- Sunroof won't close completely
- need some help with clutch! i think
- Metalic sound over bumps
- Oil pressure check
- had a problem, now its fixed, but still don't understand it
- stock headlight lighting problem
- LOUD squeaking in rain
- funny noise.
- p0300 and plug issue
- Too hot, coolant change
- Got a leak!
- grinding when downshifting to 2nd
- Clutch Problem.... Slave Cylinder perhaps?
- misfiring/ running rich/ horrible mpg...
- Got another one
- Shaking around 90km/h or 65 mph
- problems...
- HELP W/ Power Steering
- Door Rub ( not the usual bottom )
- Emergency! Car going INSANE after CAI install
- 07 SS/SC stutter
- need headligiht help
- Clunking Noise
- Car stalls when backing up with ac on!?! WTF
- so i come home last night and park my car and then hear this sound
- lower front drivers seat
- Sunroof Track Piece broken
- Left turn signal doesn't automatically click off after completing a turn
- No break lights!
- Service 30000 kms. any "How to" over here ?
- Jammed Lug Nut
- All In A Days Work!! Now I Need Help
- My First CEL
- Knock Knock!!!???
- Some quick info please!
- Problem idle after WATER/METH use
- windshield
- First CEL
- slow acceleration 2nd gear
- Online Petition to GM about 2nd gear grind
- problem with idle. please help.
- Starter problems
- warranty questions 100,000miles not so long...
- Intercooler Pump Quit?
- air conditioner fan problem
- bumper question
- Someone who has actually changed a wheel stud
- need help with black cat gauges
- Specs of metal in Oil
- DTC 2228 code
- Tried to fix boost problems
- I think i need a head-gasket
- hello, and quick question
- Possible Halo Projector problem?
- about fuel filter
- Car died 1st gear @ 6500rpm?
- Battery Dead + Trunk Wont Open
- Sweet, so...coolant display is all dashes now....
- Big loss?
- My rotors are F**Ked
- hid help
- just when i thought it was fixed....please read
- winding noise when in N when its cold?
- Car Wont Start...Help..
- Wow... new engine... ummm.. wow.
- Engine ticking sound caused by non synthetic oil use
- hopefully nothing major...
- Interesting Vid on Cobalt power steering problem
- Help my girlfriend's Cobalt!
- Got da CEL code P1516
- 07 Ls cooling fan
- Squeak coming from back wheel
- zzp 3 pod pillar
- Holy Crap
- headlights
- engine trouble need help
- Car dies at 4200 rpm!!!
- Flickering HIDs
- Locked out of first on startup???
- B&M Shift+ Noises
- Help, my windows wont move!
- Interior Lights and CEL
- What the heck is going on
- Weird burning smell
- Trying to total it.
- reduced engine power and cel
- Problems
- 05 Base Model Front Struts Leaking at 34,000 miles.
- NuStart Car Starter/Alarm 2-Way
- cobalt addicition stage 4
- Is my Car High? P0420 Catalyst System Efficiency Below Threshold (Bank 1)
- Brakes squeak after disengaged
- trunk won't open
- problem with cruise control
- car died while reving
- Need Immediate Help!
- 3rd gen projectors!!
- are these supposed to be rusty for a 3 month old car?
- Fuel Filter Changing
- brake issue
- Trunk, cluster lights, rear lights
- So I took my 2.4L manifold off today to find...
- Leaking Oil
- EBC Sport rotors and Redstuff Brake Pads Problem??
- Camshaft Correlation Code
- Clutch Probelm!!! Need Help!
- Serious Problem Wiring & Fuses
- 08 5spd LT Clutch issues
- Does Anyone Know How To Do a Crankcase Relearn With HPT
- P0325 & no power After Dual Pass,
- squeaky rattle coming from rear of interior
- ZZP washer failure. With pics
- Coolant Flush/ Rattle Solved
- Im so mad....
- problem with stock radio
- "Floaty" suspension, and car feels like it is swaying/pulling.
- Heated Seats Burning??
- Serious issue
- holy noise were did that come from?
