- Help with clutch problem!
- Sway bar links shot? video to help!
- feeling weird
- Brake Light is out
- Weird Clunk at Rest in My 09 SS/TC
- weird exhaust sound when acclerating
- Possible FIX: Power Steering DIC
- One after another...
- Remote starter just went south
- Someone Please Help I Have Problems
- Throwin Some Codes... Help?
- header to dp bolts...
- Heated leather seats stoped working
- Sunroof Button POS!
- ss/tc recal for brakes
- Squeal
- Metal flakes on REAR bumper
- parking/e-brake cable stretched
- head gasket
- What brand of Oil Filter do you use??
- Bad Supercharger???
- Massive Difference in Wheel Gaps - Broken Axles
- Megan exhaust silencer
- finally thew a CEL
- Whoosh
- P1681....Powertrain control module fault
- Vibration 65-75 MPH
- Possible causes for my CEL...??
- power steering
- Tinking noise..
- Lights turn off at night when...
- 3rd gear sync problem=new tranny, more problems..
- Two Axles, two weeks, new trans
- help with wing.(quick)
- ignition won't turn
- Taking the car in today. :)
- Hurricane Ike kicked my ass
- hp uner help
- So it flooded here, and i have a CAI
- P0106 code
- Steering wheel not aligned properly?
- 07 Getting the shift knob off
- Smells like gas
- all 4 lights on with projectors
- Car running shitty at idle
- '08 Ss/tc Gas Filling Problem???
- Gear whine...supercharger?
- CEL after crash, dealership fixed it, it's back on. HELP
- New Seats - "servce Air Bag"
- transmission gears (rear) grinding = new transmission
- need help maf
- very strange power problem...
- Key FOB problems
- butt marks in seat
- 2009 SS in shop for second time in 3 weeks
- Tech Question: Brake Lights Stay On
- cel code
- Sunroof button...
- Trouble shifting into 1st
- Windo tinting problem?
- Need a new tranny
- help with Interceptor
- Small Oil Leake (Need your help css :) )
- Turbo lag or something else.
- I got hit on the right side
- I got stabbed in the bumper.
- need help with cleaning tb
- Engine Disabled/Power Reduced after trans swap
- Knocking noise 05 ss/sc
- Drum Part Number
- Side window install?
- What size air filter do i need for cia
- Losing Pressure In Clutch...
- Power problems maybe?
- Dealer tomorrow YAY!!!
- clutch pedel pushrod broken help me
- Son Of A Curb!!!!!!!!!!!!!
- LOUD clunks
- Driver side floor SOAKED!
- cabin filter
- 08 ss/tc hard to start?
- AC makes car run bad?
- clutch issue
- fan doesn't work?
- fan doesn't work?
- 08 SS/TC - ESC Malfunctions
- Coolant Pump (I think)
- Dome light noise...
- Random Misfire Code
- rushing sound of water when hitting gas
- out of warranty repair
- exhaust
- power steering
- General Maintenance
- Alittle Help...
- Need Help - Clutch Issues
- supercharger bearing going out????
- Cobalt is not a boat....
- New CEL problem...
- rpms
- USMCFieldMP breaks an Axle...
- Eng pwr reduced
- Cracked Bellhousing, Trans Making Noise(Sorry 56k)
- ss/sc runs and sound like crap, possible intercooler pump failure? NEED HELP!!!
- 08 cobalt sport manual trany issues
- Fuel Evap - 2 hours!
- dtc p0420
- Anyone with radio problems on the 07
- cold air intake
- 07 SS S/C possable power loss
- Power Steering gone
- car wont start after putting gas in tank
- Guage Help!
- Cobalt-Semi Down!!!!!
- Seem to be overboosting
- Brakes are pissing me off... :(
- Cant see far with stock headlights?
- mass air flow sensor
- MisFire Info and what to check(updated Aug, 27,08 )
- clicking, humming and vibrations. need info
- Silver paint coming off on inside of door...
