- does anyone have this problem
- P0101 & P2178 = bad turbo??
- I feel like I cant have nice things
- Thermo Wrap _ Where to buy?
- Cobalt Rattling in the dash
- Need advice on whether or not to repair this myself
- crack in exh manifold?
- Air Conditioning
- 08 Cobalt SS CEL+No Boost
- just hit 90,xxx miles
- Wiring problems; Car won't start. Need advice.
- I went through a Large puddle and now have valve clicks...
- fuel filter
- Car stalls when slowing down
- Car wont start, no battery voltage going to hvac ig fuse(16)
- anyone have these problems too?
- 28 psi peak...
- lighting/info button issue
- unusual throttle fluctuation
- help with fan diag. overheating
- Speedometer, Output Sensor issues
- Supercharger Help - Pulley Wheel
- Tranny Leak
- where do I look?
- No steering controls.. Horn.. Service airbag?
- Cruise control, stereo, Remote opener all stopped working
- High Rpm hesitation, stops pulling, cold holding revs
- lsj turbo wastegate ticking
- crank shaft position sensor
- Emissions...
- crankshaft sensor fun...
- 08 ss esc. act. ?
- Help Diagnose insanely annoying sound
- A Few Problems After Stage Kit Install
- Why is GMPP Intake only legal on '05 2.2L in CA?
- sitting on the side of the highway
- Wierd noise.. Out of nowhere!
- so guess whats wrong with my balt now...ugh
- Code p0017 help!!
- Clutch pedal limp on wot
- 05 cobalt ecu swap question!!!!!! Need help!!!
- Turning odd now.
- got codes need help
- HELP! Red paint showing under the black paint!
- stabilizer
- air bag
- Whining/scratching noise from wheel/trans?
- Stuck link on new GM timing chain...?
- A/C Recirculation Button
- Install new engune mount and tranny mount but i have problems
- No torque/power in 1st and 2nd on a 2.2l
- Bearing help please
- Battery keeps dying
- Moog swaybar endlinks ??
- throttle position sensor
- 08 2.4 weird rpm fluctuation/surging/bucking
- Car dies while driving
- 2006 SS 2.4L Cobalt loud stall& no restart - Video provided - Please Help!
- car is running rich
- Hid relay harness help
- Clutch pressure problem
- 3 codes active. fan stays on HELP!
- loud engine noise (video)
- H/E, A/C Condenser and Radiator
- Car has trouble starting, Loss of power, No working tack
- Bad spark blowout
- Cooling Fan kicks on very often.
- Help diagnosing rear end noises
- 05 LSJ Starter Rebuild
- 07 SS/SC Stutter Problem
- Really bad pulley/bearing noise
- PCM bad
- Brembo pins seized
- clutch pressure issue please help!!!
- Car bogging, running rich, black smoke HELP
- Catastrophic Supercharger Failure
- 2010 SS GM Stage 1 RPD No Data Available, Cutting Out, Lose of Power
- clutch issue!
- Steering issues.
- 02 Sensor P0130 P0140 Codes
- Wipers won't work
- Speedometer and Electrical Problems PLEASE HELP!
- Popping noise
- High rpm problem.. Help
- Possible spark plug issue?
- Driving issues
- Bypass valve not opening completly
- torque specs for connecting rods
- Heat Exchanger Hose
- Battery saver active check charge sys
- SS/SC pcv clogged up?
- Car key FOB issue. Not with the fob :)
- P1174 Issue, need some recommendations before i take it for inspection.
- Key stuck in tumbler
- Help with P0101-P0102
- nosie from front at speeds
- Steering Column Replacement Question
- Heater always on
- Signs/Symptoms. of bad wheel hub/bearing
- wiper blade stalk
- Need Help!!!! Engine Cutting Out, Maybe MAF?
- racing brackets?
- Hissing Noise
- Help wideband acting weird
- Help p0171 and p0174
- help engine power reduced/ engine disabled
- Tune up items - 09 SS/TC LNF with 123K
- K&N SRI Installation Fail
- Loose front end..Bad suspension?
- Car's freaking out(electrical issue?)
- Weird Issues PLEASE Help!
- p2770 code
- infamous p0068 has me stumped
- Intercooler End Tank Cracked
- S/C not hitting 10 psi
- I finally found it !
- problem with key/alarm, and power locks
- Very Low Boost Issue...Help Please!!!
