check your coolant hose
- 5th Time and the car is still not fixed !
- cadalitic converter
- Pealing Dash Paint and Random Lights - Anyone Have These Fixed?
- ECU Reflash?
- Rotors
- Last GM?????
- for those of you with sycronizer problems
- To those with Worn Rotors (SS/SC)
- Puddles and cobalts
- Wtf! Still Cold Start Issues.
- What do i do now?
- problems with Cobalt...what to do???
- Ignition Cylinder goes out at 7700 miles!!!!!
- Stock Rotors
- SS SC owners, check your wings.
- Stock Rotors on the SS/SC
- Yea! Another GM Rant.
- Trunk Mounted Reverse Lights
- What is wrong!! shifter problems!!...
- Problem with POWER STEERING on DIC!!
- dealer screws up oil change!!
- stock air filter
- Tranny blew up
- door pillar vinyl bubbling/peeling
- Wiper Fluid!!
- Heater?
- anyone got any idea's
- 2.4 Problems so far..
- trunk wont open
- Warning: Cold start Issue gets worse!
- paint runs
- loud brakes in cold weather
- brake problems
- Spark Plugs Fouled Out.
- Story Time with the GM Dealer
- Whose Brakes Squeak?
- Break pedal squeeking noise
- Shift Knob
- My Baby Died!!!!!
- GM dosnt have a fix??!!
- RANT: Freaking GM Quality
- computer data
- Help me please! Blown Clutch?
- Door Panel
- No Juice
- 2problems
- Engine sounds different.
- Problems with Brakes and Exhaust on Sedan
- Update on tranny
- A few minor problems...
- XM Problem!
- why am i grinding when i go into 3rd?
- Problem with body panel fit?
- cobalt sedan nightmare
- Key Stuck In Ignition
- E-Brake not working?
- Clutch Squeaking
- weird noise when turning
- Ratling/Creeking Glove Box
- Most current numbers for the 2006 PCM
- Cel
- Dead Tranny at 4200 :(
- ss cuts out in middle of road
- SS problem:( HELP!
- Cobalt SS/SC ideling issue
- Small issue with the radio???????
- My Baby's in the shop
- My Sedan won't start today
- ABS light
- Engine vibration
- weird spoiler noise?!
- Gas Tank Sensor Problem
- engine check light on again....
- SS pulling to the left?
- Clutch - Slipping?
- Seat Belt Warning Light/Chime Cobalt SS 2.4
- window noise !!
- Curious Light
- Squeak solved...
- Shifter Breaking
- Transmission Seal Problem SS/SC
- hissing sunroof
- cd stuck in drive and lucky break
- Tsb
- Stock Radio Problems
- cheap leather
- Solved Knocking in Rear
- Can someone help me with Fujita CAI instal
- Sunroof problem?
- engine noise around timing gear cover?
- Sun Roof Squeaks
- gas tank nozzel
- Wire Harness under my 06 SS Sedan Driver Seat
- Tiny Beefs
- Fujita CAI installed but wheel scraping..
- 3.0 pulley problem!?!?!
- Noise in 06 SS S/C
- Dome light problems
- Clutch Noise
- Power Steering Noise..
