- F&$@*!G Door!!!
- Chattery wipers
- Have you changed your battery yet?
- How the heck do you remove the hood gas shock?
- warranty or mods
- just wondering
- New spark plugs & P0340
- 2.2l Weird Problems
- idling rough
- Catless exhaust problem PLEASE HELP
- anybody have intercooler problems??
- P0087?? help please!
- service manual
- lnf intercooler sucks!!!!!!!!
- knocking under boost?
- Known issues!
- Headlight bulb burnt again ...
- Weird problem.
- Fuel leak
- Anyone have the part# for...
- Camber Help
- Car Hesitation today ...
- PLEASE HElP!!!
- Man oh man
- Code P1174 - No CEL, why?
- rear ended
- kendall synthetic oil
- Rear Wheel Clicking/Grinding?
- Brake Problem
- Clutch Issues
- key fob
- im havein problems with my sport
- No freon causes the AC clutch not to work?
- help please
- What should I do now?
- tranny issues lsj g85 06ss/sc
- brakes F***** up help!!!!
- Question on warranty coverage with brakes
- A/C compressor not working??
- antifreeze in oil
- Problem With Car Please Help
- ZZP DP vibration/rattle???
- No Clutch Pressure
- No coolant in my IC filler neck??
- Stock Air Filter Replacement
- Failed Smog Test Need Quick Trouble Shooting
- Recall on various 2009 GM vehicles
- radiator install help please?
- Not a big issue, but annoying!
- What should I do, if anything?
- Pothole+ H/E+Radiator=Leak.......
- what is going wrong?
- maf location on cai
- Rattling Noise when putting clutch in at a stop
- Purge valve an easy fix?
- Headlights keep burning out!
- SUPRISE leaking strut , worn control arm bushings
- Back. Fire. Ing.
- Header/ DP now CEL
- stripped bolt
- cobalt ss sc problem
- Rear passenger window leaks!
- Check Engine plus "---" on DIC?
- Need Help
- catless converte problem.need help!!
- air sensors in wrong spots effect anything?
- painting question
- Trouble at 103K miles
- need help sorry if in wrong section (edited by erod: warranty question)
- SS/TC Boost issues
- Key stuck in ignition
- Brake Problem please help.
- anyone know what code this is B1718
- Car cannot be boosted...?
- Cause for Concern :(
- Hmm so my gears wont shift...
- Dealer B.S.
- Hesitations, CEL P0171 running lean...
- help p0172
- Front Brakes @ 10%
- help!! how to fix foggy headlights
- Reverse Lights Broken
- Turbo trouble?
- Headlight went out
- ABS and Traction
- Car wont start eng pwr reduced
- small problem
- Tranny Maintence
- High RPM After Cleaning Throttle Body
- Cel?
- Help with my projector head lights!
- Check Your Battery Compartment In Trunk!!!
- code reader
- CEL Error P0106?
- Has anyone solved the crappy e-Brake situation yet?
- Rattling Noise >:0
- Repairing Headlight.. Help..!!
- GM wtf!!! My car was not fully built!!
- Running too lean?
- Help with cousins car.
- One headlight is dimmer than the other...
- HID and reflector issues.. Help..
- Rear Rotors TSB?
- Trunk pop button
- spurratic alarm
- ABS light
- HID kit help
- Steering wheel shake while braking.
- HELP asap!
- 2008 Cobalt SS/TC problems
- New Header...weird Ticking Sound..
- Coolant display issues.
- Driver Side door doesn't open?
- Fuel Cap & MIL
- has my balt been in an accident?
- Unknow issue
- pcv braking system or something?
- Downpipe Gasket
- Bypass valve
- Battery Warranty
- HELP!!!! cant find oil filter to change oil lol
- Does anyone know why my axle won't come out?
- Steering going light?
- 0w30 Anyone use it?
- Clutch Master Firewall Tabs Broke
- Changing Transmission Fluid on 2.2
- Projector lights-problem
- Help: weird sound, sway bar link lose??