- Ticking Sound Cobalt SS/Sc Cold Start
- Try to narrow down a short
- Transmission Issue's LOL
- Flooded Car
- help me diagnose my hooptie and get her back to running condition
- dual pass leaking
- Anyone ever replace a wheel bearing?
- engine sound?
- Loose downpipe?
- P0103 code!?!?
- Tick/knock and burning oil
- car wont start!!
- Knock knock who's there
- advice on Brembo pads and rotors install
- power windows wont go down?
- Car Won't Start, New Battery, Still Won't Start
- 05 cobalt ss front end noise
- Wow, the rear rotors DO suck
- Issues with boost/performance
- Stage 2 belt too small? L61/sc
- 2005 SS/SC Power Lock Issue??
- Can't get car into 5th gear with BPS short throw shifter?
- security system malfunction
- Can someone give me a straight answer about Transmission fluid and change intervals?
- Spark plug gap on a completely stock 2.2?
- Service Air Bag
- Electric Steering question...not recall related
- MAP Sensor
- I just want to love my SS again :(
- Way too much gunk in throttle body/Supercharger..NOT good
- Wheel Spacers
- 07 cobalt SS/SC stumbling on and off throttle
- Downshifting stalling issues
- Car pulling and major vibration
- possible shortage problem due to sound systemm :s
- Going to participate in my first SCCA races this weekend! What to look out for?
- Engine swap coolant sensor going bananas ! Help
- clutch gear issue
- 2005 Blower Motor Speed Control
- banjo bolt washer #s 2009 SS
- Doesn't start and P0230
- front brakes only /beed backs 2009 SS turbo Brembos
- Engine power reduced
- Engine Hiccup?
- Airbox Mod
- just drove into five inches water
- Canister purge valve
- new rotors=new brake pads??
- bad wheel bearing diagnosis?
- Intermed steer shaft, wheel bearing,etc.
- Occasionally have problems starting
- Car Won't Start
- Steering wheel shake
- Cobalts ss/sc has exhaust leak
- P0036 / p0037
- Top End Noise
- Top End Noise
- trailing CAB bolt
- please help!! Clutch/gear issue!
- 50k mi maintenance?
- P0365
- Misfires....
- Parking brake issue- only one wheel locking
- SS/TC Brake Question
- Autometer Light can't Dim
- ABS Problem
- Help : Power steering SS/SC
- Accident, Read Quarter Panel damage
- H02s:
- Reduced Engine Power! Help
- cold start= cammed sound.
- ZZP Exhaust tip melting bumper
- Rear brake squeal
- Shift Boot Replacement
- Noob question, be easy with me...
- Security Light wont shut off!
- 2.2 lost its life
- PRK Lamp fuse help
- New ZZP downpipe...problem
- Throttle body wiring problems.
- ic coolant keeps emptying :(
- Cold air intake issues
- Ongoing Fuel Trim Problem
- DTC P2500 Can't figure out!
- Oil covered spark plug
- fuel gauge acting funny
- 2.4L What is this horrible sound? Valvetrain
- One Lighter Not Working
- o2 sensor help
- low vacuum ..no leaks? bad idle
- please post resolutions to p0300 misfire code
- p2261
- Rear hub sensors?
- Front end shaking and rattling
- Traction control problems
- Decided to keep my '05 till it's dead.... but have a few questions....?
- Injen filter cleaning
- CEL Code Scanner
- camshaft actuator problems
- ENG PWR Reduced
- Slow, high boost, knocking
- wastegate issue?
- BRAKE FLUID with E-Brake
- Truckload of owners manuals in PDF
- could use a little help here
- power steering, boost gauge stuck
- Forge BPV check engine!!!
- 2006 ss parking brake not releasing after doing rear brakes
- Engine Noise
- Bad Passenger Presence Module
- White crust on brake rotor?
- Engine Stutter Shifting From 1st to 2nd
- Hard to push clutch in....
- Help me!!
- Doors won't open
- 2007 Cobalt SS/SC Strange Idle
- Bad Catalytic Converter
- BREMBO brake caliper question
- Roll Pin Issues/Questions
- p0121
- Lt brakes on an ss?
- Need Help with HID 9007 bulb installation
- clutch shot or somethkng else?
- 06 ss/sc hesitation?
- Won't start. Not turning over
- 07 SS/SC - How do I tell if my car has dual piston front calipers?
- stock injectors in gm stage 2 car
- Water in drive floor and storage compartment!
- brake light issue
- Drivers door won't open!!
- 07 SS/SC front brakes activating all by itself!