- Bad Missfire, need help
- key is stuck in ignition
- dealership again...
- Annoying rattle
- Cases of warrantied wheels?
- Wierd Clunk On Drives Side
- Tring to find a new exhaust
- I need help.
- Exhaust Noise Help please
- Weird high pitch noise?
- CEL....again...
- Reverse lights dont work
- 2.2L Throttle response issues
- help please
- Steering Wheel not centered on brand new '09 cobalt
- Cobalt Zing
- 05 06 powertrain warrenty
- Exhaust CEL and Sunroof Plastic..??
- Stange clicking sound at idle
- air conditioning filters
- Engine Power Reduced!!
- drivetrain noise?
- Power steering
- squeaking noise when i turn?
- some more dealership Bs
- strut
- Power steering fuse?
- Rod knock!
- Anyone ride your clutch?
- Little Problem.
- Exhaust leak cause CEL?
- Squeaking noise coming from the back
- trying to replace front chevy badge
- Supercharger grinding, exhaust rattle & white smoke
- Does anyone not have problems ?
- air conditioner never gets cold...
- need help with LC-1 install
- quick question - lost interior 12v power
- gm warranty
- HELP! There is no oil on the dipstick
- New tensioner! Shredded belt! WTF!
- 2006 2.2L Recall
- clunking noise
- Car is dead
- loud bang
- Trans trouble
- boost gauge/bypass valve
- 2007 Supercharged Overheating
- The Infamous Rattle, Neverending!
- taking gm stage 2 pulley off
- RAW intake problems
- Keyless entry
- option sticker location?
- how do you remove the trunk lock?
- Help please!
- Color Differences!
- 2.2 L help
- AC Clutch
- GM Phone number
- LS coupe auto trans question
- Wonderful rattling sound
- Door won't unlock
- Sstatus lights appearing at random time
- transmission problems please help
- Dummy Light on, dealer won't fix...
- CRASHED 2.2 08 ls coupe
- idle problem
- Fluids
- car won't crank
- Stage 2
- Supercharger Seized???
- Creak in stand-still Steering (2.4L)
- car WONT start
- 2.0L problems please help!!!
- Problems
- Air fades in and out as Rpm needle jumps -- HELP!
- Windows Rattles
- need help
- Missing Brake System Hose?
- Weird sound coming from car
- just got my engine in, and it runs, but....
- 5th gear isnt in the right "position"
- ABS & Brake Light Lit up
- rear 02
- Anyone ever have doorlock problems .
- Turbo Timer pointless?
- Coolant Really High
- 2nd Gen Halos, scratches on the inside?
- Shaking/Shuttering @ Specific Speed (80 mph)
- RED STICKER? please read
- consistantly stalls
- Goota love aftermarket parts......
- Water leaking inside????
- parking brake problems
- Code p2261
- Supercharger Messed Up...
- another sunroof problem
- Changed oil runs funky
- Heater switch lights not working
- How often for basic tune ups?
- Problem. Need help!!!
- Dash Rattling Noise at Idle
- Whistling Noise WOT
- Halo Projector problem
- CEL's and general inquiry
- Airbag service light still on. How do i clear it?
- wtf aftermarket tail lights
- Cobalt Shut Off?
- IC pump
- Tranny/gear problems(2nd-4th)
- Irratic Idle after New Exhaust
- Clicking noise???
- Cobalt Wont Hold 2nd Gear
- Turn signal not turning off!
- Halo Projection Headlamps...
- help with p0341
- Problem with the supercharger pulley
- CX Racing H/E Punctured AC Condenser???
- AAS Tuning = Epic Failure
- 2008 SS Slight Ticking Noise & Steering Wheel Shake!
- Speedo, Steering CRAZY after Tranny Repair..
- dealership mess up on fuel filter
- 07 SS/SC Issues
- Not Covered under Warranty
- Door doesnt close
- Rattles in new 08 SS/TC
- soft pedal feell
- Supercharged: where have all the power gone?
- Shaking???