- Annoying, loud, squeek/squeeling sound from enginebay
- Noise on highway
- Need Shop Manual for Clutch Master Cylinder
- CAI problem
- new problem with the ss/sc :(
- quick question about coolant pump
- um, what's up with my tail light??
- service/tech help
- they fix one thing and something breaks they are making me pay
- bucking when shifting from 1st to 2nd..
- Low Coolant
- Best place to buy Clutch Master Cylinder
- ebrake fail!
- weird click from car
- When should The Fuel Injector Be cleaned? What are the signs?
- Fuel Gauge
- is the cat bad?
- Cold Air Intake / Hydroshield / Water Problem
- Problem with 2.2L LT... Question
- How to replace interior door handle?
- back seats
- Fuel gauge wronge.
- Replaced the batt. in remote now wont work
- squeky noise
- Crack in rear bumper
- Door Rubbing
- Parasitic Drain
- Valve Knock?
- great service
- Pulse In The Break Pedel
- timing chain clicking?
- Lug nuts loose
- Noise in sterring column
- p0420
- headlight bulbs!!
- Clutch Problem!! Need Advice
- Reverse Lights Not Working!
- PO171 - Yes I know, I've searched!
- Autometer Wideband???
- Rocks in the Charger Sound
- cv shaft play???
- low rpm
- Creaking in front end (warrenty question)
- Boosting 13.6 lbs w/2.8??
- Service tire monitor system
- What maintence needs to be done ??
- gen 1 left blinker
- Replacing Rotors Under Warranty
- air breather?
- Frozen Struts on my SS/SC? or maybe lower control arm bushing?
- Problem?
- LOOK!! header/CEL question
- Car is jerking/bucking
- NeED Help> Where Does Temp Plug connect to?
- Bad Gas?
- Missfiring... got p0300 and p1182
- clanking noise under hood
- Possbile trans problem??..
- 2005 cobalt 2.2 will crank but wont start
- boost gauge problem
- Help me fix a noise please
- Check engine light, what now??!!?!?!!?1!
- no powersteering?
- 2007 Black LS Right fender and front bumper replacement
- 2.2 Auto - Clunk noise in shifter when pressing on brake
- Tranny problem maybe?
- Side marker light
- Eng Pwr Reduced.. again/
- power steering symptoms
- Stage code
- Trashed rear rotors
- Battery Acid
- Warning: Dealers voiding Powertrain Warranties for Mods
- help please relearn...
- Limp mode + P0069
- HELP! reverse lights wont come on
- Need Help *sigh*
- Car not starting, battery dead... but why?
- Heat/Air wont turn off
- Broken Dipstick Tube
- WTF is wrong with my car
- Headlight flasher color : which year?
- Loud Road Noise
- stagnant water smell
- Dex-Cool, any problems?
- Coke in shifter...easy to clean?
- interior door handle
- Removing the plastic by the hood release
- Chattering?? Help please
- Blinker Issue
- Rusting already
- Recirc valve stuck open?
- Door wont open/close
- I need a new intercooler & pump
- LEMON question
- i need to vent!!!
- Newest Recalls
- Question
- Bad codes popping up on my TC
- HID installation, NEED HELP PLEASE!!!
- fuel regulator problem
- fuse help!!!
- sludge on oil cap
- Who knows how to replace steering gear?
- Door Pins
- NEED HELP ASAP w/ Wheel Hub Removel
- Knocking noise from the back...?
- What are some common problems with 08-09?
- just installed intake. HELP!!!
- Crankshaft position sensor location?
- Help
- I think i got a Clutch problem
- Siezing locks?
- HeadLight bulbs...
- CEL Fixed. MAP R\R but!!! 5lbs less boost!!?
- dealership EFFED my clutch...
- Flickering light....
- Screetching Noise Coming From Brakes
- Sucking Noise from Passenger Side.