- Car shaking under WOT
- Intake Help/ Paint help
- Help with intake
- My car is at the Dealer heres that scoop...
- Headliner/Sunroof Creaking
- Clunking Noise
- so....ummmm....is this fixable??
- Sun Roof FTL
- Evap. Leak?
- It was a long time coming
- idle problem
- Car jerking
- brakes sticking?
- Issue changing rear brakes
- Some Questions, Power steering, brake fluid
- Any Ideas??
- weird clanking noise?? :(
- GM CANADA phone line for engine probs?
- stage 2 help!!!
- Sunroof issue...
- hissing noise under acceleration....???????
- Turbo timer issue?
- P1133 Code
- Right Rear Half an Inch Higher Than Left!!!!
- Backfire question
- Secret Glove compartment thingy
- Help CEL
- why would this happen?
- Went haywire on the highway!!!
- 07 LS Window handles rattle
- help!
- need some help
- car not starting. help please
- 4th time driver headlight has blown.....
- RT downpipe/cat took a crap
- not wanting to engage in second? any help?
- issue with friends balt
- Hesitation Under Acceleration (Please Help!)
- Continuous clunking while coasting
- Cleaning the intake manifold....
- no sound!!
- Sunroof won't open!
- Bumping noise when turning
- P0507 High Idle Problem....
- Parking Break wtf?
- fing cels & reverse lights
- alarm issue
- wondering about an air filter
- need some part numbers please
- Stock headlight falling apart
- Service
- Squeaky Alternator Pulley
- ABS issues, anyone?
- Help- Car Wont Turn Over
- clicking noice
- to clutch, or not to clutch?
- took my car to the dealership
- Sway Bar Bushings and Clamps
- A/C funny noises
- Couple questions
- Problem today
- Instrument Cluster Problems...
- Fujita owners - Check this out!
- Out of Warranty
- Service Air Bag
- Interior door handle
- 2.2 misfire code in cylinder #2
- door locks have a mind of their own randomly
- does anyone have this problem?
- Should i be worried
- Zzp Dp?
- For those of you that have used EBC Brakes??
- Zzp Ftl!!!
- Popping out of gear?
- throttle dead spot
- Problem about brakes, what should i do?? Please read, need help
- poor mpg problems
- Once again
- Detonation?!
- Downpipe Blew Apart
- Car is at the dealer (misfire at idle)
- problem with GM exhaust
- getting new stage 2 injectors!
- Fuel Pump
- GM STG 2 Install wierd sounds after car is off from evap area.......
- Cooling metal at idle and when the car shuts off
- Power Steering
- Vibration Idea - Confirm my theory
- How much does it cost to get the sunroof/windshield resealed?
- solid check engine light..5th time going in
- Door Stops?
- Hack's Bearings
- My car was built on a Friday
- Reverse lights on in ALL Gears(1-5+R)
- OEM germany oil filter
- Power Steering issue.
- P1133 ? searched
- Milky Oil.... thoughts?
- Stress Cracks and leaks on Transmission
- Wheel Bearings
- Timing chain recall?
- GMPP Touring tip?
- Car runs like shit
- USMCFieldMP vs F35 Tranny
- need help please!
- somethings wrong
- Grinding into gears (repeating issue)
- Cap broke off gear selector
- Rearview mirror rattling (onstar)
- Leak
- Clinking Noise from driver's side axle area
- Outside Temp...
- 2007 SWC Volume buttons
- Problem and solution Thread
- Any idea how to remove the SWC Volume buttons.
- rattle? rock
- flashers button stuck
- Light went out now i got a bleeding hand NEED HELP!!
- RPMS go down slow.
- Top nut back size...
- Ahhhhh my battery is dead!!!
- Car leaning out past 17:1
- Yet another MIL/CEL problem
- HVAC and electrical
- another dipstick thread...
- SS SC engine knock at idle?
- Throw a P2228 Code any ideas
- Stuck in Limp Mode???
- Car accelerates at idle
- problems with clutch or tranny??
- 2007 Cobalt LS Missing while at stop light.
